Old 07-18-2012, 05:58   #8686 (permalink)
.:::GSM KING:::.'s Avatar
Member: 1765789
Nokia 2700c Successfully Flash
Connect phone on selected interface...
Core : v1.47 , FlashEngine : v1.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm561__09.97.mcusw
PPM : rm561__09.97.ppm_mena_b
CNT : rm561__09.97.image_mena_b_red
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Getting product info...
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
Connection opened successfully
Waiting for communication response.
ASIC ID: 000000010000022600010006030C192101033000
CPU ID : RAP3Gv3 , Features : No any extended features
RAP_PUB: 21A00113F7A08E567D51D1FF5A77B772DE73CF14
CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
TIME : Boot time : 00:00:06
Reopening the connection...
Waiting for response: 30
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : Check data
ADL : Data accepted
ADL : ASIC CMT select Ok
===Flashing [MCU]===
Erase : Processing rm561__09.97.mcusw
Found 6 areas to erase
Erasing area 0x00000000 - 0x000006BF, NOR, CMT
Result: 0000
Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x0137FFFF, NOR, CMT
Result: 0000
Erasing area 0x01380000 - 0x0151FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:52
Write : Processing rm561__09.97.mcusw
Total 1256 [1256/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
TIME : Write time : 00:01:01
MCU Write done
===Flashing [PPM]===
Erase : Processing rm561__09.97.ppm_mena_b
Found 1 areas to erase
Erasing area 0x01520000 - 0x01DBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:08
Write : Processing rm561__09.97.ppm_mena_b
Total 353 [353/0/0] blocks to write, writing...
TIME : Write time : 00:00:17
PPM Write done
===Flashing [CNT]===
Erase : Processing rm561__09.97.image_mena_b_red
Found 2 areas to erase
Erasing area 0x01DC0000 - 0x0215FFFF, NOR, CMT
Result: 0000
Erasing area 0x02160000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:06:30
Checking content info...
Check Image : Content size is 128k, use direct write mode
Write : Processing rm561__09.97.image_mena_b_red
Total 528 [528/0/0] blocks to write, writing...
TIME : Write time : 00:00:27
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:12:17
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia 2700 classic
Software Info: V 09.97 18-06-10 RM-561 (c) Nokia
IMEI: 351994040234063
PPM version : V 09.97 18-06-10 RM-561 (c) Nokia MEN
Product code: 0581971
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
AfterFlash operations done ;D
Done!
Elapsed: 00:13:30
Phone found!
Series 40 Device detected!
read info... - Ok
The Following User Says Thank You to .:::GSM KING:::. For This Useful Post:
Old 07-20-2012, 06:50   #8687 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Motorola v171 --unlock done---backup done---user code remove done-----
COM11 [VCP0] selected
Action: read information
Device: V170,V171,V172,V173
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 00
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 4.4.58..
HW version: MOTOROLA_C071
Flex ver: FLEX_90_61_3D03
Check Flash-1 Done
Check Flash-2...
Finished, time used: 12 sec
Remove/Install battery now !
here´s bachup of full flash and eemprom-- https://rapidshare.com/files/741077940/backup motorola v171.rar
The Following User Says Thank You to carlos32 For This Useful Post:
Old 07-20-2012, 14:50   #8688 (permalink)
dimityr.milev's Avatar
Member: 591325
sfr115
COM6 [VCP0] selected
module v4.10
Action: "sp-unlock"
unlock method: smart fast
Model: SFR-115
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:6FF0:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: TMO_UK_P109A17V1.0.1B09
Version: ZTENJ23D_09A_HW
86 byte(s) read
imei: 86120700270673
connection Ok
192 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
180 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 15 sec
The Following User Says Thank You to dimityr.milev For This Useful Post:
Old 07-21-2012, 10:32   #8689 (permalink)
saif@cellplus's Avatar
Member: 26488
Sonork: 100.1581233
Vodafone 345 unlocked successfully
COM15 [VCP0] selected
module  v4.13
Device: Vodafone-345
Action: rebuild security area
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A08]...
CPU: MT6223
high speed boot On
chip: 0011:54D8:A00C
status: 01
boot packet size: 0400
Boot Done
====>  Initialize ...
flash: 2088BAFFFFFFFF:2088BA00000000
flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb
otp offset: 003F0000
Initialize Done
====>  Set baud ...
921600
Set baud Done
====>  Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====>  Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is present
rom info detection finished
TCL-ID detection...
TCL-ID detection done
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
code offset: 00000000
ffs offset/size [01]: 003A0000/00058000
TCL-ID identification
version: 865
provider: V345X-2AVDGB1
customization: CM86FE30
customization: XM86FE30
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 003A0000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
original imei: 00003C7044B6F2
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
Write Done
====>  Finalization ...
ffs formatting...
Finalization Done
file saved: C:\InfinityBox\MModule\backup_security\Vodafone-345_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_20120721-144445.B0X.bin
Finished, time used: 1 min 26 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Regards,
Saif.
The Following User Says Thank You to saif@cellplus For This Useful Post:
Old 07-24-2012, 09:07   #8690 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
OT-305A UNLOCKED SUCCESFULY:
module v4.36
Device: Alcatel-305X, 305A
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:8F79:A00C
status: 01
Boot Done
flash: EC240200000000:2BEA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.5C7628A3 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_1382AAEA].rpl
TCL-ID detection...
device-id: 5C7628A3
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN
project-id: MAUI.08A.W08.36.SP1.V34, EAAA8213
ffs offset/size [01]: 00C00000/00400000
version: 166
provider: 305X-2DVDKE1
customization: CP16CH12
customization: XP16CH12
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
original imei: FFFFFFFFFFFFFF
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_5C7628A3_1382AAEA_201 20724-110513.B0X.bin
Finished, time used: 3 min 50 sec
The Following User Says Thank You to KYEJUSA For This Useful Post:
Old 07-24-2012, 14:35   #8691 (permalink)
taoujdate's Avatar
Member: 510826
UNLOCK BENQ S660S DONE :
COM4 [VCP0] selected
module v1.33
Device: BenQ-S660C
Action: unlock
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
error: Probably wrong model selected.
Continue anyway ?
Check Flash Done
Check Parameters...
Flash: 0089:88C500010001
file saved: C:\InfinityBox\BModule\eeprom-00_20120724-131748.78F.bin
file saved: C:\InfinityBox\BModule\eeprom-01_20120724-131759.78F.bin
file saved: C:\InfinityBox\BModule\eeprom-02_20120724-131811.78F.bin
file saved: C:\InfinityBox\BModule\eeprom-03_20120724-131839.78F.bin
file saved: C:\InfinityBox\BModule\eeprom-04_20120724-131922.78F.bin
Check Parameters Done
Check Space...
flash: Intel I28F320C3B-B B 4Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Writing Done
Finished, time used: 190 sec
The Following User Says Thank You to taoujdate For This Useful Post:
Old 07-24-2012, 16:52   #8692 (permalink)
Crazy Poster
Member: 1725927
COM10 [VCP0] selected
module v4.13
Device: ZTE-X632
Action: reset settings ("format ffs")
Do you want to make ffs/eeprom backup before format ?
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:6C7B:000C
status: FF
Boot Done
flash: C2227E22212201:2CEA0000000000
flash: Micron/Silicon7 AMD/Fujitsu std [def 0080x020000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info structure: [standard] type (07)
TCL-ID is absent
New firmware found (v.4.13, database date: 29.01.2012):
M23_Z525_C136_HW1_SW17_PCB01_GPRS_MT6223P_S00.Z525 _C136_HW1_SW17_V1_10_FMXIC.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: support@infinity-box.biz or upload files to RapidShare ? Secure Data Logistics or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 07
sw version: M23_Z525_C136_HW1_SW17_PCB01_GPRS_MT6223P_S00.Z525 _C136_HW1_SW17_V1_10_FMXIC.BIN
project-id: Z525.C136.HW1.SW17.V1.10_FMXIC, 00000000
ffs offset/size [02]: 00E00000/00200000
TCL-ID is absent
ffs/eeprom address assigned: 00E00000
reading: ZTE-X632_M23_Z525_C136_HW1_SW17_PCB01_GPRS_MT6223P_S00 .Z525_C136_HW1_SW17_V1_10_FMXIC__ffs...
file saved: C:\Archivos de programa\InfinityBox\MModule\ZTE-X632_M23_Z525_C136_HW1_SW17_PCB01_GPRS_MT6223P_S00 .Z525_C136_HW1_SW17_V1_10_FMXIC__ffs_20120724-111324.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 4 min 29 sec
The Following User Says Thank You to yankee02 For This Useful Post:
Old 07-25-2012, 15:07   #8693 (permalink)
sirnavid2010's Avatar
Member: 777729
Sonork: 100.1616470
COM15 [ProlificSerial2] selected
module v4.12
Device: Fly-SL500i
advanced flash detection disabled
Action: "sp-unlock"
unlock method: standard
enhanced security fix enabled
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6219:8B02:8B01]...
CPU: MT6219
high speed boot Off
detected CPU: MT6226MA
chip: 0031:6041:0C40
status: FF
high speed boot Off
Boot Done
flash: B0001D00000000:B0001D00000000
flash: Sharp LRS18C8A B 16Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info structure: [standard] type (04)
TCL-ID is absent
rom info ver: 04
sw version: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN
project-id: SL900A.05C.W06.08.MP.V72.F2, 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
reading: Fly-SL500i_SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_ 05C_W06_08_MP_V72_F2__ffs...
file saved: C:\InfinityBox\MModule\Fly-SL500i_SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_ 05C_W06_08_MP_V72_F2__ffs_20120715-124908.B0E.bin
detection procedure, wait...
detection procedure completed
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
area 1 patch applied Ok
====> Write ...
Write: ffs
Write Done
Finalization Done
Finished, time used: 7 min 18 sec
The Following User Says Thank You to sirnavid2010 For This Useful Post:
Old 07-25-2012, 16:18   #8694 (permalink)
KYEJUSA's Avatar
Member: 394869
OT-203X UNLOCKED SUCCESSFULY:
module v4.36
Device: Alcatel-203X, 203A, 203E
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:5E6C:A00C
status: 01
Boot Done
flash: 01227E221A2201:2BEA0000000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
TCL-ID detection...
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
version: 37L
provider: 203X-2BRGTE5
customization: CM37CC30
customization: XM37CC30
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
original imei: 35247403883535
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-203X,203A,203E_JRD23_NEP_08A_PCB01_GSM_MT6223_S00. MAUI_08A_W08_36_SP1_V28_F1__system_log__00000000_2 0120725-181116.B0X.bin
Finished, time used: 2 min 3 sec
Old 07-27-2012, 22:00   #8695 (permalink)
Crazy Poster
Member: 1725927
module v1.78
Device: Zong-A136
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:257E
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: ARO-P108A27FM U V1.0.0B04 Nov 24 2009 13 26 48 Nov 24 2009 CLARO
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Zong-A136_eeprom-static_20120727-165811.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Zong-A136_eeprom-security_20120727-165812.B1E.bin
reading eeprom-complete...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Zong-A136_eeprom-complete_20120727-165818.B1E.bin
reading additional data...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Zong-A136_lock-area_20120727-165831.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 52 sec
Old 07-30-2012, 15:41   #8696 (permalink)
KYEJUSA's Avatar
Member: 394869
VODAFONE-150 UNLOCKED SUCCESFULY:
module v4.36
Device: Vodafone-150
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:68C1:A00C
status: 01
Boot Done
flash: 8C22F60000000D:2BEA0000000000
flash: AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
TCL-ID detection...
rom info ver: 05
ffs offset/size [01]: 00390000/00068000
version: 16H
provider: 150X-2AVDKE1
customization: CW16CD60
customization: XW16CD60
TCL-ID is present
ffs/eeprom address assigned: 00390000
area1 is valid
area2 is valid
area3 is valid
area4 is valid
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Vodafone-150_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W0 8_36_SP1_V28_F1__system_log__00000000_20120730-173352.B0X.bin
Finished, time used: 1 min 57 sec
Old 08-07-2012, 13:36   #8697 (permalink)
Member: 591325
module v4.11
Action: read unlock codes
unlock method: read codes
Model: ZTE-R221_16mb
19200 autodetect
CPU: MT6223
high speed boot On
chip: 0011:6844:000C
status: FF
Hardware: MT6223,E08
Date: 2000.00.00
Version: 1.0
Version: BG-MTEL-R9SM-P109A17V1.0.0B01
86 byte(s) read
imei: 86120700637323
connection Ok
192 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
180 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 227318537470
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if phone do not ask for a code try: *983*8284#
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone (do not remove battery)
- read unlock codes
- restore original imei
Finished, time used: 13 sec
Old 08-15-2012, 11:07   #8698 (permalink)
Member: 591325
module v4.11
Action: "sp-unlock"
Model: ZTE-N295
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
high speed boot On
chip: 0000:0000:0003
status: FF
rom: 4D573031
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: MTEL-BUL-9-P107A20V1.0.0B02
Version: 10AZTENJ35_GEMINI_10A
New firmware found (v.4.11, database date: 28.11.2011):
115 byte(s) read
imei: 35771404178548
connection Ok
216 byte(s) read
reading data...
reading data #2...
writing data...
204 byte(s) read
reading data...
188 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 25 sec
Old 08-17-2012, 07:13   #8699 (permalink)
shamshad quresh's Avatar
Member: 898041
Sonork: 5346
Alcetel ot 708 unlock done.
COM63 [ProlificSerial0] selected
module  v4.13
Device: Alcatel-708X, 708A
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8303:A00A
status: 01
Boot Done
flash: 98006F00000004:09EA0000000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
Initialize Done
====>  Set baud ...
115200
Set baud Done
usb bootloader (chip) is present: 00020000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is present
startup code area #1 backup saved: C:\InfinityBox\MModule\backup_security\id.8ADC0976.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN_F9B1BE33].rpl
TCL-ID detection...
device-id: 8ADC0976
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, 33BEB1F9
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
version: 1A1
provider: 708X-2AVRGB1
customization: CN1AKD01
customization: XN1AKD01
TCL-ID is present
ffs/eeprom address assigned: 01800000
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
error: security area (sec info, cust) header is invalid
done
done
done
original imei: 35908103326159
====>  Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\InfinityBox\MModule\backup_security\Alcatel-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP1_V32__system_log_8ADC0976_F9B1BE33_20120817-105447.B0X.bin
Finished, time used: 4 min 57 sec
The Following User Says Thank You to shamshad quresh For This Useful Post:
Old 08-22-2012, 15:03   #8700 (permalink)
KYEJUSA's Avatar
Member: 394869
OT-105X UNLOCKED SUCCESFULY;
module v4.37
Device: Alcatel-105X, 105A
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:5E54:A00C
status: 01
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is present
TCL-ID detection...
rom info ver: 05
version: 66E
provider: 105X-2BRGKE9
customization: CM66CW40
customization: XM66CW40
TCL-ID is present
area1 is valid
area2 is valid
area3 is valid
area4 is valid
max address is too big, should be recalculated: 0827D124->0827C91C
done
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: c:\InfinityBox\MModule\backup_security\Alcatel-105X,105A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_201208 22-165513.B0X.bin
Finished, time used: 2 min 6 sec
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
Page generated in 0.52896 seconds with 12 queries
