Old 04-28-2009, 09:52   #46 (permalink)
ehsas_ghum's Avatar
Member: 171512
SED V890 PDA CALIBRATION OK
COM3 [VCP0] selected
module v2.73
Action: touchscreen calibration
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:0C1D:83C6
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: SZMI26_05C_W0624_S608PLUS_V1.0
Version: SZMI26_05C_HW
detecting structure #2...
done
60 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5 (mode-1)...
0 1 done
204 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 12 sec
Remove/Install battery now !
The Following 3 Users Say Thank You to ehsas_ghum For This Useful Post:
Old 04-28-2009, 12:35   #47 (permalink)
ehsas_ghum's Avatar
Member: 171512
nokia 6120c restart done
module v2.73
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:6C03:000C
boot packet size: 0400
Boot Done
Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area (code #1) is Ok
security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.8B370A40.[JIA6120_ONE_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_ MP_V2.BIN_AE381EE2].rpl
identification#1 detection finished
device-id: 8B370A40
identification#1 protocol ver: 04
ver. sw 1: JIA6120_ONE_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_ MP_V2.BIN
ver. sw 2: MAUI.07A.W07.52.MP.V2, 1DE1C751
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_8B370A40_JIA6120_ONE_PCB01_GPRS_MT6225_S 00.MAUI_07A_W07_52_MP_V2.BIN_AE381EE2_20090428-143416.B0X.bin
Finished, time used: 44 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 04-28-2009, 12:54   #48 (permalink)
cel_phon's Avatar
Member: 950201
Sonork: 100.1608088
NO DOUBT Infinity is the best with all supported models - except J-132 and T-303 (with new security)
Old 04-28-2009, 13:32   #49 (permalink)
azeem781986's Avatar
Member: 503161
Sonork: 100.1584069
LG KG270 successfully repaired ON with infinity
kg 270 dead successfully repaired with infinity the great box hre iz the log
module v1.63
Device: LG-KG270
Action: flash write
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL KG271 P16 92 V10c XXX-XX Mar 28 2007 +0
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-static_20090428-042631.B1E.bin
loading data...
data loaded
imei: 35744501703156400
reading eeprom-security_35744501703156400...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-security_35744501703156400_20090428-042633.B1E.bin
reading eeprom-complete_35744501703156400...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG270_eeprom-complete_35744501703156400_20090428-042639.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Firmware
Writing: Firmware
Erasing: Language Pack
Writing: Language Pack
Erasing: FFS-2/File system
Writing: FFS-2/File system
Write Done
Finished, time used: 417 sec
thanks infinity team
The Following 3 Users Say Thank You to azeem781986 For This Useful Post:
Old 04-28-2009, 13:37   #50 (permalink)
Member: 503161
Sonork: 100.1584069
LG kg 276 repaired with infinity
LG KG276 dead repaired successfully with ininity box rrooxx....
here z the log thanks to great team with fast updates
module v1.63
Device: LG-KG276
Action: flash write
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .00 ULC2GL KG271 P16 92 V10d XXX-XX Jun 20 2007 +0
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-static_20090426-012700.B1E.bin
loading data...
data loaded
imei: 35617601845069000
reading eeprom-security_35617601845069000...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-security_35617601845069000_20090426-012702.B1E.bin
reading eeprom-complete_35617601845069000...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KG276_eeprom-complete_35617601845069000_20090426-012708.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 398 sec
Old 04-29-2009, 07:16   #51 (permalink)
dky_tel's Avatar
Member: 120328
Thumbs down t280! unlock done
log t280! successful unlock to infinity box...
COM27 [VCP0] selected
module v1.32
Device: Sony-Ericsson-T280i
"advanced chip detection" active
Action: unlock
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
812500
Set baud done
Check hardware ...
flash: 89890400040089:89890400000000
flash: Intel ST [def 0080x040000] 32Mb
Check hardware done
Read data ...
reading Sony-Ericsson-T280i_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20090429-141339.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 115 sec
br
The Following 3 Users Say Thank You to dky_tel For This Useful Post:
Old 04-29-2009, 08:06   #52 (permalink)
Member: 767451
Angry a68 unlocked with pan1.65
select my150x click sCOM6 [VCP0] selected/.
module v1.65
Device: Sagem-my150x
Action: unlock
unlock method-1
Boot ...
e-gold: 820013
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-static_20090428-202801.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-security_20090428-202802.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-complete_20090428-202803.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_lock-area_20090428-202807.B1E.bin
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 53 sec
module v1.65
Action: unlock
unlock method-1
Boot ...
e-gold: 820013
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Remove/Install battery now !p unlock workind good thanx infinity team
The Following 4 Users Say Thank You to fidmdoe For This Useful Post:
Old 04-29-2009, 09:39   #53 (permalink)
gsm-nisse's Avatar
Member: 227038
successfull unlocked LG-KG291 by selecting KG290
==== log: [13-04-2009 19:13:36] ====
COM2 [VCP4] selected
Device: LG-KG290
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 89881600010001:89881600000000
flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 358684012900741
file saved: C:\Program Files\InfinityBox\LGA\eeprom_358684012900741_LG-KG290_20090413-191405.B1E.bin
Check flash Done
Check space...
finalization done
Check space Done
Check parameters...
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 61 sec
The Following 2 Users Say Thank You to gsm-nisse For This Useful Post:
Old 04-29-2009, 09:48   #54 (permalink)
gsm-nisse's Avatar
Member: 227038
successfull REPAIRE Modelabs ELITE by selecting Modelabs-MyWay-Slim (same connecteur)
==== log: [21-04-2009 14:48:03] ====
COM5 [VCP1] selected
module v2.67
Action: reset settings
Model: Modelabs-MyWay-Slim
19200 autodetect
Initializing [6219:8B02:8B01]...
CPU: MT6219
chip: 0031:220A:9727
status: FF
detected CPU: MT6226MA
Connecting at 19200, wait...
Hardware: MT6219B,E02
Date: 2005.04.12
Version: 1.0
Version: SL900A.05C.W06.08.MP.V64
Version: ESL6227_05C_HW
60 byte(s) read
imei: 35299001018086
connection Ok
building list...
done
items to clear: 215
items cleared: 133 of 215
items remains: 0
Finished, time used: 403 sec
==== log: [21-04-2009 14:58:32] ====
module v2.67
Action: imei
imei write method: mode-2
imei write channel: imei #1 for dual sim/mono CPU
new imei: 352990010180863
19200 autodetect
CPU: MT6219
status: FF
Date: 2005.04.12
Version: 1.0
60 byte(s) read
connection Ok
60 byte(s) read
verification...
verification done: 35299001018086
Finished, time used: 11 sec
Old 04-29-2009, 14:23   #55 (permalink)
Member: 700923
sony ericsson T303 unlock done
COM4 [VCP0] selected
module v1.32
Device: Sony-Ericsson-T303
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
software version: 1209-8242
software version: R2BC003
Check hardware done
Read data ...
reading Sony-Ericsson-T303_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090429-185631.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 198 sec
The Following 2 Users Say Thank You to w850 For This Useful Post:
Old 04-29-2009, 15:11   #56 (permalink)
uttam's Avatar
Member: 223135
Sonork: 100.1592685
Succssefully Repair Onida V110
COM5 [VCP0] selected
module v2.81
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A04:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:9A91:000C
status: FF
Boot Done
Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
identification#1 structure: 2nd [standard] generation
New firmware detected (v.2.81, database date: 28.04.2009):
CKT23_07A_ONIDA_MULTILANG_PCB01_GPRS_MT6223P_S00.A NT_ONIDA_L2EN_211_080502_TR5_SS75_CTF_FM.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: mt62xx@gmail.com
- include in your e-mail full text from phone back label (phone name etc.)
ver. sw 1: CKT23_07A_ONIDA_MULTILANG_PCB01_GPRS_MT6223P_S00.A NT_ONIDA_L2EN_211_080502_TR5_SS75_CTF_FM.BIN
ver. sw 2: ANT_ONIDA_L2EN_211_080502_TR5_SS75_CTF_FM, 00000000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Finished, time used: 49 sec
The Following 2 Users Say Thank You to uttam For This Useful Post:
Old 04-29-2009, 19:05   #57 (permalink)
sajidashraf's Avatar
Member: 501674
Sonork: THEIF OF HEART
Thumbs up ...:::kp-320 flashing done:::...
...:::KP-320 FLASHING DONE:::...
module v2.72
Device: LG-KP320
Action: write NAND flash
read mode: 01
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
source data: page only
ver. sw 1: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610IN00-001-R2K.BIN
ver. sw 2: 7S7610IN00-001-R2K, 00000000
ffs offset/size: 02000000/06000000
id-page1 Ok
end mark #4 found
nfi area detection finished: Ok
Boot ...
19200 fixed
Connecting, wait...
Initializing [6229:8A02:8A02]...
CPU: MT6229
chip: 0031:2005:0101
status: FF
Boot Done
Initialize ...
version: 3.02
cpu-id: 09
loader: 3.748.0
NAND id: 98F19095
page size: 800+40
pages/block: 40
bits i/o: 08
address cycles: 04
blocks: 0400
external ram: 00000000
finalize connection...
done
emi configuration...
ram size: 00800000
emi configuration done
ram test...
pass 1...
pass 2...
pass 3...
pass 4...
done
NOR: 0000:000000000000 [00000000]
NAND: 0098:00F100900095 [08400000]
NOR chip is not installed
Initialize Done
Set baud ...
921600
Set baud Done
Identification ...
ram test...
pass 1...
pass 2...
pass 3...
pass 4...
done
reading bootloader structure area (00080000 bytes)...
detecting bootloader structure...
warning: probably flash chip completely erased, no bootloader found
nfi area detection finished: failed
detecting bootloader structure by source file...
id-page1 Ok
Identification Done
Write ...
00006000 bytes sent
write core area 1 of 3...
00418800 bytes sent
write core area 2 of 3...
00AF9C00 bytes sent
write core area 3 of 3...
0037B400 bytes sent
Write Done
Finished, time used: 508 sec
...:::S@JID:::...
The Following 2 Users Say Thank You to sajidashraf For This Useful Post:
Old 04-30-2009, 02:48   #58 (permalink)
Member: 696126
alcatel ot s211 unlock success.....
COM7 [VCP0] selected
module v1.30
Device: Alcatel-S211
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 012A7E2A242A00:54000000000000
flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb
Check hardware done
Read data ...
reading Alcatel-S211_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Alcatel-S211_eeprom_calibration-1_20090427-005744.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 80 sec
The Following 2 Users Say Thank You to bbaj For This Useful Post:
Old 04-30-2009, 19:16   #59 (permalink)
InfinitySupport's Avatar
Member: 130995
module v2.67
19200 autodetect
CPU: MT6219
status: FF
Date: 2005.04.12
Version: 1.0
60 byte(s) read
connection Ok
building list...
done
items to clear: 215
items remains: 0
module v2.67
Action: imei
19200 autodetect
CPU: MT6219
status: FF
Date: 2005.04.12
Version: 1.0
60 byte(s) read
connection Ok
60 byte(s) read
verification...
Hello,
Please, read full flash from Modelabs Elite and send full flash backup to support@infinity-box.biz
Old 04-30-2009, 19:19   #60 (permalink)
Member: 130995
module v2.81
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
ffs/eeprom chip: 00
Write ...
Write Done
Finalization ...
formatting...
Finalization Done
Hello,
Please, read full flash from Onida-V110 and send full flash backup to support@infinity-box.biz
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
Page generated in 0.29122 seconds with 12 queries
