03-20-2020, 12:19 | #62851 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile Blue 5 Format Done Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM216) MODE : PRELOADER PORT PORT : 216 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 5100011541535838598C0642B13212DC DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100513858534142068C59DC1232B1 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : Q8XSAB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3A3E00000 [ 14.56 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E88DF8DEDCA1C7F7B794FADB5001EC3 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
03-20-2020, 12:22 | #62852 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile Energy X2 F.R.p Reset Done Operation : Reset Settings/Format FS [ v2.09 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : PreLoader USB VCOM Port (COM216) MODE : PRELOADER PORT PORT : 216 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 484A019065324741D935070577B35AB6 DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147326550735D9B65AB377 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG2e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB800000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : A076D0DDBCD29F63D05C9B911724CB79 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
03-20-2020, 13:59 | #62853 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Zimbabwe
Member: 2692778 Status: Offline Thanks Meter: 49 | Vivo y854 frp & factory reset successfully done Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : EA27A9B3 ID_BLOCK_L : 9CBB6083EE91AEFCB870F81AF625992A ID_BLOCK_L : E0A53FD222D0E7A021BE5213BC506537 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB Boot Ok! Brand : vivo ProdName : msm8953_64 ProdModel : vivo PD1730 Device : msm8953_64 AndroidVer: 8.1.0 Manufact. : vivo SysPatch : OPM1.171019.011 DevComTime: 1/4/2020 10:13:02 AM USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:22 Reconnect Power/Cable! Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 625 [MSM8953] ID_BLOCK_S : EA27A9B3 ID_BLOCK_L : 9CBB6083EE91AEFCB870F81AF625992A ID_BLOCK_L : E0A53FD222D0E7A021BE5213BC506537 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to bobohshacks For This Useful Post: |
03-20-2020, 22:26 | #62854 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Vonino Epic_E8 Motherboard : L8080F_V1_2016.07.21 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4E03018864726143B34D432067155718 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E4361726420434DB31857C367 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x000000039D000000 [eMMC] : FLASH_UCP : 14800 MiB [eMMC 16 GiB] DEV RID : 0x7D96EB90417E58F42BE889618DE3F3C1 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Vonino ProdName : Epic_E8 ProdModel : Epic E8 Device : Epic_E8 AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.0.2_elink8735b.p3h_P22 SECURITY : IMEI_SW [1] : 355806072xxxxxx IMEI_SW [2] : 869823931xxxxxx BTMAC Addr : 54EF92638781 WiFi MAC : 54EF92639145 Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4E03018864726143B34D432067155718 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E4361726420434DB31857C367 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x000000039D000000 [eMMC] : FLASH_UCP : 14800 MiB [eMMC 16 GiB] DEV RID : 0x7D96EB90417E58F42BE889618DE3F3C1 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NVM Read Ok, MT6737_eMMC.spnv Done! Elapsed: 00:01:03 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 4E03018864726143B34D432067155718 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E4361726420434DB31857C367 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x000000039D000000 [eMMC] : FLASH_UCP : 14800 MiB [eMMC 16 GiB] DEV RID : 0x7D96EB90417E58F42BE889618DE3F3C1 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Vonino ProdName : Epic_E8 ProdModel : Epic E8 Device : Epic_E8 AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.0.2_elink8735b.p3h_P22 [Read Ok] : preloader_elink8735b_p3h.bin [Read Ok] : items.img [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6737M / V1.1.2 / elink8735b_p3h / EMMC Android Info saved HWConfig Info saved FW Size : 2434 MiB Scatter saved to : D:\Documents and Settings\Hugo\Ambiente de trabalho\Vonino Epic_E8\MT6737M__Vonino__Epic_E8__Epic_E8__7.0__al ps-mp-n0.mp1-V1.0.2_elink8735b.p3h_P22\ All done! Done! Elapsed: 00:14:39 Reconnect Power/Cable! |
The Following User Says Thank You to ct3im For This Useful Post: |
03-21-2020, 05:44 | #62855 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Call Me C86 SPD Illegal Use Fix Only Formate With King Infinity CM2 Code: Card found : A19EC787 , v0138 Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.05 SCRD mode : AUTO SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ] SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ] Operation : Format FileSystem [ v1.05 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Format FileSystem [ v1.05 ] 1. Power off device 2. Press and hold BootKey or use BootCable 3. Insert cable and battery in device! Wait for device ... Device Connected! BootVersion : SPRD3 BootSource : InternalLibrary BootVersion : Infinity SCR 6531EFM v2.0 (c)2019 Port speed : 921600 FDL Flash : Control transfered! Boot Done! CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ] Make backup of sensetive data Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_036DAFF19B21_NVM.nv Executing FormatFFS ... Format FFS Done! Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post: |
03-21-2020, 08:33 | #62856 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile XLI SPD FRP Reset Done With King Infinity CM2 Code: Card found : A19EC787 , v0138 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.03 Load IDBase v10107 Ok! Operation : Format FS / Reset Settings [ v2.03 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : BQru : BQ-5002G Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:31 |
03-21-2020, 16:10 | #62857 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X700 Pro Lite MT6580 FRP Reset Done With King Infinity CM2 Code: Card found : S/N : A19EC787 , v0138 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505072BA4058F337D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505072BA4058F337D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3955EF504CAFBBE331F2B846D54 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
03-21-2020, 16:11 | #62858 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X700 Pro Lite MT6580 FRP Reset Done With King Infinity CM2 Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505074E99D9D9A3CD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505074E99D9D9A3CD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395C52CF233DD23C4251F726F11 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
03-22-2020, 11:25 | #62859 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Vivo 1815 frp reset done in flash mode Operation : Identify [ v2.09 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM18) MODE : PRELOADER PORT PORT : 18 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Vivo : SEC_MT6765 | Manual : Disabled BROM : SOCID : 9F397D48DB807F97A01CB21E9EEFEE1B5B6A020F79BC2E6499 5EE61E0D9E7022 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: 90014A484247346132A523B79C143589 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 559ABBA3348BB48EF2ED06C270588F0 DA : USB : HIGH-SPEED Boot done! Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-01-05 Build Time : 1581426572 Product Model : vivo 1815 Product Brand : vivo Product Name : PD1818CF_EX Product Device : PD1818CF_EX Product Manfct : vivo Product Info : k62v1_64_bsp Product Board : k62v1_64_bsp Board Platform : mt6765 USERDATA : ENCRYPTED NVRAM check : Passed! STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:18 Operation : Reset Settings/Format FS [ v2.09 ] Mode : FRP [ RESET PROTECTION ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM18) MODE : PRELOADER PORT PORT : 18 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000005 BROM : SecMode : SBC+SDA BROM : PRELOADER PORT MODE : Vivo : SEC_MT6765 | Manual : Disabled BROM : SOCID : 9F397D48DB807F97A01CB21E9EEFEE1B5B6A020F79BC2E6499 5EE61E0D9E7022 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] EMMC: 90014A484247346132A523B79C143589 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 559ABBA3348BB48EF2ED06C270588F0 DA : USB : HIGH-SPEED Boot done! Format Ok : RESET PROTECTION Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
03-22-2020, 11:29 | #62860 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Vivo 1815 pattern lock remove done in meta mode Operation : Identify [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM76) MODE : BOOTROM PORT : 76 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 9F397D48DB807F97A01CB21E9EEFEE1B5B6A020F79BC2E6499 5EE61E0D9E7022 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765,S01 AP_SWVR : alps-mp-o1.mp6.tc19sp-V2_k62v1.64.bsp_P293 AP_HWVR : S01 MD_CHIP : MT6765 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR12A.R2.MP.V23.P199 MD_SWVR : BBK_O1MP6_K62V1_64_BSP_HW MD_HWVR : Unknown Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2020-01-05 Build Time : 1581426572 Product Model : vivo 1815 Product Brand : vivo Product Name : PD1818CF_EX Product Device : PD1818CF_EX Product Manfct : vivo Product Info : k62v1_64_bsp Done! Elapsed: 00:00:55 Operation : Reset Settings/Format FS [ v2.09 ] Mode : META Card found : A6936825 , v0140 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.09 Load IDBase v36128 Ok! Operation : Reset Settings/Format FS [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM76) MODE : BOOTROM PORT : 76 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 0000 0000 [0200] V0: 0000 0000 [0001] BROM : SOCID : 9F397D48DB807F97A01CB21E9EEFEE1B5B6A020F79BC2E6499 5EE61E0D9E7022 BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6765,S01 AP_SWVR : alps-mp-o1.mp6.tc19sp-V2_k62v1.64.bsp_P293 AP_HWVR : S01 Format Ok : UserData Done! Elapsed: 00:00:47 Reconnect Power/Cable |
03-22-2020, 14:18 | #62861 (permalink) |
Junior Member Join Date: Mar 2020 Location: karachi, pakistan
Member: 2951627 Status: Offline Thanks Meter: 0 | plzz anyone help me. Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3332383C910042638926DE Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200913CDE267363 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xC791CE1E9136C145EB8D77FA6E87DD89 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... [Error] : Bad Magic! Encrypted FS! [Info] : DP Lock not set! Done! Elapsed: 00:00:13 Reconnect Power/Cable! |
03-23-2020, 09:59 | #62862 (permalink) | |
No Life Poster Join Date: Jun 2013 Location: BANGLADESH+UAE Age: 34
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | Quote:
03-25-2020, 07:02 | #62864 (permalink) |
No Life Poster Join Date: Feb 2019 Location: Madagascar
Member: 2897012 Status: Offline Thanks Meter: 400 | Asus_x008d pattern & frp look removed done Code: Operation : Identify [ v2.09 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM119) MODE : PRELOADER PORT PORT : 119 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : ASUS : X008 [ ZC5xx ] | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100525831424D4207D5B0ACE338EB DAInf: 4 : 2 : 147 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100525831424D4207D5B0ACE3B3EB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX1BMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C864AEB1FA3C2235E020230823823CB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : NRD90M Display ID : NRD90M.WW_Phone-14.10.1807.110-20180705 Ver. CodeName : REL Ver. Release : 7.0 Sec. Patch : 2018-07-05 Build Time : 1530781659 Product Model : ASUS_X008D Product Brand : asus Product Name : WW_Phone Product Device : ASUS_X008_1 Product Board : MT6737 Product Manfct : asus Board Platform : mt6737m Product Info : ASUS_X008D USERDATA : ENCRYPTED Done! Elapsed: 00:00:33 Code: Operation : Reset Settings/Format FS [ v2.09 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM119) MODE : PRELOADER PORT PORT : 119 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : ASUS : X008 [ ZC5xx ] | Manual : Disabled BROM : Change Configuration settings for target AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6735 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 150100525831424D4207D5B0ACE338EB DAInf: 4 : 2 : 147 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100525831424D4207D5B0ACE3B3EB EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX1BMB EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x747C00000 [ 29,12 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0xC0000000 [ 3,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : C864AEB1FA3C2235E020230823823CB STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Format Ok : USERDATA Done! Elapsed: 00:00:59 Reconnect Power/Cable! |
The Following User Says Thank You to Manikanika81 For This Useful Post: |
03-25-2020, 12:01 | #62865 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,639 | WORLD FIRST MOBICEL GEO 9.0 FW BACKUP, FRP RESET done Code: Card found : 9EF826E0 , v0140 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.08 Load IDBase v124106 Ok! Operation : Identify [ v2.08 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : Yuranc8.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 90014A483847346132A51FF8C07886DB EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E8CA1F12E6D03AC91238FFA661797AB9 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.181008.011 Display ID : PPR1.181008.011 release-keys Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-11-05 Build Time : 1573822753 Product Model : GEO Product Brand : Mobicel Product Name : GEO Product Device : GEO Product Board : GEO Product Manfct : Mobicel Product Info : GEO Product Board : k510 Board Platform : mt6739 Product Model : GEO Product Brand : Mobicel Product Name : GEO Product Device : GEO Product Manfct : Mobicel Product Board : GEO USERDATA : ENCRYPTED STORAGE : LifeStatus : Verify NOT supported by DA/HW! Done! Elapsed: 00:00:54 Code: Operation : Read Firmware [ v2.08 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : Yuranc8.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 90014A483847346132A51FF8C07886DB EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E8CA1F12E6D03AC91238FFA661797AB9 DA : USB : HIGH-SPEED Boot done! Patch Level : PPR1.181008.011 Display ID : PPR1.181008.011 release-keys Ver. CodeName : REL Ver. Release : 9 Sec. Patch : 2019-11-05 Build Time : 1573822753 Product Model : GEO Product Brand : Mobicel Product Name : GEO Product Device : GEO Product Board : GEO Product Manfct : Mobicel Product Info : GEO Product Board : k510 Board Platform : mt6739 Product Model : GEO Product Brand : Mobicel Product Name : GEO Product Device : GEO Product Manfct : Mobicel Product Board : GEO MT6739__Mobicel__GEO__9__PPR1.181008.011__GEO Read : preloader.bin Read : recovery.img Read : persist.img ExtSparse : Compression ratio : 100% Read : proinfo.img Read : md1rom.img Read : md1dsp.img Read : spmfw.img Read : mcupmfw.img Read : nvram.bin Read : lk.bin Read : loader_ext.img Read : boot.img Read : logo.bin Read : dtbo.img Read : tz.img Read : vendor.img ExtSparse : Compression ratio : 30% Read : product.img ExtSparse : Compression ratio : 55% Read : system.img ExtSparse : Compression ratio : 13% Read : cache.img Read : userdata.img FW Size : 1.66 GB Android Info saved : _Android_info.txt Scatter : MT6739_Android_scatter.txt Saved to : C:\Users\Home\Desktop\MT6739__Mobicel__GEO__9__PPR1.181008.011__GEO\ Done! Elapsed: 00:03:22 Code: Operation : Memory Tool Init [ v2.08 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM9) MODE : PRELOADER PORT PORT : 9 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0002 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000001 BROM : SecMode : SBC BROM : PRELOADER PORT MODE : 0_base : BASE_v1952 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : Yuranc8.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : PRELOADER DA : EXT_RAM initialized! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] EMMC: 90014A483847346132A51FF8C07886DB EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : E8CA1F12E6D03AC91238FFA661797AB9 DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Operation : Erase Memory Erase selected partitions [1] [0] Erase partition : FRP Erase partition Ok! Operation finished! Operation : Update Memory Info Operation finished! Close MemoryTool session Done! Elapsed: 00:02:47 Reconnect Power/Cable! |
The Following User Says Thank You to yuranc8 For This Useful Post: |
