03-18-2020, 13:36 | #62836 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Zimbabwe
Member: 2692778 Status: Offline Thanks Meter: 49 | Itel p33 successfully done Reconnect Power/Cable! Operation : Read PrivacyLock [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PASSWORD : 654321 CONTACTS : 0783309855 Reconnect Power/Cable! Done! Elapsed: 00:01:03 |
The Following 2 Users Say Thank You to bobohshacks For This Useful Post: |
03-18-2020, 14:04 | #62837 (permalink) |
Freak Poster Join Date: Aug 2016 Location: pakistan
Member: 2607653 Status: Offline Sonork: family members Thanks Meter: 177 | Q Infinity Blade SC7731GEA 8.1 Read Firmware Done CM2SP2 2.04 Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731GEA_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Device info : Patch Level : MRA58K Display ID : J106_V04-B_Infinity_blade_V1.0_20190905 Ver. Incmt : root-103233 Ver. CodeName : REL Ver. Release : 8.1 Sec. Patch : 2016-07-01 Build Time : 1567679979 Product Brand : android_1 Product Name : Infinity_blade Product Device : Infinity_blade Product Board : sp7731gea_hdr Product Manfct : android_1 Board Platform : sc8830 Product Info : Infinity_blade Product Model : Infinity blade AndroidVer : 8 VlnrLevel : 0x01 SC8830__android_1__Infinity_blade__8.1__J106_V04-B_Infinity_blade_V1.0_20190905__MRA58K__Infinity_b lade Read : prodnv.img ExtSparse : Compression ratio : 83% Read : phase.cfg Read : wmodem.bin Read : wdsp.bin Read : wnvitem.bin Read : modem_wcn.img Read : wcnnvitem.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : logo2.bin Read : logo3.bin Read : logo4.bin Read : logo5.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 88% Make : persist.img Read : sysinfo.bin ExtSparse : Compression ratio : 6% Make : cache.img Read : recovery.img Make : userdata.img Read : u-boot.bin Read : u-boot-spl.bin Firmware size : 0x484273AC ( 1.13 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! |
The Following 3 Users Say Thank You to jonny12345 For This Useful Post: |
03-18-2020, 18:44 | #62838 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Vivo_Y91C_PD1818H Flashing Done Thanks Best Regards Last edited by CYB3R GSM; 03-18-2020 at 18:51. Reason: Link Updated |
The Following User Says Thank You to CYB3R GSM For This Useful Post: |
03-18-2020, 19:34 | #62839 (permalink) |
No Life Poster Join Date: Feb 2019 Location: Madagascar
Member: 2897012 Status: Offline Thanks Meter: 400 | Itel 6910 passcode reset done Operation : Format FileSystem [ v1.05 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 653x NOR v1.3(c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q64 : 0x00800000 [ 8MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00800000_FMT_BACK_049 8C5800452_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:52 |
The Following User Says Thank You to Manikanika81 For This Useful Post: |
03-19-2020, 06:59 | #62840 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile LT550 F.R.p Reset Done Operation : Format FS / Reset Settings [ v2.04 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : Qmobile : QMobile LT550 Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:50 |
03-19-2020, 07:43 | #62841 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile M350 Pro MT6580 FRP Reset Done With Kiing Infinity CM2 Code: Card found : S/N : A19EC787 , v0138 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D420020B8CCAE1347 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D420020B8CCAE1347 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395693FD102BEED6A5E4E6B6B4E INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable!a |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
03-19-2020, 07:54 | #62842 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile i6 Metal One F.R.p Reset Done Operation : Format FS / Reset Settings [ v2.04 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731x_BASE : SC7731C_eMMC_1GB_NS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... ProtoEx : : TRCC not supported! FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:42 |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
03-19-2020, 08:05 | #62843 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Oppo A37F FRP Reset Done With King Infinity CM2 Code: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 2300C661 ID_BLOCK_L : 669EF402AD3926211E739D824D149CAC ID_BLOCK_L : DBAA14B7B82B9310B5005582806F7942 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
03-19-2020, 09:10 | #62844 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Tanzania
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | tecno RA7 Tigo unlock done >>> Repeat operation in META mode [ Platform -> Global -> Meta ] Reconnect Power/Cable! Operation : SP Unlock [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM12) MODE : PRELOADER PORT PORT : 12 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META enter failed by timeout! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : SP Unlock [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM12) MODE : PRELOADER PORT PORT : 12 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6739,S01 AP_SWVR : RA7-H394B-OGo-TZTG-LC-190726V19 MD_CHIP : MT6739 MD_SWVR : TK_MD_BASIC_HW IMEI[1] : 355xxxxxxxxxx ID0 : Lock : Locked! | MNC : 1792 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 IMEI[2] : xxxxxxxxxxx ID0 : Lock : Locked! | MNC : 256 | CNT : 16 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 Done! Elapsed: 00:01:03 |
The Following User Says Thank You to ::Evari77:: For This Useful Post: |
03-19-2020, 09:35 | #62845 (permalink) |
Freak Poster Join Date: May 2009 Location: Zimbabwe
Member: 1038694 Status: Offline Sonork: 86 Thanks Meter: 30 | hisense F16 network unlock done Operation : SP Unlock [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM28) MODE : PRELOADER PORT PORT : 28 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6739,S01 AP_SWVR : alps-mp-o1.mp1_P18 MD_CHIP : MT6739 MD_SWVR : TK_MD_BASIC_HW IMEI[1] : 862773041130799 ID0 : Lock : Locked! | MNC : 1280 | CNT : 5 | CODE : 12345678 ID1 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 56781234 ID2 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 11112222 ID3 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 33334444 ID4 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 55556666 ID5 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 77778888 ID6 : Lock : Not Locked | MNC : 0 | CNT : 5 | CODE : 99990000 Done! Elapsed: 00:00:53 |
The Following 2 Users Say Thank You to moses caston For This Useful Post: |
03-19-2020, 10:07 | #62846 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | nokai 3310 TA-1036 Format FS done Operation : Identify [ v1.20 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! SW_VERS : 15.0.0.17.00 PC_EXTR : MX 059Z3W0 IMEI[1] : 357306082976713 IMEI[2] : 352751019523267 BT_ADDR : 53EC5265A390 Security saved : NKSPDv2_357306082976713.scnv Done! Elapsed: 00:00:50 Operation : Reset Settings ( Format FS ) [ v1.20 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version BootVersion : BEST RETRO3G Port speed : 921600 FDL Flash : Control transfered! Boot Done! Erase BLK #0 Erase BLK #1 Erase BLK #2 Erase BLK #3 Format Ok! Done! Elapsed: 00:01:22 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to wsmobile For This Useful Post: |
03-19-2020, 10:37 | #62847 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | itel A23S sp9832e 8.1.0 FLASH DONE Code: Card found : 9... , v0140 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.04 Load IDBase v1119 Ok! Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2020 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : OPM2.171019.012 Display ID : A23S-SU335-8.1-MZ-Voda-L-V012-20191217 Ver. Incmt : MZ-Voda-L-V012-20191217 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-12-05 Build Time : 1576572127 Product Model : itel A23S Product Brand : Itel Product Name : SU335 Product Device : itel-A23S Product Manfct : ITEL MOBILE LIMITED Product Info : itel A23S Product Board : sp9832e_1h10_32b Board Platform : sp9832e Code: Operation : Flash Firmware [ v2.04 ] Setting : Update NVRAM : True Setting : Force NVRAM : True Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x21 PMTMng : Update PMT Ok! NVRM : nvitem_l.bin NVMng : Load 0x30 NVMng : Init SRC NVMng : SecurityInfo IMEI[1] : 354608091213457 IMEI[2] : 354648020000004 IMEI[3] : 867400020316638 WIFIMAC : FFFFFFFFFFFF BT_MAC : FFFFFFFFFFFF NVMng : Backup Ok , 0x000C61C8 NVMng : Init DST NVMng : Rx28 : Wx27 NVMng : NVM block updated! UBOOT : u-boot.bin UBOOT : u-boot.bin CODE : sml.bin CODE : sml.bin CODE : tos.bin CODE : tos.bin CODE : vbmeta.img CODE : vbmeta.img CODE : ldsp_l.bin CODE : gdsp_l.bin CODE : modem_l.bin CODE : deltanv_l.bin ERASE : FLASH_L CODE : modem_wcn.img CODE : gnssmodem.bin CODE : gnssbdmodem.bin CODE : pm_sys.bin ERASE : MISC CODE : boot.img CODE : recovery.img FSIMG : persist.img CODE : boot_logo.bmp CODE : fastboot_logo.bmp FSIMG : system.img FSIMG : vendor.img FSIMG : userdata.img FSIMG : cache.img FSIMG : prodnv.img ERASE : UBOOT_LOG UBOOT : u-boot-spl.bin Flashing finished! Reconnect Power/Cable! Done! Elapsed: 00:03:49 |
The Following 2 Users Say Thank You to yuranc8 For This Useful Post: |
03-19-2020, 17:19 | #62848 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Vodafone VDF 300 Mini7 MT6580 Dead Set Alive Done By Flashing With Infinity CM2 Code: Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : MT6580__VODAFONE__VFD_300__Smart_mini7__VFD300__alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P115__Android_6.0.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100464A323541420283E1D0513507 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BA52J [eMMC] : FLASH_CID : 150100464A323541420283E1D0513507 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395774AF1F7E19707BFD0E156D5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : 6580 , TARGET ID : 6580 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MT6580__VODAFONE__VFD_300__Smart_mini7__VFD300__alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P115__Android_6.0.ispff Init Ok , Sending blocks ... Write done , 3728 blocks sent Done! Elapsed: 00:05:51 Reconnect Power/Cable! |
03-20-2020, 07:55 | #62849 (permalink) |
No Life Poster Join Date: Sep 2015 Location: SINDH, PAKISTAN.
Member: 2452939 Status: Offline Thanks Meter: 256 | Vivo V15 1819 Reset done With CmMT2 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.09 Load IDBase v36128 Ok! Update configuration ... Socket Error # 11001 Host not found. Update failed! Check settings and/or internet connection! Operation : Reset Settings/Format FS [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6771 AP_SWTM : Thu Jan 2 20:07:54 CST 2020 AP_SWVR : alps-mp-p0.mp3.tc19sp-V1.4.1_bbk.p0mp3.k71v1.64.bsp_P286 Format Ok : UserData Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
The Following 4 Users Say Thank You to GSM SINDH For This Useful Post: |
03-20-2020, 07:58 | #62850 (permalink) |
Member: 2452939 Status: Offline Thanks Meter: 256 | Vivo Y90 Reset Done With CM2MT2 Operation : Reset Settings/Format FS [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM16) MODE : PRELOADER PORT PORT : 16 Waiting BOOT ack ... PRELOADER : ACK confirmed! INIT : META confirmed! Boot done! AP_CHIP : MT6761,S01 AP_SWVR : alps-mp-o1.mp7.tc19sp-V1.19_k61v1.64.bsp_P83 AP_HWVR : S01 Format Ok : UserData Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
