01-21-2020, 06:48 | #62101 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:30 |
01-21-2020, 07:07 | #62102 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Wiko Laney MT6572 Hanging Probelam Fix Only Formate With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447316404050CA21A56C1F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A483447316404050CA21A56C1F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3951DC0243FFD1F044E09EB9DF6 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:43 Reconnect Power/Cable! |
01-21-2020, 07:24 | #62103 (permalink) |
No Life Poster Join Date: Nov 2016 Location: ISI
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Huawei chm u01 hang on logo done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6582 , Project : mbk82_wet_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Huawei Device Model : CHM-U01 Device CPU : MT6582 Device IntName : CHM-U01 Device Version : 4.4.2 Device Compile : 8/27/2015 3:31:46 AM Device Project : ALPS.KK1.MP1.V2.11 Device ExtInfo : CHM-U01 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040503A2EA88A15B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040503A2EA88A15B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0386520DD949DCE729134AB0DAA7E23B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : mbk82_wet_kk , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3964 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:26 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:58 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:33 Reconnect Power/Cable! |
01-21-2020, 07:26 | #62104 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | G five w3 reset password done by cm2 Card found : S/N : 73CA70CC , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : EC956AC0AC2189A63C725021D0242D54 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F10.bin FileVersion : MAUI.11C.W13.52.MP.V2.F10 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Reset UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : EC956AC0AC2189A63C725021D0242D54 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Backup done Read ExtData Sorting ExtData Sort Ok, Rebuild Ok Restore ExtData All done UserCode request removed UserCode set to default ( 0000 or 1122 ) Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
01-21-2020, 07:29 | #62105 (permalink) |
Member: 2644066 Status: Offline Thanks Meter: 1,773 | Qnet b26 hang on logo done by cm2 Card found : 73CA70CC , v0137 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] Operation : Identify [ v1.04 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : DOWNLOAD BOOT_INTV : 6533G-FPTRUNK-W16.44.2 InternalVersion: g8bec5c4c Setting BOOTROM mode BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Identify : Code Integrity Check pass! inf_usb-dll:err [_usb_read_async] timeout error Done! Elapsed: 00:02:48 Reconnect Power/Cable! Operation : Reset Settings [ v1.04 ] ----- > Powered On : 1. Power On device 2. Connect USB cable 3. When device show StorageMode : Press '0' button for a 5 second! ----- > Powered Off : 1. Insert USB cable 2. Wait when device show Charge icon 3. When device show StorageMode : Press '0' button for a 5 second! Wait for device ... Device Connected! BOOT_PWR0 : 0x00600000 BOOT_INIT : 0x81C0024C BOOT_MODE : BOOTROM Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G MEMD for flsh_spi32m Branch: none Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ] Performing MemoryInit Selecting RL Sending RL Config : MemoryInit Config : Loader BOOT_MODE : RLOADER Boot IV : 0xFBA2A250 Boot done! Preparing PMT Verifying PMT Erasing 1474560 bytes FileSystem format done! Done! Elapsed: 00:00:53 Reconnect Power/Cable! |
01-21-2020, 09:29 | #62106 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | vivo Y622 (clone) Remove Virus / Read Firmware Done :) Code: Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 246 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393051D7CDA4E31177 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7CDA4E31177 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D41A48FA6FB722B36635546D3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : vivo ProdName : bbk82_wet_jb5 ProdModel : vivo Y622 Device : bbk82_wet_jb5 AndroidVer: 6.0 MTKxCPU : MT6582 MTKxPRJ : vivo_Y622.JB5.MP.V1.6 [Read Ok] : preloader_bbk82_wet_jb5.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : apps.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / bbk82_wet_jb5 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 802 MiB Scatter saved to : F:\backup files\MT6582__vivo__vivo_Y622__bbk82_wet_jb5__6.0__vivo_Y622.JB5.MP.V1.6\ All done! Done! Elapsed: 00:04:40 Reconnect Power/Cable! Operation : Scan APPs [DDirect] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 246 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393051D7CDA4E31177 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7CDA4E31177 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D41A48FA6FB722B36635546D3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait Collect and verify data according Dictionary Collect done : 0x0001 [DDCleaner Info] : Files to remove : 1 [DDCleaner Info] : Additional garbage detected : 0 Removing files ... [DDCleaner] : Removed 1 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Scan APPs [DDirect] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 246 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393051D7CDA4E31177 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7CDA4E31177 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D41A48FA6FB722B36635546D3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait [User Select] : Remove Files and Garbage [DDCleaner Info] : Files to remove : 2 [DDCleaner Info] : Additional garbage detected : 0 Removing files ... [DDCleaner] : Removed 2 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:02:13 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 246 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393051D7CDA4E31177 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7CDA4E31177 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x2BFA537D41A48FA6FB722B36635546D3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! Code: MT6582__vivo__vivo_Y622__bbk82_wet_jb5__6.0__vivo_Y622.JB5.MP.V1.6 |
01-21-2020, 09:54 | #62107 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | TECNO KC2 Remove FRP Lock Done :) Code: Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM246) MODE : PRELOADER PORT PORT : 246 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E0363285ED7A677 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C41817C61F283731691C53FBB518E581 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM246) MODE : PRELOADER PORT PORT : 246 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : TECNO : SECURE_v2 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6761 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 90014A68423861503E0363285ED7A677 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : hB8aP> EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x01000000 [ 16.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C41817C61F283731691C53FBB518E581 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.180610.011 Display ID : KC2-H6113AI-P-191024V219 Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-10-05 Build Time : 1571881678 Product Model : TECNO KC2 Product Brand : TECNO Product Name : H6113 Product Device : TECNO-KC2 Product Manfct : TECNO MOBILE LIMITED Product Info : kc2_h6113 Product Board : TECNO-KC2 Board Platform : mt6761 USERDATA : ENCRYPTED NVRAM check : Passed! Done! Elapsed: 00:00:27 |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
01-21-2020, 10:56 | #62108 (permalink) |
No Life Poster Join Date: Mar 2010 Location: south africa Age: 41
Member: 1269056 Status: Offline Thanks Meter: 1,114 | Vfd320 nework unlock done VFD 320 NETWORK LOCK DONE BY INFINITY CM2MT2 HERE IS THE LOGS Operation : SP Unlock [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM29) MODE : PRELOADER PORT PORT : 29 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : VODAFONE : VFD 320 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_SWSEC.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017041493445E526013455256B0B DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 7001004545344941340126E5B6B2555 EMMC: VEN : KINGSTON | OEM : 01 | DEV : EE4IA4 EMMC: BOOT1 : 0x00200000 [ 2,00 MB ] BOOT2 : 0x00200000 [ 2,00 MB ] RPMB : 0x00080000 [ 512,00 KB ] USER : 0xE2000000 [ 3,53 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x20000000 [ 512,00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2DAAC399CC821599CEDD6A1B768CCFA4 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Locked! | MNC : 512 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Direct unlock done! Done! Elapsed: 00:00:34 |
The Following User Says Thank You to trust4eve83 For This Useful Post: |
01-21-2020, 11:27 | #62109 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | symphony i10 Frp remove done Code: Operation : Reset Settings/Format FS [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM58) MODE : PRELOADER PORT PORT : 58 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019061344741780CA432BBC38384 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147346132A40C788483C3BB EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 1C9BD0903759E4A5E8EA4EEB853D6307 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
01-21-2020, 13:06 | #62110 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Xiaomi Redmi Note 3 Format / Repair Done :) Connect phone with press both volume keys Code: Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6795 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6795 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 30000111374736313A4B00329572E82B DAInf: 3 : 2 : 154 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 110100303136473732004B3A2BE87295 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xB0 : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 110100303136473732004B3A2BE87295 EMMC: VEN : TOSHIBA | OEM : 01 | DEV : 016G72 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6795 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4F6C9299F8F5E0258907E4C1BABC932A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : Preloader And Gadget Serial (COM268) MODE : PRELOADER PORT PORT : 268 Boot done! Patch Level : LRX22G Display ID : LRX22G Display ID : H3Z_S100_20150817 Ver. CodeName : REL Ver. Release : 5.0.2 Sec. Patch : 2016-08-01 Build Time : 1471424240 Product Model : Redmi Note 3 Product Brand : Xiaomi Product Name : hennessy Product Device : hennessy Board Platform : mt6795 Product Info : hennessy Product Manfct : Xiaomi USERDATA : PLAIN ( NOT encrypted ) IMEI[0] : 868029022xx88xx IMEI[1] : 868029022xx88xx NVRAM check : Passed! Done! Elapsed: 00:00:41 Code: Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM22) MODE : BOOTROM PORT : 22 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6795 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6795 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 30000111374736313A4B00329572E82B DAInf: 3 : 2 : 154 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 110100303136473732004B3A2BE87295 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xB0 : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 110100303136473732004B3A2BE87295 EMMC: VEN : TOSHIBA | OEM : 01 | DEV : 016G72 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6795 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 4F6C9299F8F5E0258907E4C1BABC932A STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : Preloader And Gadget Serial (COM268) MODE : PRELOADER PORT PORT : 268 Boot done! Format Ok : USERDATA Format Ok : CACHE Done! Elapsed: 00:00:59 Reconnect Power/Cable! |
01-21-2020, 19:01 | #62111 (permalink) |
No Life Poster Join Date: Oct 2007 Location: EGYPT
Member: 601566 Status: Offline Sonork: 100.1637134 Thanks Meter: 551 | sico express3-max spd 7731e read firmware done Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : SICO_Express3-Max_V01_20181225 Ver. Incmt : vGB110003 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-12-05 Build Time : 1545732854 Product Model : Express3-Max Product Brand : SICO Product Name : Express3-Max Product Device : Express3-Max Product Manfct : hena Product Info : e706_7731e_32u_o Product Board : e706_7731e_32u_o Board Platform : sp7731e AndroidVer : 8 VlnrLevel : 0x02 SP7731E__hena__Express3-Max__8.1.0__SICO_Express3-Max_V01_20181225__OPM2.171019.012__e706_7731e_32u_ o Read : u-boot.bin Read : sml.bin Read : tos.bin Read : vbmeta.img Read : pm_sys.bin Read : modem_w.bin Read : gdsp_w.bin Read : nvitem_w.bin Read : modem_wcn.img Read : gnssmodem.bin Read : gnssbdmodem.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Make : persist.img Read : phase.cfg Read : boot.img Read : recovery.img Read : system.img ExtSparse : Compression ratio : 80% Read : vendor.img ExtSparse : Compression ratio : 73% Make : userdata.img Make : cache.img Read : prodnv.img ExtSparse : Compression ratio : 40% Read : custom.bin ExtSparse : Compression ratio : 0% Read : u-boot-spl.bin Waiting for device ... ADB : Device found! ADB : Connected! ADB : Prepare Ok! Thinking about the meaning of life ... Looking for a troubles ... Just some noise around. Wait ... Firmware size : 0x60F4B338 ( 1.51 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Done! Elapsed: 00:39:07 |
The Following User Says Thank You to elpring For This Useful Post: |
01-22-2020, 05:32 | #62112 (permalink) |
Member: 2556542 Status: Offline Thanks Meter: 1,790 | symphony G100 hang on logo done Code: Operation : Reset Settings/Format FS [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM58) MODE : PRELOADER PORT PORT : 58 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : Wiko : SEC_6739 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 88010345504231303049437D3E60A4A3 EMMC: VEN : FORESEE | OEM : 301 | DEV : EPB100 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1CE100000 [ 7.22 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : FD43813AB7C96EB95463E61BB5703702 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
The Following User Says Thank You to kothamamun For This Useful Post: |
01-22-2020, 08:25 | #62115 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | TELENOR_Infinity_i Read FFw & Format Done Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 76 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323734B90042971F7D90 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200B934907D6397 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x033C521704EA0F907DFC88B27D0E0C26 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : TELENOR ProdName : TELENOR_Infinity_i ProdModel : Infinity i Device : TELENOR_Infinity_i AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : alps-mp-m0.mp1-V2.39.1_wtk6735m.35u.m0 [Read Ok] : preloader_x2605_haier_l12_telenor.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6737M / V1.1.2 / x2605_haier_l12_telenor / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2695 MiB Scatter saved to : C:\Users\Nadeem darsaiii\Desktop\MT6735__TELENOR__Infinity_i__TELE NOR_Infinity_i__6.0__alps-mp-m0.mp1-V2.39.1_wtk6735m.35u.m0\ All done! Done! Elapsed: 00:06:49 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 76 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323734B90042971F7D90 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200B934907D6397 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x033C521704EA0F907DFC88B27D0E0C26 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
