Unlock Server
Old 10-11-2009, 21:35   #946 (permalink)
dkm
Member: 879847
Alcatel Ot 363 Dead; Revived With Repair Security Area.
COM6 [VCP10] selected
module v2.91
Device: Alcatel-363X
Checking data, wait...
Action: repair security area
Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:ADDE:A00C
status: 01
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [enhanced] generation
startup code area #1 is damaged, recalculation required
rom info detection finished
device-id: 490F0251
rom info protocol ver: 05
ver. sw 1: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V9.BIN
ver. sw 2: MAUI.08A.W08.36.SP1.V9, B04C74D5
ffs offset/size: 00C00000/00400000
ffs address assigned: 00C00000
TCL identification...
version: 26A
provider: 363X-2ARGES1
customization: XI26AA31
TCL identification done
detect device sec info...
detect device sec info finished
sim-lock status: disabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is invalid
area2 is valid
area3 is valid
area4 is valid
startup code area #1 check...
Write: startup code area #1
startup code area #1 fixed
area1 is invalid
area2 is valid
area3 is valid
area4 is valid
security area (sec info, part #2) calculation...
customization: CI26AA31
done
Write: security area (sec info, part #2)
security area (sec info, part #2) calculation done
security area (sec info, part #1) calculation...
..................security area (sec info, part #1) detecting size...
security area (sec info, part #1) detecting parameters...
security area (sec info, part #1) encoding...
done
Write: security area (sec info, part #1)
security area (sec info, part #1) calculation done
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-363X_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08 _36_SP1_V9__system_log_490F0251_2A8BB34F_20091011-211752.B0X.bin
Finished, time used: 176 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to dkm For This Useful Post:
Old 10-12-2009, 06:13   #947 (permalink)
thushdt's Avatar
Member: 544160
Sonork: 100.1603100
E-tel V809 Sucessfully Repair
COM4 [VCP0] selected
module v2.93
Device: Autodetect 6205-6227 NOR
Action: "format ffs"
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:CE03:0003
status: FF
Boot Done
Initialize ...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
921600
Set baud Done
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
rom info structure: 2nd [standard] generation
New firmware detected (v.2.93, database date: 04.10.2009):
EELINK25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M3329_FM BT_V329T_ETEL_V1_3.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: mt62xx@gmail.com or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
ver. sw 1: EELINK25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M3329_FM BT_V329T_ETEL_V1_3.BIN
ver. sw 2: M3329_FMBT_V329T_ETEL_V1.3, 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
reading: EELINK25_08A_GEMINI_PCB01_GPRS_MT6225_S00.M3329_FM BT_V329T_ETEL_V1_3__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\EELINK25_08A_GEMI NI_PCB01_GPRS_MT6225_S00.M3329_FMBT_V329T_ETEL_V1_ 3__ffs_20091012-103648.B0E.bin
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 150 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following User Says Thank You to thushdt For This Useful Post:
Old 10-12-2009, 07:25   #948 (permalink)
..::ohm::..'s Avatar
Member: 662678
samsung cdma f679 unlock done by infinity
module v1.09
Device: Samsung-SCH-F679
Action: unlock
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 17 sec
The Following User Says Thank You to ..::ohm::.. For This Useful Post:
Old 10-12-2009, 08:44   #949 (permalink)
ehsas_ghum's Avatar
Member: 171512
nokia e71i repair ok
module v2.91
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001:EA03:0005
status: FF
Boot Done
Initialize ...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Initialize Done
Set baud ...
921600
Set baud Done
New firmware detected (v.2.91, database date: 03.10.2009):
STANDARD_GEMINI_PCB01_GPRS_MT6225_S00.G106AR40ATML OG090701.BIN
rom info protocol ver: 04
ver. sw 1: STANDARD_GEMINI_PCB01_GPRS_MT6225_S00.G106AR40ATML OG090701.BIN
ver. sw 2: G106AR40ATMLOG090701, 00000000
ffs/eeprom chip: 00
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 48 sec
The Following User Says Thank You to ehsas_ghum For This Useful Post:
Old 10-12-2009, 09:19   #950 (permalink)
thushdt's Avatar
Member: 544160
Sonork: 100.1603100
Lenovo V800 Done
module v2.93
Action: reset settings
Model: Autodetect 6205-6227 NOR
19200 autodetect
Initializing [6219:8A01]...
CPU: MT6219
high speed boot On
Connecting at 19200, wait...
Hardware: MT6219,E01
Date: 2004.06.18
Version: 1.7.1.2
Version: MAUI.05A.W05.36.MP.V16.F1
Version: XM3_HW
detecting structure #2...
done
57 byte(s) read
imei: 351686013*****
connection Ok
building list...
done
items to clear: 163
warning: wrong packet cs
items cleared: 163 of 163
building list...
done
items remains: 0
Finished, time used: 27 sec
Old 10-12-2009, 12:43   #951 (permalink)
Member: 847994
Sonork: 2011
R306 unlocked successfully
R306 is unlocked by infinity
thanks infinity team for helpful support
here is the screen shoot
COM5 [VCP2] selected
module v1.32
Device: Sony-Ericsson-R306
"advanced chip detection" active
Action: unlock
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
115200
Set baud done
Check hardware ...
flash: 89890400040089:89890400000000
flash: Intel ST [def 0080x040000] 32Mb
Check hardware done
Read data ...
reading Sony-Ericsson-R306_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-R306_eeprom_calibration-1_20091012-172433.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 190 sec
The Following User Says Thank You to Unique Mobile For This Useful Post:
Old 10-12-2009, 14:19   #952 (permalink)
Shakeel_pattoki's Avatar
Member: 437195
Sonork: sonork is spam!
COM23 [VCP0] selected
module  v2.75
Action: imei
imei write method: mode-2
imei write channel: imei #1 for dual sim/mono CPU
new imei: 358762541404110
Model: LG-KG195
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
chip: 0031:2C19:7621
status: FF
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7332SA00-001-R1D
Version: FP_0620
60 byte(s) read
imei: 35879402293815
connection Ok
60 byte(s) read
verification...
verification done: 35876254140411
Finished, time used: 12 sec
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 10-13-2009, 06:12   #953 (permalink)
kmaxmax's Avatar
Member: 553000
W375 motorola unlock easily with infinity !!
check it plz:
COM3 [VCP0] selected
Action: unlock
Device: W375
Connect...
Press and HOLD Power button...
rom version: 0411
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 0.0.62
HW version: MOTOROLA_H80S
LP ver: 0062_001
Flex ver: FLEX_B3_005
cpu id: 08B6
imei eeprom: 35300301xxxxxxxx
required SW version: 0.0.62
sp-locked: 23430.
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _3530036xxxxxxxx
20091012-220745.34E.bin
unlock step-1 Ok
unlock step-2 Ok
unlock step-3 Ok
unlock step-4 Ok
unlock step-5 Ok
finished Ok
Finished, time used: 71 sec
Kmax
The Following 4 Users Say Thank You to kmaxmax For This Useful Post:
Old 10-13-2009, 08:10   #954 (permalink)
thushdt's Avatar
Member: 544160
Sonork: 100.1603100
Chinese Nokia TM17M1 Repair Done
module v2.93
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A04:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:A131:000C
status: FF
Boot Done
Initialize ...
flash: EC257E25062501:2BEA0000000000
flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
Set baud ...
921600
Set baud Done
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00800000
ver. sw 1: VIEWTRAN23C_07B_PCB01_GPRS_MT6223P_S00.TM16_LANG1_ V2_0.BIN
ver. sw 2: TM16_LANG1_V2.0, 00000000
ffs offset/size: 00700000/00100000
standard ffs/eeprom offset detected: 00700000
checking area [00000000]: 00000000-007FFFFF...
ffs/eeprom found near: 00700000
ffs/eeprom size: 00100000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00700000-007FFFFF
reading: VIEWTRAN23C_07B_PCB01_GPRS_MT6223P_S00.TM16_LANG1_ V2_0__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\VIEWTRAN23C_07B_P CB01_GPRS_MT6223P_S00.TM16_LANG1_V2_0__ffs_2009101 3-123319.B0E.bin
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 89 sec
Old 10-13-2009, 08:55   #955 (permalink)
ehsas_ghum's Avatar
Member: 171512
cect a800
Action: imei
Connecting, wait...
Hardware version: MT6226, E02
Hardware version: PCB1.1
Software version: A850i_ST_5.00B_XXXX0
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
new imei: 355987456023653
verification Ok
Finished, time used: 38 sec
Power off phone now !
Old 10-13-2009, 08:57   #956 (permalink)
ehsas_ghum's Avatar
Member: 171512
sigmtel S2
module v2.91
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001203:0009
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
ver. sw 1: GINWAVE25_06B_PCB01_GPRS_MT6225_S00.FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1_0_013_080306.BIN
ver. sw 2: FXD-S3_FOREIGN_MR106_004_5S-MC-C01-RF3198_V1.0.013_080306, 00000000
ffs/eeprom chip: 00
Write ...
Write Done
Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 37 sec
Old 10-13-2009, 13:40   #957 (permalink)
sahil00150's Avatar
Member: 624567
Nec E121 Unlocked Sucessfully
COM5 [VCP0] selected
Device: Nec-E121
Action: Unlock
Boot...
Press and HOLD Power button !
Connecting, wait...
flash: 01227E22212200:98E59F00000000
flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Check Flash Done
Check space...
file saved: backup_eeprom_unlock-1_20091013-163226.3CE.bin
file saved: backup_eeprom_unlock-2_20091013-163228.3CE.bin
Check space Done
Check parameters...
Check parameters Done
Format file system...
area-01...
area requested/selected: 02/02
Format file system Done
Write...
Preparing...
Finalizing...
area requested/selected: 01/01
Write Done
Finished
Time used: 36 sec
The Following User Says Thank You to sahil00150 For This Useful Post:
Old 10-13-2009, 13:43   #958 (permalink)
sahil00150's Avatar
Member: 624567
NEC E-121 Sucessfully Unlocked..........
Device: Nec-E121
Action: Unlock
Boot...
Connecting, wait...
Boot Done
Set baud...
460800
Set baud Done
Check Flash...
Check Flash Done
Check space...
Check space Done
Check parameters...
area-01...
Write...
Preparing...
Finalizing...
Write Done
Finished
Time used: 36 sec
Old 10-13-2009, 14:38   #959 (permalink)
Member: 679135
Sonork: 100.1606448
Nec N343i
COM2 [VCP0] selected
Device: Nec N343i
advanced flash detection active
Action: Unlock
Boot...
Connecting, wait...
Boot Done
Set baud...
115200
Set baud Done
Check Flash...
Check Flash Done
Check space...
file saved: C:\Archivos de programa\InfinityBox\QModule\backup_eeprom_unlock-1_20091013-010301.22E.bin
file saved: C:\Archivos de programa\InfinityBox\QModule\backup_eeprom_unlock-2_20091013-010304.22E.bin
Check space Done
Check parameters...
area-01...
Write...
Preparing...
Finalizing...
Write Done
Finished
Time used: 41 sec
The Following User Says Thank You to hvalero2001 For This Useful Post:
Old 10-13-2009, 14:53   #960 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
KG195 read phone code
module v2.90
Action: read codes
unlock method: read codes
Model: LG-KG195
19200 autodetect
CPU: MT6226
chip: 0031:C1C1:80AE
status: FF
Date: 2005.04.12
Version: 1.0
Version: 7S7332SA00-001-R1C
Version: FP_0620
60 byte(s) read
imei: 35673301496297
connection Ok
208 byte(s) read
156 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 5464
Finished, time used: 11 sec
The Following User Says Thank You to guljee786 For This Useful Post:
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
Page generated in 0.59279 seconds with 12 queries
