Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #8296 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2008 Location: Nepal Age: 27
Member: 799195 Status: Offline Sonork: all gsm cdma tool is best Thanks: 64
| === [11/11/2011 1:12:52 PM] ==== COM3 [VCP0] selected module v4.07 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... FREEFLY35_09A_PCB01_GPRS_MT6235B_S01.H618_M35_BF_V 05__firmware_20111111-130931.B4M.bin loaded nfi area detection... bootloader version: FREEFLY35_09A_BOOTLOADER_V005_MT6235B_H618_M35_BF_ V05.bin nfi area detection (3 cores) finished: Ok ffs/eeprom record offset detected ffs/eeprom record size detected nfi area detection... bootloader version: FREEFLY35_09A_BOOTLOADER_V005_MT6235B_H618_M35_BF_ V05.bin nfi area detection (3 cores) finished: Ok ffs/eeprom record offset detected ffs/eeprom record size detected Model: _Autodetect MT6228-6268 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8B00:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235B,E00 Date: 2000.00.00 Version: 1.0 Version: H618_M35_BF_V05 Version: FREEFLY35_09A_HW ==================== New firmware found (v.4.07, database date: 09.11.2011): H618_M35_BF_V05 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 90 byte(s) read imei: 35868800000015 connection Ok 512 byte(s) read 89 byte(s) read reading data #2... 512 byte(s) read calibration value: 0 writing data... verification... verification Ok Finished, time used: 19 sec Remove/Install battery now ! |
| | #8297 (permalink) |
| ==== [11/11/2011 12:17:41 PM] ==== COM3 [VCP0] selected module v4.07 Device: _Autodetect MT6228-6268 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8B00:8A00 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6235:8B00:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: H618_M35_BF_V05 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: FREEFLY35_09A_BOOTLOADER_V005_MT6235B_H618_M35_BF_ V05.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: FREEFLY35_09A_PCB01_GPRS_MT6235B_S01.H618_M35_BF_V 05.BIN project-id: H618_M35_BF_V05, 73AE058F code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.4.07, database date: 09.11.2011): FREEFLY35_09A_PCB01_GPRS_MT6235B_S01.H618_M35_BF_V 05.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== warning: can not format: HW_STORAGE_NOR is not present Format... autodetection mode... Format done Disconnect... done file saved: c:\InfinityBox\MModule\backup_security\FREEFLY35_0 9A_PCB01_GPRS_MT6235B_S01.H618_M35_BF_V05__system_ log_20111111-121847.B4X.bin Finished, time used: 1 min 6 sec Remove/Install battery now ! |
| | #8298 (permalink) |
| ==== [11/10/2011 2:44:02 PM] ==== COM3 [VCP0] selected module v4.07 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6003:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.B017_T3T4_GF IVE_V05_L08_08.BIN project-id: B017.T3T4.GFIVE.V05.L08.08, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 49 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #8299 (permalink) |
| huawei g6600 unlock done ==== [11/8/2011 3:23:11 PM] ==== COM3 [VCP0] selected module v4.05 Action: read unlock codes unlock method: read codes Model: Huawei-G6600_64mb Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E5.2AV01V01.04 Version: BYD35_09A_PMWY_HW ==================== New firmware found (v.4.05, database date: 20.10.2011): E5.2AV01V01.04 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 82 byte(s) read imei: 35751003914986 connection Ok 189 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 177 byte(s) read reading data... 972 byte(s) read lock[1] code: + 87350410 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 24 sec Remove/Install battery now ! |
| | #8300 (permalink) |
| COM3 [VCP0] selected module v4.05 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:70D0:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.4.05, database date: 20.10.2011): SIG23_08A_PCB01_GPRS_MT6223_S00.S501ANV01_01B04_M5 _FOR.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: mtk@infinity-box.com or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: SIG23_08A_PCB01_GPRS_MT6223_S00.S501ANV01_01B04_M5 _FOR.BIN project-id: S501ANv01.01b04_M5_FOR, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 55 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| | #8301 (permalink) |
| COM3 [VCP0] selected module v4.05 Device: Spice-D88N Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On detected CPU: MT6226MA chip: 0031 143:9424status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent rom info detection finished rom info ver: 04 sw version: IACN26_07A_PMJ_PCB01_GPRS_MT6226M_S01.MAUI_07A_W07 _32_MP_V28.BIN project-id: MAUI.07A.W07.32.MP.V28, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/001F0000 rom info structure: [standard] type (04) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 98004900000002:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:2AEA0000000000 Finalization Done Finished, time used: 2 min 10 sec Remove/Install battery now ! |
| | #8302 (permalink) |
| COM3 [VCP0] selected module v4.05 Device: Spice-M5252 Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:B853:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2BEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.4.05, database date: 20.10.2011): JIN_S06_SMS_PCB01_GPRS_MT6223P_S00.PN-SC_CN_LLNUMLD_221_YYMMDD_CAM_MCPMCP_O.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: JIN_S06_SMS_PCB01_GPRS_MT6223P_S00.PN-SC_CN_LLNUMLD_221_YYMMDD_CAM_MCPMCP_O.BIN project-id: PN-SC_CN_LLNUMLD_221_YYMMDD_CAM_MCPMCP_O, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: JIN_S06_SMS_PCB01_GPRS_MT6223P_S00.PN-SC_CN_LLNUMLD_221_YYMMDD_CAM detecting firmware build... ............................................ firmware date/time: 2009-06-18 21-15 hw1: CKT23C_08A_GEMINI_HW hw2: 00 done detecting product-id... .................................................. .............. done detecting languages... ........................................ language parameters detected detected languages: En Finished, time used: 59 sec Remove/Install battery now ! |
| | #8303 (permalink) |
| COM3 [VCP0] selected module v4.01 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:2CDA:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP 1_V20.BIN project-id: MAUI.07A.W07.36.SP1.V20, 00000000 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 16J provider: S319X-2BVGGB1 customization: CH16CS20 customization: XH16CS20 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 00C00000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XH16CS20 customization name adjusted flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35239402001973 flash: 98004900000002:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:2AEA0000000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_0 7A_W07_36_SP1_V20__system_log__00000000_20111020-135044.B0X.bin Finished, time used: 3 min 9 sec Remove/Install battery now ! |
| | #8304 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2008
Member: 679135 Status: Offline Sonork: 100.1606448 Thanks: 332
| Huawei G7010 Code: COM3 [VCP11] selected module v4.07 Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: ESPC113B146SSC Version: VER.B 115 byte(s) read imei: 35391504371921 Finished, time used: 29 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 8 sec Remove/Install battery now ! |
| | #8306 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007 Location: pakistan Age: 30
Member: 653398 Status: Offline Sonork: 100.1619594 Thanks: 1
| Vodafone 547 unlock done COM5 [VCP0] selected module v4.07 Action: "sp-unlock" unlock method: smart fast Model: Vodafone-547 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: VF_UK_EN_P107A4V1.2.0B06 Version: 09AZTENJ35_09A 83 byte(s) read imei: 3596 connection Ok 189 byte(s) read reading data... reading data #2... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! thanks infinity team good job for me |
| The Following User Says Thank You to haroon454 For This Useful Post: |
| | #8307 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: May 2010
Member: 1297521 Status: Offline Thanks: 3
| Huawei G7010 Telenor Serbia done COM37 [VCP0] selected module v4.07 Model: Huawei-G7010 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: SRBC21B278SSCPAB Version: VER.C 115 byte(s) read imei: 35391504680250 Finished, time used: 7 sec Remove/Install battery now ! Now click to "OK" button and press and HOLD phone "Power" button again ! interface: META_DLL_v6.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! Shutdown... done Finished, time used: 6 sec Remove/Install battery now ! |
| | #8308 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Aug 2008 Location: the same about Facundo Cabral
Member: 839359 Status: Offline Thanks: 29
| Other ZTE-G N281 from Telcel México via RX TX GND cable COM3 [VCP0] selected module v4.07 Action: "sp-unlock" unlock method: smart fast Model: ZTE-N281 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ES_MX_TELCEL8_P107A3V1.0.0B04 Version: 09AZTENJ35_09A ==================== New firmware found (v.4.07, database date: 09.11.2011): ES_MX_TELCEL8_P107A3V1.0.0B04 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 83 byte(s) read imei: 35769203606741 connection Ok 189 byte(s) read reading data... reading data #2... building new data... writing data... 177 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 20 sec Remove/Install battery now ! thank´s and BR |
| | #8309 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 5346 Thanks: 252
| Huwai g7002 unlock in few seconds. Code: ==== [11/12/2011 4:19:16 AM] ==== COM40 [Serial2] selected module v4.07 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G7002 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9703:0006 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: G5.2EG01V02.11 Version: P2 67 byte(s) read imei: 356XXXXXXXXXXXXX connection Ok 178 byte(s) read reading data... reading data #2... building new data... writing data... 166 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 11 sec Remove/Install battery now ! |
| | #8310 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: Sri Lanka
Member: 576633 Status: Offline Thanks: 147
| Vodafone 345 unlock done ! COM10 [VCP0] selected module v4.01 Device: Vodafone-345 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:41FC:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088BAFFFFFFFF:2088BA00000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb otp offset: 003F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info ver: 05 sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size [01]: 003A0000/00058000 TCL-ID identification version: 869 provider: V345X-2AVDLK1 customization: CM86KS50 customization: XM86KS50 TCL-ID identification done rom info structure: [standard] type (05) TCL-ID is present ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected customization: XM86KS50 customization name adjusted flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 2088BAFFFFFFFF:2088BA00000000 flash: 2088BAFFFFFFFF:2088BA00000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 0000B3E0F3A3B4 flash: 2088BAFFFFFFFF:2088BA00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088BAFFFFFFFF:2088BA00000000 Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Vodafone-345_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20111113-141350.B0X.bin Finished, time used: 2 min 2 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| need software for 5161 by cable | mln2000 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 08-29-2010 20:17 |
