Old 12-06-2019, 11:03   #61396 (permalink)
Member: 2548908
Sonork: 100.1672479
Thanks Meter: 403
Titanic T2 FRP Remove Done By CM2
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 11010030303447453001AB57480F4331
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 11010030303447453001AB57480F4331
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0x6D75BC6354316C6A42D15C868D652987
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:11
Reconnect Power/Cable!
Old 12-06-2019, 15:45   #61397 (permalink)
Member: 512551
Sonork: 100.1626194
Thanks Meter: 56
Lightbulb itel a33 frp done great team
Card found : 9pp[]C5 , v0138
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r1
Operation : Format FS / Reset Settings [ v2.00r1 ]
Mode : Default [ Reset Settings + FRP ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Sedning Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sedning Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:46
The Following 2 Users Say Thank You to goodname For This Useful Post:
Old 12-07-2019, 05:06   #61398 (permalink)
Member: 1383093
Thanks Meter: 51
QMobile Super Rock read ok
Operation : Read Flash [ v1.05 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v2.0 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Read Flash Ok, Size : 4.00 MiB
QMobile_Super_Rock_V05_07-17-2019
Project Version: SC6531EFM_BAR
MMI Version: SC6531EFM_BAR
BASE Version: BASE_SVN
HW Version: SC6531EFM_BAR
07-17-2019 20:21:01
LOG Version: V1.0.1
Saved to : H:\E\ALL DEVISES\china and\sc6531\s708\QMobile_Super_Rock_V05_07-17-2019.bin
Done!
Elapsed: 00:00:58
Operation : Format FileSystem [ v1.05 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
The Following User Says Thank You to ahmc For This Useful Post:
Old 12-07-2019, 07:10   #61399 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,823
[FL] : Total size : 0x92040DA4 [ 2.28 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM264)
MODE : PRELOADER PORT
PORT : 264
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 484A01906531473832310705612384F4
DAInf: 4 : 2 : 156
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 90014A48384731655073132F4842361
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x1D2000000 [ 7.28 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : E1A007827EA038AEEA6090B367105F9
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
SEC_DL : False (CUST)
SEC_DL : SECURE USB DL DISABLED
SEC_ID : 0x35464646304237304435444533464335
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader code ...
Update bootloader Ok!
Write : LK
Write : BOOT
Write : RECOVERY
Write : LOGO
Write : SECRO
Write : SYSTEM
Write : CACHE
Write : USERDATA
[FL] : Flashing finished!
Done!
Elapsed: 00:02:28
Old 12-07-2019, 08:28   #61400 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,921
qmobile l9 format and reed flash don
Card found : CE90936C , v0138
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.05
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : C000 : NOR : [ 4MB-8MB ]
1. Power off device
Wait for device ...
Device not found!
Remove battery, cable. Check cable and connection. Repeat operation!
Operation : Reset Settings [ v1.05 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00200000
BOOT_INIT : 0x8F1CE7E6
BOOT_MODE : BOOTROM
Boot_CPU  : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV  : 0xFBA2A250
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:23
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_INIT : 0x8F18E7E6
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Read done, 0x00400000
Verify FlashContent
MCU verified
CAL verified
FAC verified
Device Info Details :
[0] : S069_YXSD_C1810_QMobile_L103_F3_QQVGA
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_rda6625
[5] : flsh_spi32m
[6] : gc9105/gc9102/st7735s/nv3021/gc9106
[7] : gc6133/gc6123/bf3a01serial
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
[11] : 2018-01-22_15:17:01
[12] : Qmobile_V16_20180122
Saved to : H:\QMOBILE\QMOBILE\L-SERIES\L9 RDA\
Saved as : SC6533G_4MiB_S069_YXSD_C1810_QMobile_L103_F3_QQVGA_Qmobile_V16_20180122_2018-01-22_151701.ilod
Done!
Elapsed: 00:01:26
Best Regards
MR,
Niaz muhammad
Always Follow The Forum RULES
Use Only Thanks Button
Old 12-07-2019, 14:11   #61401 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Wintel Shain Dead Recaver
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1393344997A6_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:24
Old 12-08-2019, 05:02   #61402 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,150
Wiko Laney MT6572 Hanging Probelam Fix Only Formate With King Infinity CM2
Card found : S/N : A19EC787 , v0138
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 33 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A4834473164040500A2B8F8C1D1
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040500A2B8F8C1D1
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3954FBFBE18972E3A18AAA79759
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:29
Old 12-08-2019, 08:22   #61403 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Telenor Infinity_i4 Read FFw And Format Done
Operation : Read Firmware [ v2.06 ]
PORT : 264
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
AGENT : Found MT6735
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 700100544232383136201EFA41BE6FF1
DAInf: 4 : 2 : 155
DA : DRAM ready!
EMMC: 700100544232383136201EFA41BEA5F1
EMMC: VEN : KINGSTON | OEM : 01 | DEV : TB2816
EMMC:
USER : 0x3A8000000 [ 14.63 GB ]
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : A2133A98B045FD5EC32B5CF179F47BB8
Boot done!
Patch Level : O11019
Display ID : H3732.YBT.V51B9.16+1.WB1B5.FB3B5.8.1.Go.Telenor.V0 1.01.20190723
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2019-07-05
Build Time : 1563849222
Product Model : Infinity_i4
Product Brand : Telenor
Product Name : V51
Product Device : V51
Product Manfct : Condor
Product Info : V51
Product Board : k37mv1_bsp
Board Platform : mt6737m
MT6737M__Condor__Infinity_i4__8.1.0__H3732.YBT.V51 B9.16+1.WB1B5.FB3B5.8.1.Go.Telenor.V01.01.20190723 __O11019__V51
SecureDevice : Plain
Read : preloader.bin
Read : proinfo.img
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : recovery.img
Read : logo.bin
Read : secro.img
Read : tz.img
Read : odmdtbo.img
Read : vendor.img
ExtSparse : Compression ratio : 47%
Read : system.img
ExtSparse : Compression ratio : 12%
Read : cache.img
Read : userdata.img
Read : sdrpmb.img
FW Size : 1.57 GB
Android Info saved : _Android_info.txt
Scatter : MT6737_Android_scatter.txt
Saved to : C:\Users\AkhtarAli\Desktop\MT6737M__Condor__Infini ty_i4__8.1.0__H3732.YBT.V51B9.16+1.WB1B5.FB3B5.8.1 .Go.Telenor.V01.01.20190723__O11019__V51\
Done!
Elapsed: 00:03:26
Operation : Reset Settings/Format FS [ v2.06 ]
PORT : 264
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:41
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 12-08-2019, 08:49   #61404 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,150
Qmobile A950 MT6583 Hanging Probelam Fix With King Infinity CM2
Wait for phone...
Phone found! [ 33 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BB_CPU_NME : [MediaTek] MT6583|6589_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.3.2 on BBID : 0x86
eMMC Flash : 4B0001153030534A8F9F034D57606232
[eMMC] : FLASH_INF : [SAMSUNG] , M00SJ
[eMMC] : FLASH_CID : 1501004B4A5330304D039F8F32626057
[eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000
DEV RID : 0xD9C8F395760FAA79EC76F25FDA28E4D1
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:17
Old 12-08-2019, 09:13   #61405 (permalink)
Member: 2935044
Thanks Meter: 56
QMobile i6 Metal ONE Hang on Done By Flashing With CM2MTK
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=aiBJbMLHQ-s
The Following User Says Thank You to AAdnan Mobile For This Useful Post:
Old 12-08-2019, 13:16   #61406 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,999
HiSense U601S FRP REMOVE DONE
assalamu alaikum
by
hamada yousri
gem flash
The Following User Says Thank You to profkefah For This Useful Post:
Old 12-08-2019, 14:29   #61407 (permalink)
Member: 1758871
Sonork: bhatti
Thanks Meter: 107
Gfive shine flash file
GFIVE SHINE FLASH FILE CM2-SCR Read dne
SC6531E
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0D8 EF9857F75_NVM.nv
By ZakaUllah Bhatti
Download Mega Link
The Following User Says Thank You to bhatti123 For This Useful Post:
Old 12-08-2019, 14:42   #61408 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
QMobile i2 POWER Frp
Card found : AD74A837 , v0137
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r2
Operation : Identify [ v2.00r2 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS
Sending Init Boot ...
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Patch Level    : MRA58K
Display ID     : QMobile_i2_POWER_MP_08_11
Ver. CodeName  : REL
Ver. Release   : 6.0
Sec. Patch     : 2016-10-05
Build Time     : 1480322474
Product Model  : QMobile i2 POWER
Product Brand  : QMobile
Product Name   : i2_POWER
Product Device : i2_POWER
Product Board  : sp7731cea
Product Manfct : QMobile
Board Platform : sc8830
Product Info   : i2_POWER
UserData : STATE : PLAIN
Done!
Elapsed: 00:00:45
Operation : Format FS / Reset Settings [ v2.00r2 ]
Mode : Reset FRP
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:41
Old 12-09-2019, 05:30   #61409 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile Infinity D Read F.F.w Done
PTFN : MediaTek USB Port (COM10)
MODE : BOOTROM
PORT : 10
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
BROM : SecMode : SBC
BROM : BOOTROM
Fail to disable Dog!
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 484A01906134473864C3A532F535F06C
DAInf: 4 : 2 : 156
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : 90014A483847346132A5C3646CF035F5
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ]
DRAM : DRAM: 0x40000000 [ 1.00 GB ]
DA : DRAM ready!
EMMC: 90014A483847346132A5C3646CF035F5
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2
EMMC:
RNID : 39CC3F19FBB7951C9A1B4CAE1100B5E5
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM265)
PORT : 265
Boot done!
Display ID : O11019 release-keys
Ver. CodeName : REL
Sec. Patch : 2018-11-05
Build Time : 1544501971
Product Device : Q_Infinity_D
Product Info : k200_1g
Product Model : k200
Product Brand : TINNO
Product Name : k200
Product Manfct : TINNO
Product Board : k200_1g
Board Platform : mt6580
MT6580__TINNO__k200__8.1.0__O11019__k200_1g
SecureDevice : Paired type!
-> INFO : That device MAY dead after ReadOut Flashing in some rare cases!
Read : proinfo.img
Read : nvram.bin
Read : persist.img
ExtSparse : Compression ratio : 100%
Read : lk.bin
Read : boot.img
Read : recovery.img
Read : logo.bin
Read : odmdtbo.img
Read : misc.img
Read : vendor.img
ExtSparse : Compression ratio : 58%
Read : tz.img
Read : secro.img
Read : system.img
ExtSparse : Compression ratio : 22%
Read : cache.img
Read : userdata.img
FW Size : 1.33 GB
Scatter : MT6580_Android_scatter.txt
Saved to : C:\Users\AkhtarAli\Desktop\MT6580__TINNO__k200__8. 1.0__O11019__k200_1g\
Done!
Elapsed: 00:06:29
Old 12-09-2019, 06:24   #61410 (permalink)
Member: 2548908
Sonork: 100.1672479
Thanks Meter: 403
ITEL S11 Pro FRP Remove Done By CM2
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : A801114D5A425343421090015C35C549
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0xA8 , OEM : 0111
[eMMC] : FLASH_INF : [NOT_IN_BASE] , BCSBZ
[eMMC] : FLASH_CID : A801114D5A425343421090015C35C549
[eMMC] : FLASH_LEN : 0x00000001D4400000
[eMMC] : FLASH_UCP : 7492 MiB [eMMC 8 GiB]
DEV RID : 0x6D75BC63B78F3A75DAA7591F12107FE9
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:13
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.60184 seconds with 9 queries
