Old 12-03-2019, 13:07   #61366 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile S6 MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0138
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 33 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4841473265050702C7147573EF
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A4841473265050702C7147573EF
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395268CDE7659A8773203953F4B
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:23
Reconnect Power/Cable!
Old 12-03-2019, 15:49   #61367 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
QMobile Black Two Frp
Device info :
Patch Level    : MRA58K
Display ID     : QMobile BlackTwo_MP_07_05
Ver. CodeName  : REL
Ver. Release   : 6.0
Sec. Patch     : 2017-03-05
Build Time     : 1525669287
Product Model  : QMobile Black Two
Product Brand  : QMobile
Product Name   : Black_Two
Product Device : Black_Two
Product Board  : sp7731cea
Product Manfct : QMobile
Board Platform : sc8830
Product Info   : Black_Two
UserData : STATE : PLAIN
Done!
Elapsed: 00:00:48
Operation : Format FS / Reset Settings [ v2.00r2 ]
Mode : Reset FRP
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:40
Old 12-03-2019, 17:06   #61368 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
G Five Fire Dead Recaver
SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ]
Operation : Format FileSystem [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource  :  InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash  : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1079CA1C0B81_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:24
Old 12-03-2019, 17:24   #61369 (permalink)
Freeboy08's Avatar
Member: 1272267
Sonork: 100.1667652
Thanks Meter: 299
Itel A16 frp unlock done by infinity box
Operation : Format FS / Reset Settings [ v2.03 ]
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:55
The Following 2 Users Say Thank You to Freeboy08 For This Useful Post:
Old 12-04-2019, 04:20   #61370 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile I6 Metal 1 SPD77xx Logo Stuck Fix By Flashing With King Infinity CM2
Infinity SC Firmware Detected
FW Size : 2874 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : i6_Metal_ONE_new
Device CPU : i6_Metal_ONE
Device IntName : i6_Metal_ONE
Device Version : 6.0
Device Compile : 12/15/2016 10:31:38 AM
Device Project : MRA58K release-keys
Device ExtInfo : QMobile i6 Metal ONE
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 35 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x19 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:16:54
Old 12-04-2019, 05:56   #61371 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Alcatel Vodafone VFD300 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 33 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100464A323541420283E1D0513507
[eMMC] : FLASH_INF : [SAMSUNG] , BA52J
[eMMC] : FLASH_CID : 150100464A323541420283E1D0513507
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F395774AF1F7E19707BFD0E156D5
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:12
Old 12-04-2019, 06:33   #61372 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,921
huawei y5 frp reset don
Done!
Elapsed: 00:01:16
Operation : Reset Settings/Format FS [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM84)
MODE : BOOTROM
PORT : 84
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
BROM : SecMode  : SBC
BROM : BOOTROM
MODE : Huawei : Y5 [ MYA-Lxx ] | Manual : Disabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 90014A484147346132D419AA68BB2E07
DAInf: 4 : 2 : 147
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : 484A019061344741AA19D432072EBB68
     EMI : DEV : INFINITY
     EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
INIT : 0xBC : LP/DDR3 [ 0x00000000 :  [ 0 B ] ]
DRAM : DRAM: 0x80000000 [ 2.00 GB ]
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 90014A484147346132D419AA68BB1507
        EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x3AB400000 [ 14.68 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 8FDD1539620DBE8C69D88145EA3F45CD
 STATUS : DA : NOR OTP GETSIZE FAIL
 BSTYLE : EMMC FLASH BOOT
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM120)
MODE : PRELOADER PORT
PORT : 120
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:01:31
Best Regards
MR,
Niaz muhammad
Always Follow The Forum RULES
Use Only Thanks Button
Old 12-04-2019, 08:31   #61373 (permalink)
Member: 395389
Sonork: no idi
Thanks Meter: 182
xt 1585 frp remove
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode .
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : kinzie_verizon
Model : XT1585
FRP reset passed! Make FACTORY RESET from menu!
-- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
The Following User Says Thank You to szktk For This Useful Post:
Old 12-04-2019, 12:14   #61374 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Qmobile i6 metal one reset frp done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 19 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:43
Old 12-04-2019, 12:17   #61375 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Vgotel i251 reset password done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_036 959A70F24_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:20
Old 12-04-2019, 14:24   #61376 (permalink)
bhalaygilani's Avatar
Member: 1647864
Thanks Meter: 62
Huawei Y5ii CUN-U29 FRP reset done with cm2mt2 2.06
Work Mode Huawei CUN-U29
Operation : Identify [ v2.06 ]
PTFN : MediaTek PreLoader USB VCOM Port (COM9)
PORT : 9
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : Huawei : Y5II [ CUN-U29 ] | Manual : Disabled
AGENT : Found MT6582
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 484A019061344738D220D4325D74EC84
DAInf: 4 : 2 : 135
DA : DRAM ready!
EMMC: 90014A483847346132D420D284EC745D
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2
EMMC:
USER : 0x1D2000000 [ 7.28 GB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000
RNID : BB8B1503F4A39DA8911CDAEDF21297D3
DA : USB : HIGH-SPEED
Boot done!
Patch Level : HUAWEICUN-U29
Display ID : CUN-U29C578B127
Ver. CodeName : REL
Ver. Release : 5.1
Build Time : 1491967505
Product Model : HUAWEI CUN-U29
Product Brand : HUAWEI
Product Name : CUN-U29
Product Device : HUAWEI-U6582
Product Board : CUN-U29
Product Manfct : HUAWEI
Board Platform : mt6582
Product Info : hq6582_we_b1b_l1
USERDATA : PLAIN ( NOT encrypted )
Done!
Just initialize Memory Tool ...select frp partition and erase it
Operation : Memory Tool Init [ v2.06 ]
PORT : 9
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 135
DA : DRAM ready!
EMMC:
Boot done!
Set default path : C:\InfinityBox\CM2MT2\phdata\
Ready!
Operation : Erase Memory
Erase selected partitions [1]
[0] Erase partition : FRP
Erase partition Ok!
Operation finished!
The Following User Says Thank You to bhalaygilani For This Useful Post:
Old 12-04-2019, 15:00   #61377 (permalink)
Member: 2706332
Thanks Meter: 14
iTel A33 Privacy Protection Read Done
Card found : EE6AACAB , v0138
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.03
Load IDBase v10107 Ok!
Operation : Read PrivacyLock [ v2.03 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
PASSWORD : 000045
CONTACTS : *********
Done!
Elapsed: 00:02:13
The Following 3 Users Say Thank You to cool_dude_zim For This Useful Post:
Old 12-04-2019, 16:05   #61378 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
QMobile i8i PRO Frp
Patch Level    : NRD90M
Display ID     : QMobile_i8i PRO_MP_31_01
Ver. CodeName  : REL
Ver. Release   : 7.0
Sec. Patch     : 2017-12-05
Build Time     : 1531927066
Product Model  : QMobile i8i PRO
Product Brand  : Qmobile
Product Name   : i8i_PRO
Product Device : i8i_PRO
Product Manfct : Qmobile
Product Info   : i8i_PRO
UserData : STATE : ENCRYPTION
Done!
Elapsed: 00:00:49
Mode : Reset FRP
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:43
Old 12-04-2019, 18:32   #61379 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
QMobile i6_Metal_ONE_new Flash
FW Size : 2874 MiB
Load Ok!
File Info
======= Flash
3. Insert cable
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Flashing now
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Elapsed: 00:14:14
The Following User Says Thank You to Tanha0321 For This Useful Post:
Old 12-04-2019, 18:33   #61380 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
QMobile X32 Frp
Model Name  : X32
Model Brand : QMobile
Model Device: X32_new
AndrVersion : 6.0
BaseBand CPU: X32
CompileDate : 2/23/2017 10:16:53 AM
Project Ver : MRA58K release-keys
Model Ext   : QMobile X32
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:30
3. Insert cable
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:34
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.56383 seconds with 9 queries
