Old 06-06-2011, 12:48   #7471 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
COM3 selected
module v3.31
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 352275030076733
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:9FBF:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
New firmware found (v.3.31, database date: 29.05.2011):
CKT23C_07B_OWL_SBTEL_PCB01_GPRS_MT6223P_S00.OWL-S10_SB-TEL_L1EN_202_090121_CAM010_MCP128+32_FM.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 04
sw version: CKT23C_07B_OWL_SBTEL_PCB01_GPRS_MT6223P_S00.OWL-S10_SB-TEL_L1EN_202_090121_CAM010_MCP128+32_FM.BIN
project-id: OWL-S10_SB-TEL_L1EN_202_090121_CAM010_MCP128+32_FM, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 8 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 06-06-2011, 12:49   #7472 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
COM3 selected
module v3.31
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
460800
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
detecting ffs/eeprom structure pass 1...
ffs/eeprom detected ok: element #1
reading: CKT23C_07B_OWL_SBTEL_PCB01_GPRS_MT6223P_S00.OWL-S10_SB-TEL_L1EN_202_090121_CAM010_MCP128+32_FM__ffs...
file saved: C:\InfinityBox\ChineseMiracle\CKT23C_07B_OWL_SBTEL _PCB01_GPRS_MT6223P_S00.OWL-S10_SB-
TEL_L1EN_202_090121_CAM010_MCP128+32_FM__ffs_20110 606-173934.B0E.bin
detection procedure, wait...
detection procedure completed
====> Write ...
Write: ffs
Write Done
Finalization Done
Finished, time used: 3 min 14 sec
Old 06-06-2011, 13:04   #7473 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
COM4 selected
module v1.78
Device: IMobile-101 HW-A
Action: read flash
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\InfinityBox\Pana01\IMobile-101 HW-A_eeprom-static_20110428-001242.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\InfinityBox\Pana01\IMobile-101 HW-A_eeprom-security_20110428-001243.B1E.bin
reading eeprom-complete...
file saved: C:\InfinityBox\Pana01\IMobile-101 HW-A_eeprom-complete_20110428-001245.B1E.bin
backup critical area Done
Check memory ...
reading flash...
file saved: C:\Documents and Settings\Administrator\Desktop\INFINITY SHELL\IMobile-101 HW-A_flash_20110428-001316.B1X.bin
completed
Finished, time used: 1 min 3 sec
Old 06-06-2011, 13:05   #7474 (permalink)
Member: 621121
== eeprom write done ==
COM32 [VCP1] selected
module  v3.29
Action: write flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
M110_ABROAD_PCB01_GPRS_MT6225_S00.M110_081225_FM_COMP_ABR_V1_4_4__ffs_20110416-183048.B0E.bin
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8F03:000A
status: FF
Boot Done
flash: 98000300000000:18E59F00000000
Initialize Done
====>  Set baud ...
921600
Set baud Done
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
TCL-ID is absent
New firmware found (v.3.29, database date: 04.04.2011):
M110_ABROAD_PCB01_GPRS_MT6225_S00.M110_081225_FM_COMP_ABR_V1_4_4.BIN
- send flash backup files to support: mtk@infinity-box.com or upload files to http://rapidshare.com or http://4shared.com
rom info ver: 04
sw version: M110_ABROAD_PCB01_GPRS_MT6225_S00.M110_081225_FM_COMP_ABR_V1_4_4.BIN
project-id: M110_081225_FM_COMP_ABR_V1.4.4, 00000000
TCL-ID is absent
ffs/eeprom chip: 00
reading: M110_ABROAD_PCB01_GPRS_MT6225_S00.M110_081225_FM_COMP_ABR_V1_4_4__ffs...
file saved: C:\InfinityBox\ChineseMiracle\M110_ABROAD_PCB01_GPRS_MT6225_S00.M110_081225_FM_COMP_ABR_V1_4_4__ffs_20110416-190158.B0E.bin
====>  Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
sec info (fast) detection...
Write Done
Finalization Done
Finished, time used: 3 min 18 sec
Old 06-06-2011, 13:10   #7475 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
COM4 selected
module v1.78
Action: reset settings ("format ffs")
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\InfinityBox\Pana01\IMobile-101 HW-A_eeprom-static_20110428-001703.B1E.bin
loading data...
data loaded
file saved: C:\InfinityBox\Pana01\IMobile-101 HW-A_eeprom-security_20110428-001704.B1E.bin
file saved: C:\InfinityBox\Pana01\IMobile-101 HW-A_eeprom-complete_20110428-001706.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 21 sec
Old 06-06-2011, 13:12   #7476 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
COM3 [VCP0] selected
module v3.31
Action: touchscreen calibration
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
E880_KDI1DOVF4_E880_GPRS_MT6225_S00.01_0__fullflas h_20110209-220655.B0M.bin loaded
Model: Autodetect 6205-6239 NOR
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:7E03:0005
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: E880_EVTST.01.0_25S00
Version: EVEN25_HW
44 byte(s) read
imei: 35217603020976
connection Ok
512 byte(s) read
174 byte(s) read
reading data #2...
512 byte(s) read
calibration value: 0
writing data...
verification...
verification Ok
Finished, time used: 10 sec
Old 06-06-2011, 13:20   #7477 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
COM3 [VCP3] selected
module v3.31
DEWAV6225_06B_PCB01_GPRS_MT6225_S00.R31_D300VTLNV1 _0_5_M7__fullflash_20110114-185848.B0M.bin loaded
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:1C03:000E
status: FF
Date: 2006.06.14
Version: 1.0
Version: R31_D300VTLNV1.0.5_M7
Version: DEWAV6225_06B_HW
44 byte(s) read
imei: 35172500815633
connection Ok
512 byte(s) read
160 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 13 sec
Old 06-06-2011, 13:47   #7478 (permalink)
Member: 621121
== dead repair done by ffs ==
module  v3.29
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
ffs/eeprom chip: 00
file saved: C:\Users\AlaM\Desktop\M110_ABROAD_PCB01_GPRS_MT6225_S00.M110_081225_FM_COMP_ABR_V1_4_4__ffs_20110416-183048.B0E.bin
====>  Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 26 min 26 sec
Old 06-06-2011, 13:49   #7479 (permalink)
JONONItelecom™'s Avatar
Member: 1076772
Sonork: 100.1601881
LG-KP135
COM5 [VCP0] selected
module v1.39
Device: LG-KP135
Action: reset
Boot ...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
460800
Set baud Done
Check flash ...
current eeprom imei: 353955021409402
file saved: C:\Program Files\INFINITY\LGA\eeprom_353955021409402_LG-KP135_20110606-184648.B1E.bin
reading _eeprom-ffs_353955021409402...
file saved: C:\Program Files\INFINITY\LGA\_eeprom-ffs_353955021409402_LG-KP135_20110606-184822.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 207 sec
Old 06-06-2011, 13:51   #7480 (permalink)
Member: 621121
== imei repair done ==
Phone should be Switched ON !
Connecting, wait...
imei-1: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei-1: 353923030000000
verification Ok
Finished, time used: 9 sec
Old 06-06-2011, 13:58   #7481 (permalink)
Member: 621121
== touchscreen repair done ==
module  v3.29
mode: 2
19200 autodetect
CPU: MT6225
high speed boot On
chip: 0001:9A03:0001
status: FF
Date: 2006.06.14
Version: 1.0
Version: X12_S9325_V3.0_0619_1
Version: UNISTAR25_GEMINI_HW
detecting structure #2...
 5 11 done
67 byte(s) read
imei: 13579024681122
warning: current phone imei is incorrect !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #5 (mode-2)...
 0warning: wrong packet cs
 1warning: wrong packet cs
 2 3 done
209 byte(s) read
reading data #2...
512 byte(s) read
writing data...
verification...
verification Ok
Power-On and test phone now
If calibration is not completed yet:
1. make "Reverse calibration order" Checked and try again
2. try another calibration mode
Finished, time used: 12 sec
Old 06-06-2011, 14:15   #7482 (permalink)
Member: 651892
LDF k9000 Fm Bluetooth Flash Done
COM6 selected
module v3.31
Action: write flash
write: Firmware
AOXUN25_GEMINI_PCB01_GPRS_MT6225_S00.D10_V005_LDF_ TOSH_ML_080928__LDF-K-9000_16m_En_Ru_Fr_Es_It_Id_Th_Vn_Tr_Farsi_Ar.B0M.b in
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:3C03:0006
status: FF
Boot Done
flash: 98004900000002:00000000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
921600
Set baud Done
it's time to stop: 0000000000008DE418F09FE518F09FE518F09FE518F09FE5
TCL-ID is absent
rom info ver: 04
sw version: AOXUN25_GEMINI_PCB01_GPRS_MT6225_S00.D10_V005_LDF_ TOSH_ML_080928.BIN
project-id: D10_V005_LDF_TOSH_ML_080928, 00000000
TCL-ID is absent
checking area [00000000]: 00080000-00FFFFFF...
Can't detect ffs/eeprom area
Do you want to use standard ffs/eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs/eeprom address selected by user
ffs/eeprom chip: 00
reading: AOXUN25_GEMINI_PCB01_GPRS_MT6225_S00.D10_V005_LDF_ TOSH_ML_080928__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\AOXUN25_GEMINI_PC B01_GPRS_MT6225_S00.D10_V005_LDF_TOSH_ML_080928__f fs_20110606-153551.B0E.bin
Code CRC check error fix...
firmware do not have "Code CRC check error" area
No licensed to produce fix...
warning: firmware do not have this kind of fault
====> Write ...
usb bootloader (file) is absent
startup code area #1 check...
done
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Finished, time used: 10 min 47 sec
Old 06-06-2011, 14:39   #7483 (permalink)
Member: 621121
== Call auto disconnect after 3 sec done by format ffs ==
COM2 [VCP0] selected
module  v3.27
Do you want to make ffs/eeprom backup before format ?
====>  Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:1803:0002
status: FF
Boot Done
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
Initialize Done
====>  Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
sw version: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.6688E_V2_KXD_NOATV_DSIM_T4_V02BA.BIN
project-id: 6688E_V2_KXD_NOATV_DSIM_T4_V02Ba, 00000000
TCL-ID is absent
ffs/eeprom chip: 00
reading: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.6688E_V2_KXD_NOATV_DSIM_T4_V02BA__ffs...
file saved: C:\Users\AlaM\Desktop\GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.6688E_V2_KXD_NOATV_DSIM_T4_V02BA__ffs_20110309-184706.B0E.bin
====>  Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 2 min 12 sec
Old 06-06-2011, 14:40   #7484 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
module v3.31
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
Version: EVEN25_HW
44 byte(s) read
connection Ok
building list...
done
items to clear: 161
items cleared: 161 of 161
building list...
done
items remains: 0
Finished, time used: 23 sec
Old 06-06-2011, 14:42   #7485 (permalink)
Member: 621121
== White screen After welcome logo repair done by full erase whole Nand chip ==
module  v3.26
Device: Autodetect 6228-6253 NAND
Action: erase whole flash chip
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6225:8A03:8A00
status: FF
bbchip bl ver: FE
NOR flash id[0057]: 0001:227E22202200 [SPANSION] S71PL127N
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_EXIST/00000100
NAND flash id[0007]: 00EC:00F100000095 [SAMSUNG] K9F1G08X0M
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 0000C000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===>  detect existing firmware structure...
detect ffs...
ffs offset/size: 00000000/08000000
ffs size: 128Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: BM26A1.B07.M01.03.14
detect NOR info...
number of areas/bytes to read: 1:00040000
reading (HW_STORAGE_NOR)...
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 04
sw version: FOXLINK6225_07A_PCB01_GPRS_MT6225_S00.BM26A1_B07_M01_03_14.BIN
project-id: BM26A1.B07.M01.03.14, 00000000
TCL-ID is absent
detect NAND info...
number of areas/bytes to read: 1:00080000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
warning: incorrect header: EC67A8FE8BBA3D36B7A3A7554A5F71B9
warning: can not detect header
nfi area detection (0 cores) finished: failed
warning: ffs can not be detected
TCL-ID detection...
===>  done
New firmware found (v.3.26, database date: 12.02.2011):
- send flash backup files to support: mt62xx@gmail.com or upload files to http://rapidshare.com or http://4shared.com
Format...
00000000-07FFFFFF...
Disconnect...
done
Finished, time used: 43 sec
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
Page generated in 0.50329 seconds with 12 queries
