Old 09-10-2019, 17:06   #60166 (permalink)
Member: 1099994
Thanks Meter: 24
Qmobile l8i read imei repair done
Operation : Identify [ v1.02 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : 6533G-FPTRUNK-W16.44.2
InternalVersion: g8bec5c4c
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Identify : Code Integrity Check pass!
Done!
Elapsed: 00:00:39
Reconnect Power/Cable!
Operation : Repair Security Items [ v1.02 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
LookUp for SECURITY
Verify SECURITY
Old Device Security Info :
IMEI[1] : 35556111--------
IMEI[2] : 355561111-------
BT_ADDR : 992E00D2C342
New Device Security Info :
IMEI[1] : 353963-----------
IMEI[2] : 353963----------
Repair Done!
Done!
Elapsed: 00:00:30
Old 09-11-2019, 02:12   #60167 (permalink)
fertxter's Avatar
Member: 1344255
Sonork: 1659066
Thanks Meter: 106
Exclamation MyPhone My28s logo only done by CM2 SPD
Procedure
Open CM2 SPD
Select SP [SC773x] eMMC [Android 5.x]
Click Service
Thin Click Format File System / Reset Settings
And wait to Finish
Logs
Set mode to : SP [SC773x] eMMC [Android 5.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 17 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:23
The Following 2 Users Say Thank You to fertxter For This Useful Post:
Old 09-11-2019, 05:36   #60168 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,895
qmobile black two full flash done
Card found: S/N : CE90936C , v0137
Chinese Miracle II  [SPD module] v 1.27
Set mode to : SP SC77xx [Model Select]
Loading    : QMobile_BlackTwo_MP_21_06.pac
CRVersion  : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : QMobile_BlackTwo_MP_21_06
FastCheck  : 0x0092BF8D2B
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : SC7702_pike_modem_AndroidM_mir_balun.dat
File : DSP_DM_G2.bin
File : SC8800G_pike_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : persist.img
File : sysinfo.img
File : userdata.img
File : LOGO.bmp
File : CHARGE.bmp
File : cache.img
File : u-boot.bin
File : SC7720_UMS.xml
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : QMobile_BlackTwo_MP_21_06.pac
PacCPUinfo : SC77xx
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : boot.img
File : recovery.img
File : system.img
File : persist.img
File : sysinfo.img
File : userdata.img
File : LOGO.bmp
File : CHARGE.bmp
File : cache.img
File : u-boot.bin
3. Insert cable
Device boot not done
Check Drivers
Try again
======= Flash
PacCPUinfo : SC77xx
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : boot.img
File : recovery.img
File : system.img
File : persist.img
File : sysinfo.img
File : userdata.img
File : LOGO.bmp
File : CHARGE.bmp
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 19 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x19 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : NVM Update
Current ID   : NV_W
Current Part : wfixnv1
[FlashProc] : Ok!
Current ID   : NV_WCN
Current Part : wcnfixnv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID   : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC7702_pike_modem_AndroidM_mir_balun.dat
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_G2.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : SC8800G_pike_wcn_dts_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : PERSIST
Current File : persist.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : SYSINFO
Current File : sysinfo.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : LOGO.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : CHARGE.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID   : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:04:01
Best Regards
MR,
Niaz muhammad
Always Follow The Forum RULES
Use Only Thanks Button
Old 09-11-2019, 07:36   #60169 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Phicomm E5051 MT6737 FRP Reset Done With King Infiniy CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 38 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A0190613447410735A532831A698C
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GA
[eMMC] : FLASH_CID : 90014A484147346132A535078C692483
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395FCC3A21BC1195A06D022C5AB
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:49
Old 09-11-2019, 10:49   #60170 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 405
ITEL A33 W5001P,,,PRIVACY SUCCESSFULLY DONE
Card found : 1BC1..... , v0137
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r2
Operation : Identify [ v2.00r2 ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS
Sending Init Boot ...
ERROR : FDL Start Failed!
Error : Fail to boot FDL!
Unsupported device with selected fdl! Change settings!
VER : BP_R1.0.0
LEN : 76A786D6
CPU : itel-W5001P
VER : W5001P-F3102-8.1-OP-V026-20190223_1530_user
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : PAC : W5001P-F3102-8.1-OP-V026-20190223_1530_user.pac
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
UserData : STATE : DAMAGED
Done!
Elapsed: 00:00:40
Error : No PAC selected! Break!
Open : W5001P-F3102-8.1-OP-V026-20190223_1530_user.pac
VER : BP_R1.0.0
LEN : 0x76A786D6
CPU : itel-W5001P
Reading package ...
Read package finished!
Patch Level : OPM2.171019.012
Display ID : W5001P-F3102-8.1-OP-V026-20190223
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2019-02-05
Build Time : 1550908275
Product Model : itel W5001P
Product Brand : Itel
Product Name : F3102
Product Device : itel-W5001P
Product Manfct : itel
Product Info : F3102
Product Board : itel-W5001P
Board Platform : sp7731e
Operation : Flash Firmware [ v2.00r2 ]
Setting : Update NVRAM : False
Setting : Force NVRAM : False
Setting : Update PMT : True
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
PMTMng : Load PMT
PMTMng : 0x25
PMTMng : Update PMT Ok!
CODE : prodnv.img
ERASE : UBOOT
UBOOT : u-boot-spl-16k-sign.bin
CODE : vbmeta-sign.img
CODE : SC9600_pike2_pubcp_PLD_base_nv_modem.dat
CODE : delta_nv.bin
CODE : PIKE2_DM_DSP.bin
CODE : pike2_cm4.bin
CODE : gnssmodem.bin
CODE : gnssbdmodem.bin
CODE : PM_pike2_cm4.bin
CODE : boot.img
CODE : recovery.img
FSIMG : system.img
FSIMG : userdata.img
CODE : logo.bmp
CODE : logo.bmp
FSIMG : cache.img
FSIMG : vendor.img
CODE : cover.img
CODE : chargelogo.bmp
CODE : charger_remind.bmp
CODE : lk_charge.bmp
ERASE : W_RUNTIMENV1
ERASE : MISC
CODE : tos-sign.bin
CODE : sml-sign.bin
UBOOT : u-boot-sign.bin
FSIMG : persist.img
Flashing finished!
Done!
Elapsed: 00:07:11
Old 09-11-2019, 11:28   #60171 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile X700 Pro MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 38 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100513832334D42009BAEF23DA3EF
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D42009BAEF23DA3EF
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395B072698E9FB885BD028231E9
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:12
Old 09-11-2019, 12:14   #60172 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile I6 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 38 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473165050730CB6C9DB3BF
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A4838473165050730CB6C9DB3BF
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F3950A89449D9101C4CE4C193DE5
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:14
Old 09-11-2019, 12:23   #60173 (permalink)
Member: 2233266
Thanks Meter: 158
samphony l90 flash done
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q64 : 0x00800000 [ 8MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00800000_FMT_BACK_129 5C5751B91_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:14
Old 09-11-2019, 13:14   #60174 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Qmobile e2 party hang on logo done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
Operation : Identify [ v1.04 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Device Info Details :
[0] : sc6533g_XS09_H1_Q
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_hs8292u
[5] : flsh_spi32m
[6] : nv3029e/nv3029g/nv3029h/st7789/gc9304c/gc9305/gc9306/gc9307/otm3208
[7] : bf3a01serial/gc6123/gc6133/sp0821
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
[11] : 2018-07-11_17:20:26
[12] : H1_Q_Qmobile_V01
inf_usb-dll:err [_usb_read_async] timeout error
Done!
Elapsed: 00:02:56
Operation : Reset Settings [ v1.04 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:55
Old 09-11-2019, 13:36   #60175 (permalink)
Member: 2233266
Thanks Meter: 158
walton mm21 formate done
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_087 D1260E745_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:14
Old 09-11-2019, 13:42   #60176 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Onice i touch m1 hang on logo done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 460001154D32584E4AD00142BF1146D0
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID : 150100464E58324D4201D04AD04654BF
DEV RID : 0x0B9C44DEAF68DD45AF3D49614EFFC744
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : ONICE
ProdName : ONICE_I-TOUCH_M1
ProdModel : i-touch M1
Device : ONICE_I-TOUCH_M1
AndroidVer: 7.0
MTKxCPU : MT6737M
MTKxPRJ : alps-mp-n0.mp1-V1.0.2_vz6737m.35.i.n_P46
Done!
Elapsed: 00:00:18
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:34
Old 09-11-2019, 15:48   #60177 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile Blue 5 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 38 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100513858534142068C59DC1232B1
[eMMC] : FLASH_INF : [SAMSUNG] , BASX8
[eMMC] : FLASH_CID : 150100513858534142068C59DC1232B1
DEV RID : 0xD9C8F395FFFB29A60A75BB870F00432B
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:48
Old 09-11-2019, 16:53   #60178 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,225
Lg g4 h818 frp remove done
HI
by
@mohand
gem flash
http://www.youtube.com/watch?v=b3IcBHosY1s&feature=*********
The Following User Says Thank You to profkefah For This Useful Post:
Old 09-12-2019, 05:55   #60179 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Oppo A37F Pattran Reset Done With King Infinity CM2
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 2448F744
ID_BLOCK_L : 41A3D925901E0B06E156BEA7603BBB93
ID_BLOCK_L : 0372DC6F60F35BE8EDC88D7A48A7B19A
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 537418296
Done!
Elapsed: 00:00:31
Old 09-12-2019, 06:00   #60180 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile I6i MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 38 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100464A32374D4202BDFFDC5CB231
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D4202BDFFDC5CB231
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3952154D2A575F9DD93CF17D796
EXT RAM : 0x30000000 [768 MiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:24
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.52286 seconds with 9 queries
