Old 11-06-2019, 15:01   #61081 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Vgotel ocean9l reset frp done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC983x] eMMC [Generic Android 7.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 26 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC983x eMMC Loader v5.0 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:32
Reconnect Power/Cable!
Old 11-06-2019, 15:03   #61082 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Qmobile i6 metal 2018 7731e reset frp dome by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r2
Operation : Format FS / Reset Settings [ v2.00r2 ]
Mode : Default [ Reset Settings + FRP ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Sedning Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sedning Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:42
Old 11-06-2019, 15:05   #61083 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Moto e4 reset frp done by cm2
Infinity-Box Android Service Tool [AST] v1.03
Operation : Identify [ v1.03 ]
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Main Info ============
CPU : MSM8917
CID : 0x0002
IMEI :
UID : 67BB730800000000000000000000
Model Info ============
DevModel : XT1767
IntName : perry
SW Info ============
DevSWVer : Blur_Version.26.271.1.perry_verizon.verizon.en.US
DevQCVer : LA.UM.5.6.r1-03800-89xx.0
BaseBand : M8917_16000.269.04.03.02R PERRY_NA_CUST
BootLDRv : moto-msm8917-BA.33
HW Info ============
eMMCInfo : 16GB SAMSUNG QE63MB RV=08 PV=03 FV=0000000000000003
DRAMInfo : 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=06 M7=00 M8=1F
Lock Info ============
WarrantyVoid : no
FRP Lock : protected (77)
Done!
Elapsed: 00:00:04
Operation : Moto ADB Enable [ v1.03 ]
Mode : Enable Factory
Connect Ok!
Operation done!
-- > Info : Wait till device boot, make "Enable ADB" operation after
-- > Info : Don't forget DISABLE "FACTORY MODE" after make "RESET FRP"!
Done!
Elapsed: 00:00:04
Mode : Enable ADB
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with : 192.168.137.2
Connected to device!
Device : XT1767
Switching to FACTORY ...
Setting Unsecure mode
Waiting device ...
Connect Ok!
Device : XT1767
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1767
Setting ADB ...
1. Disconnect cable from device, wait device reboot
2. Make "Reset FRP"
3. Disable "FACTORY MODE" after operations done!
Done!
Elapsed: 00:00:58
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : perry_verizon_f
Model : Moto E (4)
FRP reset passed! Make FACTORY RESET from menu!
-- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:12
Mode : Disable Factory
Connect Ok!
Operation done!
Done!
Elapsed: 00:00:04
Old 11-06-2019, 16:54   #61084 (permalink)
Member: 2897012
Sonork: MTK81
Thanks Meter: 155
Wiko tommy 2 plus frp remove done by cm2
Operation : Identify [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 425 [MSM8917]
ID_BLOCK_S : D0264190
ID_BLOCK_E : 00007705
ID_BLOCK_L : 7415AAD2B6BFD3BC40CBF1CD27C05DA6
ID_BLOCK_L : 7CB658274EFE3C74AB77ED5FE788383E
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000390000000 [ eMMC 16 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x70 , VENDOR : KINGSTON , NAME : EHAEE8
Boot Ok!
Brand     : WIKO
ProdName  : v3941
ProdModel : Tommy2 Plus
Device    : v3941
AndroidVer: 7.1.1
Manufact. : Tommy2 Plus
SysPatch  : NMF26F
DevComTime: 28/08/2017 02:37:09
QLMxCPU   : MSM8937
USERData : NORMAL
GCSec    : NORMAL
Done!
Elapsed: 00:00:38
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:41
The Following 2 Users Say Thank You to Manikanika81 For This Useful Post:
Old 11-07-2019, 06:00   #61085 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile I8i SPD77XX FRP Reset Done With King Infinity CM2
Card found: S/N : A19EC787 , v0138
Set mode to : SP [SC773x] eMMC [Android 6.x]
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:26
Old 11-07-2019, 06:38   #61086 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 610
Qmobile dabang power read flash file and format done
Operation : Read Flash [ v1.05 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v2.0 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Read Flash Ok, Size : 4.00 MiB
QMobile_Dabang Power_V06_20190228
Project Version: SC6531EFM_BAR
MMI Version: SC6531EFM_BAR
BASE Version: BASE_SVN
HW Version: SC6531EFM_BAR
02-28-2019 15:46:27
LOG Version: V1.0.1
Saved to : C:\Users\Luckey1\Desktop\QMobile_Dabang Power_V06_20190228.bin
Done!
Elapsed: 00:00:39
Operation : Format FileSystem [ v1.05 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_196 BD25AA9D5_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:22
The Following User Says Thank You to Luckey1 For This Useful Post:
Old 11-07-2019, 07:05   #61087 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Qmobile e5 classic hang on logo done by cm2
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
Operation : Reset Settings [ v1.04 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00200000
BOOT_INIT : 0x2D717F15
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:50
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 11-07-2019, 10:23   #61088 (permalink)
Member: 2431049
Sonork: 100.1680262:hunnyck
Thanks Meter: 870
Nokia TA-1010 Flash done
Card found : 8494CDF4 , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.10
Open VPLfile : TA-1010_059Z1B8_20.14.11.vpl
Description : TA-1010 MH
DeviceType : TA-1010
ProductCode : 059Z1B8
SoftwareVer : 20.14.11
PPM LangPack :
[1] : Gujarati (India)
[2] : Kannada (India)
[3] : Marathi (India)
[4] : Telugu (India)
[5] : Punjabi (India)
[6] : Tamil (India)
[7] : Hindi (India)
[8] : Urdu (Islamic Republic of Pakistan)
[9] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.10 ]
Setting : UserData erase : True
Setting : LangPack Only : False
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM153)
MODE : NOKIA USB SERIAL
PORT : 153
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 535440B0963727D6EA18B66360DC895B
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : N103.30.04.11.p1
BOOT : SWR : 30.04.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : N103.30.04.11.p1
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00C8 : 0060 : 0016 : 0000
NOR: [GigaDevice] GD25LQ32
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
VPL SoftwareVersion : 20.14.11 [TA-1010]
DEV SoftwareVersion : 30.04.11
SWInfo compare result : VPL SW ( Major version ) is LOWER, than in DEVICE!
Load FlashSet :
MROM : TA-1010_ROM_eMP_20.14.11
LANG : TA-1010_LANG_PACK_ROM_MH_eMP_20.14.11_001
CUST : TA-1010_CUSTPACK_ROM_MH_eMP_20.14.11_001
JUMP : TA-1010_JUMP_TABLE_MH_eMP_20.14.11_001
VIVA : TA-1010_VIVA_eMP_20.14.11
Prepare FlashSet :
DCR : TA-1010_ROM_eMP_20.14.11
DCR : TA-1010_LANG_PACK_ROM_MH_eMP_20.14.11_001
DCR : TA-1010_CUSTPACK_ROM_MH_eMP_20.14.11_001
DCR : TA-1010_JUMP_TABLE_MH_eMP_20.14.11_001
DCR : TA-1010_VIVA_eMP_20.14.11
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1010_ROM_eMP_20.14.11
Write : TA-1010_LANG_PACK_ROM_MH_eMP_20.14.11_001
Write : TA-1010_CUSTPACK_ROM_MH_eMP_20.14.11_001
Write : TA-1010_JUMP_TABLE_MH_eMP_20.14.11_001
Write : TA-1010_VIVA_eMP_20.14.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1010_ROM_eMP_20.14.11
Verify : TA-1010_LANG_PACK_ROM_MH_eMP_20.14.11_001
Verify : TA-1010_CUSTPACK_ROM_MH_eMP_20.14.11_001
Verify : TA-1010_JUMP_TABLE_MH_eMP_20.14.11_001
Verify : TA-1010_VIVA_eMP_20.14.11
Done!
Elapsed: 00:02:26
The Following User Says Thank You to hunnyck For This Useful Post:
Old 11-07-2019, 11:08   #61089 (permalink)
bhalaygilani's Avatar
Member: 1647864
Thanks Meter: 62
q mobile i8i pro fromat done with cm2spd 1.27
Log is here
Set mode to : SP [SC773x] eMMC [Android 7.x]
3. Insert cable
Phone found! [ 15 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:28
Old 11-07-2019, 11:12   #61090 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile X11 MT6572 Logo Stuck Fix Only Flashing With King Infinity CM2
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040503A2677FB19F
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040503A2677FB19F
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F39518121D3587852B62AFC3636B
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3856 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 1
Erase : 0x0000000000C00000-0x00000000E7B00000
Flash Pre-Erase Done, time used : 00:00:04
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : PRO_INFO
Image Flash Ok
Flash now : NVRAM
Image Flash Ok
Flash now : PROTECT_F
Image Flash Ok
Flash now : PROTECT_S
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : MISC
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EXPDB
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:09:11
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : PRO_INFO
Verify Passed : NVRAM
Verify Passed : PROTECT_F
Verify Passed : PROTECT_S
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : MISC
Verify Passed : LOGO
Verify Passed : EXPDB
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:02:23
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:12:02
Old 11-07-2019, 11:39   #61091 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Vgo tel v11 hang on logo done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100513832334D4200A7D4AAB2C389
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D4200A7D4AAB2C389
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xE6C52A7DE77EE10F86DA65FBAF316B0B
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:11
Old 11-07-2019, 11:44   #61092 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Qmobile xli reset pattern done by cm2
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : BQru : BQ-5002G
Sending Init Boot ...
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:59
Old 11-07-2019, 16:31   #61093 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,424
GFIVE Fire Dead Recaver
SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ]
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0F755BBF4881_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:01:16
Old 11-07-2019, 17:43   #61094 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,424
Nokia 3 Frp Reset
Brand     : Unknown
ProdName  : Unknown
ProdModel : Heart
Device    : Unknown
AndroidVer: 8.0.0
MTKxCPU   : MT6737M
MTKxPRJ   : alps-mp-o0.mp1-V3.47_k37mv1.64_P10
Done!
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
SecCfgVal : 0x05000000
BromVer   : 0x00FF
BLVersion : 0x0002
BootLdrSS : LOCKED with CERT
Processing DA stage
DA Select done, will use SecMode DA
Running DA ver.4.2 on BBID : 0x9B
eMMC Flash : 514E011336394A32C205105207C51537
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0x13 , OEM : 014E
[eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2
[eMMC] : FLASH_CID : 13014E51324A3936521005C237154407
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID    : 0xD5229C2567937E9951BC55ECDD109F3B
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:14
Old 11-07-2019, 20:33   #61095 (permalink)
Member: 87188
Thanks Meter: 202
Doogee MIX FRP succeeded!
Chinese Miracle2 MTK 2.06 Select only Custom DA: http://mark1.uw.hu/DA_PL.rar
(rar will unpack.)
Operation : Reset Settings/Format FS [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
PTFN : MediaTek PreLoader USB VCOM (Android) (COM28)
MODE : PRELOADER PORT
PORT : 28
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000001
BROM : SecMode : SBC
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : DA_PL.bin
AGENT : Found MT6757
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 90014A484347386134A202163801644F
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HCG8a4
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000
RNID : 69904FC6EFAB7F121CCC5FDCA932CA8B
DA : USB : HIGH-SPEED
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:20
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.94429 seconds with 9 queries
