Old 11-03-2011, 01:13   #8266 (permalink)
Member: 1176958
Motorola wx290 unlock done
module v4.01
Device: Motorola-WX290
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:9F6A:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.DC4E2992 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN_331B13D4].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: DC4E2992
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V40_F5.BIN
project-id: MAUI.08A.W08.36.SP1.V40.F5, D4131B33
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 665
provider: M290X-2ADCJM1
customization: CP66GY18
customization: XP66GY18
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35155104132230
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Motorola-WX290_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W0 8_36_SP1_V40_F5__system_log_DC4E2992_331B13D4_2011 1020-164537.B0X.bin
Finished, time used: 4 min 14 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to yaro_rguez For This Useful Post:
Old 11-03-2011, 08:34   #8267 (permalink)
Malik Irfan85's Avatar
Member: 1484062
Sonork: 1610135
Vodafone 340 Unlock Done,
COM10 [Serial2] selected
module v4.01
Action: "sp-unlock"
unlock method: smart fast
Model: Vodafone-340
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001003:A009
status: 01
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: BM35A1.V2.22.M00.02.44
Version: FOXLINK25_08B_HW
81 byte(s) read
imei: 35592203531004
connection Ok
186 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
174 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 26 sec
Old 11-03-2011, 10:01   #8268 (permalink)
ZubairArain's Avatar
Member: 751908
LG KP320 Flashing Done
COM5 [VCP0] selected
module v4.01
Device: LG-KP320
Action: write flash NAND
write: Firmware
KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
external bootloader is not present
bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin
nfi area detection (3 cores) finished: Ok
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6229:8A02:8A02
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00020000
external RAM: absent
done
Set baudrate (921600)...
done
ram test...
testing 32bit...
32bit ram test passed
testing 16bit...
16bit ram test passed
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: 7S7610AA00-001-R1A
detect NAND info...
number of areas/bytes to read: 1:00080000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610AA00-001-R1A.bin
TCL-ID detection...
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 04
sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1A.BIN
project-id: 7S7610AA00-001-R1A, 00000000
ffs offset/size [01]: 02000000/06000000
rom info structure: [standard] type (04)
TCL-ID is absent
===> done
New firmware found (v.4.01, database date: 19.08.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
done
number of cores: 3
loading files...
number of areas: 3
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 6 min 33 sec
Old 11-04-2011, 09:30   #8269 (permalink)
NKhan_Gsm's Avatar
Member: 1646177
Sonork: 100.1604654
ZTE N281 Successfully Unlocked:
==== [11/4/2011 12:11:55 PM] ====
COM10 [VCP0] selected
module v4.04
Action: "sp-unlock"
Model: ZTE-N281
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
high speed boot On
chip: 0000:0000:0003
status: FF
rom: 4D573031
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: TMO_UK_P107A3V1.0.2B11
Version: 09AZTENJ35_09A
83 byte(s) read
imei: 35547302600000
connection Ok
189 byte(s) read
reading data...
reading data #2...
writing data...
177 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 52 sec
WBR
Old 11-06-2011, 05:38   #8270 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Nasaki M606
module v4.05
Action: reset settings ("format ffs")
Model: _Autodetect MT6253 NOR
19200 autodetect
Initializing [6253:8A02:8A00]...
CPU: MT6253
high speed boot On
chip: 0000:0000:000F
status: FF
Hardware: MT6253,E02
Date: 2000.00.00
Version: 1.0
Version: C100A3P.XT.NASAKI01.110425.01
Version: TELSDA53_SLIM_09A_HW
New firmware found (v.4.05, database date: 20.10.2011):
- send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage
detecting structure #2...
1 2 3 5 7 8 9 11 12 13 done
86 byte(s) read
imei: 35414304128185
connection Ok
warning: wrong packet cs
building list...
done
items to clear: 158
items cleared: 158 of 158
building list...
done
items remains: 0
Finished, time used: 25 sec
Old 11-06-2011, 08:12   #8271 (permalink)
Member: 1484062
Sonork: 1610135
Kp100 Imei Successfully Changed.
Phone must be SWITCHED ON !
Connecting, wait...
Connection Ok
Action: imei
software version: KP100FL-01-V10a-214-01-NOV-06-2008+0
original imei: 35490303365939900
new imei: 35490303365939
imei verification Ok
Done
Finished
Old 11-06-2011, 17:28   #8272 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
ZTE-S213 UNLOCKED BY READ CODES
module v4.04
Action: read unlock codes
unlock method: read codes
Model: ZTE-S213
19200 autodetect
CPU: MT6223
high speed boot On
chip: 0011:7F22:000C
status: FF
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: E-UGD-P109A14V1.0.0B05
Version: ZTENJ23D_09A_HW
New firmware found (v.4.04, database date: 17.10.2011):
86 byte(s) read
imei: 86491300549444
connection Ok
192 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
180 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 200172000482
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if phone do not ask for a code try: *983*8284#
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone (do not remove battery)
- read unlock codes
- restore original imei
Finished, time used: 16 sec
Old 11-07-2011, 10:37   #8273 (permalink)
fredinho's Avatar
Member: 975275
Sonork: 100.1607001
COM12 [VCP0] selected
module v4.05
Device: _Autodetect MT6205-6239 NOR
Action: "user code"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A08]...
CPU: MT6223
high speed boot On
chip: 0011:737B:000C
status: FF
Boot Done
flash: 7F227E220A2201:2BEA0000000000
flash: AMD/Fujitsu std [D 0008x002000 003Ex010000 0008x002000] 4Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
detecting chip #08 in region #00...
detecting chip #09 in region #00...
detecting chip #0A in region #00...
detecting chip #0B in region #00...
detecting chip #0C in region #00...
detecting chip #0D in region #00...
detecting chip #0E in region #00...
detecting chip #0F in region #00...
number of flash chip/regions detected: 10/01
Initialize Done
====> Set baud ...
115200
Set baud Done
interesting cpu type found
device parameters detection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
rom info structure: [standard] type (07)
TCL-ID is absent
M7026D_YGTR_128X160_PCB01_GSM_MT6223_S00.M7026DYGT R_EN_FR_G1G2_0120.BIN
rom info ver: 07
sw version: M7026D_YGTR_128X160_PCB01_GSM_MT6223_S00.M7026DYGT R_EN_FR_G1G2_0120.BIN
project-id: M7026DYGTR_EN_FR_G1G2_0120, 00000000
ffs offset/size [02]: 00380000/00080000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00380000
standard ffs/eeprom offset confirmed: 00380000
detecting ffs/eeprom size...
ffs/eeprom size: 00080000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00380000-003FFFFF
firmware area: 00000000-0037FFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 1...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok: element #1
lock area found
====> Write ...
Write: lock-area-1
Write Done
Finalization Done
Finished, time used: 1 min 47 sec
Old 11-07-2011, 23:22   #8274 (permalink)
SFR-_-MAN's Avatar
Member: 1633151
Sonork: SFR-_-MAN
Cool G7010 unlock done !!!
COM35 [VCP0] selected
module v4.06
Model: Huawei-G7010
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
Version: ESPC113B146SSC
Version: VER.B
115 byte(s) read
imei: 35XXXXXXXXXXXX
Finished, time used: 7 sec
Now click to "OK" button and press and HOLD phone "Power" button again !
interface: META_DLL_v6.1016.00
Connect...
Connecting...
done
Shutdown...
done
Old 11-08-2011, 00:30   #8275 (permalink)
Member: 679135
Sonork: 100.1606448
COM3 [VCP15] selected
module v4.05
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
Version: G6620SS.C210.M40.05.03N
Version: CKT53_12832_09B_HW
116 byte(s) read
imei: 35194804762025
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + 36620356
- read unlock codes
Finished, time used: 12 sec
Old 11-08-2011, 09:39   #8276 (permalink)
Member: 1608238
unlocked by infinty cdma dongal.
checking version...
Apr 24 2009C2809C02B105
Huawei C2809 version B105 selected..
Downloading mode...
Erasing...
patching in progress...
patching in progress 33%...
patching in progress 66%...
patching in progress 99%...
patching in progress 100%...
done...
Finished, time used: 5 min 31 sec
Old 11-08-2011, 10:33   #8277 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
COM7 [VCP0] selected
module v1.78
Device: Huawei-T161L
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: 0 R_T161L_01 A_T161L_09 25 5 H5 5
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: F:\data\Infinity\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20111108-015647.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: F:\data\Infinity\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20111108-015648.B1E.bin
reading eeprom-complete...
file saved: F:\data\Infinity\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20111108-015649.B1E.bin
reading additional data...
file saved: F:\data\Infinity\InfinityBox\Pana01\Huawei-T161L_lock-area_20111108-015653.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Old 11-08-2011, 10:49   #8278 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Nasaki
COM4 [VCP0] selected
module v4.05
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
- send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare ? Secure Data Logistics or http://4shared.com
86 byte(s) read
connection Ok
building list...
done
items to clear: 158
building list...
done
items remains: 0
Old 11-08-2011, 10:52   #8279 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Nasaki
module v4.05
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
86 byte(s) read
connection Ok
building list...
done
items to clear: 158
building list...
done
items remains: 0
Old 11-08-2011, 10:53   #8280 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Mahi v2
module v4.05
Device: _Autodetect MT6253 NOR
Action: write flash
write: Firmware
Z100_C151_HW1_SW4_PCB01_GPRS_MT6253_S00.Z100_XT-5700_MAHI-V1-0602.BIN_FLNTY5701111183KC__fullflash_20111107-163712.B0M.bin
skip: Customization
skip: Eeprom/ffs
nor area detection...
"format ffs" active
Connect...
Connecting...
Booting...
CPU: 6253:8A04:8A00
status: FF
bbchip bl ver: FE
NOR flash id[00C0]: 0098:009E00000000 [TOSHIBA] TC58FYM7T8C
chip size: 16Mb
otp status/size: S_DA_NOR_OTP_EXIST/00020000
NAND flash chip: not installed
done
done
interesting cpu type found: 6253:8A04:8A00
ram test...
testing 32bit...
testing 16bit...
ram test passed
detect ffs...
ffs offset/size: 00000000/00000000
detect sec ro...
project-id: Z100.XT-5700.Mahi-V1-0602
detect NOR info...
number of areas/bytes to read: 1:00050000
reading (HW_STORAGE_NOR)...
TCL-ID detection...
rom info ver: 07
sw version: Z100_C151_HW1_SW4_PCB01_GPRS_MT6253_S00.Z100_XT-5700_MAHI-V1-0602.BIN_FLNTY5701111183KC
project-id: Z100.XT-5700.Mahi-V1-0602, 00000000
ffs offset/size [02]: 00E00000/00200000
TCL-ID is absent
===> done
done
number of cores: 1
loading files...
number of areas: 1
done
write...
write core...
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
Page generated in 0.51017 seconds with 12 queries
