Old 09-16-2019, 12:30   #60391 (permalink)
Member: 714710
Sonork: offline
Thanks Meter: 1,014
Yuho uno frp done by cm2
Done!
Elapsed: 00:00:37
Operation : Format FS / Reset Settings [ v2.00r1 ]
Mode : Reset FRP
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Sedning Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sedning Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
Reconnect Power/Cable!
Done!
Elapsed: 00:01:50
The Following 2 Users Say Thank You to DHEERAJ_SHARMA For This Useful Post:
Old 09-16-2019, 13:57   #60392 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Oppo A37F FRP QLM Reset Done With King Infinity CM2
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 26102528
ID_BLOCK_L : BD473DD974E2EF1AC5BA5ABB84DF5777
ID_BLOCK_L : CBBA04A7A83BA320A51045B2B07F6952
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:34
Old 09-16-2019, 14:03   #60393 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
Scatter Load Ok , BaseBand : MT6582 , Project : mtk_android , Storage : EMMC
Files found : 10 , Set to Flash : 9
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004B3858564D42067A0AD45D91FF
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMVX8
[eMMC] : FLASH_CID : 1501004B3858564D42067A0AD45D91FF
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x277A235751A8321968466F22203B7158
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : mtk_android , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 4000 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 3
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000001000000-0x0000000000500000
Erase : 0x0000000002900000-0x00000003A0C00000
Flash Pre-Erase Done, time used : 00:00:10
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash Write Done, time used : 00:03:05
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Data Verify Done, time used : 00:01:03
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:39
Old 09-16-2019, 14:27   #60394 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile X25 MT6572 Dead Set Fix Done By Flashing With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Scatter Load Ok , BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
Files found : 17 , Set to Flash : 16
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 38 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A483447316404050FA2C7DAC115
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A483447316404050FA2C7DAC115
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F395DB4B39E2A1F47053CDF79088
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
BL : Skip checking by User request!
BL : BatteryLevel : 4117 mV
Total blocks to Erase : 1
Erase : 0x0000000000C00000-0x00000000E7B00000
Flash Pre-Erase Done, time used : 00:00:06
Preloader Download skipped by user request!
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : PRO_INFO
Image Flash Ok
Flash now : NVRAM
Image Flash Ok
Flash now : PROTECT_F
Image Flash Ok
Flash now : PROTECT_S
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : MISC
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EXPDB
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:09:34
Processing : Verify
Verify Passed : MBR
Verify Passed : PRO_INFO
Verify Passed : NVRAM
Verify Passed : PROTECT_F
Verify Passed : PROTECT_S
Verify Passed : MISC
Verify Passed : EXPDB
Verify Passed : USRDATA
Data Verify Done, time used : 00:02:25
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:12:26
Old 09-16-2019, 15:16   #60395 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 925
Huawei mya l22 reset frp done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D33314553B30D421DB7DDF2
DRAM configured from IDB!
DRAM size : 0x80000000
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420DB353F2DD841D
DEV RID : 0xB9E2EB77E68A3B3D1F62EDDF3E78564D
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:20
Old 09-16-2019, 16:00   #60396 (permalink)
Member: 2548908
Sonork: 100.1672479
Thanks Meter: 385
Itell P11 FRP Remove Done By CM2
==== Wait for phone...
Phone found! [ 4 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:25
Old 09-16-2019, 17:18   #60397 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 757
love to infinty cm2 ,2019 security done
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:30
qmobile i5i 2019 frp and format done thanks infintry team keep it more strong and give us more update
The Following User Says Thank You to ihsan.khan.gsm For This Useful Post:
Old 09-16-2019, 19:46   #60398 (permalink)
Member: 689942
Thanks Meter: 276
Successful Lenovo A2016b30 google account removal on Infinitybox
After trying via FRP Octopus, Via UMT MTK, and unsuccessfully at Miracle. I was able to delete Vibe lenovo's google account through Infinity's Chinese Miracle.
thank you very much.
The Following User Says Thank You to celltellpb For This Useful Post:
Old 09-16-2019, 21:06   #60399 (permalink)
Member: 689942
Thanks Meter: 276
Successful Alcatel 4034E google account removal on Infinitybox
I was able to delete Alcatel 4034E google account through Infinity's Chinese Miracle.
Old 09-17-2019, 09:15   #60400 (permalink)
Member: 2562097
Thanks Meter: 168
First in the World Huawei Y7 2019 Frp Removed By Cm2
The Following 3 Users Say Thank You to umera5zal008 For This Useful Post:
Old 09-17-2019, 10:18   #60401 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 925
Qmobile i6 matle one hang on logo done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Infinity SC Firmware Detected
FW Size : 2874 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : i6_Metal_ONE_new
Device CPU : i6_Metal_ONE
Device IntName : i6_Metal_ONE
Device Version : 6.0
Device Compile : 12/15/2016 10:31:38 AM
Device Project : MRA58K release-keys
Device ExtInfo : QMobile i6 Metal ONE
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 25 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x19 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:07:11
Old 09-17-2019, 19:04   #60402 (permalink)
raisalina's Avatar
Member: 1911970
Sonork: 9741081772
Thanks Meter: 1,744
Thumbs up vivo y91 1816 frp done cm2
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM86)
MODE : PRELOADER PORT
PORT : 86
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : PRELOADER PORT
MODE : Vivo : Y91 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL_MT6765_S00.bin
AGENT : Found MT6765
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00040000 [ 256.00 KB ]
        DRAM: 0x20000000 [ 512.00 MB ]
        EMMC: 150100514436334D420187B89B5026EF
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QD63MB
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x01000000 [ 16.00 MB ]
              USER   : 0x747C00000 [ 29.12 GB ]
        CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 597DB33BC7652609FF9F8D11BEFA2D32
DA : USB : HIGH-SPEED
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:20
http://www.youtube.com/watch?v=IqRhnI0fR_M
The Following 2 Users Say Thank You to raisalina For This Useful Post:
Old 09-17-2019, 19:24   #60403 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,427
Infinix X627 Frp Reset
Patch Level    : PPR1.180610.011
Display ID     : X627-H624STXYZAa-P-190619V232
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-06-05
Build Time     : 1560938743
Product Model  : Infinix X627
Product Brand  : Infinix
Product Name   : H624
Product Device : Infinix-X627STU
Product Manfct : INFINIX MOBILITY LIMITED
Product Info   : x627_h624
Product Board  : Infinix-X627
Board Platform : mt6761
USERDATA : ENCRYPTED
Done!
Elapsed: 00:00:28
Operation : Reset Settings/Format FS [ v2.06 ]
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM11)
PORT : 11
BROM : Init BROM
BROM init passed!
     CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6761
BROM : DA sent
     DA : AGENT started!
DA : SYNC
        DRAM: 0x80000000 [ 2.00 GB ]
        EMMC: 7001005441323833322327AC209666AF
        EMMC: VEN : KINGSTON | OEM : 01 | DEV : TA2832
        EMMC:
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x74A000000 [ 29.16 GB ]
        CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 4F1AE200DA0AA2CBBB19B775283AAE86
Boot done!
Done!
Elapsed: 00:00:28
The Following User Says Thank You to Tanha0321 For This Useful Post:
Old 09-18-2019, 06:40   #60404 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 925
Qmobile k100 reset password done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : C000 : NOR : [ 4MB-8MB ]
Operation : Format FileSystem [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_189 4C61028ED_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:23
Old 09-18-2019, 06:47   #60405 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 925
Qmobile q12 hang on logo done by cm2
SCRD mode : AUTO
SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ]
Operation : Identify [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:21
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1D8 410BB9F09_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:19
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.86393 seconds with 9 queries
