08-19-2019, 15:50 | #60181 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile x25 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : s4011 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040504A2AD9D32A7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040504A2AD9D32A7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0CF2E6DECEDC3CC71E6AF8387618B315 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s4011 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3562 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:07 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4011.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:49 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:52 Reconnect Power/Cable! |
08-19-2019, 16:26 | #60182 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A57 QLM FRP Reset Done With King Infinity CM2 Card found : A19EC787 , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : AA3E47F4 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : 4AE011AFE3819889F29CE246E1C88782 ID_BLOCK_L : EADD444DF8AE27B7768F5C4367364437 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
08-19-2019, 16:38 | #60183 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I8 MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6582 , Project : s4710 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 82 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040503A232F41235 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040503A232F41235 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395FBD22D59576E38C0A77F03A2 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s4710 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3685 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000001CEE00000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:04 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:01:23 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:49 Reconnect Power/Cable! |
08-20-2019, 09:08 | #60184 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Condor Infinity I4 MT6735 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 5400017031383242FA1D20361B8C33DA Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 6182B [eMMC] : FLASH_CID : 700100544232383136201DFADA33A51B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A8000000 [eMMC] : FLASH_UCP : 14976 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F3951098EA442136DE0B2C383C46 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
08-20-2019, 09:56 | #60185 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Manama Bahrain
Member: 1344255 Status: Offline Sonork: 1659066 Thanks Meter: 131 | Samsung J7 Pro Clone Logo Only Done by CM2 Samsung J7 Pro Clone Logo Only Done by CM2 Open CM2 Select Service Click Identify And Format / Rest Setting and Wait Code: Logs Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A3C892A0C9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3C892A0C9 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x53495E168A5880BE5862B966582FE387 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
The Following User Says Thank You to fertxter For This Useful Post: |
08-20-2019, 10:03 | #60186 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | VgoTel i700 Jumbo Read User Code Done Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 255 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : FF3EB118BB8B2288D37703B2CC5149AF BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 1928 PLock|MobTrack : Not active Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
08-20-2019, 11:27 | #60188 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | ZTE Blade A520 FRP reset done Use CM2MT2 Default boot Press and hold vol+ and vol- then connect cable Code: Operation : Reset Settings/Format FS [ v2.05 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM25) MODE : BOOTROM PORT : 25 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100464E58324D420679A6EE2789D9 DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 460001154D32584EA6790642D98927EE NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E58324D420679A6EE2714D9 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FNX2MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 27F60E9B876784A715A9C6373945359E STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM45) MODE : PRELOADER PORT PORT : 45 Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
08-20-2019, 12:21 | #60189 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Vgo tel i10 classic hang on logo done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] IMEI[1] : IMEI[2] : Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format FileSystem [ v1.04 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v1.1 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_006 6AB76D796_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
08-20-2019, 14:37 | #60190 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | LG Nexus 5X Flashing Done0000000 Code: Infinity-Box LG Service Tool [ LGS ] v1.03 Loading firmware ... FType : TOT file BB_Gen : QLM Model : H791 Version : LGH791AT-00-V10n-NXS-XXX-NOV-23-2015-32G-FACTORY SWInfo : userdebu File [0] : PrimaryGPT File [1] : modem File [2] : pmic File [3] : sbl1 File [4] : tz File [5] : sdi File [6] : hyp File [7] : rpm File [8] : aboot File [9] : sbl1bak File [10] : pmicbak File [11] : tzbak File [12] : hypbak File [13] : rpmbak File [14] : abootbak File [15] : sec File [16] : misc File [17] : persist File [18] : imgdata File [19] : laf File [20] : keymaster File [21] : cmnlib File [22] : keymasterbak File [23] : cmnlibbak File [24] : oem File [25] : boot File [26] : recovery File [27] : vendor File [28] : vendor File [29] : vendor File [30] : cache File [31] : system File [32] : system File [33] : system File [34] : system File [35] : system File [36] : system File [37] : system File [38] : system File [39] : system File [40] : system File [41] : system File [42] : system File [43] : system File [44] : system File [45] : system File [46] : system File [47] : system File [48] : system File [49] : system File [50] : system File [51] : system File [52] : system File [53] : system File [54] : system File [55] : system File [56] : system File [57] : system File [58] : system File [59] : system File [60] : system File [61] : system File [62] : userdata File [63] : userdata File [64] : userdata File [65] : userdata File [66] : userdata File [67] : userdata File [68] : userdata File [69] : userdata File [70] : userdata File [71] : userdata File [72] : userdata File [73] : userdata File [74] : userdata File [75] : userdata File [76] : userdata File [77] : userdata File [78] : userdata File [79] : userdata File [80] : userdata File [81] : userdata File [82] : userdata File [83] : userdata File [84] : userdata File [85] : userdata File [86] : userdata File [87] : userdata File [88] : userdata File [89] : userdata File [90] : userdata File [91] : userdata File [92] : userdata File [93] : userdata File [94] : userdata File [95] : userdata File [96] : userdata File [97] : userdata File [98] : userdata File [99] : userdata File [100] : userdata File [101] : userdata File [102] : userdata File [103] : userdata File [104] : userdata File [105] : userdata File [106] : userdata File [107] : userdata File [108] : userdata File [109] : userdata File [110] : userdata File [111] : userdata File [112] : userdata File [113] : userdata File [114] : userdata File [115] : userdata File [116] : userdata File [117] : userdata File [118] : userdata File [119] : userdata File [120] : userdata File [121] : userdata File [122] : userdata File [123] : userdata File [124] : userdata File [125] : userdata File [126] : userdata File [127] : userdata File [128] : userdata File [129] : userdata File [130] : userdata File [131] : userdata File [132] : userdata File [133] : userdata File [134] : userdata File [135] : userdata File [136] : userdata File [137] : userdata File [138] : userdata File [139] : userdata File [140] : userdata File [141] : userdata File [142] : userdata File [143] : userdata File [144] : userdata File [145] : userdata File [146] : userdata File [147] : userdata File [148] : userdata File [149] : userdata File [150] : userdata File [151] : userdata File [152] : userdata File [153] : userdata File [154] : userdata File [155] : userdata File [156] : userdata File [157] : userdata File [158] : userdata File [159] : BackupGPT Load Ok! Operation : Flash [ v1.03 ] Forced Flash : Disabled Factory Reset : Enabled 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! [INFO] : Low Battery level ignored by user request! Loading firmware Load ok! Checking compatibility Checking passed! Prepare device Prepare Passed! Secure prepare passed! Start flashing device Flash : PrimaryGPT Flash : modem Flash : pmic Flash : sbl1 Flash : tz Flash : sdi Flash : hyp Flash : rpm Flash : aboot Flash : sbl1bak Flash : pmicbak Flash : tzbak Flash : hypbak Flash : rpmbak Flash : abootbak Flash : sec Flash : misc Flash : persist Flash : imgdata Flash : laf Flash : keymaster Flash : cmnlib Flash : keymasterbak Flash : cmnlibbak Flash : oem Flash : boot Flash : recovery Flash : vendor Flash : vendor Flash : vendor Flash : cache Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : system Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : userdata Flash : BackupGPT Processing Post-Flashing tune Flash done! Reconnect Power/Cable! Done! Elapsed: 00:01:09 |
08-20-2019, 15:25 | #60191 (permalink) |
Registered User Join Date: Jan 2006 Location: Romania Age: 39
Member: 215866 Status: Offline Sonork: 100.1617874 Thanks Meter: 125 | iHunt Alien X FRP remove OK MediaTek Helio P60 Select Oppo F5 Operation : Reset Settings/Format FS [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Oppo : F5 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 150100444836444D42059913DA7D94BD EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A8763635644193F7480DBFA44C2B96F9 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:15 Reconnect Power/Cable! Last edited by nae; 08-20-2019 at 15:31. |
The Following User Says Thank You to nae For This Useful Post: |
08-20-2019, 15:31 | #60192 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile energy x2 reset frp done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4841473265050720CAF13CB371 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050720CAF13CB371 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x0B9C44DEE77CB6339F8D738A60930AC8 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
08-20-2019, 15:34 | #60193 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qmobile e100 party reset password done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.04 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Identify : Code Integrity Check pass! Device Info Details : [0] : SC6533 [1] : 8809 [2] : 8809e2 [3] : CT8851C [4] : pasw_hs8292u [5] : flsh_spi32m [6] : gc9102/gc9106/st7735r/HT2018 [7] : byd3A01/BF3A02/gc6123/gc6133/sp0820 [8] : rdabt_8809 [9] : rdafm_8809e [10] : release [11] : 2018-11-15_12:01:08 [12] : HA001_128160_ZYD_F6_QMOBILE_EnArPeUr_2IN1_R82809 inf_usb-dll:err [_usb_read_async] timeout error Done! Elapsed: 00:02:50 Reconnect Power/Cable! Operation : Reset Settings [ v1.04 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD inf_usb-dll:err [_usb_read_async] timeout error BOOT_INTV : * Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Preparing PMT Verifying PMT Erasing 1474560 bytes FileSystem format done! Done! Elapsed: 00:01:21 Reconnect Power/Cable! |
The Following User Says Thank You to A.G.Shahid For This Useful Post: |
08-20-2019, 15:36 | #60194 (permalink) |
Member: 215866 Status: Offline Sonork: 100.1617874 Thanks Meter: 125 | identify info Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Oppo : F5 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL_CRYPTO.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 150100444836444D42059913DA7D94BD EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0xE8F800000 [ 58,24 GB ] CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A8763635644193F7480DBFA44C2B96F9 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : iHunt_Alien_X_20181121 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-08-05 Build Time : 1542801998 Product Model : Alien_X Product Brand : iHunt Product Name : Alien_X Product Device : Alien_X Product Manfct : Vanzo Product Info : q610 Product Board : q610 Board Platform : mt6763 USERDATA : ENCRYPTED Done! Elapsed: 00:00:17 |
08-21-2019, 05:19 | #60195 (permalink) |
No Life Poster Join Date: Aug 2014
Member: 2233266 Status: Offline Thanks Meter: 252 | samphony g100 frp done PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : Wiko : SEC_6739 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 880103455042313030493AA96403A42D EMMC: VEN : FORESEE | OEM : 301 | DEV : EPB100 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1CE100000 [ 7.22 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D6A72B0E433A1B4F5BDA2BC2EA3153DD DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
