Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #6136 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: Bangladesh Age: 28
Member: 908875 Status: Offline Thanks: 269
| Quote:
module v3.62 Action: "sp-unlock" unlock method: smart fast Model: T-Mobile-Zest Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:65AC:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B05 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403424647 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! | |
| The Following User Says Thank You to OYES AHMED For This Useful Post: |
| | #6137 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: M__B__Din
Member: 950201 Status: Online Sonork: 100.1608088 Thanks: 119
| COM7 [VCP0] selected module v3.26 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001 20F:0006status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: HX684_GEMINI_07B_HW.WX684_AR10_NT57_B2_V1_9ETEST--091124.BIN project-id: WX684_AR10_NT57_B2_V1.9ETEST, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: HX684_GEMINI_07B_HW.WX684_AR10_NT57_B2_V1_9ETEST--091124__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\HX684_GEMINI_07B_ HW.WX684_AR10_NT57_B2_V1_9ETEST--091124__ffs_20110212-153358.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 2 min 17 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| The Following User Says Thank You to cel_phon For This Useful Post: |
| | #6138 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks: 1,423
| COM4 [VCP1] selected module v3.26 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 350724987043321 Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:5E3B:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: MAUI.07B.W08.28.MP.V14.F1 Version: HEXING23D_GEMINI_ULC_07B_HW_0201 detecting structure #2... 1 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #2... 1 5 11 done 67 byte(s) read verification... verification done: 35072498704332 Finished, time used: 14 sec Remove/Install battery now ! |
| The Following User Says Thank You to joni_rajpura For This Useful Post: |
| | #6139 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2010 Location: :::LONDON:::
Member: 1442994 Status: Offline Thanks: 51
| <<<<<<<<<<<<doro phone easy 410gsm unlock DONE>>>>>>>>>>>. COM19 [VCP0] selected module v3.74 Action: read unlock codes unlock method: read codes Model: Doro-PhoneEasy-410s Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5E88:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: SHELL_S09_2V8_DORO410_L14EN_202_100521_MCP128+32_B T_FM_SMS Version: CKT23D_08A_HW 80 byte(s) read imei: 35759603195541 connection Ok 191 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 179 byte(s) read reading data... 972 byte(s) read lock[1] code: + 65995367 lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 12 sec Remove/Install battery now ! THANX INFINITY TEAM AK' |
| The Following User Says Thank You to AbDuLlAH kHaWaR For This Useful Post: |
| | #6140 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2004 Age: 34
Member: 93284 Status: Offline Thanks: 709
| Vodafone 541 Unlock OK Vodafone 541 Unlocked OK, Cable Alc S320 Code: COM3 [VCP0] selected module v3.74 Device: Vodafone-541 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:FD03:A007 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.B1C87F9E.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN_741CA52F].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: B1C87F9E rom info ver: 07 sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN project-id: MAUI.08A.W08.40.SP1.V32, 2FA51C74 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 17P provider: 708X-2HVDGB1 customization: CN17FC92 customization: XN17FC92 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FC92 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN17FC92 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35908103678104 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32__system_log_B1C87F9E_741CA52F_20110212-122029.B0X.bin Finished, time used: 4 min 11 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! BR |
| The Following User Says Thank You to owiec77 For This Useful Post: |
| | #6141 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2007 Location: Bomb Blast on bloddy Nato...
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks: 67
| Vodafone-340 unlocked..........using vygis gs102 cable ------------------------------ ------------------------------ but lost logs........ |
| The Following User Says Thank You to khalidjan For This Useful Post: |
| | #6142 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2010 Location: Nokia SL3 unlock Fast service Age: 22
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks: 200
| Vodafone 543 unlock done... ![]() COM6 [VCP0] selected module v3.71 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001 303:A000status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.E10FD E50.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_814E5441].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: E10FDE50 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 41544E81 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 267 provider: 543X-2AVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003576059 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_E10FDE50_814E5441_2011021 2-150732.B0X.bin Finished, time used: 5 min 9 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| The Following User Says Thank You to md_amin For This Useful Post: |
| | #6143 (permalink) |
| Vodafone-340 unlocked using vygis gs102 cable.......... But......lost logs to show Thanx infinity team |
| | #6144 (permalink) |
| Junior Member ![]() Join Date: Oct 2005 Location: Poland,Wloclawek
Member: 194290 Status: Offline Thanks: 170
| COM45 [VCP0] selected Device: Toshiba-TS10 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:98E59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 00005279 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-1_20110212-144328.39E.bin file saved: C:\Program Files\InfinityBox\QModule\backup_eeprom_unlock-2_20110212-144333.39E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 Format file system Done Write... Preparing... area requested/selected: 02/02 Finalizing... area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 93 sec |
| The Following User Says Thank You to grzyb_26 For This Useful Post: |
| | #6145 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: SAMIA LAND
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks: 206
| ZTE-R221 UNLOCKED SUCCESSFULY module v3.74 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:6DD2:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E-WGD-ORANGE-P109A17SV1.0.0B04 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403454251 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 16 sec Remove/Install battery now ! |
| The Following User Says Thank You to KYEJUSA For This Useful Post: |
| | #6146 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2007
Member: 614304 Status: Offline Thanks: 30
| COM12 [VCP0] selected module v3.73 Action: "sp-unlock" unlock method: smart fast Model: ZTE-A211 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:1F89:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: PE-PT-TMN-P109A2V1.0.3B06 Version: 07AZTENJ23_07A_PMJ 44 byte(s) read imei: 35547302094582 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 18 sec Remove/Install battery now ! |
| The Following User Says Thank You to Unlocker_001 For This Useful Post: |
| | #6147 (permalink) |
| COM15 [VCP2] selected module v3.74 Device: Spice-S415-2008-03-19 Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 7F22C400000000:18E59F00000000 flash: T 2Mb otp offset: 001F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 001B0000/00050000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 7F22C400000000:18E59F00000000 Backup required data Done ====> Patch required data ... ...... lock area found Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ........ error: area 1 can not apply patch Special operation Done ====> Write ... flash: 7F22C400000000:18E59F00000000 flash: 7F22C400000000:18E59F00000000 Write: lock-area-1 Write Done ====> Finalization ... Finalization Done Finished, time used: 23 sec Remove/Install battery now ! |
| The Following 3 Users Say Thank You to joni_rajpura For This Useful Post: |
| | #6148 (permalink) |
| COM3 [VCP3] selected module v1.44 Device: LG-3000 operation: SP-unlock Phone should be Switched ON ! connecting... change baudrate... checking version... RD300F09 LG RD-3000 version 9 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 43 sec |
| | #6149 (permalink) |
| Major Poster ![]() ![]() Join Date: Mar 2008
Member: 715924 Status: Offline Thanks: 272
| COM9 [VCP0] selected module v3.74 Device: Alcatel-543X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001 303:A00Astatus: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.A6D85 0FE.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_814E5441].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: A6D850FE rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 41544E81 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 267 provider: 543X-2AVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003618470 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_A6D850FE_814E5441_201102 13-140600.B0X.bin Finished, time used: 4 min 7 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| The Following 2 Users Say Thank You to muktadirma For This Useful Post: |
| | #6150 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2007
Member: 621455 Status: Offline Thanks: 1,050
| Alcatel E207 succesfull unlock ........ here is log and remmember to hold power button till process end .......... COM3 [VCP8] selected module v1.38 Device: Alcatel-E207 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data ... reading Alcatel-E207_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Alcatel-E207_eeprom_calibration-1_20110213-143427.80E.bin Read data done Check data ... Check data done Write ... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Write done Finished, time used: 1 min 9 sec Remove/Install battery now ! |
| The Following 2 Users Say Thank You to ikkks For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
