Old 10-27-2010, 18:09   #5956 (permalink)
Member: 621121
Thanks Meter: 335
Huawei C2201 read user code successfully
==== log: [10/27/2010 7:39:30 PM] ====
COM2 [VCP0] selected
Device: Huawei-C2205
Checking data, wait...
Action: user code
Connect...
Phone must be Powered-On
Connect Done
Read phone info...
software compiled: Nov 25 200620:10:25
software released: Dec 03 200412:00:00
software version: V100R001*
model id: 108
MSM: F060
build id: V100R001BENC10
ESN: 8CD7834B
Read phone info Done
Verify access...
user code: 1832
Verify access Done
Decode data...
code is not set or unknown eeprom
Decode data Done
Finished, time used: 14 sec
Remove/Install battery now !
The Following User Says Thank You to alamgir80 For This Useful Post:
Old 10-27-2010, 18:11   #5957 (permalink)
Member: 74958
Thanks Meter: 30
Vodafone 225 /ZTE225 red flash, eep,ffs sp-unlock etc ,log here:
==== [2010-10-02 11:43:32] ====
module v1.78
Device: Vodafone-225
Action: read flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Failed
Finished, time used: 23 sec
Device: ZTE-225
==== [2010-10-02 11:44:16] ====
module v1.78
Device: ZTE-225
Action: read flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: -DE-P108A2V1.0.0B03 12 27 46 VDF-P108A2B07-De-DE03 g3dBV2.0 04.1
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-static_20101002-114439.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-security_20101002-114440.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-complete_20101002-114441.B1E.bin
backup critical area Done
Check memory ...
reading flash...
file saved: D:\Infinity\Vodafon\225\back\ZTE-225_flash_20101002-114609.B1X.bin
completed
Finished, time used: 2 min 48 sec
==== [2010-10-02 11:50:25] ====
module v1.78
Device: ZTE-225
Action: read ffs/eeprom
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-static_20101002-115045.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-security_20101002-115045.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-complete_20101002-115047.B1E.bin
Check memory ...
completed
Finished, time used: 17 sec
==== [2010-10-02 11:56:36] ====
module v1.78
Device: ZTE-225
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-static_20101002-115654.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-security_20101002-115655.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-complete_20101002-115656.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_lock-area_20101002-115659.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 24 sec
The Following User Says Thank You to -=sKy=- For This Useful Post:
Old 10-27-2010, 18:12   #5958 (permalink)
Member: 74958
Thanks Meter: 30
DCT-4 Tools module ,Interface: Cyclone-Box (emu. com-port) Nokia 2220s unlock re-lock. Log here:
card found: S/N 2532:0116
Port COM7 open OK
Connect phone on selected interface... Wait...
Phone found...
Phone in Local mode
IMEI: 351548046290899
Phone Nokia 2220s connected
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Settings Software Upgrade Defaults...
Set OK!
Settings Service Centre Defaults...
Set OK!
Settings Production Tune Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Check phone mode...
Phone already in Test mode, skip change...
Read Lock Info
Locked to Default Test Operator
Connect to server...
Unlocking...
All done !
Check phone mode...
UserCode clear - Ok
12:51 card found: S/N 2532:0116
Port COM7 open OK
Phone found...
Phone in Test mode
Check phone mode...
Read Lock Info
Lock to 260-03
All done !
12:54 Operating mode is OK, no need change...
Reading PM from field 0 to 400
Field [1] 6 Record(s)
Record 0: 120 byte(s) readed - Ok
Record 2: 90 byte(s) readed - Ok
Record 4: 110 byte(s) readed - Ok
Record 6: 90 byte(s) readed - Ok
Field [362] 2 Record(s)
Record 0: 1 byte(s) readed - Ok
Record 1: 144 byte(s) readed - Ok
Saved as D:\InfinityBox\Nokia\Backup\RM-590 Nokia 2220s_351548046290899_0_400.pm
Done!
12:54 card found: S/N 2532:0116
Port COM7 open OK
Phone found...
Phone in Test mode
Phone Nokia 2220s connected - Ok
IMEI 351548046290899
Read Lock Info
Locked to IDEA Centertel;Poland
Unlocking...
Unlock - Ok
Port COM7 close
Old 10-27-2010, 19:33   #5959 (permalink)
Member: 633231
Thanks Meter: 666
COM1 [Serial0] selected
module v1.78
Device: ZTE-A35
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
sw version: ARO-P108A7 Z B01-EnEs-DOM02 g3dBV2.0 ES-DOM-CLARO-P108A7 Z V1.0.
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-static_20101028-023307.B1E.bin
loading data...
data loaded
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-security_20101028-023309.B1E.bin
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20101028-023315.B1E.bin
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_lock-area_20101028-023333.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 1 min 3 sec
The Following User Says Thank You to thewolverine For This Useful Post:
Old 10-27-2010, 19:51   #5960 (permalink)
Member: 633231
Thanks Meter: 666
Coral 620 unlock done
module v3.62
Action: "sp-unlock"
unlock method: smart fast
Model: Coral-620
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:131A:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: C2082_2.9.FM.US.DIGICEL_HDR_AAC
Version: C2082_US
44 byte(s) read
imei: 35743402347165
connection Ok
157 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 11 sec
Old 10-27-2010, 20:50   #5961 (permalink)
ponix's Avatar
Member: 229016
Sonork: 100.1590620
Thanks Meter: 128
OM4 [VCP0] selected
module v3.52
Action: "sp-unlock"
Model: Vodafone-340
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:2E03:A007
status: 01
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: BM35A1.V2.22.M00.02.34
Version: FOXLINK25_08B_HW
81 byte(s) read
imei: 35592203089210
connection Ok
186 byte(s) read
reading data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 16 sec
The Following User Says Thank You to ponix For This Useful Post:
Old 10-28-2010, 04:38   #5962 (permalink)
Rajan chhetri's Avatar
Member: 799195
Sonork: all gsm cdma tool is best
Thanks Meter: 112
sucsessfully repaired & unloc chinise G-fone by infinity box
found new firmware flash file sended to [email protected]
here is log
==== C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e [28/10/2010 10:22:15] ====
web site: Infinity-Box - About
support forum in English: Infinity-Box - GSM-Forum
Loading data, wait...
[Infinity Box] Chinese Miracle v3.25
smart-card: connected
S/N: xxxxxx
Wait...
Device: Autodetect 6205-6239 NOR
Done
==== [28/10/2010 10:22:57] ====
COM3 [VCP0] selected
module v3.25
Action: "user code"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:8886:000C
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
New firmware found (v.3.25, database date: 20.10.2010):
L100K_PCB01_GPRS_MT6223P_S00.L100K_00A9_V1_0_0.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 04
sw version: L100K_PCB01_GPRS_MT6223P_S00.L100K_00A9_V1_0_0.BIN
project-id: L100K_00A9_V1_0_0, 00000000
code offset: 00000000
ffs offset/size [01]: 00D40000/002C0000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00D40000
standard ffs/eeprom offset confirmed: 00D40000
detecting ffs/eeprom size...
ffs/eeprom size: 002C0000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00D40000-00FFFFFF
firmware area: 00000000-00D3FFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
lock area found
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: lock-area-1
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 2 min 36 sec
==== [28/10/2010 10:32:31] ====
module v3.25
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
reading: L100K_PCB01_GPRS_MT6223P_S00.L100K_00A9_V1_0_0__fu llflash...
The Following User Says Thank You to Rajan chhetri For This Useful Post:
Old 10-28-2010, 05:56   #5963 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Action: "repair imei"
Model: Autodetect 6205-6239 NOR
Phone should be Switched ON !
Connecting, wait...
imei-2: 353526988209398
imei write method: mode-1
imei write channel: imei #2 for dual sim/mono CPU
new imei-2: 357263025885479
verification Ok
Finished, time used: 2 sec
The Following User Says Thank You to KK Mobile For This Useful Post:
Old 10-28-2010, 06:12   #5964 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Action: read/check information
Connecting, wait...
Hardware version: MT6225, E05
Hardware version: PCBA V3.1
Software version: 9600_SAMSUNG64x32_RD
Software date: 2006.06.14
Barcode: 083101MT012345678901234567                                  10
imei-1: 356809030152544
imei-2: 135790246811220
imei-3: 356809030152544
Finished, time used: 3 sec
Connecting, wait...
new imei-2: 357875001959141
verification Ok
Connecting, wait...
Old 10-28-2010, 06:30   #5965 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
T303 hang done
Device: Sony-Ericsson-T303
Action: reset settings
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 89890400040089:89890400000000
flash: Intel ST [def 0080x040000] 32Mb
software version: 1209-8242
software version: R2CA005
Check hardware done
Read data ...
reading Sony-Ericsson-T303_eeprom_calibration-1...
file saved: C:\Documents and Settings\KK Mobile\Desktop\Sony-Ericsson-T303_eeprom_calibration-1_20101028-104701.80E.bin
reading Sony-Ericsson-T303_ffs...
file saved: C:\Documents and Settings\KK Mobile\Desktop\Sony-Ericsson-T303_ffs_20101028-105251.80E.bin
Read data done
Check data ...
Check data done
Write ...
Erase: ffs
Write done
Finished, time used: 7 min 52 sec
Old 10-28-2010, 06:35   #5966 (permalink)
meeza_84's Avatar
Member: 279362
Sonork: 100.1594141
Thanks Meter: 408
vodafone-340 unlock done
COM30 [VCP0] selected
module v3.63
Device: Vodafone-340
Action: "sp-unlock"
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:7803:A005
status: 01
Boot Done
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
rom info structure: [standard] type (05)
TCL-ID is absent
rom info ver: 05
sw version: FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_22_M 00_02_42.BIN
project-id: BM35A1.V2.22.M00.02.42, 00000000
ffs offset/size [01]: 00B80000/00480000
TCL-ID is absent
ffs/eeprom address assigned: 00B80000
sim-lock status: enabled
product id: BM35V2MP_MA7V28JR9BT71SDRPK7GS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
reading: Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42__ffs_20101028-102838.B0E.bin
detection procedure, wait...
detection procedure completed
error: phone is not locked or unknown eeprom
====> Write ...
Write: ffs
Write Done
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-340_FOXLINK25_08B_PCB01_GPRS_MT6225_S00.BM35A1_V2_ 22_M00_02_42__system_log__00000000_20101028-102940.B0X.bin
Finished, time used: 4 min 45 sec
The Following User Says Thank You to meeza_84 For This Useful Post:
Old 10-28-2010, 06:45   #5967 (permalink)
Member: 799195
Thanks Meter: 112
sucsessfully repaid phone with formating with infinity box
here is log of Zen mobile-z77
==== [28/10/2010 12:30:49] ====
module v3.25
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:B603:0001
status: FF
Boot Done
flash: 01227E223C2200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
921600
Set baud Done
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 02000000
TCL-ID is absent
TBG125623_6512_PCB01_GPRS_MT6225_S00.125623_6512_V 1402.BIN
rom info ver: 05
sw version: TBG125623_6512_PCB01_GPRS_MT6225_S00.125623_6512_V 1402.BIN
project-id: 125623_6512_V1402, 00000000
ffs offset/size [01]: 01000000/01000000
TCL-ID is absent
standard ffs/eeprom offset detected: 01000000
standard ffs/eeprom offset confirmed: 01000000
ffs/eeprom size: 01000000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01000000-01FFFFFF
firmware area: 00000000-00FFFFFF
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 2 min 19 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 10-28-2010, 07:01   #5968 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,297
Thumbs up 5130 rm-495 another flash done !!
registered to: kmaxmax
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm495__07.95.mcusw
PPM : rm495__07.95.ppm_aa
CNT : rm495__07.95.image_aa_red
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Getting product info...
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
Connection opened successfully
Waiting for communication response.
[BB5 FLASH]: Bootrom Ok!
RAP_PUB:   138000079C747F56553B58B17CFD7002CC0305F4
CMT_ROOT:  9DDBFCFE6E73CED7D8C6268C8EB85723
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
TIME : Boot time : 00:00:06
Reopening the connection...
Waiting for response: 30
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : Check data
ADL : Data accepted
ADL : ASIC CMT select Ok
   ===Flashing [MCU]===
Erase : Processing rm495__07.95.mcusw
Found 6 areas to erase
Erasing area 0x00000000 - 0x000006BF, NOR, CMT
Result: 0000
Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT
Result: 0000
Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:11
Write : Processing rm495__07.95.mcusw
Total 1178 [1178/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
TIME : Write time : 00:00:55
MCU Write done
   ===Flashing [PPM]===
Erase : Processing rm495__07.95.ppm_aa
Found 1 areas to erase
Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:52
Write : Processing rm495__07.95.ppm_aa
Total 392 [392/0/0] blocks to write, writing...
TIME : Write time : 00:00:18
PPM Write done
   ===Flashing [CNT]===
Checking content info...
Check Image : Content size is 128k, use direct write mode
Erase : Processing rm495__07.95.image_aa_red
Found 2 areas to erase
Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT
Result: 0000
Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:04:57
Write : Processing rm495__07.95.image_aa_red
Total 776 [776/0/0] blocks to write, writing...
TIME : Write time : 00:00:37
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:09:54
Reboot phone now...
Reading Phone Info....
Connected phone -   Nokia 5130c-2
Software Info:     V 07.95 03-02-10 RM-495 (c) Nokia
IMEI:  354223038479473
PPM version :   V 07.95 03-02-10 RM-495 (c) Nokia             AA
Product code:  0571965
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
AfterFlash operations done... Reconnect, wait...
Done!
Elapsed: 00:10:35
Phone found!
Series 40 Device detected!
read info...  - Ok
The Following 3 Users Say Thank You to kmaxmax For This Useful Post:
Old 10-28-2010, 07:25   #5969 (permalink)
kushol's Avatar
Member: 293662
Sonork: 100.1622609
Thanks Meter: 314
Vodafone 340 Unlock Done
COM29 [VCP1] selected
module v3.62
Action: "sp-unlock"
Model: Vodafone-340
19200 autodetect
CPU: MT6225
chip: 0001:9103:A00E
status: 01
Date: 2006.06.14
Version: 1.0
Version: BM35A1.V2.22.M00.02.42
81 byte(s) read
imei: 35592203385177
connection Ok
186 byte(s) read
reading data...
reading data #2...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 19 sec
The Following User Says Thank You to kushol For This Useful Post:
Old 10-28-2010, 10:02   #5970 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Alcatel E230x unlock done
Infinity Ote-reader works good . . . .
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.80446 seconds with 9 queries
