Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #751 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: M__B__Din
Member: 950201 Status: Offline Sonork: 100.1608088 Thanks: 119
| COM3 [VCP0] selected Action: unlock Device: C113(a),C114,C115,C116,C117,C118 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 1.0.49.E. HW version: _E88 imei otp: 356480005642065 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _356480005642065_20090830-024509.18E.bin imei eeprom: 356480005642065 Check Flash-2 Done Write... Write Done Finished, time used: 21 sec Remove/Install battery now ! |
| The Following User Says Thank You to cel_phon For This Useful Post: |
| | #752 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 26
Member: 171512 Status: Offline Thanks: 141
| O2 X2I UNLOCK OK FIRST I TRY WITH B MODUL 1.31 BUT NOT SOLVE AFTER THIS I INSTALL NEW 1.33 N SET IS OK KNOW THANKS INFINTY TEAM COM3 [VCP0] selected module v1.33 Device: O2X2i Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0089:881200010001 file saved: C:\Program Files\InfinityBox\BModule\eeprom-00_20090830-150721.85F.bin Check Parameters Done Check Space... Flash: 0089:881200010001 flash: Intel 128MBit-T Strata T 16Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:881200010001 Writing Done Finished, time used: 60 sec Remove/Install battery now ! |
| The Following User Says Thank You to ehsas_ghum For This Useful Post: |
| | #753 (permalink) |
| nktel a200 repair ok COM3 [VCP0] selected module v2.90 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1D03:0006 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 89881200010001:89881200000000 flash: Intel Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.K7_PBLCD_PBCAME RA_T3_V3_1.BIN ver. sw 2: k7_PbLCD_PbCamera_T3_V3.1, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 89881200010001:89881200000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 89881200010001:89881200000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 89881200010001:89881200000000 Finalization Done Finished, time used: 40 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #754 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Hert of North KA 25 Age: 32
Member: 115516 Status: Offline Thanks: 777
| S940 COM8 selected module v2.79 Device: Spice-S940 Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 chip: 0031:E341:5E1C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 89890100040089:89890100000000 flash: Intel ST [def 0080x040000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: D:\Program Files\InfinityBox\MModule\backup_security\id.3DFDE B15.[D280_SPICE_PCB01_GPRS_MT6227_S01.KAB280_INA_EN_HI_ 1_07_213.BIN_E0FC53D3].rpl ==================== New firmware detected (v.2.79, database date: unknown): D280_SPICE_PCB01_GPRS_MT6227_S01.KAB280_INA_EN_HI_ 1_07_213.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: support@infinity-box.biz - send flash backup files to support: support@infinity-box.biz - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 3DFDEB15 identification#1 protocol ver: 04 ver. sw 1: D280_SPICE_PCB01_GPRS_MT6227_S01.KAB280_INA_EN_HI_ 1_07_213.BIN ver. sw 2: KAB280_INA_EN_HI_1.07.213, 2CAC031F ffs offset/size: 01400000/00C00000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Spice-S940_D280_SPICE_PCB01_GPRS_MT6227_S01.KAB280_INA_E N_HI_1_07_213__ffs... file saved: D:\infinity\FLASH FILE\spice S940\Spice-S940_D280_SPICE_PCB01_GPRS_MT6227_S01.KAB280_INA_E N_HI_1_07_213__ffs_20090830-204121.B0E.bin flash: 89890100040089:89890100000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 89890100040089:89890100000000 Finalization Done file saved: D:\Program Files\InfinityBox\MModule\backup_security\Spice-S940_D280_SPICE_PCB01_GPRS_MT6227_S01.KAB280_INA_E N_HI_1_07_213__system_log_3DFDEB15_E0FC53D3_200908 30-204219.B0X.bin Finished, time used: 430 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! Hear is pinouts thanks to saif751 for pinouts guidence |
| The Following 2 Users Say Thank You to az cells For This Useful Post: |
| | #755 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks: 332
| COM2 [VCP0] selected Device: Nec-N342i Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:98E59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 00005282 Boot Done Set baud... 460800 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Archivos de programa\InfinityBox\QModule\backup_eeprom_unlock-1_20090828-202552.13E.bin file saved: C:\Archivos de programa\InfinityBox\QModule\backup_eeprom_unlock-2_20090828-202557.13E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 Format file system Done Write... Preparing... area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 37 sec |
| The Following User Says Thank You to hvalero2001 For This Useful Post: |
| | #756 (permalink) |
| Nec-N342i Unlocked COM2 [VCP0] selected Device: Nec-N342i Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:98E59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 00005282 Boot Done Set baud... 460800 Set baud Done Check Flash... Check Flash Done Check space... file saved: C:\Archivos de programa\InfinityBox\QModule\backup_eeprom_unlock-1_20090828-202552.13E.bin file saved: C:\Archivos de programa\InfinityBox\QModule\backup_eeprom_unlock-2_20090828-202557.13E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 Format file system Done Write... Preparing... area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 37 sec |
| | #757 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: Romania, Deva
Member: 107324 Status: Offline Thanks: 30
| ZTE-G X761 ==== log: [8/31/2009 3:56:02 PM] ==== COM1 [Serial0] selected module v2.75 Action: unlock unlock method: smart fast Model: ZTE-X761 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001 703:0002status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: X761_Z2_SF_BFFA106 Version: ZTEMT25_07A_HW_C 44 byte(s) read imei: 35787302307140 connection Ok 157 byte(s) read reading data... reading data #2... building new data... writing data... 145 byte(s) read reading data... building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
| The Following User Says Thank You to cdor For This Useful Post: |
| | #758 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks: 382
| LG KP202 (Orange UK) unlocked successfully >>>> COM1 [VCP0] selected module v1.38 Device: LG-KP202 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 354912010299640 current otp imei: 354912010299640 file saved: C:\Program Files\InfinityBox\LGA\eeprom_354912010299640_LG-KP202_20090831-105457.B1E.bin ... version: ure----LGELECKP20204d Check flash Done Check space ... current eeprom imei: 354912010299640 ..................................... finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 32 sec Remove/Install battery now ! |
| The Following User Says Thank You to zeel_zeel For This Useful Post: |
| | #759 (permalink) |
| COM3 [VCP0] selected module v2.91 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: erase flash chip Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6227:8A02:8A01]... CPU: MT6227 high speed boot On chip: 0031:0B79 260status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.02 cpu-id: 08 loader: 3.0840.00.00 NAND: Toshiba TC58DVM92A1FT 512+16 32 pages, 66Mb NAND id: 9876A5C0 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 external ram: 00800000 finalize connection... done ram test... pass 1... pass 2... pass 3... pass 4... done NOR: 0098:004900000000 [01000000] NAND: 0098:007600A500C0 [04200000] Initialize Done Set baud ... 921600 Set baud Done Identification ... ram test... pass 1... pass 2... pass 3... pass 4... done reading bootloader structure area (00010000 bytes)... detecting bootloader structure... warning: incorrect bootloader header: 814C0100824C0100834C0100844C0100 nfi area detection finished: failed warning: can not detect chip parameters, default values assigned Identification Done Write ... formatting... .................................................. .................................................. Write Done Finished, time used: 51 sec Remove/Install battery now ! |
| | #760 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: ~InSiDe Of Ns & SamsunG WoRlD~
Member: 942693 Status: Offline Sonork: 1592619 Thanks: 1,768
| KP115 UNLOCK DONE!! COM208 [VCP0] selected module v1.39 Device: LG-KP115 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 011445002058927 file saved: C:\Archivos de programa\InfinityBox\LGA\eeprom_011445002058927_LG-KP115_20090901-144516.B1E.bin .... Check flash Done Check space ... current eeprom imei: 011445002058927 ................................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 53 sec Remove/Install battery now ! |
| The Following User Says Thank You to 69eyes For This Useful Post: |
| | #761 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks: 200
| T280i hang on Logo successfully Repaired by flashing Firmware&Flex and writing Eeprom. OM10 [VCP0] selected module v1.34 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20090901-054018.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: 89890400040089:89890400000000 Write: Firmware Area: Flex flash: 89890400040089:89890400000000 Write: Flex Write done Finished, time used: 622 sec Remove/Install battery now ! ==== log opened: [9/1/2009 5:54:02 AM] ==== Application: C:\Program Files\InfinityBox\HModule\HModule.exe Loading data, wait... [Infinity Box] v1.34 S/N: 356A:0112 Wait... Device: Sony-Ericsson-T280i Done Loading file v.02... T280i_repair_ffs_01.80E.bin loaded ==== log: [9/1/2009 5:54:40 AM] ==== COM10 [VCP0] selected module v1.34 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: flash write "smart write" active Skip: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Write: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20090901-060143.80E.bin Read data done Check data ... Check data done Write ... Area: Eeprom flash: 89890400040089:89890400000000 Write: Eeprom Write done Finished, time used: 1047 sec Remove/Install battery now ! WBR |
| The Following User Says Thank You to NawabN Sahoo For This Useful Post: |
| | #762 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2007
Member: 510826 Status: Online Thanks: 1,364
| [{ Flash Fly Hi SLDR Successfully }] COM3 [VCP0] selected module v2.85 Device: Fly-Hi-SLDR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware Fly-Hi-SLDR_SL900A_KPN_PCB01_GPRS_MT6226M_S01[1].SL900A_05C_W06_08_MP_V72_F2_2007-01-31_En_Dutch.B0M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Fly-Hi-SLDR_repair_eeprom_01[1].B0E.bin Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:FD5F:BD7F status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: SL900A_KPN_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06_0 8_MP_V72_F2.BIN ver. sw 2: SL900A.05C.W06.08.MP.V72.F2, 00000000 ffs offset/size: 00E00000/00200000 ffs address assigned: 00E00000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... firmware patch sp-lock #0/0 applied firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done Write ... Area: Firmware flash: B0001D00000000:B0001D00000000 Write: Firmware Area: Eeprom/ffs flash: B0001D00000000:B0001D00000000 Write: Eeprom/ffs detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... ffs formatting... flash: B0001D00000000:B0001D00000000 Finalization Done Finished, time used: 2296 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| The Following User Says Thank You to taoujdate For This Useful Post: |
| | #763 (permalink) |
| kg200 repair ok COM3 [VCP2] selected module v2.90 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On chip: 0031:2A41:E3C8 status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7330SA00-001-R1D Version: EP1 detecting structure #2... done 60 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 204 warning: wrong packet cs warning: wrong packet cs items cleared: 204 of 204 building list... done items remains: 0 Finished, time used: 36 sec Remove/Install battery now ! |
| | #764 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Age: 33
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks: 3,732
| Alcatal C701x Successfully Unlocked COM13 [VCP0] selected module v2.84 Device: Alcatel-C701X, C701A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware C701X-2AALPH1_XC16BF01_JRD26_06A_PCB01_GPRS_MT6226_S02[1].MAUI_06A_W06_28_MP_V41_2007-04-30_En_Fr_Es_It_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A03:8A02]... CPU: MT6226 chip: 0031:FB2A:A000 status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22302200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.FE4D6 DD4.[JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V17.BIN_6DAFF008].rpl rom info detection finished device-id: FE4D6DD4 rom info protocol ver: 05 ver. sw 1: JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_06A_W06_52_SP 1_V17.BIN ver. sw 2: MAUI.06A.W06.52.SP1.V17, F70F5092 ffs offset/size: 01200000/00E00000 ffs address assigned: 01200000 detect device sec info... detection phase #1... detect device sec info finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35320501702628 Backup required data Done Patch required data ... Patch required data Done Special operation ... firmware patch sp-lock #1 is not required firmware patch sp-lock #2 is not required Special operation Done Write ... startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-C701X,C701A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V17__system_log_FE4D6DD4_6DAFF008_20 090902-182222.B0X.bin Area: Firmware flash: 01227E22302200:2BEA0000000000 Write: Firmware detect device sec info... detection phase #1... detect device sec info finished security area (sec info, part #2) calculation... customization: CC16BF01 done flash: 01227E22302200:2AEA0000000000 flash: 01227E22302200:2AEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E22302200:2AEA0000000000 flash: 01227E22302200:2AEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Write Done Finalization ... ffs formatting... flash: 01227E22302200:2AEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-C701X,C701A_JRD26_06A_PCB01_GPRS_MT6226_S02.MAUI_0 6A_W06_52_SP1_V17__system_log_FE4D6DD4_6DAFF008_20 090902-183501.B0X.bin Finished, time used: 796 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| The Following User Says Thank You to shahzaadbutt For This Useful Post: |
| | #765 (permalink) |
| *** Fly Hi SLDR Successfully Unlocked *** COM3 [VCP0] selected module v2.79 Action: unlock unlock method: smart fast Model: Fly-Hi-SLDR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:FD5F:BD7F status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: SL900A.05C.W06.08.MP.V72.F2 Version: ESL6227_05C_HW 60 byte(s) read imei: 35274502019952 connection Ok 208 byte(s) read reading data... reading data #2... building new data... writing data... done Finished, time used: 15 sec Remove/Install battery now ! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
