02-06-2020, 11:29 | #62371 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | infnix hot 4 pro frp reset done Load IDBase v123080 Ok! Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100514531334D420D9338A86D1B0D DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514531334D420D9338A86D740D EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A23F953A21DCA6A96E5C23FF6FE1151 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Display ID : X572-H5312CE-N-181011V97 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-09-05 Build Time : 1539245564 Product Model : Infinix X572 Product Brand : Infinix Product Name : H5312 Product Device : Infinix-X572 Product Manfct : Infinix Board Platform : mt6753 Product Info : Infinix-X572 USERDATA : ENCRYPTED Done! Elapsed: 00:00:20 Operation : Reset Settings/Format FS [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM4) MODE : PRELOADER PORT PORT : 4 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6753 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100514531334D420D9338A86D1B0D DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100514531334D420D9338A86D740D EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A23F953A21DCA6A96E5C23FF6FE1151 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:01:35 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Arslanmayo For This Useful Post: |
02-06-2020, 12:31 | #62373 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Nigeria
Member: 974244 Status: Offline Thanks Meter: 50 | Itel P33 privacy done by cm2spd2.03 Card found : E3B1B8F3 , v0138 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.03 Load IDBase v10107 Ok! Operation : Read PrivacyLock [ v2.03 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PASSWORD : 357951 CONTACTS : 08142154353 Reconnect Power/Cable! Done! Elapsed: 00:02:10 |
The Following User Says Thank You to philantropist For This Useful Post: |
02-06-2020, 12:36 | #62374 (permalink) |
Member: 974244 Status: Offline Thanks Meter: 50 | mobicel option in spd2 remove frp itel a14 Card found : E3B1B8F3 , v0138 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.03 Load IDBase v10107 Ok! Operation : Format FS / Reset Settings [ v2.03 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Mobicel : ASTRO Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:12 Operation : Read FW [ v2.03 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Mobicel : ASTRO Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! |
02-06-2020, 12:45 | #62375 (permalink) |
Member: 974244 Status: Offline Thanks Meter: 50 | itel p33plus read info an other operations done by spd2 2.03 Card found : E3B1B8F3 , v0138 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.03 Load IDBase v10107 Ok! Operation : Format FS / Reset Settings [ v2.03 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.03 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v2.03 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : W6001-F3103-8.1-OP-V051-20191216 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-12-05 Build Time : 1576480750 Product Model : itel W6001 Product Brand : Itel Product Name : F3103 Product Device : itel-W6001 Product Manfct : itel Product Info : F3103 Product Board : itel-W6001 Board Platform : sp7731e Display ID : W6001-F3103-8.1-OP-V051-20191216 Update DataBase ... Platform Version: MOCORTM_17C_W18.31.2_P26_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.31.2_P26 HW Version: sc7731e_modem CMP_Time : 10-18-2019 17:20:01 MODEM TAG : MOCORTM_17C_W18.31.2_P26_Debug_FM_BASE_17C_W18.31. 2_P26_sc7731e_modem_pike2_pub UserData : STATE : PLAIN Done! Elapsed: 00:02:25 Operation : Format FS / Reset Settings [ v2.03 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:12 Operation : Format FS / Reset Settings [ v2.03 ] Mode : Reset Settings [ Format FS ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Reconnect Power/Cable! Done! Elapsed: 00:00:59 |
02-06-2020, 14:00 | #62377 (permalink) | |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | Tablate condor tfx-708g FRP REMOVE DONE assalamu alaykom by ali2287 DZGSM Quote:
The Following 3 Users Say Thank You to profkefah For This Useful Post: |
02-06-2020, 14:05 | #62378 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,802 | Itel it1516 Plus FLASHING DONE assalamu alaykom by الفرسان فون gem-flash |
02-06-2020, 14:45 | #62379 (permalink) |
Freak Poster Join Date: Nov 2019 Location: South Africa Age: 33
Member: 2934673 Status: Offline Sonork: Still Not Created Thanks Meter: 218 | vodacom kicka 5 network unlock DONE CM2 Card found : 84B8FE80 , v0139 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.07 Load IDBase v124106 Ok! Operation : SP Unlock [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM37) MODE : PRELOADER PORT PORT : 37 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017041493848190501343F462011 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 7001004548384941340105191120463F EMMC: VEN : KINGSTON | OEM : 01 | DEV : EH8IA4 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1C8000000 [ 7.13 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : D920BBBD13482D90C72B779380F204C9 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ID0 : Lock : Locked! | MNC : 512 | CNT : 219 | CODE : 12345678 ID1 : Lock : Not Locked! ID2 : Lock : Not Locked! ID3 : Lock : Not Locked! ID4 : Lock : Not Locked! ID5 : Lock : Not Locked! ID6 : Lock : Not Locked! Direct unlock done! Done! Elapsed: 00:00:19 YOUTUBE VIDEO HERE https://www.youtube.com/watch?v=dj3dEVpiNhs |
The Following 4 Users Say Thank You to GSM.AFRICA For This Useful Post: |
02-06-2020, 14:51 | #62380 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Gtab Tab G18I MT6582 Logo Stuck Fix Only Formate With King Infinity CM2 Card found : S/N : A19EC787 , v0138 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642023C20F3C561257 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642023C20F3C561257 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000001CE100000 [eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395790B74587095034082347A6A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:44 Reconnect Power/Cable! |
02-06-2020, 17:56 | #62381 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | Flash done infinix x626 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM19) MODE : PRELOADER PORT PORT : 19 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : INFINIX : SECURE_BASE | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SWSEC.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] EMMC: 700100544132383332231DD96B6E2683 EMMC: VEN : KINGSTON | OEM : 01 | DEV : TA2832 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x74A000000 [ 29,16 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 894B83F88FEFA8E7A63C4C85A55E53A6 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000009B00000 Erase : 0x000000000DB00000 : 0x000000011E500000 Erase : 0x0000000130000000 : 0x000000000E900000 Erase : 0x000000013EC00000 : 0x0000000016280000 Erase : 0x0000000156E80000 : 0x00000000C4180000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : MD1IMG Write : SPMFW Write : SCP1 Write : SCP2 Write : SSPM_1 Write : SSPM_2 Write : LK Write : LK2 Write : BOOT Write : LOGO Write : DTBO Write : TEE1 Write : TEE2 Write : VENDOR Write : SYSTEM Write : VBMETA Write : CACHE Write : RECOVERY Write : TKV Write : TRANFS Write : USERDATA SEC_DL : False (RAPHAEL) SEC_ID : 0x494E46494E495459424F584245535432 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:23 Reconnect Power/Cable! |
The Following User Says Thank You to tikourine For This Useful Post: |
02-07-2020, 06:59 | #62382 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Inside
Member: 455852 Status: Offline Sonork: 100.1596308 Thanks Meter: 1,993 | Fly FS517 Alive with cm2 SPD Chinese Miracle II [SPD module] v 1.25 Set mode to : SP SC77xx [Model Select] Loading : FS517_SW_20170908_SW17_FLY.pac CRVersion : BP_R1.0.0 PacCPUinfo : SharkLSGLobalMarlinAndroid5.1 PacVersion : SW17_FLY_FS517_2017_09_08 FastCheck : 0x0093ED08D0 Loading files ... File : fdl1.bin File : fdl2.bin File : ltenvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : ltemodem.bin File : ltedsp.bin File : ltegdsp.bin File : ltewarm.bin File : pmsys.bin File : wcnfdl.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo.bmp File : cache.img File : persist.img File : sysinfo.img File : u-boot.bin File : SharkLSGLobalMarlinAndroid5.1.xml Load Ok! ==== Wait for phone... Phone found! [ 23 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x26 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WLTE Current File : ltemodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_WLTE_LTE Current File : ltedsp.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_WLTE_GGE Current File : ltegdsp.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : WARM_WLTE Current File : ltewarm.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DFS Current File : pmsys.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FDL_WCN Current File : wcnfdl.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : wcnmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WLTE Current Part : l_runtimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : PERSIST Current File : persist.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : SYSINFO Current File : sysinfo.img Flashing now ... [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:03:53 Reconnect Power/Cable! |
02-07-2020, 10:43 | #62383 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | leagoo z6 mini frp off Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 184 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000000804F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
02-07-2020, 13:16 | #62384 (permalink) |
No Life Poster Join Date: Feb 2019 Location: Madagascar
Member: 2897012 Status: Offline Thanks Meter: 400 | Wiko sunny2 hang on logo solved by cm2 Code: Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Wiko : SUNNY2 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : MRA58K release-keys Ver. Incmt : 109 Ver. CodeName : REL Ver. Release : 6.0 Sec. Patch : 2017-09-05 Build Time : 1508118076 Product Board : v2510 Board Platform : sc8830 Product Info : v2510 Product Model : SUNNY2 Product Brand : WIKO Product Name : V2510 Product Device : V2510 Product Manfct : WIKO SecInfo : IMEI[1] : 35xxxxxxxxxxxx9 IMEI[2] : 35xxxxxxxxxxxx9 IMEI[3] : 35xxxxxxxxxxxx3 WIFIMAC : BC4101FC0A39 BT_MAC : 89CDFC0141BC Platform Version: MOCORTM_W16.28.2_P11_Debug Project Version: sc7731C_CP0_modem BASE Version: TM_BASE_W16.28.2_P11 MMI Version: sc7731C_modem HW Version: sc7731C_CP0_modem CMP_Time : 10-02-2017 18:13:10 MODEM TAG : MOCORTM_W16.28.2_P11_Debug_TM_BASE_W16.28.2_P11_sc7731C_CP0_modem_sc7731C_CP0_modem_sc7731C_modem UserData : STATE : PLAIN Done! Elapsed: 00:01:34 Operation : Format FS / Reset Settings [ v2.04 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Wiko : SUNNY2 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:01:15 |
02-07-2020, 13:30 | #62385 (permalink) |
Member: 2897012 Status: Offline Thanks Meter: 400 | Doogee x60l hang on logo done by cm2 Code: Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.07 Load IDBase v120125 Ok! Update configuration ... Update Ok! Load IDBase v120125 Ok! Operation : Identify [ v2.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port_V1632 (COM37) MODE : BOOTROM PORT : 37 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A48414732650507420010370D6D DAInf: 4 : 2 : 155 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 484A019065324741004207056D0D3710 NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : eMMC [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x40000000 [ 1,00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147326550742001037926D EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG2e EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB800000 [ 14,68 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x40000000 [ 1,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 638261C48CB3F417C47E3A7F3B6C8BDB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM183) MODE : PRELOADER PORT PORT : 183 Boot done! Patch Level : NRD90M Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-02-05 Build Time : 1524821179 Product Model : X60L Product Brand : DOOGEE Product Board : t596_dg_d5506_x60l_n_37m35 Product Manfct : DOOGEE Board Platform : mt6737m Product Info : t596_dg_x60l Display ID : DOOGEE-X60L-android7.0-20180116 Product Name : t596_dg_x60l Product Device : t596_dg_x60l Product Board : t596_dg_d5506_x60l_n_37m35 USERDATA : PLAIN ( NOT encrypted ) Backup sensetive data [ 10 ] Backup path : Backup\MT6735__638261C48CB3F417C47E3A7F3B6C8BDB\ [3] Read : NVRAM [19] Read : NVDATA [2] Read : PROINFO [6] Read : LK [4] Read : PROTECT1 [5] Read : PROTECT2 [0] Read : PRELOADER Backup done! Done! Elapsed: 00:00:55 Code: Operation : Write Flash [ v2.07 ] Repartition : Enabled Flash Verify : Disabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Flash Format : Disabled Files :11 [FL] : Set : preloader_t596_dg_d5506_x60l_n_37m35.bin [FL] : Set : lk-verified.bin [FL] : Set : boot-verified.img [FL] : Set : recovery-verified.img [FL] : Set : logo-verified.bin [FL] : Set : secro-verified.img [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0x8F7492FC [ 2,24 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM146) MODE : PRELOADER PORT PORT : 146 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 90014A48414732650507420010370D6D DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147326550742001037926D EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG2e EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB800000 [ 14,68 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 638261C48CB3F417C47E3A7F3B6C8BDB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (CUST) SEC_DL : SECURE USB DL DISABLED SEC_ID : 0x35464646304237304435444533464335 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000000080000 Erase : 0x0000000001C80000 : 0x0000000124B80000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader code ... Update bootloader Ok! Write : LK Write : BOOT Write : RECOVERY Write : LOGO Write : SECRO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:03:51 Last edited by Manikanika81; 02-07-2020 at 13:37. |
