11-12-2019, 18:32 | #61216 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile X900 Flash Code: Brand : QMobile ProdName : QMobile X900 ProdModel : QMobile X900 Device : QMobile AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : QMobileX900_MP_LOW_2014_1104 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6592 , Project : eastaeon92_wet_kk , Storage : EMMC Files found : 12 , Set to Flash : 11 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : QMobile Device CPU : MT6592 Device IntName : QMobile X900 Device Version : 4.4.2 Device Compile : 5/29/2015 3:04:12 AM Device Project : QMobileX900_MP_2015_0310 Device ExtInfo : QMobile X900 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040503A2B5A39149 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040503A2B5A39149 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD5229C25C16C870F8766D952FD0E9812 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : eastaeon92_wet_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3910 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x00000001CE300000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:52 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:27 Reconnect Power/Cable! |
11-12-2019, 21:00 | #61217 (permalink) |
No Life Poster Join Date: Mar 2016 Location: IN THE KERNEL
Member: 2545468 Status: Offline Thanks Meter: 234 | Pattern cleaning + google account cleaning + 100% CM2SP2 software copy Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.02 Load IDBase v10107 Ok! Operation : Identify [ v2.02 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.02 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : I940B_IPRO_CO_V02_20190115 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-01-05 Build Time : 1547541136 Product Model : Opal 4S Product Brand : IPRO Product Name : Opal4S Product Device : Opal4S Product Manfct : IPRO Product Info : te4b_zk940b Product Board : Opal4S Board Platform : sp7731e Update DataBase ... Platform Version: MOCORTM_17C_W18.23.4_P12_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.23.4_P12 HW Version: sc7731e_modem CMP_Time : 11-12-2018 20:40:47 MODEM TAG : MOCORTM_17C_W18.23.4_P12_Debug_FM_BASE_17C_W18.23. 4_P12_sc7731e_modem_pike2_pub UserData : STATE : PLAIN Done! Elapsed: 00:02:38 Operation : Read PrivacyLock [ v2.02 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PLLock : NOT found or NOT set! Reconnect Power/Cable! Done! Elapsed: 00:01:10 Operation : Read FW [ v2.02 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : I940B_IPRO_CO_V02_20190115 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-01-05 Build Time : 1547541136 Product Model : Opal 4S Product Brand : IPRO Product Name : Opal4S Product Device : Opal4S Product Manfct : IPRO Product Info : te4b_zk940b Product Board : Opal4S Board Platform : sp7731e VlnrLevel : 0x00 SP7731E__IPRO__Opal_4S__8.1.0__I940B_IPRO_CO_V02_2 0190115__OPM2.171019.012__te4b_zk940b Read : prodnv.img ExtSparse : Compression ratio : 50% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_w.bin Make : persist.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : modem_wcn.img Read : modem_w.bin Read : deltanv_w.bin Read : gdsp_w.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 76% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 49% Read : vbmeta.img Make : userdata.img Read : u-boot-spl.bin Firmware size : 0x50E596A4 ( 1,26 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:35:35 Operation : Format FS / Reset Settings [ v2.02 ] Mode : Default [ Reset Settings + FRP ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:15 |
The Following User Says Thank You to jrbravo For This Useful Post: |
11-13-2019, 09:14 | #61219 (permalink) | |
Freak Poster Join Date: May 2016 Location: chitral drosh pakistan
Member: 2568942 Status: Offline Sonork: no id Thanks Meter: 9 | Quote:
11-13-2019, 09:42 | #61220 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Inside
Member: 455852 Status: Offline Sonork: 100.1596308 Thanks Meter: 1,992 | TELE 2 LTE Unlock OK Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 5600017030303031C811503859534CD5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 7001005631303030385011C8D54C8359 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB] DEV RID : 0x3B686A1682FD8EA406828720688ABAC4 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SIM Lock Status : Locked! Unlocking now ... Unlock done! Done! Elapsed: 00:01:05 Reconnect Power/Cable! |
11-13-2019, 13:31 | #61221 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | OALE x1 Format Done OALE x1 Format Done Operation : Reset Settings/Format FS [ v2.06 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM264) MODE : PRELOADER PORT PORT : 264 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 30000115564E433004150130CB811408 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 1501003030434E563001150481481CB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : 00CNV0 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : F24918E694F78976C9013735E689F4D1 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:35 |
11-13-2019, 13:33 | #61222 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | VgoTel i252 Read User Code Done VgoTel i252 Read User Code Done Operation : Read UserCode [ v1.58 ]
Phone found! [ 255 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 7DB2424E780055328BC5D6CD4257950D BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32 [0] : FLASH_DIE : 00C8 0060 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 7861 PLock|MobTrack : Not active Done! Elapsed: 00:00:04 Reconnect Power/Cable! |
11-13-2019, 13:57 | #61223 (permalink) |
Freak Poster Join Date: Nov 2019 Location: Narowal
Member: 2935044 Status: Offline Thanks Meter: 75 | Infinix Hot S Pin+FRP Reset Done By 1 Click With CM2 Infinix Hot S Pin+FRP Reset Done By 1 Click With CM2 Here are Logs <a href='https://postimages.org/' target='_blank'><img src='https://i.postimg.cc/DZr9cSmy/Infinix-Hot-S-Pin-FRP-Reset-Done-By-1-Click-With-CM2.png' border='0' alt='Infinix-Hot-S-Pin-FRP-Reset-Done-By-1-Click-With-CM2'/></a><br /><a href='https://postimages.org/'>upload images for forums</a><br /> Youtube Link https://www.youtube.com/watch?v=iGbihtXqzxE |
The Following User Says Thank You to AAdnan Mobile For This Useful Post: |
11-13-2019, 14:01 | #61224 (permalink) |
Member: 2935044 Status: Offline Thanks Meter: 75 | LAVA iris 702 Pin+FRP Reset Done By 1 Click With CM2 LAVA iris 702 Pin+FRP Reset Done By 1 Click With CM2 Here are Logs <a href='https://postimages.org/' target='_blank'><img src='https://i.postimg.cc/VNqwKGV8/LAVA-iris-702-Pin-FRP-Reset-Done-By-1-Click-With-CM2.png' border='0' alt='LAVA-iris-702-Pin-FRP-Reset-Done-By-1-Click-With-CM2'/></a> Youtube Link https://www.youtube.com/watch?v=GtkrNCtHQu0 |
11-13-2019, 14:04 | #61225 (permalink) |
Member: 2935044 Status: Offline Thanks Meter: 75 | Lava iris 820 Format+FRP Reset Done By 1 Click With CM2 Lava iris 820 Format+FRP Reset Done By 1 Click With CM2 Here are Logs <a href='https://postimages.org/' target='_blank'><img src='https://i.postimg.cc/dVmvBNXK/Lava-iris-820-Format-FRP-Reset-Done-By-1-Click-With-CM2.png' border='0' alt='Lava-iris-820-Format-FRP-Reset-Done-By-1-Click-With-CM2'/></a><br /><a href='https://postimages.org/'>free web image hosting</a><br /> Youtube Link https://www.youtube.com/watch?v=J0Qh7XX86A4 |
11-13-2019, 14:06 | #61226 (permalink) |
Member: 2935044 Status: Offline Thanks Meter: 75 | Nokia TA-1047 Pin+FRP Reset Done By 1 Click With CM2 Nokia TA-1047 Pin+FRP Reset Done By 1 Click With CM2 Here are Logs <a href='https://postimages.org/' target='_blank'><img src='https://i.postimg.cc/YqXCgC4w/Nokia-TA-1047-Pin-FRP-Reset-Done-By-1-Click-With-CM2.png' border='0' alt='Nokia-TA-1047-Pin-FRP-Reset-Done-By-1-Click-With-CM2'/></a> Youtube Link https://www.youtube.com/watch?v=_Rsk-qG9o7o |
11-13-2019, 16:59 | #61227 (permalink) |
Freak Poster Join Date: Sep 2005 Location: pakistan Age: 43
Member: 180340 Status: Offline Thanks Meter: 36 | ZTE T610 Firmware read done Card found : D7E67166 , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0554324B ID_BLOCK_L : A3FEC0BF52A6948FFCDD201063575409 ID_BLOCK_L : 44B1EAB11809BFBA57479954B74349C9 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : ZTE ProdName : P809A20 ProdModel : ZTE T610 Device : P809A20 AndroidVer: 5.1.1 Manufact. : ZTE QLMxCPU : MSM8909 DevInfo : MSM8909__ZTE__ZTE__ANDR_v5.1.1__ZTE_T610__P809A20_ _P809A20 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin [Read Ok] : gpt_main2.bin [Read Ok] : cdt.mbn [Read Ok] : gpt_backup2.bin Android Info saved! Read finished! Configuration : MSM8909 / eMMC Firmware Size : 1513 MiB Done! Elapsed: 00:04:43 Reconnect Power/Cable! |
The Following User Says Thank You to israrge For This Useful Post: |
11-13-2019, 19:01 | #61228 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile S2_Pro Frp Code: Brand : QMobile ProdName : S2_Pro ProdModel : S2 Pro Device : S2_Pro AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : ALPS.W10.24.p0 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D42007CC4C61F63B9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D42007CC4C61F63B9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C25E12780378592E5BD2105A934 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
11-13-2019, 19:05 | #61229 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | QMobile A9 Flash Code: Brand : QMobile ProdName : A9 ProdModel : A9 Device : A9 AndroidVer: 4.0.4 MTKxCPU : MT6577 MTKxPRJ : ALPS.ICS2.MP.V1 Done! Elapsed: 00:00:11 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x0F WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594815A175D0ABBF41 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD5229C253011EFC66936B5D26AAD2294 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : Old Dedvice , skip BatteryLevel check BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000008000 Erase : 0x0000000000F28000-0x00000000873C0000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:15 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:35 Reconnect Power/Cable! |
11-13-2019, 19:06 | #61230 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Infinix HOT 4 Frp Reset Code: Brand : Infinix ProdName : X557A1 ProdModel : Infinix HOT 4 Device : X557 AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : X557-H807AD-N-190220V181 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 11 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D420D7E65A8383483 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420D7E65A8383483 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD5229C2538F6415CC6DC95764C0D464A INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
