Old 05-21-2020, 11:31   #63151 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,164
Gfive Hero 3 SPD77xx Logo Resetert Fix Only Formate With King Infinity CM2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 5 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:18
Reconnect Power/Cable!
Old 05-21-2020, 11:35   #63152 (permalink)
Member: 1698141
Sonork: 1617901
Thanks Meter: 75
telenor condor infinity a4 flash file read with cm2
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Device info :
Patch Level : OPM2.171019.012
Display ID : SPRG02PRO_V06_20181211
Ver. Incmt : 54
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-11-05
Build Time : 1544516976
Product Model : Infinity a4
Product Brand : Condor
Product Name : Infinity_a4
Product Device : Infinity_a4
Product Manfct : SPA Condor Electronics
Product Info : Infinity_a4
Product Board : sp9832e_1h10
Board Platform : sp9832e
AndroidVer : 8
VlnrLevel : 0x02
SP9832E__SPA_Condor_Electronics__Infinity_a4__8.1. 0__SPRG02PRO_V06_20181211__OPM2.171019.012__Infini ty_a4
Read : u-boot.bin
Read : sml.bin
Read : tos.bin
Read : vbmeta.img
Read : ldsp_l.bin
Read : gdsp_l.bin
Read : modem_l.bin
Read : nvitem_l.bin
Read : modem_wcn.img
Read : gnssmodem.bin
Read : gnssbdmodem.bin
Read : pm_sys.bin
Read : boot.img
Read : recovery.img
Make : persist.img
Read : boot_logo.bmp
Read : fastboot_logo.bmp
Read : system.img
ExtSparse : Compression ratio : 86%
Read : vendor.img
ExtSparse : Compression ratio : 76%
Make : userdata.img
Make : cache.img
Read : prodnv.img
ExtSparse : Compression ratio : 35%
Read : phase.cfg
Read : u-boot-spl.bin
Firmware size : 0xB3819990 ( 2.80 GiB )
Android Info saved : _Android_info.txt
Old 05-21-2020, 11:37   #63153 (permalink)
allttar's Avatar
Member: 136220
Thanks Meter: 92
itel a33 spd Successfully opened frp thanks infinity-box
itel a33 8,1,1 spd Successfully opened frp thanks infinity-box
Device not found!
Remove battery, cable. Check cable and connection. Repeat operation!
Operation : Identify [ v2.05 ]
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Display ID : W5001P-F3102-8.1-OP-V057-20191226
Ver. Incmt : OP-V057-20191226
Ver. CodeName : REL
Sec. Patch : 2020-01-05
Build Time : 1577359868
Product Model : itel W5001P
Product Brand : Itel
Product Name : F3102
Product Device : itel-W5001P
Product Manfct : itel
Product Info : F3102
Product Board : itel-W5001P
Board Platform : sp7731e
Platform Version: MOCORTM_17C_W18.31.2_P26_Debug
Project Version: pike2_pub
BASE Version: FM_BASE_17C_W18.31.2_P26
HW Version: sc7731e_modem
CMP_Time : 10-18-2019 17:20:01
MODEM TAG : MOCORTM_17C_W18.31.2_P26_Debug_FM_BASE_17C_W18.31. 2_P26_sc7731e_modem_pike2_pub
UserData : STATE : PLAIN [EXTFS]
Done!
Elapsed: 00:02:10
Operation : Format FS / Reset Settings [ v2.05 ]
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:56
The Following User Says Thank You to allttar For This Useful Post:
Old 05-21-2020, 17:54   #63154 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 976
Vodafone VDF630 (Smart N10) Reading firmware and SP Unlock in Meta mode successfully done!
Identify in flash mode:
Operation : Identify [ v2.10 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM72)
MODE : BOOTROM
PORT : 72
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0200
     TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E1
BROM : SecMode  : SBC+ARB
BROM : BROM|BL  : 0x05|0xFE
BROM : BOOTROM
MODE : 0_base : BASE_v1952 | Manual : Disabled
BROM : SOCID : 2A235BD6FA492D47F50B14F145E0678B46108A6FD3754EC47784F7ABD3BB43EB
BROM : ARB : ACTIVE : LOG : F0: 102B 0000  F3: 0000 0000 [0200]  V0: 0000 0000 [0001]
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6761
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
DA : EXT_RAM NOT initialized!
     EMI : DEV : INFINITY
     EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
     EMI : CNT : 0004
     EMI : Init EMI from INTERNAL DB
     EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
        SRAM: 0x00039000 [ 228,00 KB ]
        DRAM: 0x80000000 [ 2,00 GB ]
        EMMC: 150100514536334D420368E36834B523
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x3A3E00000 [ 14,56 GB ]
        CHIP : MT6761 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : BCFC96FE5F38433459BB330C4EB442D8
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : P00610
Display ID     : P00610 release-keys
Ver. CodeName  : REL
Ver. Release   : 9
Sec. Patch     : 2019-03-05
Build Time     : 1554612746
Product Device : VFD630
Product Info   : C400
Product Board  : MT6761
Product Model  : VFD 630
Product Brand  : Vodafone
Product Name   : Smart_N10
Product Manfct : Vodafone
Board Platform : mt6761
USERDATA : ENCRYPTED
NVRAM check : Passed!
Backup sensetive data [ 10 ]
Backup path : Backup\MT6761__BCFC96FE5F38433459BB330C4EB442D8\
[24] Read : NVRAM
[8] Read : NVDATA
[15] Read : PROINFO
[25] Read : LK
[7] Read : NVCFG
[10] Read : PROTECT1
[11] Read : PROTECT2
[13] Read : PERSIST
[0] Read : PRELOADER
Backup done!
STORAGE : LifeStatus : OK!
Done!
Elapsed: 00:00:33
Identify in meta mode:
Mode : META
PTFN : MediaTek PreLoader USB VCOM (Android) (COM25)
MODE : PRELOADER PORT
PORT : 25
PRELOADER : ACK confirmed!
INIT : META confirmed!
Boot done!
AP_CHIP : MT6761
AP_SWTM : Sun Apr  7 15:14:23 CST 2019
AP_SWVR : alps-mp-p0.mp1-V3.12
MD_CHIP : MT6761
MD_SWTM : 2000.00.00
MD_DSPV : 1.0
MD_DSPP : MOLY.LR12A.R3.MP.V31.3.P31
MD_SWVR : TK_MD_BASIC_HW
MD_HWVR : Unknown
Ver. CodeName  : REL
Ver. Release   : 9
Build Time     : 1554621263
Product Info   : C400
Product Name   : Smart_N10_EEA_SS
IMEI[1] : 35995610074xxxx
Done!
Elapsed: 00:00:43
Read NVRAM:
Operation : Read Security [ v2.10 ]
MODE : BOOTROM
PORT : 72
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0004
        EMMC:
Boot done!
NVM saved as : MT6761__eMMC__.mt_sec
NVM saved to : C:\1\630\
Done!
Elapsed: 00:00:29
Read firmware:
Operation : Read Firmware [ v2.10 ]
ExtSparse   : Enabled
ForceRead   : Disabled
MODE : BOOTROM
PORT : 72
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0004
        EMMC:
Boot done!
Ver. CodeName  : REL
Ver. Release   : 9
Product Info   : C400
MT6761__Vodafone__VFD_630__9__P00610__C400
Read : preloader.bin
Read : recovery.img
Read : persist.img
ExtSparse : Compression ratio : 100%
Read : proinfo.img
Read : md1rom.img
Read : spmfw.img
Read : tinysys-scp.bin
Read : tinysys-sspm.bin
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : dtbo.img
Read : tz.img
Read : vendor.img
ExtSparse : Compression ratio : 52%
Read : system.img
ExtSparse : Compression ratio : 6%
Read : vbmeta.img
Read : cache.img
Read : security.img
Read : userdata.img
FW Size  : 3,46 GB
Scatter  : MT6761_Android_scatter.txt
Saved to : C:\1\630\MT6761__Vodafone__VFD_630__9__P00610__C400\
Done!
Elapsed: 00:04:37
And finally success unlock:
Operation : SP Unlock [ v2.10 ]
Mode : META
PORT : 25
Boot done!
AP_CHIP : MT6761
MD_CHIP : MT6761
ID0 : Lock : Locked! | MNC : 1536 | CNT : 5 | CODE : 00000000000000000000000000000000
ID1 : Lock : Not Locked | MNC : 0 | CNT : 0 | CODE : 00000000000000000000000000000000
ID2 : Lock : Not Locked | MNC : 0 | CNT : 0 | CODE : 00000000000000000000000000000000
ID3 : Lock : Not Locked | MNC : 0 | CNT : 0 | CODE : 97887E79000000000000000000000000
ID4 : Lock : Not Locked | MNC : 0 | CNT : 0 | CODE : 00000000000000000000000000000000
ID5 : Lock : Not Locked | MNC : 0 | CNT : 0 | CODE : 00000000000000000000000000000000
ID6 : Lock : Not Locked | MNC : 0 | CNT : 0 | CODE : 00000000000000000000000000000000
Done!
Elapsed: 00:00:46
The Following User Says Thank You to Dr_Wolodya For This Useful Post:
Old 05-22-2020, 13:12   #63155 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 977
Huawei mya l22 reset frp done by cm2
Card found : S/N : 73CA70CC , v0143
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 510001154D33314553B30D421DB7DDF2
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x80000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420DB353F2DD841D
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xB9E2EB77E68A3B3D1F62EDDF3E78564D
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:20
Old 05-22-2020, 13:14   #63156 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 977
Qmobile b18 hang on logo done by cm2
Operation : Check / Read Info [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 823EBD32BAD37F90DFA18E2D7A0FB8F0
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C200 2500 3600 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00300000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
File_Info : R036_QMOBILE_PCB01_gsm_MT6260_S00.R036_QMOBILE_BT_ FM_V011_20140711.bin
FileVersion : R036_QMOBILE_BT_FM_V011_20140711
Done!
Elapsed: 00:00:30
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x002B6000-0x002FFFFF , LEN : 0x0004A000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:28
Old 05-22-2020, 13:42   #63157 (permalink)
Member: 1916841
Sonork: ck
Safarico Neon Ray Hang On LOGO Or Fastboot Done By Flashing With CM3 SP2
[https://*********/kLFPG03AU0Y]
Old 05-23-2020, 04:53   #63158 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 977
Oppo a5s reset pattern done by cm2
Card found : 73CA70CC , v0143
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.10
Load IDBase v518137 Ok!
Update configuration ...
Update Ok!
Mode : META
PTFN : MediaTek USB Port_V1632 (COM35)
MODE : BOOTROM
PORT : 35
BROM : Init BROM
BROM init passed!
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+ARB
BROM : BOOTROM
BROM : SOCID : 930E5F49B8BFD7AC4A975894E62013F8317D91C4D45E993D12 1DF4365A807912
BROM : Configuring target for META
BROM : META configured!
Boot done!
AP_CHIP : MT6765,S01
AP_SWTM : Sun Apr 12 10:48:31 CST 2020
AP_SWVR : CPH1909_11_A.37_200412_3c30b5de
AP_HWVR : S01
MD_CHIP : MT6765
MD_DSPV : 1.0
MD_DSPP : MOLY.LR12A.R2.TC16.SP.V50.5.P95
MD_SWVR : OPPO_O1MP6_K65V1_64_BSP_HW
MD_HWVR : Unknown
Patch Level : O11019
Ver. CodeName : REL
Sec. Patch : 2020-04-05
Product Manfct : OPPO
Done!
Elapsed: 00:01:07
Operation : Reset Settings/Format FS [ v2.10 ]
Mode : META
MODE : BOOTROM
PORT : 35
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
Boot done!
AP_HWVR : S01
Format Ok : UserData
Done!
Elapsed: 00:00:51
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 05-23-2020, 08:15   #63159 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 3,147
iTel A33 spd cpu frp remove done
original poster
allttar
Device not found!
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Ver. CodeName : REL
Elapsed: 00:02:10
Mode : Reset FRP
BootMode : FLASH
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:56
The Following 3 Users Say Thank You to profkefah For This Useful Post:
Old 05-23-2020, 08:20   #63160 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 3,147
IKU i3 FRP REMOVE DONE
ORIGINAL POSTER
calmsystem
محمد درويش
The Following 2 Users Say Thank You to profkefah For This Useful Post:
Old 05-24-2020, 00:43   #63161 (permalink)
Member: 2127933
good job pro thnk you for share
Old 05-24-2020, 06:32   #63162 (permalink)
ajaystarin's Avatar
Member: 173081
Sonork: 100.1621322
Thanks Meter: 283
Vivo Y81 (Vivo 1803) Pattern & Frp Done by CM2MT2 V2.11
Operation : Reset Settings/Format FS [ v2.11 ]
Mode : FULL FACTORY ( FORCED + FRP )
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM3)
PORT : 3
BROM : Init BROM
BROM init passed!
BROM : SecLevel : 0x00000005
BROM : BROM|BL : 0xFF|0x03
BROM : PRELOADER PORT
MODE : Vivo : Y83 | Manual : Disabled
BROM : SOCID : EEAEEF2D340A654F2A04DE1C7500EDD39A7582CC6DB6F2E112 DAAF78859C045D
AGENT : MTK_AllInOne_DA_VIP.bin
AGENT : Found MT6765
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x30000000 [ 768.00 MB ]
EMMC: 150100474436424D42012CF69B3D9551
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 42148A70697A9BCD732EA0CA179F0A88
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:30
Regards
Ajay Gupta
The Following 3 Users Say Thank You to ajaystarin For This Useful Post:
Old 05-24-2020, 07:13   #63163 (permalink)
ajaystarin's Avatar
Member: 173081
Sonork: 100.1621322
Thanks Meter: 283
Vivo Y81 (Vivo 1803) flash Done by CM2MT2 V2.11
Used Firmware Name :- PD1732F_EX_A_2.5.5_vivo_mtk_alps-release-o1.mp6-pre4_mt6762
Operation : Write Flash [ v2.11 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Flash Format : Disabled
Files :23
[FL] : Set : preloader_k62v1_64_bsp.bin
[FL] : Set : recovery-verified.img
[FL] : Set : survival-verified.img
[FL] : Set : oem.img
[FL] : Set : efuse.img
[FL] : Set : md1img-verified.img
[FL] : Set : md1dsp-verified.img
[FL] : Set : spmfw-verified.img
[FL] : Set : scp-verified.img
[FL] : Set : sspm-verified.img
[FL] : Set : lk-verified.img
[FL] : Set : boot-verified.img
[FL] : Set : logo-verified.bin
[FL] : Set : odmdtbo-verified.img
[FL] : Set : tee-verified.img
[FL] : Set : vendor.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0x171E27DA8 [ 5.78 GB ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM23)
PORT : 23
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
[FL] : HW verification passed!
SEC_DL : False (RAPHAEL)
SEC_ID : 0x494E46494E495459424F584245535432
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000005688000
Erase : 0x0000000007688000 : 0x0000000004000000
Erase : 0x000000000C088000 : 0x0000000014000000
Erase : 0x0000000021800000 : 0x0000000000800000
Erase : 0x0000000025000000 : 0x0000000000200000
Erase : 0x0000000025500000 : 0x0000000009980000
Erase : 0x0000000032E80000 : 0x0000000257180000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader backup copy ...
Update bootloader backup copy Ok!
Write : RECOVERY
Write : SURVIVAL
Write : CUST
Write : EFUSE
Write : MD1IMG
Write : MD1DSP
Write : SPMFW
Write : SCP1
Write : SCP2
Write : SSPM_1
Write : SSPM_2
Write : LK
Write : LK2
Write : BOOT
Write : LOGO
Write : ODMDTBO
Write : TEE1
Write : TEE2
Write : VENDOR
Write : SYSTEM
Write : CACHE
Write : USERDATA
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:04:22
Regards
Ajay Gupta
The Following User Says Thank You to ajaystarin For This Useful Post:
Old 05-25-2020, 06:20   #63164 (permalink)
Member: 890257
Sonork: 1668120:SSR MOBILES
Thanks Meter: 47
Thumbs up I tel a40 frp
The Following 2 Users Say Thank You to ssrmobiles For This Useful Post:
Old 05-25-2020, 07:28   #63165 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 977
Vgo tel super jumbo i700 hang on logo done by cm2
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.06
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SCRD mode : AUTO
SCRD mode : AUTO
SCRD mode : AUTO
SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB]
Operation : Identify [ v1.06 ]
BootMode : FLASH
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device not found!
BootMode : FLASH
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 653x NOR v1.3(c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:23
Operation : Format FileSystem [ v1.06 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_058 2172F0352_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:25
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.52697 seconds with 9 queries
