Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #8221 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Online Sonork: 100.1608410 Thanks: 13
| Sony-Ericsson-T280i hang on logo done COM3 [VCP0] selected module v1.38 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20111013-155330.80E.bin reading Sony-Ericsson-T280i_ffs... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_ffs_20111013-160607.80E.bin Read data done Check data ... Check data done Write ... flash: 89890400040089:89890400000000 Erase: ffs Write done Finished, time used: 15 min 25 sec Remove/Install battery now ! |
| | #8222 (permalink) |
| Huawei-G6600 unlock done COM3 [VCP0] selected module v3.62 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G6600 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2PT01V01.10 Version: BYD35_09A_PMWY_HW 82 byte(s) read imei: 35751003754787 connection Ok 189 byte(s) read reading data... reading data #4... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
| | #8223 (permalink) |
| lip top done COM3 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:9129:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0013:2088C400000000 error: no any expected answer flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box UN-CHECKED ! 3. make flash write operation If still no luck: send mail to support (mt62xx@gmail.com) with detailed description of problem, attach the next files in your e-mail: 1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log 2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin detecting chip #01 in region #00... flash: 2088C4FFFF0013:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\_ffs_20111016-095308.B0E.bin flash: 2088C4FFFF0013:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFF0013:2088C400000000 Finalization Done Finished, time used: 6 min 0 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #8224 (permalink) |
| lg kg 130 unlocked COM3 [VCP0] selected module v1.39 Device: LG-KG130 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 355311016261978 current otp imei: 355311016261978 file saved: C:\Program Files\InfinityBox\LGA\eeprom_355311016261978_LG-KG130_20111015-152042.B1E.bin ....... version: 234-30V10a44KG130P40FL Check flash Done Check space ... current eeprom imei: 355311016261978 ................................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 35 sec Remove/Install battery now ! |
| | #8225 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Aug 2007 Location: Pakistan " Karachi " Age: 31
Member: 572216 Status: Online Sonork: 100.1612300 Thanks: 961
| COM49 [VCP0] selected module v1.73 Device: Huawei-T161L Checking data, wait... Action: "sp-unlock" unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: 0 R_T161L_01 A_T161L_09 25 5 H5 5 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20111016-151514.B1E.bin loading data... data loaded reading eeprom-security... file saved: c:\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20111016-151514.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20111016-151515.B1E.bin reading additional data... file saved: c:\InfinityBox\Pana01\Huawei-T161L_lock-area_20111016-151520.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 27 sec Remove/Install battery now ! |
| | #8226 (permalink) |
| Sagem-my226 done COM3 [VCP0] selected module v1.73 Device: Sagem-my226 Checking data, wait... Action: reset settings ("format ffs") Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EBI_IH_290607_1101 290607_1101 EBI_IH Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-static_20111016-134326.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\v226_eep65535.cfg error: can't load database v.13 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-security_20111016-134327.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-complete_20111016-134332.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 29 sec Remove/Install battery now ! |
| | #8227 (permalink) |
| ufone g3610 unlock done COM3 [VCP1] selected module v4.03 Action: read unlock codes unlock method: read codes Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:4BA1:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C19SP03S Version: L75_HW 80 byte(s) read imei: 35398504438061 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 27011561 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 16 sec Remove/Install battery now ! |
| | #8228 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: Bangladesh Age: 28
Member: 908875 Status: Offline Thanks: 269
| Another T-Mobile-Zest Unlock done.. COM43 [VCP0] selected module v3.74 Action: "sp-unlock" unlock method: smart fast Model: T-Mobile-Zest Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 chip: 0011:5C72:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B09 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 86853300727746 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! |
| | #8229 (permalink) |
| Another Vodafone 340 unlock done COM10 [VCP0] selected module v3.74 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-340 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:3003:A00B status: 01 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: BM35A1.V2.22.M00.02.42 Version: FOXLINK25_08B_HW 81 byte(s) read imei: 35592203354898 connection Ok 186 byte(s) read reading data... reading data #2... building new data... writing data... 174 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
| | #8230 (permalink) |
| T-Mobile-Zest Unlock done.. OM10 [VCP0] selected module v3.74 Action: "sp-unlock" unlock method: smart fast Model: T-Mobile-Zest Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 chip: 0011:79A2:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B07 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403826206 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 12 sec Remove/Install battery now ! |
| | #8231 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: PK Age: 24
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks: 728
| COM11 [Serial2] selected module v4.01 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:BE03:000D status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.4.01, database date: 19.08.2011): GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.A03_BHT_ DSIM_ST_V3.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: GOLDDRAGON25_GEMINI_PCB01_GPRS_MT6225_S00.A03_BHT_ DSIM_ST_V3.BIN project-id: A03_BHT_DSIM_ST_V3, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFF0043:2088C400000000 Finalization Done Finished, time used: 1 min 21 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #8232 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks: 1,426
| COM10 [VCP0] selected module v1.73 Device: ZTE-125 Checking data, wait... Action: write flash Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: VDF-P108A1B07-Hi-IN07 g3dBV2.0 Jul 10 2008 19 09 17 04.12.00 18. Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: c:\InfinityBox\Pana01\ZTE-125_eeprom-static_20111019-164452.B1E.bin loading data... wrong database file: c:\InfinityBox\Pana01\z125_eep65535.cfg error: can't load database v.11 reading eeprom-security... file saved: c:\InfinityBox\Pana01\ZTE-125_eeprom-security_20111019-164452.B1E.bin reading eeprom-complete... file saved: c:\InfinityBox\Pana01\ZTE-125_eeprom-complete_20111019-164500.B1E.bin backup critical area Done Check memory ... unlocking... lock found lock type #1 found operation done Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 1 min 22 sec Remove/Install battery now ! |
| | #8233 (permalink) |
| | #8234 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Aug 2007 Location: (PAKISTAN)
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks: 495
| Huawei T156 unlocked => module version: v. => operation (3) started: COM4 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081033961684 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 18 sec Power Off/On phone now ! |
| | #8235 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2003 Location: CELLPLUS-INTERNET-INDIA
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks: 1,770
| Motorolla C139 SP-Unlock DONE ![]() COM30 [VCP0] selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.01.E. HW version: _E88 LP ver: LPH_C139_ASIA2_00A Flex ver: FFH_C139_67_30A imei otp: 35xxxxxxxxxxxxxxxx Check Flash-1 Done Check Flash-2... reading ... file saved: C:\InfinityBox\Moto01\backup_eeprom_calibration_35 xxxxxxxxxxxxx_20111019-171911.31E.bin imei eeprom: 35xxxxxxxxxxxxxx Check Flash-2 Done Write... Write Done Finished, time used: 20 sec Remove/Install battery now ! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
