Old 01-29-2020, 13:29   #62161 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Qmobile m2 reset password done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB]
Operation : Identify [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 653x NOR v1.3(c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_156 C528ADD2B_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:24
Old 01-29-2020, 13:32   #62162 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
QMOBILE X700i HANG ON LOGO DONE BY CM2
Card found : S/N : 73CA70CC , v0137
Scatter Load Ok , BaseBand : MT6580 , Project : d5110_qmobile , Storage : EMMC
Files found : 9 , Set to Flash : 8
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : d5110_qmobile
Device CPU : MT6580
Device IntName : d5110_qmobile
Device Version : 5.1
Device Compile : 7/17/2015 12:51:50 PM
Device Project : ALPS.L1.MP6.V2_RGK6580.WE.L_P2
Device ExtInfo : QMobile X700i
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100523832314D4200E003CA6E722B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM128
[eMMC] : FLASH_CID : 150100523832314D4200E003CA6E722B
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x0CF2E6DE176B77EE19AD1C77DEB15E93
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : d5110_qmobile , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3550 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001C80000-0x0000000003320000
Erase : 0x00000000050A0000-0x000000039DCE0000
Flash Pre-Erase Done, time used : 00:00:08
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_d5110_qmobile.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:08:34
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:03
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:08:57
Old 01-29-2020, 13:33   #62163 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Oppo a37 reset frp done by cm2
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Identify [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 2687E70E
ID_BLOCK_L : 9B6D07FF5EC4F1FCAB80705D9AE17159
ID_BLOCK_L : 42319F2E23B21CA92C8BCC050FE6F0DB
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Brand : OPPO
ProdName : A37f
ProdModel : A37f
Device : A37f
AndroidVer: 5.1.1
SWVersion : A37fEX_11.A.28_INT_028_201710081545
Manufact. : OPPO
SysPatch : LMY47V
DevComTime: 10/8/2017 9:26:49 AM
QLMxCPU : MSM8916
USERData : NORMAL
GCSec : EMPTY
Done!
Elapsed: 00:00:16
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:19
Old 01-29-2020, 14:26   #62164 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,150
Oppo A37f QLM Pattren Reset Done With Lose Data With King Infinity CM2
Card found : A19EC787 , v0138
Operation : Read PatternLock [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 1F431EC9
ID_BLOCK_L : DE265CBA15818EB966DB351AE5BC3414
ID_BLOCK_L : 1E75DB7267EE50D5E8C7884143A2BC9F
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 36957
Done!
Elapsed: 00:00:16
Old 01-29-2020, 14:35   #62165 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 2,033
Coolpad y71-811 format all done
Operation : Identify [ v2.07 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM6)
MODE : PRELOADER PORT
PORT : 6
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 90014A4841473265050760A1D5334C25
DAInf: 4 : 2 : 155
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 90014A484147326550760A1D5339225
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG2e
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3AB800000 [ 14.68 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 82306EF16CD898275BEE253F13C9F6E
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level : LMY47D
Ver. CodeName : REL
Ver. Release : 5.1
Sec. Patch : 2016-05-01
Build Time : 1470057741
Product Model : Y71-811
Product Brand : Coolpad
Product Name : CPY71_811
Product Device : CPY71_811
Product Manfct : Coolpad
Board Platform : mt6735m
Product Info : CPY71_811
Display ID : 5.1.023.P1.Y71-811
USERDATA : PLAIN ( NOT encrypted )
IMEI[0] : 868423022435270
IMEI[1] : 868423022447267
NVRAM check : Passed!
Done!
Elapsed: 00:00:17
Operation : Reset Settings/Format FS [ v2.07 ]
PORT : 6
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:45
Old 01-29-2020, 14:37   #62166 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,123
Operation : Format FileSystem [ v1.05 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Spreadtrum Boot Block version 1.2
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_107 D36642A88_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:25
Old 01-29-2020, 14:37   #62167 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,679
Lava z60 7.0 frp done one click
LAVA Z60 7.0 FRP DONE ONE CLICK
http://www.youtube.com/watch?v=umAZ0j0ol34
Old 01-29-2020, 14:38   #62168 (permalink)
Member: 1080718
Thanks Meter: 2,123
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1C6 BFE9CF8ED_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:19
Old 01-29-2020, 14:38   #62169 (permalink)
Member: 1080718
Thanks Meter: 2,123
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0F9 8456C8F7F_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:19
Old 01-29-2020, 14:40   #62170 (permalink)
Member: 1080718
Thanks Meter: 2,123
Qmobile A290 hang on logo done with cm2
======= Flash
Wait for phone...
Phone found! [ 23 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A4834473164040506A206C82271
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040506A206C82271
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x033C5217539B5FC27503A5A24A0BFFA7
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
BL : Skip checking by User request!
BL : BatteryLevel : 3772 mV
BL : BatteryLevel Ok
Preloader Download skipped by user request!
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:31
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : SEC_RO
Verify Passed : ANDROID
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:37
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:17
Old 01-29-2020, 14:43   #62171 (permalink)
Member: 1080718
Thanks Meter: 2,123
Qmobile A550 Fully Dead Recover Done With Great King CM2
======= Flash
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A483447316404860CA2A06AA073
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
[eMMC] : FLASH_CID : 90014A483447316404860CA2A06AA073
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0x033C521702A7E490C8B5058C3970B48E
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s7611a , Storage : EMMC
Switching to HSUSB
HSUSB Init Ok
BL : BatteryLevel : 3702 mV
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E3000000
Flash Pre-Erase Done, time used : 00:00:02
Use : preloader_s7611a.bin
PartCount : 0014
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:04:47
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR2
Verify Passed : FAT
Data Verify Done, time used : 00:00:47
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:06:06
Old 01-29-2020, 15:01   #62172 (permalink)
Member: 1080718
Thanks Meter: 2,123
Tecno Spark Kc2 Dl fix done With Great King CM2
Operation : Fix DL [ v2.07 ]
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM7)
PORT : 7
BROM : Init BROM
BROM init passed!
CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
MODE : TECNO : SECURE_v2 | Manual : Disabled
AGENT : MTK_AllInOne_DA_SWSEC.bin
AGENT : Found MT6761
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
SRAM: 0x00080000 [ 512.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 150100474436424D42018BA296738627
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB
EMMC:
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : DDF1CD779851076CE49794CC4C06AC96
Boot done!
DLFix : Init
DLFix : Prepare ...
DLFix : Process ...
Done!
Elapsed: 00:00:39
Old 01-29-2020, 15:03   #62173 (permalink)
Member: 1080718
Thanks Meter: 2,123
Tecno spark kc2 frp remove done with great king cm2
PORT : 7
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Done!
Elapsed: 00:00:22
The Following User Says Thank You to Nadeem Waris For This Useful Post:
Old 01-29-2020, 15:50   #62174 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,679
MOTO E4 XT1762 DS hang on logo Done
http://www.youtube.com/watch?v=dCdNs0RARf8
Old 01-30-2020, 04:32   #62175 (permalink)
Member: 1080718
Thanks Meter: 2,123
Gresso Metal1 fully dead recover done just 1 click with cm2
SPRD mode : SC6531 : REV : E000 : NOR : [ 4MB ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1E7 8B71F8EF9_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:16
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.51366 seconds with 9 queries
