Old 07-29-2019, 16:14   #59686 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Qmobile w35 hang on logo done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 17 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : sp7731geahdplusoversea
Model Brand : QMobile
Model Device: QMobile_W35
AndrVersion : 5.1
BaseBand CPU: SP7731GEA_HD
CompileDate : 12/4/2015 8:55:40 AM
Project Ver : QMobile W35_MP_30_10
Model Ext : QMobile_W35
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:20
Reconnect Power/Cable!
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 17 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:21
Old 07-30-2019, 06:42   #59687 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile S6s MT6580 FRP Reset Done WIth King Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100514531334D4207B87AE4DF937B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D4207B87AE4DF937B
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395BC2008E21D13FF6E6E0435C8
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:51
Old 07-30-2019, 09:11   #59688 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Qmobile d7 reset password done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 2079D1AF525E10B15646D86840D96C41
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:12
Old 07-30-2019, 09:12   #59689 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Vgotel ocean9l reset frp done by cm2
Set mode to : SP [SC983x] eMMC [Generic Android 7.x]
3. Insert cable
Phone found! [ 17 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC983x eMMC Loader v5.0 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:32
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 07-30-2019, 11:56   #59690 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile X30 MT6572 Dead Set Alive Done By Flashing With Infinity CM2
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 45 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A483447326111013A9690C322AD
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111013A9690C322AD
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3950E00308FBCF6707314949D10
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3679 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4050ap.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:51
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:43
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:57
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 07-30-2019, 12:06   #59691 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,486
Smile VgoTel i550 Read User Code Done
Operation : Read UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 255 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 9F8FA5C8AFD13CDCD85F815AE7609F9F
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 3719
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:13
Old 07-30-2019, 12:47   #59692 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile X32 Power SPD77XX FRP Reset Done With King Infinity CM2
Card found: S/N : A19EC787 , v0137
Set mode to : SP [SC773x] eMMC [Android 6.x]
Infinity SC Firmware Detected
FW Size : 2579 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : X32
Device CPU : X32
Device IntName : X32
Device Version : 6.0
Device Compile : 11/22/2016 2:40:54 AM
Device Project : MRA58K release-keys
Device ExtInfo : QMobile X32
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x19 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:04:49
Old 07-30-2019, 13:51   #59693 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Qmobile k100 reset password done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : C000 : NOR : [ 4MB-8MB ]
Operation : Format FileSystem [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_189 4C61028ED_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:23
Old 07-30-2019, 16:48   #59694 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile Z12 MT6735 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 45 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 520001154D423158663B0742F31C71D0
[eMMC] : FLASH_INF : [SAMSUNG] , BMB1X
[eMMC] : FLASH_CID : 150100525831424D42073B66D07183F3
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xD9C8F395C451CF1925D3442AD3315A19
EXT RAM : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:13
Old 07-31-2019, 06:08   #59695 (permalink)
Member: 2233266
Thanks Meter: 156
litetel 4501 reade code done
Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 5B4FFFD3C90E0F96C32762ACCDD41B4C
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 0852
Done!
Elapsed: 00:00:24
Old 07-31-2019, 07:22   #59696 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Nokia N3 MT6737 FRP Reset Done With King Infinity CM2
Operation : HW Test [ v1.58 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:28
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:08
Operation : Fix Unknown BaseBand [ v1.58 ]
User accepted FixBB operation!
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:13
Wait for phone...
Phone found! [ 45 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0002
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DA Select done, will use SecMode DA
Running DA ver.4.2 on BBID : 0x9B
eMMC Flash : 460001154D32364E156C0342A3871E9A
[eMMC] : FLASH_INF : [SAMSUNG] , BM26N
[eMMC] : FLASH_CID : 150100464E36324D42036C159A1E45A3
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395D2B44BE7060ABD2A2B0CFF0F
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:35
Old 07-31-2019, 07:33   #59697 (permalink)
Member: 2233266
Thanks Meter: 156
nokia 1650 lock reset done- nokia module (old is goold0
UFS S/N 72640 boot - Ok
Connect phone on selected interface...
Phone found!
Series 40 Device detected! [DCT4+]
read info... - Ok
Resetting selected items...
Operating mode is OK, no need change...
Settings Full Factory Defaults...
Set OK!
Settings Software Upgrade Defaults...
Set OK!
Settings Service Centre Defaults...
Set OK!
Settings Production Tune Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Settings Leave Factory defaults...
Set OK!
Elapsed: 00:00:03
Reading Phone Info....
SW ver :
IMEI :
PPM : 0549964
CNT : P06w45.v50
DSP Ver : 2912029961802
PCode : V 5.32
18-05-08
RM-305
(c) NMP
BPCode : V 5.32
18-05-08
RM-305
(c) NMP
MF
HWID : 0566045
LCDVer : 0203271
IMEI :
Sl Conf : 000-00-000
Sl Prof : -
Sl Aux :
Hw Sig :
Country : Unknown
Operator : Unknown
Lock info:
Block 1
Block 2
Block 3
Block 4
ected!
Old 07-31-2019, 07:41   #59698 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Samsung t102 hang on logo done by cm2
SCRD mode : AUTO
SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ]
Operation : Identify [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
IMEI[1] : 868270030035117
IMEI[2] : 868270030035125
Done!
Elapsed: 00:00:16
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_069 B31B5145F_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:18
Operation : Read Flash [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Read Ok, 4194304 bytes
Saved to : G:\Mix Flash File\0B69DEC96785_SPRD_SPI_GIGADEVICE_GD25Q_4MiB.b in
Done!
Elapsed: 00:00:43
Old 07-31-2019, 08:09   #59699 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Oppo A37F QLM Patrren Read Done With King Infinity CM2
Operation : Read PatternLock [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 2587FF7F
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 04FC9660CF5B40433C11E3EC2B76FECE
ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 123456
Done!
Elapsed: 00:00:20
Old 07-31-2019, 08:46   #59700 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 818
Walton Rh3 firmware backup without da
Operation : Read Firmware [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM5)
MODE : BOOTROM
PORT : 5
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
BROM : SecMode  : SBC
BROM : BOOTROM
MODE : 0_base : BASE_v1724 | Manual : Disabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 150100514531334D420DFC08962C8B8B
DAInf: 4 : 2 : 155
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : 510001154D33314508FC0D428B8B2C96
     EMI : DEV : INFINITY
     EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
INIT : 0xBC : LP/DDR3 [ 0x00000000 :  [ 0 B ] ]
DRAM : DRAM: 0x80000000 [ 2.00 GB ]
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 150100514531334D420DFC08962CC38B
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x3A3E00000 [ 14.56 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 1592926D1CF264889EA8ECC010D82F04
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : DA USB VCOM Port (COM6)
MODE : PRELOADER PORT
PORT : 6
Boot done!
Patch Level    : NRD90M
Display ID     : Primo_RH3_20180105_V06
Ver. CodeName  : REL
Ver. Release   : 7.0
Sec. Patch     : 2018-01-05
Build Time     : 1515141312
Product Model  : Primo RH3
Product Brand  : WALTON
Product Name   : RH3
Product Device : Primo_RH3
Product Board  : WALTON
Product Manfct : WALTON
Board Platform : mt6737m
Product Info   : Primo_RH3
MT6737M__WALTON__Primo_RH3__7.0__Primo_RH3_20180105_V06__NRD90M__Primo_RH3
SecureDevice : Paired type!
-> INFO : That device MAY dead after ReadOut Flashing in some rare cases!
Read : preloader.bin
Read : proinfo.img
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : recovery.img
Read : logo.bin
Read : secro.img
Read : tz.img
Read : teeinfo.img
Read : system.img
ExtSparse : Compression ratio : 11%
Read : cache.img
Read : userdata.img
FW Size  : 3.55 GB
Android Info saved : _Android_info.txt
Scatter  : MT6737_Android_scatter.txt
Saved to : E:\MT6737M__WALTON__Primo_RH3__7.0__Primo_RH3_20180105_V06__NRD90M__Primo_RH3\
Done!
Elapsed: 00:10:00
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.89397 seconds with 9 queries
