Old 09-14-2019, 17:03   #60376 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Lenovo c2 reset pin done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 514E011336394A32620210521BB2C816
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x13 , OEM : 014E
[eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2
[eMMC] : FLASH_CID : 13014E51324A39365210026216C8831B
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0xB9E2EB77DF6C7267D482078472DE225E
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:38
Reconnect Power/Cable!
Old 09-14-2019, 17:06   #60377 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Qmobile j5 reset pattern done by cm2
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 510001154D333238EC2F0042A59D7596
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D42002FEC9675A3A5
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x0CF2E6DEA2BD5BCB0570C52DE8B05C32
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:45
Old 09-14-2019, 17:18   #60378 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Qmobile l1 classic reset password done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ]
Operation : Identify [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:17
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0F9 532DBBBFB_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:21
Old 09-14-2019, 18:07   #60379 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Motorolla XT1254 FRP Reset Done With King Infinity CM2
Card found : A19EC787 , v0137
Infinity-Box Android Service Tool [AST] v1.03
Operation : Moto ADB Enable [ v1.03 ]
Mode : Enable ADB
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with : 192.168.137.2
Connected to device!
Device : XT1254
Switching to FACTORY ...
Setting Unsecure mode
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
1. Disconnect cable from device, wait device reboot
2. Make "Reset FRP"
3. Disable "FACTORY MODE" after operations done!
Done!
Elapsed: 00:00:35
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : quark_verizon
Model : XT1254
FRP reset passed! Make FACTORY RESET from menu!
-- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:13
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post:
Old 09-14-2019, 19:02   #60380 (permalink)
Member: 2906511
Thanks Meter: 67
oppo f5 read info and unlock password done by cm2mt2 14/9/2019
here is log
Operation : Identify [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM30)
MODE : BOOTROM
PORT : 30
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+ARB
BROM : BOOTROM
MODE : Oppo : F5 | Manual : Disabled
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001
BROM : SOCID : 33D064E401DB7229A6ECACAABCF42AD37B4666E6B141DEDCA0 FCD15A0F645FF4
BROM : SLA
BROM : SLA Passed!
BROM : SLA CHLNG not used
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL_CRYPTO.bin
AGENT : Found MT6763
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6763
EMI : SRC : preloader_oppo6763_17031.bin
EMI : CNT : 000F
EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ]
EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ]
EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ]
EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ]
EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ]
EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ]
EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ]
EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ]
EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 90014A484247346132A535DA8F884CF
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : BF8A6F3990F3D98365EB93379FB23A6
DA : USB : HIGH-SPEED
Boot done!
Patch Level : N6F26Q
Ver. CodeName : REL
Ver. Release : 7.1.1
Sec. Patch : 2019-08-05
Build Time : 1565771588
Product Manfct : OPPO
Board Platform : mt6763
Product Model : OPPO CPH1723
Product Brand : OPPO
Product Name : CPH1723
Product Device : M6763A
Product Board : full_oppo6763_17031
Product Info : oppo6763_17031
SW Version : A.38
SW OTA Version : M6763A_11.A.38_0380_201908141524
SW OTA Name : CPH1723EX_11_A.38_190814
Display ID : CPH1723EX_11_A.38_190814
Kernel Info : 4.4.22-G201908141524
USERDATA : ENCRYPTED
Done!
Elapsed: 00:01:28
Operation : Reset Settings/Format FS [ v2.06 ]
MODE : BOOTROM
PORT : 30
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 L0: 8005 0000 [0001] 00: 1012 0000 F3: 4001 0035 01: 102A 0001
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6763
EMI : CNT : 000F
EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Done!
Elapsed: 00:01:53
The Following User Says Thank You to safina gsm For This Useful Post:
Old 09-14-2019, 19:21   #60381 (permalink)
Member: 1984825
Thanks Meter: 100
Good job brother
Sent from my iPhone using Tapatalk
Old 09-15-2019, 05:48   #60382 (permalink)
Member: 2233266
Thanks Meter: 226
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_049 8421F832D_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:17
Old 09-15-2019, 07:26   #60383 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,730
Smile infinix X609 Format Done
PTFN : MediaTek PreLoader USB VCOM (Android) (COM264)
MODE : PRELOADER PORT
PORT : 264
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : MTK_AllInOne_DA_SP.bin
AGENT : Found MT6580
BROM : DA sent
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001154D3236454D030342B356D7CE
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 150100464536324D4203034DCED756B3
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB
EMMC:
USER : 0x3A3E00000 [ 14.56 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : F92D347F59CEE3ADF4B45A1CE42B8CF2
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
Boot done!
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:34
Old 09-15-2019, 07:27   #60384 (permalink)
Member: 953334
Sonork: 100.1614005
Smile VgoTel i800 Super Jumbo Read User Code Done
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 255 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CA02
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : D9CAC3A9F5134A81F88F5273CC9F21CD
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 4422
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:07
Old 09-15-2019, 14:07   #60385 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Qmobile s9 hang on logo done by cm2
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 90014A484147326505070012130DB3D3
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A484147326505070012130DB3D3
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395E2BF760203164671278F8048
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:23
Old 09-15-2019, 14:36   #60386 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Qmobile i6i reset frp done by cm2
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100464A32374D4202A965C4A8A2BB
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D4202A965C4A8A2BB
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x0B9C44DE9FD72B55E40A4525409474E2
EXT RAM : 0x30000000 [768 MiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : QMobile
ProdName : QMobile i6i
ProdModel : QMobile i6i
Device : QMobile
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2_TINNO6580.WE.L
MODEM :
BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P4_1_wg_n
EXTRA :
LCD : Not info available
LCD Res : 854x480
TOUCH [0] : ektf2k_s5222
TOUCH [1] : ft6336
CAM [0] : gc0310_mipi_yuv
CAM [1] : ov5670_mipi_raw_sunwin
CAM [2] : ov5670_mipi_raw_cmk
CAM [3] : gc2355_mipi_raw
MODEM : STOM_MODEM =s5030_hspa_modem_b18_pk_p4
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:09
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:26
Old 09-16-2019, 03:38   #60387 (permalink)
Member: 1872484
Thanks Meter: 11
MyPhone MYA16 FRP DONE BY CM2
Let me share you this MyPhone MYA16 FRP DONE BY CM2
I have no screenshots, maybe this video could help as our reference
http://www.youtube.com/watch?v=hpGYoq54Lh4
Please Subscribe
Hope it helps
BRB
Ang Panauhin
The Following User Says Thank You to Pepz19 For This Useful Post:
Old 09-16-2019, 07:36   #60388 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Mode : Enable ADB
Connect Ok!
Waiting ...
Device : XT1254
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
2. Make "Reset FRP"
Done!
Elapsed: 00:00:33
Connect Ok!
Model : XT1254
Done!
Elapsed: 00:00:12
Old 09-16-2019, 09:57   #60389 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Vgo tel v11 hang on logo done by cm2
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100513832334D4200A7D4AAB2C389
[eMMC] : FLASH_CID : 150100513832334D4200A7D4AAB2C389
DEV RID : 0xE6C52A7DE77EE10F86DA65FBAF316B0B
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:11
Old 09-16-2019, 11:05   #60390 (permalink)
ernie78's Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,712
mynx1 no service done
Open : S57MY_MYNX1_20181009_V1_08.pac
VER : BP_R1.0.0
LEN : 0x5B48E955
CPU : sp7731e_1h10
VER : S57MY_MYNX1_20181009_V1_08
Reading package ...
Read package finished!
Patch Level : OPM2.171019.012
Display ID : S57MY_MYNX1_20181009_V1.08
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-09-05
Build Time : 1539093200
Product Model : myNX1
Product Brand : MyPhone
Product Name : myNX1
Product Device : myNX1
Product Manfct : MyPhone
Product Info : te97_s57
Product Board : sp7731e_1h10
Board Platform : sp7731e
Operation : Flash Firmware [ v2.00r2 ]
Setting : Update NVRAM : False
Setting : Force NVRAM : False
Setting : Update PMT : True
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : PAC : S57MY_MYNX1_20181009_V1_08.pac
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
PMTMng : Load PMT
PMTMng : 0x1F
PMTMng : Update PMT Ok!
CODE : prodnv.img
ERASE : UBOOT
UBOOT : u-boot-spl-16k-sign.bin
CODE : vbmeta-sign.img
CODE : SC9600_pike2_pubcp_PLD_base_nv_modem.dat
CODE : pike2_pubcp_PLD_base_nv_deltanv.bin
CODE : PIKE2_DM_DSP.bin
CODE : pike2_cm4.bin
CODE : gnssmodem.bin
CODE : gnssbdmodem.bin
CODE : PM_pike2_cm4.bin
CODE : boot.img
CODE : recovery.img
FSIMG : system.img
FSIMG : userdata.img
CODE : logo.bmp
CODE : logo.bmp(1)
FSIMG : cache.img
FSIMG : vendor.img
ERASE : W_RUNTIMENV1
ERASE : MISC
CODE : tos-sign.bin
CODE : sml-sign.bin
UBOOT : u-boot-sign.bin
FSIMG : persist.img
Flashing finished!
Done!
Elapsed: 00:08:15
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.62050 seconds with 9 queries
