12-31-2010, 11:36 | #7651 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | module v3.71 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7CE9:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E-WGD-ORANGE-P109A17SV1.0.0B03 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403005179 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
12-31-2010, 12:46 | #7652 (permalink) |
No Life Poster Join Date: Jan 2008 Location: sai baba shirdi Age: 44
Member: 670629 Status: Offline Sonork: 100.1590208 Thanks Meter: 431 | COM30 [VCP0] selected module v3.25 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001103:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: VK600.SW.V00.02.WEIKAI Version: VK600_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 352978*********** connection Ok detecting structure #1... 1 5 6 8 9 10 12 13 14 done 178 byte(s) read 166 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 2313 Finished, time used: 14 sec Remove/Install battery now ! |
The Following User Says Thank You to d.jain For This Useful Post: |
12-31-2010, 13:33 | #7653 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | COM2 [VCP0] selected module v1.41 Device: Huawei-C2900 operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... disable minlock... Phones should be restarting now... Finished, time used: 5 sec |
The Following 3 Users Say Thank You to JINDALGSM™ For This Useful Post: |
12-31-2010, 13:33 | #7654 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | COM2 [VCP0] selected module v1.41 Device: ZTE-C3xx-TATA operation: SP-unlock Phone should be Switched ON ! connecting... OFFLINE... send spc... disabling minlock... Done... Phones should be restarting now... Finished, time used: 7 sec |
12-31-2010, 13:42 | #7655 (permalink) |
Freak Poster Join Date: Jul 2010 Location: india , Delhi
Member: 1346449 Status: Offline Thanks Meter: 56 | ................The best CDMA unlocking tool is infinity cdma tool................. download click this link.......... Last edited by InfinityHelp; 06-27-2020 at 09:44. Reason: lagacy links removed |
The Following User Says Thank You to manu_smart For This Useful Post: |
01-01-2011, 04:52 | #7656 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | lg kg275 flash done COM4 [VCP0] selected module v1.73 Device: LG-KG275 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL KG270 P16 92 V10e XXX-XX Jun 20 2007 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-static_20101228-151444.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\lge_gb3a_eep65535.cfg error: can't load database v.14 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-security_20101228-151445.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG275_eeprom-complete_20101228-151452.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Write Done Finished, time used: 6 min 24 sec Remove/Install battery now ! |
The Following User Says Thank You to naveedbutt For This Useful Post: |
01-01-2011, 04:53 | #7657 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | e71 done COM4 [VCP0] selected module v3.25 Action: reset settings ("format ffs") Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4703:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: N96_P11_TOSHIBA_S5LCD_V1.0.2 Version: GIONEE25_GEMINI_07B_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 112 warning: wrong packet cs items cleared: 112 of 112 building list... done items remains: 0 Finished, time used: 49 sec Remove/Install battery now ! |
01-01-2011, 05:38 | #7658 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | COM2 [VCP1] selected module v1.41 Device: LG-3500 operation: SP-unlock Phone should be Switched ON ! connecting... RD350F08 LG RD-3500 version 8 selected.. OFFLINE... sending boot... sending command... patching in progress... patching in progress 50%... patching in progress 100%... Done... Phones should be restarting now... Finished, time used: 39 sec |
The Following User Says Thank You to joni_rajpura For This Useful Post: |
01-01-2011, 05:45 | #7659 (permalink) |
Junior Member Join Date: Jul 2010 Location: Cuba
Member: 1354009 Status: Offline Thanks Meter: 1 | Unlock Huawei-T201 COM4 [VCP0] selected modulo v1.78 Servicio: Huawei-T201-HW-A Checkeando datos, espere... Action: "sp-unlock" unlock method-1 Boot ... Mantenga Presionado el boton Power ! e-gold: 820000 loading... next part... boot answer: 01 Deje de presionar el boton power ahora ! Boot Done Seleccionar velocidad ... 115200 Seleccionar velocidad Done Connecting ... Flash 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... leyendo eeprom-static... Archivo guardado: D:\Program Files\InfinityBox\Pana01\Huawei-T201-HW-A_eeprom-static_20101215-212036.B1E.bin loading data... data loaded leyendo eeprom-security... Archivo guardado: D:\Program Files\InfinityBox\Pana01\Huawei-T201-HW-A_eeprom-security_20101215-212038.B1E.bin leyendo eeprom-complete... Archivo guardado: D:\Program Files\InfinityBox\Pana01\Huawei-T201-HW-A_eeprom-complete_20101215-212044.B1E.bin reading additional data... Archivo guardado: D:\Program Files\InfinityBox\Pana01\Huawei-T201-HW-A_lock-area_20101215-212057.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Escribir ... Erasing: lock-area Writing: lock-area Escribir Done Finalizado, tiempo usado: 1 min 3 sec Quite/coloque la bateria ahora ! |
The Following User Says Thank You to dare4969 For This Useful Post: |
01-01-2011, 08:48 | #7660 (permalink) |
No Life Poster Join Date: Jul 2009 Location: chandigarh INDIA
Member: 1066865 Status: Offline Thanks Meter: 593 | 5130-c successfully flashed Code: Connect phone on selected interface... Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm495__07.97.mcusw PPM : rm495__07.97.ppm_mh CNT : rm495__07.97.image_CTV_INDIA_HINDI_red Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Getting product info... Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response. [BB5 FLASH]: Bootrom Ok! RAP_PUB: 0D600216A74F7D566B14E45780700413B32285BC CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing UPDAPP... Processing PASUBTOC... TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data accepted ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm495__07.97.mcusw Found 6 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT Result: 0000 Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT Result: 0000 Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT Result: 0000 Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:21 Write : Processing rm495__07.97.mcusw Total 1178 [1178/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] TIME : Write time : 00:01:06 MCU Write done ===Flashing [PPM]=== Erase : Processing rm495__07.97.ppm_mh Found 1 areas to erase Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:56 Write : Processing rm495__07.97.ppm_mh Total 450 [450/0/0] blocks to write, writing... TIME : Write time : 00:00:25 PPM Write done ===Flashing [CNT]=== Checking content info... Check Image : Content size is 128k, use direct write mode Erase : Processing rm495__07.97.image_CTV_INDIA_HINDI_red Found 2 areas to erase Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT Result: 0000 Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:04:59 Write : Processing rm495__07.97.image_CTV_INDIA_HINDI_red Total 536 [536/0/0] blocks to write, writing... TIME : Write time : 00:00:30 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:10:19 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 5130c-2 Software Info: V 07.97 13-09-10 RM-495 (c) Nokia IMEI: 359329026239517 PPM version : V 07.97 13-09-10 RM-495 (c) Nokia MH Product code: 0577793 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Reset LifeTimer ... Ok! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! Set phone to Normal mode... AfterFlash operations done... Done! |
The Following User Says Thank You to sunny_luthras99 For This Useful Post: |
01-01-2011, 09:10 | #7661 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | ZTE R-221 UNLOCKED COM6 [VCP7] selected module v3.70 Action: "sp-unlock" unlock method: smart fast Model: ZTE-R221 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:64A2:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B04 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35547302600000 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! But After unlock it shows invalid IMEI plz fix this issue I have to re-write IMEI |
The Following User Says Thank You to gsmpointhrp For This Useful Post: |
01-01-2011, 09:54 | #7662 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 3110 downgrade successfully card found: S/N 0390:0118 registered to: jindalgsm4255 DLL not found... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.21.mcusw PPM : rm237__07.21.ppm_mr CNT : rm237__07.21.image_ctv_india_mr Flashing phone now... Check files done... -> Check SW version... FlashFile version : 07.21 Phone version : 07.30 07-05-09 RM-237 (c) Nokia. -> Check SW version : Downgrade try Backup CRT308 data... CRT308 Backup Created... Getting product info... RAP_BOOT: 0901010002010000 RAP_PUBLIC: 05C0010C65D17C564B8A9B4ABE71D94051AD48F9 CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: C0E691EA16A7593A9BB28832D7312A39F7ED668D Checking CNT sector PN<>FL PN CNT sector : 128 kb Converted content already exist, skip convert and using 128k DownGr: Prepare phone for downgrade... DownGr: Prepare Started.... Psec : 12704 -> Prepare status : Ok DownGr: Phone ready! Loader len: 253888, CHK: 129B ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data NOT accepted by phone, continue at user risk ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.21.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:02:03 Write : Processing rm237__07.21.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:00:45 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.21.ppm_mr Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:37 Write : Processing rm237__07.21.ppm_mr Total 227 [227/0/0] blocks to write, writing... TIME : Write time : 00:00:11 PPM Write done ===Flashing [CNT]=== Erase : Processing rm237__07.21.image_ctv_india_mr_128 Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:01:46 Write : Processing rm237__07.21.image_ctv_india_mr_128 Total 256 [256/0/0] blocks to write, writing... TIME : Write time : 00:00:12 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:05:35 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.21 05-11-08 RM-237 (c) Nokia. IMEI: 356833024380440 PPM version : V 07.21 05-11-08 RM-237 (c) Nokia. MR Product code: 0566963 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:06:01 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
The Following 2 Users Say Thank You to JINDALGSM™ For This Useful Post: |
01-01-2011, 09:59 | #7663 (permalink) |
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | nokia 3110c another downgrade successfully card found: S/N 0390:0118 registered to: jindalgsm4255 DLL not found... Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 3110c Software ver : V 07.30 07-05-09 RM-237 (c) Nokia. IMEI : 355220039623082 Ape Ver : APE Var : APE ADSP: DSP Ver : ICPR61_08w10 APE Test: PPM : V 07.30 07-05-09 RM-237 (c) Nokia. B CNT : Content: ora_pl_games V 07.30 07-05-09 RM-237 (c) Nokia. Product SN : MYM309692 Product code : 0556977 Base Prd.code: 0542523 Module code : 0203291 Long Prod.SN : Hardware info======= HWID : 5009 Retu : 32 Tahvo : 53 Batery: 3997 mV Camera: CMT BT: 06cc-P9.1 APE BT: APE HW: LCDVer: RF ic : Lock info =========== IMEI : 355220039623082 IMEI spNet : 3A 55 22 00 93 26 03 08 IMEI svNet : 33 55 22 00 93 26 03 28 F7 Conf key : 0000000000000000 Provider key : 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created... User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm237__07.21.mcusw PPM : rm237__07.21.ppm_d CNT : rm237__07.21.image_o2_cz Flashing phone now... Check files done... -> Check SW version... FlashFile version : 07.21 Phone version : 07.30 07-05-09 RM-237 (c) Nokia. -> Check SW version : Downgrade try Backup CRT308 data... CRT308 Backup Created... Getting product info... RAP_BOOT: 0901010002010000 RAP_PUBLIC: 07D0010E0EA28B56FDB58F94A9236F7C4E2AD723 CMT_ROOTKEY: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP_PAPUBKEY: C0E691EA16A7593A9BB28832D7312A39F7ED668D Checking CNT sector PN<>FL PN CNT sector : 128 kb ConvertImage: Processing rm237__07.21.image_o2_cz ConvertImage: Page Size is 64K, converting... ConvertImage: File converted DownGr: Prepare phone for downgrade... DownGr: Prepare Started.... Psec : 160 -> Prepare status : Ok DownGr: Phone ready! Loader len: 253888, CHK: 129B ADL -> Sending loader... Update Server code succesfully sent to phone! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Check data ADL : Data NOT accepted by phone, continue at user risk ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing rm237__07.21.mcusw Found 9 areas to erase Erasing area 0x00000000 - 0x000006BF, NOR, CMT Result: 0000 Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT Result: 0000 Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT Result: 0000 Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT Result: 0000 Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT Result: 0000 Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT Result: 0000 Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT Result: 0000 Erasing area 0x01060000 - 0x01067FFF, NOR, CMT Result: 0000 Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:57 Write : Processing rm237__07.21.mcusw Total 944 [944/0/0] blocks to write, writing... CMT : Writing Hash CERT [NOLO] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [PAPUBKEYS] CMT : PAPUBKEYS skip, already sent CMT : Writing Hash CERT [UPDAPP] CMT : Writing Hash CERT [DSP0] CMT : Writing Hash CERT [MCUSW] CMT : Writing Hash CERT [PMM_CONF] CMT : Writing Hash CERT [SBIF_CONF] TIME : Write time : 00:01:23 MCU Write done ===Flashing [PPM]=== Erase : Processing rm237__07.21.ppm_d Found 1 areas to erase Erasing area 0x01080000 - 0x0151FFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:17 Write : Processing rm237__07.21.ppm_d Total 229 [229/0/0] blocks to write, writing... TIME : Write time : 00:00:20 PPM Write done ===Flashing [CNT]=== Erase : Processing rm237__07.21.image_o2_cz_128 Found 1 areas to erase Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT Result: 0000 TIME : Erase time : 00:00:39 Write : Processing rm237__07.21.image_o2_cz_128 Total 256 [256/0/0] blocks to write, writing... TIME : Write time : 00:00:22 CNT Write done ADL : End flashing Flashing done! Total flash time : 00:04:01 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 3110c Software Info: V 07.21 05-11-08 RM-237 (c) Nokia. IMEI: 355220039623082 PPM version : V 07.21 05-11-08 RM-237 (c) Nokia. D Product code: 0556977 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... FullFactorySet...OK! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 0 certs Uploading certificates... Writen 21 certs! AfterFlash operations done... Reconnect, wait... Done! Elapsed: 00:04:24 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
01-01-2011, 12:20 | #7664 (permalink) |
No Life Poster Join Date: Dec 2007 Location: pakistan Age: 41
Member: 653398 Status: Offline Thanks Meter: 669 | v171 unlock done COM4 [VCP0] selected Action: unlock Device: V170,V171,V172,V173 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 4.4.69.. HW version: MOTOROLA_C071 Flex ver: FLEX_90_61_4204 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20110101-161548.20E.bin Check Flash-2 Done Write... Write Done Finished, time used: 40 sec Remove/Install battery now ! |
The Following User Says Thank You to haroon454 For This Useful Post: |
01-01-2011, 12:52 | #7665 (permalink) |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | COM8 [VCP6] selected module v3.70 Action: reset settings ("format ffs") Model: LG-KP220 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:ECAB5BB status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7338SA00-002-R1B Version: EP_0920 60 byte(s) read imei: 35167202429298 connection Ok building list... done items to clear: 230 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 230 of 230 building list... done items remains: 0 Finished, time used: 49 sec Remove/Install battery now ! |
