Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #8251 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: PK Age: 24
Member: 959010 Status: Offline Sonork: 100.1602440 Thanks: 728
| Gild 6700 done COM3 [Serial2] selected module v4.05 Device: _Autodetect MT6253 NOR Checking data, wait... Action: write flash write: Firmware SZMI53_6432_09B_PCB01_GPRS_MT6253_S00.GILD_6700S_V 09.BIN_FLNK5N6433ATM_AD11__Glid-6700_8m_En_Fr_Ar_Hi.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C8]: 00EC:225400000000 [SAMSUNG] K5N6433ATM chip size: 8Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: GILD.6700S.V09 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: SZMI53_6432_09B_PCB01_GPRS_MT6253_S00.GILD_6700S_V 09.BIN_FLNK5N6433ATM_AD11 project-id: GILD.6700S.V09, 00000000 code offset: 00000000 ffs offset/size [02]: 00700000/00100000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 3 min 6 sec Remove/Install battery now ! |
| | #8252 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2010
Member: 1341599 Status: Offline Thanks: 638
| COM22 [VCP0] selected module v3.97 Device: Motorola-WX181 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:505B:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 564 provider: M181X-CARGAP2 customization: CM56CC12 customization: XM56CC12 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM56CC12 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0826B790 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 0000F590E58443 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20111031-131259.B0X.bin Finished, time used: 1 min 57 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #8253 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2009 Location: Ganimedes
Member: 1067814 Status: Online Sonork: 100.1618982 Thanks: 139
| Alcatel-222X, 222A SucessFull!!!!! COM6 [VCP0] selected module v4.01 Device: Alcatel-222X, 222A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot Off chip: 0011:638D:A00C status: 01 high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28.BIN project-id: MAUI.08A.W08.36.SP1.V28, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 16A provider: 222A-2ARGDO1 customization: CO16NX00 customization: XO16NX00 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XO16NX00 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 01260000214641 flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-222X,222A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28__system_log__00000000_20111031-183701.B0X.bin Finished, time used: 2 min 6 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #8254 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks: 13
| ufone g3610 unlocked COM3 [VCP1] selected module v4.03 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:5127:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C19SP03S Version: L75_HW 80 byte(s) read imei: 02508092000015 warning: wrong packet cs connection Ok 185 byte(s) read reading data... reading data #2... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 20 sec Remove/Install battery now ! COM3 [VCP1] selected module v4.03 Action: read unlock codes unlock method: read codes Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:5127:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C19SP03S Version: L75_HW 80 byte(s) read imei: 02508092000015 warning: wrong packet cs connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 173 byte(s) read reading data... 972 byte(s) read lock[1] code: - default lock[2] code: - default lock[3] code: - 1122 lock[4] code: - default lock[5] code: - default lock[6] code: - default lock[7] code: - default if code is not accepted by phone: - insert wrong sim card into phone - power-On phone - enter code: 12345678 - wait 10 seconds - power-Off phone via "Power" button (do not remove battery) - read unlock codes again Finished, time used: 12 sec Remove/Install battery now ! |
| | #8255 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: in your Heart
Member: 1484062 Status: Offline Sonork: 1610135 Thanks: 469
| Alcatel 505x Unlock ok. COM9 [Serial2] selected module v4.01 Device: Alcatel-505X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:ACAE:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\MModule\backup_security\id.42071561 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_59B64033].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 42071561 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 3340B659 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 268 provider: 505X-2CALGR1 customization: CP26AK22 customization: XP26AK22 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XP26AK22 customization name adjusted flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98000300000001:2BEA0000000000 flash: 98000300000001:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35777003317718 flash: 98000300000001:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:2BEA0000000000 Finalization Done file saved: C:\InfinityBox\MModule\backup_security\Alcatel-505X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V34__system_log_42071561_59B64033_20111031-173223.B0X.bin Finished, time used: 2 min 49 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #8256 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2003 Location: CELLPLUS-INTERNET-INDIA
Member: 26488 Status: Offline Sonork: 100.1581233 Thanks: 1,770
| Sony Ericsson J120i Restart done COM30 [VCP0] selected module v1.38 Device: Sony-Ericsson-J120i "advanced chip detection" active Action: reset settings Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb software version: 1030-000 software version: MLD-5- Check hardware done Read data ... reading Sony-Ericsson-J120i_eeprom_calibration-1... file saved: C:\InfinityBox\HModule\Sony-Ericsson-J120i_eeprom_calibration-1_20111101-160946.6AE.bin reading Sony-Ericsson-J120i_ffs... file saved: C:\InfinityBox\HModule\Sony-Ericsson-J120i_ffs_20111101-160958.6AE.bin Read data done Check data ... Check data done Write ... flash: 89886200010001:89886200000000 Erase: ffs Write done Finished, time used: 29 sec Remove/Install battery Regards, Saif. |
| | #8257 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 189374 Status: Offline Thanks: 49
| lephone K3 - New firmware, Format to clear user code COM16 [VCP0] selected module v4.05 Action: reset settings ("format ffs") Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:6B8F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E08 Date: 2000.00.00 Version: 1.0 Version: 6223D_C61T_ALX_1.03_N28_ML_E_BT_CTEL_v01 Version: HUIYUE23C_08A_GEMINI_HW ==================== New firmware found (v.4.05, database date: 20.10.2011): 6223D_C61T_ALX_1.03_N28_ML_E_BT_CTEL_v01 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35114478002258 connection Ok building list... done items to clear: 107 items cleared: 107 of 107 building list... done items remains: 0 Finished, time used: 31 sec Remove/Install battery now ! |
| | #8258 (permalink) |
| COM4 [Serial2] selected module v4.05 Device: _Autodetect MT6253 NOR Checking data, wait... Action: write flash write: Firmware SZMI53_6432_09B_PCB01_GPRS_MT6253_S00.GILD_6700S_V 11.BIN_FLNK5N6433ATM_AD11_2011-02-10__Gild-6700_8m_En_Fr_Ar_Hi.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C8]: 00EC:225400000000 [SAMSUNG] K5N6433ATM chip size: 8Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: GILD.6700S.V09 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: SZMI53_6432_09B_PCB01_GPRS_MT6253_S00.GILD_6700S_V 09.BIN_FLNK5N6433ATM_AD11 project-id: GILD.6700S.V09, 00000000 code offset: 00000000 ffs offset/size [02]: 00700000/00100000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 3 min 16 sec Remove/Install battery now ! |
| | #8259 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2010 Age: 24
Member: 1300364 Status: Offline Thanks: 72
| motorola wx181 unlock ok ![]() Code: Loading data, wait... [Infinity Box] MModule v4.05 smart-card: connected S/N: 7xxxxxF Wait... trying to select model: /WX181 model selected via command line: Motorola-WX181 Device: Motorola-WX181 Initialization done ==== [01/11/2011 15:43:45] ==== COM3 [VCP0] selected module v4.05 Device: Motorola-WX181 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:5D94:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 8C22F60000000D:2BEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 564 provider: M181X-2AALFR1 customization: CM56EF13 customization: XM56EF13 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM56EF13 customization name adjusted flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... max address is too big, should be recalculated: 0827D124->0826B790 ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 8C22F60000000D:2BEA0000000000 flash: 8C22F60000000D:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: FFFFFFFFFFFFFF flash: 8C22F60000000D:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 8C22F60000000D:2BEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_20111101-154535.B0X.bin Finished, time used: 1 min 31 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #8261 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004 Location: Amoude-syria Age: 38
Member: 98928 Status: Offline Thanks: 34
| SFR115 unlock done her the log: Code: COM18 [VCP0] selected module v3.75 Action: "sp-unlock" unlock method: smart fast Model: SFR-115 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:43EB:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: EFS-SFR-R9SM-P109A17V1.0.2B01 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35403004008727 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 15 sec Remove/Install battery now ! |
| | #8262 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Aug 2007 Location: (PAKISTAN)
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks: 496
| COM4 [VCP0] selected module v4.05 Device: _Autodetect MT6253 NOR Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00020000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: L5BMM44.9.52.1.1T04M1118_M713 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: JWT_X167B_102_PCB01_GPRS_MT6253_S00.L5BMM23_9_52_1 _0T02M1026_M713.BIN project-id: L5BMM44.9.52.1.1T04M1118_M713, 00000000 code offset: 00000000 ffs offset/size [02]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ===> done area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\InfinityBox\MModule\JWT_X167B_102_PCB01_GPRS_MT 6253_S00.L5BMM23_9_52_1_0T02M1026_M713__fullflash_ 20111031-190219.B0M.bin Disconnect... done Finished, time used: 8 min 21 sec Remove/Install battery now ! |
| | #8263 (permalink) |
| COM4 [VCP0] selected module v4.05 Action: reset settings ("format ffs") Model: _Autodetect MT6253 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: L5BMM44.9.52.1.1T04M1118_M713 Version: LCSH53_BU2_09A_HW ==================== New firmware found (v.4.05, database date: 20.10.2011): L5BMM44.9.52.1.1T04M1118_M713 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 1 2 3 5 7 8 9warning: wrong packet cs 11 12 13 done 86 byte(s) read imei: 35602304703002 connection Ok building list... done items to clear: 152 warning: wrong packet cs items cleared: 152 of 152 building list... done items remains: 0 Finished, time used: 31 sec Remove/Install battery now ! Action: read/check information |
| | #8264 (permalink) |
| COM4 [VCP0] selected module v4.05 Action: reset settings ("format ffs") Model: LG-KG195 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7990:AE5C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7332SA00-001-R1D Version: FP_0620 60 byte(s) read imei: 35398800029629 connection Ok building list... done items to clear: 188 warning: wrong packet cs items cleared: 177 of 188 items remains: 0 Finished, time used: 1 min 26 sec Remove/Install battery now ! Action: read/check information Model: LG-KG195 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: FP_0620 Software version: 7S7332SA00-001-R1D" Software date: 2005.04.12 Barcode: AT+EGMR=0,5 Finished, time used: 6 sec Remove/Install battery now ! |
| | #8265 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2011 Location: gsmsection Age: 25
Member: 1678945 Status: Online Sonork: 100.1620753 Thanks: 9
| COM3 [VCP1] selected module v4.01 Device: SFR-121 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:8850:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\InfinityBox\MModule\backup_security\id.65EE5AB3 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_1A153EDA].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 65EE5AB3 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, DA3E151A code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: A62 provider: F121X-2ASFFR1 customization: CIA6CA08 customization: XIA6CA08 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XIA6CA08 customization name adjusted flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35723104005216 flash: 01227E22202200:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:2BEA0000000000 Finalization Done file saved: C:\InfinityBox\MModule\backup_security\SFR-121_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_ 36_SP1_V34__system_log_65EE5AB3_1A153EDA_20111102-161128.B0X.bin Finished, time used: 3 min 8 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
