Old 03-22-2011, 08:28   #6691 (permalink)
ROYAL-GSM's Avatar
Member: 281547
Sonork: 100.1609533
mbo model m004 safe format done
COM30 [VCP1] selected
module v3.27
Action: reset settings ("format ffs")
Model: Autodetect 6205-6239 NOR
Checking data, wait...
19200 autodetect
Initializing [6253:8A02:8A00]...
CPU: MT6253
high speed boot On
chip: 0000:0000:000F
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6253,E02
Date: 2000.00.00
Version: 1.0
Version: 6253_C85K_ALX_N20_ML_A_V02
Version: HUIYUE53_09A_HW
New firmware found (v.3.27, database date: 01.03.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
detecting structure #2...
1 4 5 8 9 10 11 12 13 done
88 byte(s) read
imei: 35231214001048
connection Ok
building list...
done
items to clear: 137
warning: wrong packet cs
items cleared: 137 of 137
building list...
done
items remains: 0
Finished, time used: 30 sec
Remove/Install battery now !
The Following User Says Thank You to ROYAL-GSM For This Useful Post:
Old 03-22-2011, 08:36   #6692 (permalink)
Member: 283534
COM7 [VCP0] selected
module v1.39
Device: LG-KP110
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Write: Eeprom
"smart write" active
Boot ...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 352129022328455
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352129022328455_LG-KP110_20110322-122225.B1E.bin
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
flash: 01227E22212200:F0B0FF00000000
write: 2nd chip area
Write: Eeprom
Write Done
Finished, time used: 637 sec
The Following User Says Thank You to minh tan For This Useful Post:
Old 03-22-2011, 08:43   #6693 (permalink)
joni_rajpura's Avatar
Member: 508072
Action: "repair imei"
Model: Spice-S404N
Phone should be Switched ON !
Connecting, wait...
imei-1: 135790246811220
imei write method: mode-1
new imei-1: 353923034274973
verification Ok
Finished, time used: 3 sec
The Following User Says Thank You to joni_rajpura For This Useful Post:
Old 03-22-2011, 11:06   #6694 (permalink)
MUNEEB_AKHTAR_RAZA's Avatar
Member: 152244
Sonork: 100.1591179
COM10 [VCP1] selected
module v3.80
Action: read unlock codes
unlock method: read codes
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
status: FF
Date: 2000.00.00
Version: 1.0
Version: G6620SS.C200.M40.04.10
Version: CKT53_12832_09B_HW
New firmware found (v.3.80, database date: 20.03.2011):
- send flash backup files to support: support@infinity-box.biz or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
116 byte(s) read
imei: 3519480xxxxxx
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + 37508954
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if phone do not ask for a code try: *983*8284#
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone (do not remove battery)
- read unlock codes
- restore original imei
Finished, time used: 13 sec
The Following User Says Thank You to MUNEEB_AKHTAR_RAZA For This Useful Post:
Old 03-22-2011, 11:11   #6695 (permalink)
asif ali's Avatar
Member: 388647
Sonork: sheerazi
Vodafone-541 unlock successfull
COM12 [VCP0] selected
module v3.73
Device: Vodafone-541
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:C903:A009
status: 01
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.03C31 BA9.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_AB686FA6].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 03C31BA9
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, A66F68AB
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID identification
version: 17G
provider: 708X-2FVDGB1
customization: CN17FC92
customization: XN17FC92
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 01800000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is valid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: disabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
done
done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35908103279173
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-541_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08 _40_SP1_V32__system_log_03C31BA9_AB686FA6_20110322-150921.B0X.bin
Finished, time used: 4 min 35 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to asif ali For This Useful Post:
Old 03-22-2011, 13:45   #6696 (permalink)
Member: 643478
vodafone 543 unlock done
COM5 [VCP3] selected
module v3.75
Device: Vodafone-543
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001:0603:A00E
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.C8DC8 D76.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_9096F062].rpl
New firmware found (v.3.75, database date: 12.02.2011):
TCL-ID detection...
device-id: C8DC8D76
rom info ver: 07
sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN
project-id: MAUI.08A.W08.40.SP1.V32.F3, 62F09690
version: 268
provider: 543X-2AVDGB1
customization: CN26FC01
customization: XN26FC01
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
sim-lock status: enabled
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
version is not found in database: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 00006F50->00006C50
done
done
done
original imei: 35982003836996
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_C8DC8D76_9096F062_2011032 2-172937.B0X.bin
Finished, time used: 5 min 50 sec
The Following User Says Thank You to moon955 For This Useful Post:
Old 03-22-2011, 13:54   #6697 (permalink)
Member: 643478
module v3.75
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: C8DC8D76
rom info ver: 07
version: 268
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
Old 03-22-2011, 14:02   #6698 (permalink)
kmaxmax's Avatar
Member: 553000
haier c3000 unlock done
COM7 [QCUSB_COM7_2] selected
module v1.49
Device: Haier-C2000, C2010, C3000, C3010 old
operation: SP-unlock
connecting...
OFFLINE...
disabling minlock...
Done...
Phones should be restarting now...
Finished, time used: 4 sec
The Following User Says Thank You to kmaxmax For This Useful Post:
Old 03-22-2011, 14:06   #6699 (permalink)
Member: 643478
module v3.75
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
TCL-ID detection...
device-id: C8DC8D76
rom info ver: 07
version: 268
TCL-ID is present
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
done
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
Old 03-22-2011, 14:23   #6700 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
MOTOROLA-WX181 UNLOCKED
module v3.79
Device: Motorola-WX181
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:40A4:A00C
status: 01
Boot Done
flash: 2088BAFFFFFFFF:2088BA00000000
flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
115200
Set baud Done
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
rom info structure: [standard] type (05)
TCL-ID is present
TCL-ID detection...
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
code offset: 00000000
ffs offset/size [01]: 003A0000/00058000
version: 564
provider: M181X-CARGAP5
customization: CM56DD10
customization: XM56DD10
TCL-ID is present
ffs/eeprom address assigned: 003A0000
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
max address is too big, should be recalculated: 0827D124->0826B790
done
original imei: 00005C8073A28A
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20110322-051851.B0X.bin
Finished, time used: 2 min 6 sec
The Following User Says Thank You to KYEJUSA For This Useful Post:
Old 03-22-2011, 14:37   #6701 (permalink)
KYEJUSA's Avatar
Member: 394869
VODAFONE-150 UNLOCKED
module v3.79
Device: Vodafone-150
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:6811:A00C
status: 01
Boot Done
flash: 8C22F60000000D:2BEA0000000000
flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
TCL-ID detection...
rom info ver: 05
ffs offset/size [01]: 00390000/00068000
version: 16H
provider: 150X-2AVDKE1
customization: CW16CD60
customization: XW16CD60
TCL-ID is present
ffs/eeprom address assigned: 00390000
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
original imei: FFFFFFFFFFFFFF
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Vodafone-150_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20110322-053348.B0X.bin
Finished, time used: 2 min 2 sec
Old 03-22-2011, 17:04   #6702 (permalink)
KYEJUSA's Avatar
Member: 394869
ALCATEL-305X UNLOCKED
module v3.79
Device: Alcatel-305X, 305A
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:A936:A00C
status: 01
Boot Done
flash: EC240200000000:2BEA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.6E874C61 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_1382AAEA].rpl
TCL-ID detection...
device-id: 6E874C61
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN
project-id: MAUI.08A.W08.36.SP1.V34, EAAA8213
ffs offset/size [01]: 00C00000/00400000
version: 166
provider: 305X-2DVDKE1
customization: CP16CH10
customization: XP16CH10
TCL-ID is present
ffs/eeprom address assigned: 00C00000
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_6E874C61_1382AAEA_201 10322-074756.B0X.bin
Finished, time used: 3 min 12 sec
Old 03-22-2011, 18:17   #6703 (permalink)
Member: 663355
unlock bess zv219 100%
COM19 [Serial2] selected
module v3.80
Action: "sp-unlock"
unlock method: smart fast
Model: Bess-VZ219
19200 autodetect
CPU: MT6253
status: FF
Date: 2000.00.00
Version: 1.0
Version: TV31US.YB3.00.M01.00.13
Version: FOXLINK53_09A_HW
86 byte(s) read
imei: 01247000023272
connection Ok
192 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
- read unlock codes
writing data...
verifying...
verification Ok
done
Finished, time used: 14 sec
The Following User Says Thank You to WENMODE29 For This Useful Post:
Old 03-23-2011, 06:09   #6704 (permalink)
kmaxmax's Avatar
Member: 553000
Haier C3000 unlock done !!
module v1.49
connecting...
OFFLINE...
Done...
The Following 2 Users Say Thank You to kmaxmax For This Useful Post:
Old 03-23-2011, 06:29   #6705 (permalink)
Member: 508072
COM2 [VCP1] selected
module v1.49
Device: ZTE-C201, C202, C203, C204
connecting...
checking diag mode...
Calculating spc based on esn...
DBF78E0A
ESN(hex) : 0A8EF7DB
ESN(dec) : 01009369563
trying to sending spc based on esn...
SPC:530591
Correct spc
disable minlock...
Done...
enable RUIM...
Done...
Finished, time used: 10 sec
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post:
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
Page generated in 0.94090 seconds with 12 queries
