Old 08-01-2019, 10:27   #59881 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Oppo A37FW QLM FRP Reset Done With King Infinity CM2
Card found : A19EC787 , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Reset Settings [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 26DFF941
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 46BED4228D190601FE53BDA26D34BC8C
ID_BLOCK_L : BAC977D6DB4AF471946334EDE70E1823
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Old 08-01-2019, 11:41   #59882 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
OALE X2 MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 45 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : F40122426977696E2010323731368481
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0xF4 , OEM : 0122
[eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi
[eMMC] : FLASH_CID : F40122426977696E2010323731368481
[eMMC] : FLASH_LEN : 0x00000001CD000000
[eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F3955FA5AB5383231A731E928027
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:34
Old 08-01-2019, 12:03   #59883 (permalink)
Member: 1025102
Thanks Meter: 73
Reser FRP Motorola TX 1700 - OK
Old 08-01-2019, 12:07   #59884 (permalink)
Member: 1025102
Thanks Meter: 73
Goog reset FRP Motorola TX 1700
Old 08-01-2019, 12:53   #59885 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Huawei mya l22 reset frp done by cm2
Card found : S/N : 73CA70CC , v0137
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D33314553B30D421DB7DDF2
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x80000000
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420DB353F2DD841D
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xB9E2EB77E68A3B3D1F62EDDF3E78564D
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:20
Old 08-01-2019, 12:55   #59886 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
VGO TEl I550 PLUS RESET PASSWORD DONE BY CM2
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 42D977B475618E444EB4519E3048A2BB
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:12
Old 08-01-2019, 12:57   #59887 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Voice v990 hang on logo done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB]
Operation : Format FileSystem [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 653x NOR v1.3(c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_197 C8E8AF84A_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:22
Old 08-01-2019, 13:01   #59888 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Rivo m1 hang on logo done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Infinity SC Firmware Detected
FW Size : 1653 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : M1
Device Model : sp7731c_1h10_32v4
Device CPU : sp7731ceb
Device IntName : sp7731c_1h10_32v4_oversea
Device Version : 6.0
Device Compile : 3/9/2017 11:24:09 AM
Device Project : MRA58K release-keys
Device ExtInfo : M1
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 17 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x21 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_720x1280.bin
Write Data ...
Write Data Ok!
Write CodeData : logo2.bin
Write Data ...
Write Data Ok!
Write CodeData : logo3.bin
Write Data ...
Write Data Ok!
Write CodeData : logo4.bin
Write Data ...
Write Data Ok!
Write CodeData : logo5.bin
Write Data ...
Write Data Ok!
Write CodeData : logo6.bin
Write Data ...
Write Data Ok!
Write CodeData : logo7.bin
Write Data ...
Write Data Ok!
Write CodeData : logo8.bin
Write Data ...
Write Data Ok!
Write CodeData : logo9.bin
Write Data ...
Write Data Ok!
Write CodeData : logo10.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:04:09
Old 08-01-2019, 14:16   #59889 (permalink)
Member: 2233266
Thanks Meter: 232
spd 6531e formate done cm2 spd
Phone found! [ 13 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:09
Old 08-01-2019, 14:17   #59890 (permalink)
Member: 2233266
Thanks Meter: 232
dcl d10 spd 6531e formate done cm2 spd
Phone found! [ 13 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:09
Old 08-01-2019, 15:16   #59891 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Lenovo a2020a40 reset frp done by cm2
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Identify [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 092A35CF
ID_BLOCK_L : D42C46B01F8BB0B36CC1331CDBA62E1E
ID_BLOCK_L : E19C228D8E11B9CACF2E6358AA455378
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Brand : Lenovo
ProdName : angus3A4
ProdModel : Lenovo A2020a40
Device : angus3A4
AndroidVer: 5.1.1
Manufact. : LENOVO
SysPatch : LMY47V
DevComTime: 11/9/2016 5:22:19 AM
QLMxCPU : MSM8909
QLMxPRJ : A2020a40_USR_S189_1611091320_Q8909_ROW
USERData : NORMAL
GCSec : NORMAL
Done!
Elapsed: 00:00:14
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:20
Old 08-01-2019, 16:50   #59892 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,083
Himax H18 only supported by SCR
Operation : Identify [ v1.04 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00200000
BOOT_INIT : 0x60A6F6C6
BOOT_MODE : BOOTROM
Boot_CPU  : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV  : 0xFBA2A250
Boot done!
Identify : Code Integrity Check pass!
Device Info Details :
[0] : sc6533g_XS35_E11_A
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_hs8292u
[5] : flsh_spi32m
[6] : st7789/gc9304c/gc9305/ili9325/ili9341/gc9306/LGDP4535/nv3029e/otm3208/nv3029g/nv3029h/ili9340
[7] : bf3a01serial/gc6123/gc6133/sp0820
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
[11] : 2018-01-17_18:20:19
[12] : E11_A22_HIMAX_V29
Done!
Elapsed: 00:00:29
Operation : Read Flash [ v1.04 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_INIT : 0x70A6F6C6
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Read done, 0x00400000
Verify FlashContent
MCU verified
CAL verified
FAC verified
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_hs8292u
[5] : flsh_spi32m
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
Saved to : C:\Users\mess\Desktop\
Saved as : SC6533G_4MiB_sc6533g_XS35_E11_A_E11_A22_HIMAX_V29_2018-01-17_182019.ilod
Done!
Elapsed: 00:00:36
Operation : Read UserCode [ v1.04 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_INIT : 0x62A6F6C6
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Preparing PMT
Verifying PMT
Dump USERSPACE
Open USERSPACE
USERSPACE : 120
Check USERSPACE
Parse USERSPACE
CODE : 56325
Read done!
Done!
Elapsed: 00:00:19
Old 08-01-2019, 16:53   #59893 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,083
We l7
Operation : Reset Settings/Format FS [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM9)
MODE : BOOTROM
PORT : 9
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
BROM : SecMode  : SBC
BROM : BOOTROM
MODE : 0_base : BASE_v1912 | Manual : Disabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 514E011335394A3269071151E39410A1
DAInf: 4 : 2 : 156
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : 13014E51324A393551110769A11094E3
     EMI : DEV : INFINITY
     EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
INIT : 0xBC : LP/DDR3 [ 0x00000000 :  [ 0 B ] ]
DRAM : DRAM: 0x40000000 [ 1.00 GB ]
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 13014E51324A393551110769A11094E3
        EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J95Q
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x1D2000000 [ 7.28 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 42001E7E28226C5B6A961B1A5B3AB6C8
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM40)
MODE : PRELOADER PORT
PORT : 40
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:34
Old 08-01-2019, 17:40   #59894 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,083
itel p32
PTFN : MediaTek PreLoader USB VCOM (Android) (COM34)
PORT : 34
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : PRELOADER PORT
BROM : DA sent
     DA : AGENT started!
eMMC : OK
eMMC : 460001154D32364E793B034293450F9A
DAInf: 4 : 2 : 156
     DA : DRAM ready!
        EMMC: 150100464E36324D42033B799A0F4593
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB
        EMMC:
              RPMB   : 0x00080000 [ 512.00 KB ]
        RNID : A8FCACAE9DF93FD3C6EA7BD2DAB142DF
DA : USB : HIGH-SPEED
Boot done!
Done!
Elapsed: 00:00:30
Old 08-02-2019, 04:29   #59895 (permalink)
fertxter's Avatar
Member: 1344255
Sonork: 1659066
Thanks Meter: 118
Smile Cherry Mobile Flare S4 Max FRP lock done CM2
Logs
Card found : S/N : 0000000000000000, v0138
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 700100563130303038502635316B339B
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 80001
[eMMC] : FLASH_CID : 700100563130303038502635316B339B
[eMMC] : FLASH_LEN : 0x00000001C3000000
[eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB]
DEV RID    : 0x7A3C37BC631D3E845F1981F2D4A4AD8F
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:09
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:53
The Following 2 Users Say Thank You to fertxter For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.79720 seconds with 9 queries
