Old 10-18-2019, 06:36   #60751 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,045
Infinix X521 Frp Remove Done
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 81 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505072B900A7124FB
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505072B900A7124FB
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x0386520DAEDCD8B391BC70C36F0B69E7
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:10
Reconnect Power/Cable!
Old 10-18-2019, 06:37   #60752 (permalink)
Member: 1080718
Thanks Meter: 2,045
Wait for phone...
Phone found! [ 81 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:37
Old 10-18-2019, 06:37   #60753 (permalink)
Member: 1080718
Thanks Meter: 2,045
Operation : Format FileSystem [ v1.03 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_106 7E4A5C27F_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:15
Old 10-18-2019, 07:17   #60754 (permalink)
djmurod86's Avatar
Member: 455852
Sonork: 100.1596308
Thanks Meter: 1,072
Operation : SP Unlock [ v1.58 ]
Mode : Direct Unlock
Wait for phone...
Phone found! [ 104 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 484A0190653147381B2A0705496187AD
[eMMC] : FLASH_CID : 90014A483847316505072A1BAD871349
DEV RID : 0x3B686A1606A79AB5936F727305986EE0
SOC VERIFY : C1
Boot Ok!
SIM Lock Status : Locked!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:41
The Following User Says Thank You to djmurod86 For This Useful Post:
Old 10-18-2019, 10:52   #60755 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 891
Vgo tel i8 reset password done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : AA04E1066E3F1B5BC148DAE91B6EE036
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:12
Old 10-18-2019, 14:55   #60756 (permalink)
CYB3R GSM's Avatar
Member: 2469611
Thanks Meter: 329
MT6580__QTab__V7_Metal__8.1.0__QTab_V7_Metal_MP_15 112018__O11019__tb8321p2_bsp
Patch Level    : O11019
Display ID     : QTab_V7_Metal_MP_15112018
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2018-09-05
Build Time     : 1542335039
Product Model  : V7_Metal
Product Brand  : QTab
Product Name   : V7_Metal
Product Device : V7_Metal
Product Manfct : QTab
Product Info   : tb8321p2_bsp
Product Board  : tb8321p2_bsp
Board Platform : mt6580
MT6580__QTab__V7_Metal__8.1.0__QTab_V7_Metal_MP_15112018__O11019__tb8321p2_bsp
SecureDevice : Plain
Read : preloader.bin
Read : proinfo.img
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : recovery.img
Read : logo.bin
Read : odmdtbo.img
Read : vendor.img
ExtSparse : Compression ratio : 72%
Read : tz.img
Read : secro.img
Read : system.img
ExtSparse : Compression ratio : 24%
Read : cache.img
Read : userdata.img
FW Size  : 1.26 GB
Android Info saved : _Android_info.txt
Scatter  : MT6580_Android_scatter.txt
Saved to : C:\InfinityBox\CM2MT2\Flash\MT6580__QTab__V7_Metal__8.1.0__QTab_V7_Metal_MP_15112018__O11019__tb8321p2_bsp\
Done!
Elapsed: 00:07:33
Old 10-18-2019, 17:22   #60757 (permalink)
Member: 2897012
Sonork: MTK81
Thanks Meter: 99
Logicom LeMoov Pin,Frp Look Remove done
Operation : Identify [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM146)
MODE : PRELOADER PORT
PORT : 146
Waiting BOOT ack ...
PRELOADER : ACK confirm FAIL!
BROM : Init BROM
BROM init passed!
     CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : Wiko : SEC_6739 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL.bin
AGENT : Found MT6739
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00040000 [ 256,00 KB ]
        DRAM: 0x40000000 [ 1,00 GB ]
        EMMC: 8801034E436172642016573EE72F45F9
        EMMC: VEN : FORESEE | OEM : 301 | DEV : NCard
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x1D2000000 [ 7,28 GB ]
        CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : C6B3599B704A006DF4EFEF47AEB038AC
DA : USB : HIGH-SPEED
Boot done!
Display ID     : LOGICOM_LeMoov_HW01_SW12
Ver. CodeName  : REL
Sec. Patch     : 2018-05-05
Build Time     : 1527840792
Product Model  : LeMoov
Product Brand  : Logicom
Product Name   : LeMoov
Product Device : LeMoov
Product Manfct : Logicom
Product Info   : LeMoov
Product Board  : LeMoov
Board Platform : mt6739
USERDATA : ENCRYPTED
Backup sensetive data [ 10 ]
Backup path : Backup\MT6739__C6B3599B704A006DF4EFEF47AEB038AC\
[21] Read : NVRAM
[8] Read : NVDATA
[14] Read : PROINFO
[22] Read : LK
[7] Read : NVCFG
[10] Read : PROTECT1
[11] Read : PROTECT2
[0] Read : PRELOADER
Backup done!
Done!
Operation : Reset Settings/Format FS [ v2.06 ]
PORT : 146
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
AGENT : DA_PL.bin
BROM : DA sent
     DA : AGENT started!
DA : SYNC
        EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:53
The Following User Says Thank You to Manikanika81 For This Useful Post:
Old 10-19-2019, 06:53   #60758 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 891
Qmobile l1 classic hang on logo done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ]
Operation : Identify [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:17
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0F9 532DBBBFB_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:21
Old 10-19-2019, 07:39   #60759 (permalink)
Member: 1080718
Thanks Meter: 2,045
Operation : Read UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 38 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : F995056BB31044CD6E87DF271D91997A
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 9999
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:41
Old 10-19-2019, 07:40   #60760 (permalink)
Member: 1080718
Thanks Meter: 2,045
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 38 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Reading Flash Content now ...
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
File_Info : RDR61D_F118_PCB01_gprs_MT6261_S00.VGOTEL_VMATE_I52 5_V06.bin
FileVersion : VGOTEL_VMATE_i525_V06
Saved to : C:\InfinityBox\CM2MTK\Read_out\RDR61D_F118_PCB01_g prs_MT6261_S00.VGOTEL_VMATE_I525_V06.bin
Done!
Elapsed: 00:00:28
Old 10-19-2019, 07:42   #60761 (permalink)
Member: 1080718
Thanks Meter: 2,045
Lenovo A319 Restart Prob DOne With Great Cm2
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 81 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A483447326111013D9AACBA82FD
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111013D9AACBA82FD
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x0386520DC4FA2401927C3E5E061FDBE1
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3842 mV
BL : BatteryLevel Ok
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:05:46
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:04
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:06:01
Old 10-19-2019, 07:43   #60762 (permalink)
Member: 1080718
Thanks Meter: 2,045
QMobile_ENERGY_X2 Read FFW Done With Great Cm2
Wait for phone...
Phone found! [ 37 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4841473265050707BB7402B3F5
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A4841473265050707BB7402B3F5
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0x0386520DAA0F53D7EAC9EFD4D7C7AF54
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
xGPT : Normalize settings Ok!
Brand : QMobile
ProdName : ENERGY_X2
ProdModel : QMobile ENERGY X2
Device : ENERGY_X2
AndroidVer: 6.0
MTKxCPU : MT6580
MTKxPRJ : ALPS.W10.24.p0
[Read Ok] : preloader_v3800.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6580 / V1.1.2 / v3800 / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 2870 MiB
Scatter saved to : C:\Users\Waris Gsm\Desktop\MT6580__QMobile__QMobile_ENERGY_X2__EN ERGY_X2__6.0__ALPS.W10.24.p0\
All done!
Done!
Elapsed: 00:12:11
The Following User Says Thank You to Nadeem Waris For This Useful Post:
Old 10-19-2019, 07:45   #60763 (permalink)
Member: 1080718
Thanks Meter: 2,045
QMobile_ENERGY_X2 Format Done With Great Cm2
Wait for phone...
Phone found! [ 37 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:53
Old 10-19-2019, 07:46   #60764 (permalink)
Member: 1080718
Thanks Meter: 2,045
Wait for phone...
Phone found! [ 233 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : AFD421509A0B4AF85EF9CE207CBB56B9
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_LEN : 0x00300000
SDS_INFO : 0x002FE000 , 0x00002000
Read ExtData
Sorting ExtData
Reading UserCode
Active : No , Code : 7562
Privacy Lock :W
Done!
Elapsed: 00:00:04
Old 10-19-2019, 10:08   #60765 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 891
Gfive crown hang on logo done by cm2
SCRD mode : AUTO
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Done!
Elapsed: 00:00:15
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_069 27B6CA25E_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:19
Operation : Read Flash [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Read Ok, 4194304 bytes
Saved to : G:\Mix Flash File\0E9B558DB5A8_SPRD_SPI_WINBOND_W25Q_4MiB.bin
Done!
Elapsed: 00:00:43
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.47747 seconds with 9 queries
