10-28-2010, 20:09 | #6001 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | Quote:
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
10-28-2010, 22:10 | #6002 (permalink) |
No Life Poster Join Date: Nov 2007
Member: 633231 Status: Offline Thanks Meter: 666 | Port COM1 open OK Connect phone on selected interface... Wait... Phone found... Phone in Local mode Phone Nokia 5000d-2b connected - Ok IMEI 011601007590302 Read Lock Info Locked to Orange;Dominican Republic Unlocking... Unlock - Ok Port COM1 close |
The Following User Says Thank You to thewolverine For This Useful Post: |
10-28-2010, 22:13 | #6003 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | COM1 [Serial0] selected module v3.62 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R220 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:5A03:000B status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: SE-DM-CLARO8-P103D1FV1.0.0B03 Version: SE-DM-CLARO8-P103D1FV1.0.0B03 44 byte(s) read imei: 35519103288338 connection Ok 157 byte(s) read reading data... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
10-28-2010, 22:22 | #6004 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | 6270 Code: Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 20600019B52A0054E74EFED65BA5B83841742AEA CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 22FE00EC < SAMSUNG [SEC] => K8S5615ETA FLASHID : 22FE00EC , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 3D4EB3D80EB900F842AE957BC9AC364E7E653F7B00 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm56b5003.90.mcusw.bin CMT select Ok Found 4 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00180000 - 0x00B69DB5 CMT , NOR , Area : 0x00000000 - 0x000FFFFF CMT , NOR , Area : 0x00120000 - 0x0017FFFF CMT , NOR , Area : 0x00C00000 - 0x0117FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:59 Write : Processing rm56b5003.90.mcusw.bin CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [PMM_CONF] CMT: Writing Hash CERT [SBIF_CONF] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [MCUSW] Total writen 728 blocks TIME : Write time : 00:01:15 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 20600019B52A0054E74EFED65BA5B83841742AEA CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 22FE00EC < SAMSUNG [SEC] => K8S5615ETA FLASHID : 22FE00EC , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 3D4EB3D80EB900F842AE957BC9AC364E7E653F7B00 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm56b5003.90.ppm_k CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00C00000 - 0x0117FFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:02 Write : Processing rm56b5003.90.ppm_k Total writen 277 blocks TIME : Write time : 00:00:29 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000010000022600010006010C192101001101 CMT EM0 ID : 00000232 CMT EM1 ID : 00000352 CMT PUB ID : 20600019B52A0054E74EFED65BA5B83841742AEA CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 191EC665DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 22FE00EC < SAMSUNG [SEC] => K8S5615ETA FLASHID : 22FE00EC , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : 3D4EB3D80EB900F842AE957BC9AC364E7E653F7B00 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok Erase : Processing rm56b5003.90.image_k CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x01180000 - 0x01FDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:01:34 Write : Processing rm56b5003.90.image_k Total writen 300 blocks TIME : Write time : 00:00:38 Init Service mode... Wait... Reading Phone Info.... Connected phone - Nokia 6270 Software Info: V 03.90 09-02-07 RM-56 (c) Nokia. IMEI: 357576007841461 Product code: 0522840 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Reset LifeTimer ... Ok Checking User Certificates... Total - 0 certs Uploading certificates... No data, delete skipped Writen 21 certs! AfterFlash operations done... Reconnect, wait... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Format for "Hang" s40 without Local contacts are saved USB\UFS Code: Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 24300215A8A802543C118B4A3D9C86435F80633D CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:06 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok Starting Erase Custom Block Block erase Ok, continue... Erase Custom Area Erasing area 0x02660000 - 0x03F9FFFF, NOR, CMT Result: 0000 ADL : End Erasing Erase done! Total time : 00:00:08 Try Reboot phone now... Done! UserArea format done Phone disconected! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok BackUp UserData : [PhoneBook] Generation mode : [S40] Reading Phonebook... 584 phonebook records are found! Saved to: C:\RM-325 Nokia 6600 fold_355729021933853.S4pb Done... Code: Will Write RPL keys now... Check RPL file... NMP RPL Detected, converting... Convert done! NPC Data found! CCC Data found! HWC Data found! SimLock Data found! SimLock key found! SuperDongle Key found! WMDRM key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000030000022600010007600C192102011104 EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 2640020781330344C859711494FD51916713A2A9 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA Use RAPUv11_2nd.fg Processing RAWLOADER... FLIC : 004000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg Boot Done! :) TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] ADL: Preparing for write certificates... Erase NPC... Ok Writing NPC... Ok Erase CCC... Ok Writing CCC... Ok Erase HWC... Ok Writing HWC... Ok ADL: Writing Flash certs done! :) ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... Check phone mode... Phone already in Test mode, skip change... Writing SimLock Key... Ok! Writing SimLock Data... Ok! Writing Super Dongle Key... Ok! SDD Key status : SD Data is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! :( Write WMDRM_PD... Ok Done! Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... Code: Connect phone on selected interface... Files Set for Flashing : MCU : rm470__13.10.mcusw PPM : rm470__13.10.ppm_i CNT : rm470__13.10_ISM_018.image_i_bg_black Check FlashFiles, Please, wait... Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102011104 CMT EM0 ID : 00000C34 CMT EM1 ID : 00000C30 CMT PUB ID : 2640020781330344C859711494FD51916713A2A9 CMT MODE ID : 00 CMT R_HASH : 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID : 3E273BF637BE26FA CMT : Sending 2nd loader... Use : RAPUv11_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLASHID : 004000EC , CMT , NAND FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAPUv11_algo_xsr16.fg CMT Algo sent CMT PAPUB : BA40E42B6F3B8A6EFEE35B4A9D15924EB132C68900 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... CMT select Ok Erase : Processing rm470__13.10.mcusw CMT select Ok Found 7 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x00020000 - 0x000203FF CMT , NAND , Area : 0x00060000 - 0x0009FFFF CMT , NAND , Area : 0x000A0000 - 0x0041FFFF CMT , NAND , Area : 0x00420000 - 0x0069FFFF CMT , NAND , Area : 0x006A0000 - 0x01F1FFFF CMT , NAND , Area : 0x02900000 - 0x02FBFFFF CMT , NAND , Area : 0x0F2C0000 - 0x0F8BFFFF Erasing, wait..... CMT : Group erase Ok Erase Partition 0x08 , CMT , NAND CMT : Partition erase Ok Erase Partition 0x0A , CMT , NAND CMT : Partition erase Ok Erase Partition 0x0B , CMT , NAND CMT : Partition erase Ok TIME : Erase time : 00:00:02 Write : Processing rm470__13.10.mcusw CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [ISA+DYNSW] Total writen 228 blocks TIME : Write time : 00:02:35 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102011104 CMT EM0 ID : 00000C34 CMT EM1 ID : 00000C30 CMT PUB ID : 2640020781330344C859711494FD51916713A2A9 CMT MODE ID : 00 CMT R_HASH : 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID : 3E273BF637BE26FA CMT : Sending 2nd loader... Use : RAPUv11_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLASHID : 004000EC , CMT , NAND FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAPUv11_algo_xsr16.fg CMT Algo sent CMT PAPUB : BA40E42B6F3B8A6EFEE35B4A9D15924EB132C68900 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... CMT select Ok Erase : Processing rm470__13.10.ppm_i CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x01F20000 - 0x028FFFFF Erasing, wait..... CMT : Group erase Ok TIME : Erase time : 00:00:02 Write : Processing rm470__13.10.ppm_i Total writen 52 blocks TIME : Write time : 00:00:41 Setting FlashMode 1st boot Ok, C0 CMT part info : CMT ASICID : 000000030000022600010007600C192102011104 CMT EM0 ID : 00000C34 CMT EM1 ID : 00000C30 CMT PUB ID : 2640020781330344C859711494FD51916713A2A9 CMT MODE ID : 00 CMT R_HASH : 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID : 3E273BF637BE26FA CMT : Sending 2nd loader... Use : RAPUv11_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 004000EC < SAMSUNG [SEC] => KAT00F00RA [NAND] FLASHID : 004000EC , CMT , NAND FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAPUv11_algo_xsr16.fg CMT Algo sent CMT PAPUB : BA40E42B6F3B8A6EFEE35B4A9D15924EB132C68900 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... CMT select Ok Erase : Processing rm470__13.10_ISM_018.image_i_bg_black CMT select Ok Found 1 areas to erase, erase group Asic : CMT , Sub : NAND CMT , NAND , Area : 0x02FC0000 - 0x0F2BFFFF Erasing, wait..... CMT : Group erase Ok Erase Partition 0x08 , CMT , NAND CMT : Partition erase Ok TIME : Erase time : 00:00:04 Write : Processing rm470__13.10_ISM_018.image_i_bg_black Total writen 205 blocks TIME : Write time : 00:02:44 |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
10-29-2010, 07:02 | #6005 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | Vodafone-340 unlocked COM9 [VCP0] selected module v3.54 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F703:A009 status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.42 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203346404 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! |
The Following User Says Thank You to khalidjan For This Useful Post: |
10-29-2010, 07:36 | #6006 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | Spice-S415 imei done Action: "repair imei" Model: Spice-S415-2008-03-19 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 115200 Phone detected, wait... imei-1: 135790246811220 imei write method: mode-1 new imei-1: 353923036663066 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
10-29-2010, 08:03 | #6007 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | 7210S Flash sucess in fbus ufsx Quote:
The Following 4 Users Say Thank You to .::AZEEM::. For This Useful Post: |
10-29-2010, 08:31 | #6008 (permalink) |
Insane Poster Join Date: Dec 2006
Member: 413738 Status: Offline Thanks Meter: 7 | Unicare 510 unlock done checking version... Nov 23 2009QSC6010-UN510C Unicare 510 C version selected.. Offline... Downloading mode... Sending boot... patching in progress... patching in progress 50%... patching in progress 100%... Done... phones should be restart... Finished, time used: 23 sec |
The Following 3 Users Say Thank You to kalpesh.1978 For This Useful Post: |
10-29-2010, 09:01 | #6009 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | MTS S100 ZTE unlock done COM36 [QCUSB_COM36_1] selected module v1.33 Device: ZTE-S100 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 6 sec |
The Following User Says Thank You to akashub For This Useful Post: |
10-29-2010, 10:00 | #6010 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 23 sec |
The Following 3 Users Say Thank You to JINDALGSM™ For This Useful Post: |
10-29-2010, 10:28 | #6011 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Ghana
Member: 1230787 Status: Offline Thanks Meter: 96 | successfully unlocked vodafone 541. COM1 [Serial0] selected module v3.59 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7B03:A005 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.694EC ED3.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_064A906B].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 694ECED3 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 6B904A06 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17C provider: 708X-2FVDGH1 customization: CN17FZ83 customization: XN17FZ83 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FZ83 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FZ83 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103062515 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_694ECED3_064A906B_20101029-091815.B0X.bin Finished, time used: 4 min 41 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to lloydgsm For This Useful Post: |
10-29-2010, 12:11 | #6012 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: Pakistan
Member: 1417911 Status: Offline Sonork: 100.109719 Thanks Meter: 128 | 5310 Flash Sucessfully By BB5 Easy Service Tool Here Is Logs Quote:
The Following 3 Users Say Thank You to .:Gsm_Expert:. For This Useful Post: |
10-29-2010, 13:26 | #6013 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | E61 i flash with ufs interfce Code: Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Files Set for Flashing : MCU : rm227_m128_h20_ks_prod_306336900_c00_combined.bin PPM : rm227_m128_h20_ks_prod_306336900_v12_variant.bin CNT : rm227_rm294_cp_3.0.fpsx FlashFile verify disabled Backup enabled, Will read Certificates now... Backup CRT308 CRT308 Backup Created... :) Setting FlashMode 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 43534624DD8713BFF3D76261C6C382E942300577 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 11D0001241964F507E3EC57767123905B52BBA5F CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLASHID : 22E800EC , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBD00 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg APE Loader sent, Boot Ok APE Flash ID: 00780098 < TOSHIBA => K5E1G12ACM FLASHID : 00780098 , APE , NAND FLCNT : 000002000000060000000000000000 Sending ALGO.... Use : h3_sam_nand_xsr.fg APE Algo sent APE PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBC00 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT : Read NPC certificate... Cert size : 20480 byte(s) IMEI : 351879013334174 CMT : Read CCC certificate... Cert size : 2048 byte(s) CMT : Read HWC certificate... Cert size : 2048 byte(s) CMT : Read VARIANT certificate... Cert size : 0 byte(s) APE : Read NPC certificate... Cert size : 0 byte(s) APE : Read CCC certificate... Cert size : 0 byte(s) APE : Read HWC certificate... Cert size : 0 byte(s) APE : Read VARIANT certificate... Cert size : 0 byte(s) Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\infinity bb5 tool\Best\Backup\Cert\351879013334174_2nd.rpl Setting FlashMode 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 43534624DD8713BFF3D76261C6C382E942300577 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 11D0001241964F507E3EC57767123905B52BBA5F CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLASHID : 22E800EC , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBD00 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg APE Loader sent, Boot Ok APE Flash ID: 00780098 < TOSHIBA => K5E1G12ACM FLASHID : 00780098 , APE , NAND FLCNT : 000002000000060000000000000000 Sending ALGO.... Use : h3_sam_nand_xsr.fg APE Algo sent APE PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBC00 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... CMT select Ok APE select Ok Erase : Processing rm227_m128_h20_ks_prod_306336900_c00_combined.bin CMT select Ok Found 3 areas to erase, erase group Asic : CMT , Sub : NOR CMT , NOR , Area : 0x00000000 - 0x0052959D CMT , NOR , Area : 0x006A0000 - 0x006DFFFF CMT , NOR , Area : 0x00F00000 - 0x00FDFFFF Using TimeOut : 5 min ( 300 sec ) Erasing, wait..... CMT : Group erase Ok APE select Ok Found 3 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x00000000 - 0x0007FFFF APE , NAND , Area : 0x00080000 - 0x000803FF APE , NAND , Area : 0x000C0000 - 0x03CFFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:46 Write : Processing rm227_m128_h20_ks_prod_306336900_c00_combined.bin CMT select Ok CMT: Writing Hash CERT [NOLO] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [ADL] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] APE select Ok APE: Writing Hash CERT [KEYS] APE: Writing Hash CERT [X-LOADER] APE: Writing Hash CERT [PRIMAPP] APE: Writing Hash CERT [SOS+LOADER] APE: Writing Hash CERT [ADL] APE: Writing Hash CERT [SOS+XZIP] APE: Writing Hash CERT [PASUBTOC] APE: Writing Hash CERT [PAPUBKEYS] APE: Writing Hash CERT [SOS*CORE] APE: Writing Hash CERT [SOS+ROFS] APE: Writing Hash CERT [SOS+ROFX] Total writen 1499 blocks TIME : Write time : 00:04:01 APE close... Ok Setting FlashMode 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 43534624DD8713BFF3D76261C6C382E942300577 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 11D0001241964F507E3EC57767123905B52BBA5F CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLASHID : 22E800EC , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBD00 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg APE Loader sent, Boot Ok APE Flash ID: 00780098 < TOSHIBA => K5E1G12ACM FLASHID : 00780098 , APE , NAND FLCNT : 000002000000060000000000000000 Sending ALGO.... Use : h3_sam_nand_xsr.fg APE Algo sent APE PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBC00 Transmission mode : Dual (Ddr, TX2) Boot Done! Partitioning.... Partitioning Ok... CMT select Ok APE select Ok Erase : Processing rm227_m128_h20_ks_prod_306336900_v12_variant.bin APE select Ok Found 1 areas to erase, erase group Asic : APE , Sub : NAND APE , NAND , Area : 0x02860000 - 0x03CFFFFF Erasing, wait..... APE : Group erase Ok TIME : Erase time : 00:00:01 Write : Processing rm227_m128_h20_ks_prod_306336900_v12_variant.bin APE: Writing Hash CERT [SOS+ROFX] Total writen 1497 blocks TIME : Write time : 00:01:27 APE close... Ok Setting FlashMode 1st boot Ok, C0 APE part info : APE ASICID : 17100708 APE MODE ID : 00 APE PUB ID : 43534624DD8713BFF3D76261C6C382E942300577 APE R_HASH : 49A97E826B93BA20B7ED0B082475C005 APE ROM ID : 1DFD66132C872FD4 CMT part info : CMT ASICID : 000000010000022600010006010C192101003000 CMT EM0 ID : 00000295 CMT EM1 ID : 00000B22 CMT PUB ID : 11D0001241964F507E3EC57767123905B52BBA5F CMT MODE ID : 00 CMT R_HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID : 273F6D55DFAAF68F CMT : Sending 2nd loader... Use : RAP3Gv3_2nd.fg CMT Loader sent, Boot Ok CMT Flash ID: 22E800EC < SAMSUNG [SEC] => K5G2829ATC FLASHID : 22E800EC , CMT , NOR FLCNT : 00000000000000000000000000000000 FLMCID : FFFF000000000000 Sending ALGO.... Use : RAP3Gv3_algo.fg CMT Algo sent CMT PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBD00 Transmission mode : Dual (Ddr, TX2) APE : Sending 2nd loader... Use : helen3_2nd.fg APE Loader sent, Boot Ok APE Flash ID: 00780098 < TOSHIBA => K5E1G12ACM FLASHID : 00780098 , APE , NAND FLCNT : 000002000000060000000000000000 Sending ALGO.... Use : h3_sam_nand_xsr.fg APE Algo sent APE PAPUB : AB1F68D2E4D7D0487762E37D74EA7D923C341FBC00 Transmission mode : Dual (Ddr, TX2) Boot Done! CMT select Ok APE select Ok Erase : Processing rm227_rm294_cp_3.0.fpsx Erase : No any region, skip erase TIME : Erase time : 00:00:00 Write : Processing rm227_rm294_cp_3.0.fpsx APE select Ok Phone found! Series 60 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia E61i-1 Software ver : V 3.0615.3 31-01-08 RM-227 (c) Nokia. IMEI : 351879013xxxxxx Ape Ver : 3.0633.69.00 06-02-08 RM-227 (c)Nokia APE Var : 3.0633.69.00_v12 06-02-08 RM-227 (c)Nokia APE ADSP: 256 DSP Ver : SL06w14PB_07w42 APE Test: PPM : CNT : Product SN : YCB052297 Product code : 0553433 Base Prd.code: 0538125 Module code : Long Prod.SN : Hardware info======= HWID : 2009 Retu : 15 Tahvo : 22 Batery: 4745 mV Camera: CMT BT: APE BT: HCI Version 2 (rev. 0). LMP Version 2 (rev. 3504). Manufacturer 13. APE HW: 1 LCDVer: RF ic : 17211721 Lock info =========== IMEI : 35187901333xxxxx IMEI spNet : IMEI svNet : Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= User Code : 12345 UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Phone disconected! Connect phone on selected interface... |
The Following 3 Users Say Thank You to Mohsin-* For This Useful Post: |
10-29-2010, 15:02 | #6014 (permalink) |
Member: 633231 Status: Offline Thanks Meter: 666 | Port COM1 open OK Connect phone on selected interface... Wait... Phone found... Phone in Local mode Phone Nokia 2610 connected - Ok IMEI 011287000470369 Read Lock Info Locked to T-Mobile;U.S.A. Unlocking... Unlock - Ok Port COM1 close |
10-29-2010, 15:02 | #6015 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | COM14 [VCP0] selected module v3.62 Device: Alcatel-708X, 708A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:9F03:A007 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:09EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.7EFCE 077.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_FE304F8D].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 7EFCE077 rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 8D4F30FE code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17S provider: 708X-2ATLES2 customization: CN17ES95 customization: XN17ES95 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17ES95 customization name adjusted flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17ES95 customization name adjusted flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22302200:09EA0000000000 flash: 01227E22302200:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103187620 flash: 01227E22302200:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22302200:09EA0000000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_7EFCE077_FE304F8D_20 101029-185639.B0X.bin Finished, time used: 6 min 2 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to msashami For This Useful Post: |
