Old 06-01-2011, 12:28   #12361 (permalink)
gsmpointhrp's Avatar
Member: 416286
Sonork: 100.1622339
Thanks Meter: 759
COM6 [VCP10] selected
module v3.74
Action: reset settings ("format ffs")
Model: LG-KG195
Checking data, wait...
19200 autodetect
Initializing [6226:8A02:8A01]...
CPU: MT6226
chip: 0031:1841:CCA0
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6226,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7332SA00-001-R1B
Version: FP_0620
60 byte(s) read
imei: 35673301219704
connection Ok
building list...
done
items to clear: 219
warning: wrong packet cs
items cleared: 219 of 219
building list...
done
items remains: 0
Finished, time used: 1 min 22 sec
Remove/Install battery now !
Old 06-01-2011, 12:54   #12362 (permalink)
Member: 1023408
Thanks Meter: 23
unlock huawei G6620 succesfully
Version: G6620SS.C210.M40.05.01
Version: CKT53_12832_09B_HW
116 byte(s) read
imei: 3519480xxxxxxx
coneccion Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
Leyendo datos...
220 byte(s) read
lock[1] code: + 37842456
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone
- read unlock codes
- restore original imei
Finalizado, tiempo usado: 18 sec
Quite/coloque la bateria ahora !
Old 06-01-2011, 13:00   #12363 (permalink)
Member: 1023408
Thanks Meter: 23
unlock Zonda-ZMTN610 success
COM1 [VCP1] selected
modulo v3.77
Servicio: Zonda-ZMTN610
Checkeando datos, espere...
Habilitada la deteccion avanzada del chip
Action: "sp-unlock"
Metodo unlock: standard fast
====> Boot ...
Mantenga Presionado el boton Power !
19200 fixed
Conectando, espere...
Iniciando [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:AA7D:000C
status: FF
Tamaño del boot packet: 0400
Deje de presionar el boton power ahora !
Boot Done
====> Iniciar ...
Flash 98000300000001:2BEA0000000000
Flash Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
numero de flash chip/regiones detectadas: 01/01
Iniciar Done
====> Seleccionar velocidad ...
115200
Seleccionar velocidad Done
====> Iniciar bootcode ...
Iniciar bootcode Done
====> Comprobar la integridad del firmware ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: T01C_TELCEL_PCB01_GPRS_MT6223P_S00.ZMTN610_SW_V01_ 16.BIN
project-id: ZMTN610_SW_V01_16, 00000000
code offset: 00000000
ffs offset/size [01]: 00A00000/005F0000
TCL-ID is absent
ffs/eeprom address assigned: 00A00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Comprobar la integridad del firmware Done
====> Comprobar el contenido del firmware ...
Comprobar el contenido del firmware Done
====> Backup de datos requeridos ...
Backup de datos requeridos Done
====> Revisión de datos requeridos ...
lock area found
lock area found
Revisión de datos requeridos Done
====> Operacion Especial ...
detecting parameters to apply patch area 1...
required data found
Escribir area 1 (pass 1)
area 1 patch applied Ok
detecting parameters to apply patch area 2...
error: area 2 can not apply patch
Operacion Especial Done
====> Escribir ...
Escribir lock-area-1
Escribir lock-area-4
Escribir Done
====> Finalizado ...
Finalizado Done
Finalizado, tiempo usado: 2 min 40 sec
Old 06-01-2011, 14:11   #12364 (permalink)
Member: 633231
Thanks Meter: 666
COM8 [VCP0] selected
modulo v1.78
Servicio: ZTE-A35
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
115200
Connecting ...
Flash 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: ARO-P108A7 Z B01-EnEs-DOM02 g3dBV2.0 ES-DOM-CLARO-P108A7 Z V1.0.
Check parameters Done
backup critical area ...
leyendo eeprom-static...
Archivo guardado: c:\InfinityBox\Pana01\ZTE-A35_eeprom-static_20110531-210518.B1E.bin
loading data...
data loaded
leyendo eeprom-security...
Archivo guardado: c:\InfinityBox\Pana01\ZTE-A35_eeprom-security_20110531-210519.B1E.bin
leyendo eeprom-complete...
Archivo guardado: c:\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20110531-210526.B1E.bin
reading additional data...
Archivo guardado: c:\InfinityBox\Pana01\ZTE-A35_lock-area_20110531-210545.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Escribir ...
Erasing: lock-area
Writing: lock-area
Escribir Done
Finalizado, tiempo usado: 1 min 13 sec
Old 06-01-2011, 15:02   #12365 (permalink)
JINDALGSM™'s Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,705
nokia 7210c flashing done
card found: S/N 0390:0118
registered to: jindalgsm4255
Connect phone on selected interface...
Core version : 1.22 , Rev : 4.5
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm436__07.23.mcusw
PPM : rm436__07.23.ppm_c
CNT : rm436__07.23.image_c_de
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Getting product info...
Dead Mode is Selected
Waiting for USB device...
--- Press phone's power button or insert cable & charger! ---
Connection opened successfully
Waiting for communication response.
[BB5 FLASH]: Bootrom Ok!
ASIC ID: 000000010000022600010006030C192101033000
CPU ID : RAP3Gv3 , Features : No any extended features
RAP_PUB: 23E000053D036B503A8F97F08D4A46EF7A0F5951
CMT_ROOT: 9DDBFCFE6E73CED7D8C6268C8EB85723
PatchRAWLoader: Patched OK
Processing RAWLOADER...
Processing UPDAPP...
Processing PASUBTOC...
TIME : Boot time : 00:00:06
Reopening the connection...
Waiting for response: 30
ADL -> [2nd] changing...
ADL Server confirm flashmode!
ADL : Check data
ADL : Data accepted
ADL : ASIC CMT select Ok
===Flashing [MCU]===
Erase : Processing rm436__07.23.mcusw
Found 6 areas to erase
Erasing area 0x00000000 - 0x000006BF, NOR, CMT
Result: 0000
Erasing area 0x000006C0 - 0x0001FFFF, NOR, CMT
Result: 0000
Erasing area 0x00040000 - 0x000BFFFF, NOR, CMT
Result: 0000
Erasing area 0x000C0000 - 0x0013FFFF, NOR, CMT
Result: 0000
Erasing area 0x00140000 - 0x0119FFFF, NOR, CMT
Result: 0000
Erasing area 0x011A0000 - 0x0133FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:02:11
Write : Processing rm436__07.23.mcusw
Total 1170 [1170/0/0] blocks to write, writing...
CMT : Writing Hash CERT [NOLO]
CMT : Writing Hash CERT [KEYS]
CMT : Writing Hash CERT [PRIMAPP]
CMT : Writing Hash CERT [PASUBTOC]
CMT : Writing Hash CERT [PAPUBKEYS]
CMT : Writing Hash CERT [UPDAPP]
CMT : Writing Hash CERT [DSP0]
CMT : Writing Hash CERT [MCUSW]
TIME : Write time : 00:00:59
MCU Write done
===Flashing [PPM]===
Erase : Processing rm436__07.23.ppm_c
Found 1 areas to erase
Erasing area 0x01340000 - 0x01BDFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:59
Write : Processing rm436__07.23.ppm_c
Total 448 [448/0/0] blocks to write, writing...
TIME : Write time : 00:00:22
PPM Write done
===Flashing [CNT]===
Erase : Processing rm436__07.23.image_c_de
Found 2 areas to erase
Erasing area 0x01BE0000 - 0x01F7FFFF, NOR, CMT
Result: 0000
Erasing area 0x01F80000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:05:49
Checking content info...
Check Image : Content size is 128k, use direct write mode
Write : Processing rm436__07.23.image_c_de
Total 1424 [1424/0/0] blocks to write, writing...
TIME : Write time : 00:01:10
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:11:32
Reboot phone now...
Reading Phone Info....
Connected phone - Nokia 7210 Supernova
Software Info: V 07.23 17-07-09 RM-436 (c) Nokia
IMEI: 356930039944713
PPM version : V 07.23 17-07-09 RM-436 (c) Nokia C
Product code: 0581686
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Settings After Flash Defaults...
FullFactorySet...OK!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
AfterFlash operations done... Reconnect, wait...
Done!
Elapsed: 00:12:34
Phone found!
Series 40 Device detected!
read info... - Ok
Old 06-01-2011, 15:06   #12366 (permalink)
Member: 4813
Thanks Meter: 401
UFS S/N 12874 boot - Ok
Phone found!
read info... - Ok
SW ver : V 06.20 01-12-10 RH-125 (c) Nokia
IMEI : 357000046450796
PPM : V 06.20
01-12-10
RH-125
(c) Nokia
EK
PCode : 059C017
BPCode : 059F8R0
HWID : 1014
LCDVer : TPO:BOHAIv80
HX5081
Sl Conf : 284-01-00053285640
Sl Prof : 800000000003000-2
Sl Aux : 000B0000
Hw Sig : 428FC156E4B5927A
Provider : MobilTel AD;Bulgaria
Lock info:
Block 1
L1:Close;
Done!
MCU : rh125_006.200
PPM : rh125_006.20ad
CNT : rh1250_nai06.20ad
Infineon flashing...
Booting phone now....
Sync Ok , A2
CPU ID : XGOLD , A200341100
Boot Ok , 01AB
Algo Ok , 01
SBL mode Ok
SBL : Default_RAM_Bootloader
EPP CFG [Bering]...
FLASH ID : 00EC0000007A2200
FLASH ID : UNKNOW [Not In Base]
Boot Done!
File : rh125_006.200
Image : hw_f11_rh125_r06.200.fls
Cert block found, sending....
Cert sent
Found 3 region(s)
Processing Region 1/3
Erase , Start : 0x00800000 , Len : 0x00210000
Erasing, wait ...
Erase done
Write , Start : 0x00800000 , Len : 0x00210000
Flashing , wait ...
Region flash done
Processing Region 2/3
Erase , Start : 0x00C60000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00C60000 , Len : 0x00209840
Flashing , wait ...
Region flash done
Processing Region 3/3
Erase , Start : 0x00FFC000 , Len : 0x00004000
Erasing, wait ...
Erase done
Write , Start : 0x00FFC000 , Len : 0x00000040
Flashing , wait ...
Region flash done
Check : 02AD
File : rh125_006.20ad
Image : hw_f11_rh125_006.20ad.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x00210000 , Len : 0x00250000
Erasing, wait ...
Erase done
Write , Start : 0x00210000 , Len : 0x001C8500
Flashing , wait ...
Region flash done
Check : BD14
File : rh1250_nai06.20ad
Image : hw_f11_rh1250_nai06.20ad.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x00EB0000 , Len : 0x000D0000
Erasing, wait ...
Erase done
Write , Start : 0x00EB0000 , Len : 0x00050580
Flashing , wait ...
Region flash done
Check : 02CB
Flashing done, rebooting...
-> Infineon info : Do FullFactory Sets after flashing
Flashing Done!
Init Service mode... Wait...
Afterflash settings...
SW ver : V 06.20
01-12-10
RH-125
(c) Nokia
PCode : 059C017
SwUpgradeSet...OK!
All done!
Old 06-01-2011, 16:15   #12367 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
registered to: saeedullah_khan
MCU : rm217__07.30.mcusw
PPM : rm217__07.30.ppm_r
CNT : rm217__07.30.image_ora_pl_red_128
Check files done...
ASIC ID: 000000010000022600010006010C192101001101
RAP_PUB: 1CA0020EED567E56E82BEBDC7C59F5AF47D69D70
CMT_ROOT: BAF3A9C3DBFA8454937DB77F2B8852B1
TIME : Boot time : 00:00:05
ADL : Check data
ADL : Data accepted
Erase : Processing rm217__07.30.mcusw
Found 9 areas to erase
Result: 0000
Result: 0000
Erasing area 0x00020000 - 0x0007FFFF, NOR, CMT
Result: 0000
Erasing area 0x00080000 - 0x000DFFFF, NOR, CMT
Result: 0000
Erasing area 0x00100000 - 0x001FFFFF, NOR, CMT
Result: 0000
Erasing area 0x00200000 - 0x0031FFFF, NOR, CMT
Result: 0000
Erasing area 0x00320000 - 0x0105FFFF, NOR, CMT
Result: 0000
Erasing area 0x01060000 - 0x01067FFF, NOR, CMT
Result: 0000
Erasing area 0x01068000 - 0x0107FFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:12
Write : Processing rm217__07.30.mcusw
Total 944 [944/0/0] blocks to write, writing...
CMT : Writing Hash CERT [PMM_CONF]
CMT : Writing Hash CERT [SBIF_CONF]
TIME : Write time : 00:01:46
MCU Write done
Erase : Processing rm217__07.30.ppm_r
Erasing area 0x01080000 - 0x015FFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:16
Write : Processing rm217__07.30.ppm_r
Total 329 [329/0/0] blocks to write, writing...
TIME : Write time : 00:00:35
PPM Write done
Erase : Processing rm217__07.30.image_ora_pl_red_128
Erasing area 0x01600000 - 0x01FDFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:00:51
Write : Processing rm217__07.30.image_ora_pl_red_128
Total 288 [288/0/0] blocks to write, writing...
TIME : Write time : 00:00:31
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:05:12
Reboot phone now...
Connected phone - Nokia 6300
Software Info: V 07.30 07-05-09 RM-217 (c) Nokia.
IMEI: 353215039314791
PPM version : V 07.30 07-05-09 RM-217 (c) Nokia. R
Product code: 0559490
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:05:49
Phone found!
read info... - Ok
Old 06-01-2011, 16:15   #12368 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
UFS S/N 113742 boot - Ok
Phone found!
read info... - Ok
Reading User code...
User Code is: 822786
Done!
Resetting User Code to default (12345)...
Clear data : Ok
Result: 12345
Done!
Resetting selected items...
Check phone mode...
Phone in Local mode
Seting Test mode... wait...
Test mode set
Settings Full Factory Defaults...
Set OK!
Settings Software Upgrade Defaults...
Set OK!
Settings Service Centre Defaults...
Set OK!
Settings Production Tune Defaults...
Set OK!
Settings User Data Defaults...
Set OK!
Settings Leave Factory defaults...
Set OK!
Elapsed: 00:00:11
Connected phone - Nokia 5310 XpressMusic
Software ver : V 05.81 06-02-08 RM-303 (c) Nokia
IMEI : 354196023695891
Ape Ver :
APE Var :
APE ADSP:
DSP Ver :
APE Test: Error
PPM : V 05.81
06-02-08
RM-303
(c) Nokia
I
CNT : Content: i_red
V 05.81
06-02-08
RM-303
(c) Nokia
Product SN : DJM070816
Product code : 0568515
Base Prd.code: 0544850
Module code : 0203899
Long Prod.SN : 0
Hardware info=======
HWID : 1006
Retu : 15
Tahvo : 22
Batery: 4395 mV
Camera:
CMT BT: Error
APE BT: Error
APE HW: Error
LCDVer: SEIKO
RF ic : 064c0601
Lock info ===========
IMEI spNet :
IMEI svNet :
Conf key : 0000000000000000
Provider key : 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : Key 0 [3] , Fbus 0 [10]
Blocks : 7
LOCK STATUS :
BLK : 1
Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
User Code : not set
MMC pwd : no any record found
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Old 06-01-2011, 16:16   #12369 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
CNT : rm237__07.21.image_mea4_128
Check files done...
-> Custom flashing in dead mode active!
-> Phone will boot in normal mode after flash!
RAP_PUB: 181000037EFB7A563E0B87C97E85FA536BA05FE0
Erase : Processing rm237__07.21.image_mea4_128
Erasing area 0x01520000 - 0x01FDFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:01:59
Write : Processing rm237__07.21.image_mea4_128
Total 208 [208/0/0] blocks to write, writing...
TIME : Write time : 00:00:11
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:02:10
Reboot phone now...
Connected phone - Nokia 3110c
Software Info: V 07.21 05-11-08 RM-237 (c) Nokia.
IMEI: 353203039416956
PPM version : V 07.21 05-11-08 RM-237 (c) Nokia. MEA
Product code: 0565473
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:03:31
Phone found!
read info... - Ok
Old 06-01-2011, 16:17   #12370 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
PPM : rm436__07.23.ppm_mb
CNT : rm436__07.23.image_mb
Check files done...
RAP_PUB: 2340010C7A795750521083101855A1BF9C0396BF
ADL : Check data
ADL : Data accepted
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
TIME : Erase time : 00:02:03
MCU Write done
Erase : Processing rm436__07.23.ppm_mb
Result: 0000
TIME : Erase time : 00:00:55
Write : Processing rm436__07.23.ppm_mb
Total 387 [387/0/0] blocks to write, writing...
TIME : Write time : 00:00:20
PPM Write done
Erase : Processing rm436__07.23.image_mb
Result: 0000
Result: 0000
TIME : Erase time : 00:04:58
Write : Processing rm436__07.23.image_mb
Total 1296 [1296/0/0] blocks to write, writing...
TIME : Write time : 00:01:16
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:10:45
Reboot phone now...
IMEI: 355743024286219
PPM version : V 07.23 17-07-09 RM-436 (c) Nokia MB
Product code:
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:11:34
Phone found!
read info... - Ok
Old 06-01-2011, 16:18   #12371 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
port COM1 open OK
Backup Certificates now...
Setting FlashMode
FlashMode set Ok
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID : 000000010000022600010006400C192101031103
CMT EM0 ID : 00000296
CMT EM1 ID : 00000B22
CMT PUB ID : 0AF0000889AD005295643F40C6FC233BDA239859
CMT MODE ID : 00
CMT R_HASH : CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT ROM ID : 4B9B75103E691FF8
CMT : Sending 2nd loader...
Use : RAPIDOv11_2nd.fg , Rev : 0.0 Ver : 1.37.1
CMT Loader sent, Boot Ok
MCU Configuration
MCU Cfg Ok , 03
FLASHID : 003000EC , CMT , NAND
CMT Flash ID : 003000EC < SAMSUNG [SEC] => K5W1G13ACB
FLCNT : 00030000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAPIDOv11_algo.fg , Rev : 0.0 Ver : 1.40.0
CMT Algo sent
CMT PAPUB : 0FE1BA92D924A658E4800780FA6F4868100AC9475A
Transmission mode : Dual (Ddr, TX2)
Boot Done!
CMT : Read NPC certificate...
Cert size : 2048 byte(s)
IMEI : 355938040205447
CMT : Read CCC certificate...
Cert size : 1024 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 0 byte(s)
Cert Read done!
SL2 Simlock read ... ok
CRT308 Backup Created
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
SimLock Data saved...
SimLock Key saved...
RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.22\Backup\Cert\355938040205447.rpl
Phone found!
Series 60 Device detected!
read info... - Ok
Read Uniq key data started...
Phone Imei: 355938040205447
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
rap= 0AF0000889AD005295643F40C6FC233BDA239859
hash= CAEEBB65D3C48E6DC73B49DC5063A2EE
key= 1EF411719F1A592236E441440DE4FBAD34FEF5EF
Key file updated...
Done!
Phone disconected!
Phone found!
read info... - Ok
MCU : rm243_06.51_prd_core.fpsx
PPM : rm243_06.51_prd_vB21_01_mea_b.fpsx
CNT : rm243_06.51_prd_UDA_Classic_Red.fpsx
Check files done...
-> SWversion check skipped : Manual mode selected
Backup CRT308 data...
RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.22\Backup\Cert\355938040205447_SIM.rp l
Check communication with phone....
ADL req restart
Communication verify done... Preparing...
Gathering phone info...
Batery valtage : 3788 mV
-> Batery voltage less, than 3,8V (3788mV). Continue at user risk
DownGr: Prepare phone for downgrade...
DownGr: Prepare Started.... Psec : 160
-> Prepare status : Ok
DownGr: Phone ready!
Reboot....
Waiting for communication response...
ASIC ID: 000000010000022600010006400C192101031103
CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0AF0000889AD005295643F40C6FC233BDA239859
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Processing UPDAPP ...
Processing PASUBTOC ...
Boot Done!
TIME : Boot time : 00:00:31
Get req info : empty
Erase : Processing rm243_06.51_prd_core.fpsx
Found 3 areas to erase
Erasing area 0x00040000 - 0x00082FFF, NAND, CMT
Result: 0000
Erasing area 0x00083400 - 0x0087FFFF, NAND, CMT
Result: 0000
Erasing area 0x00B80000 - 0x04DFFFFF, NAND, CMT
Result: 0000
Partition erase not allowed by loader
Partitioning : Ok [5]
TIME : Erase time : 00:00:00
Write : Processing rm243_06.51_prd_core.fpsx
Total 385 [385/0/0] blocks to write, writing...
CMT : Writing Hash CERT [ADA]
CMT : Writing Hash CERT [RAP3NAND]
CMT : Writing Hash CERT [SOS*UPDAPP]
CMT : Writing Hash CERT [SOS*DSP0]
CMT : Writing Hash CERT [SOS*ISASW]
CMT : Writing Hash CERT [SOS*CORE]
CMT : Writing Hash CERT [SOS+ROFS]
TIME : Write time : 00:01:07
MCU Write done
Erase : Processing rm243_06.51_prd_vB21_01_mea_b.fpsx
Erasing area 0x03300000 - 0x04DFFFFF, NAND, CMT
Result: 0000
Write : Processing rm243_06.51_prd_vB21_01_mea_b.fpsx
Total 158 [158/0/0] blocks to write, writing...
CMT : Writing Hash CERT [SOS+ROFX]
TIME : Write time : 00:00:29
PPM Write done
Erase : Processing rm243_06.51_prd_UDA_Classic_Red.fpsx
Erasing area 0x04E00000 - 0x07B3FFFF, NAND, CMT
Result: 0000
Write : Processing rm243_06.51_prd_UDA_Classic_Red.fpsx
Total 1 [1/0/0] blocks to write, writing...
TIME : Write time : 00:00:00
CNT Write done
ADL : End flashing
ADL : Finalize...
Flashing done!
Total flash time : 00:01:37
Reboot phone now...
Connected phone - Nokia 6120
Software Info: V 06.51 04-02-09 RM-243 (c) Nokia
IMEI: 355938040205447
Ape Version: 06.51
Product code: 0550022
Checking...
SimLock status : Can't get status
Read Info Done!
SwUpgradeSet...OK!
Done!
Elapsed: 00:02:27
Phone found!
read info... - Ok
Repair SD procedure started...
Key file exists, no need to read...
Operating mode is OK, no need change...
Writing Super Dongle Key... Ok!
Done!
Local SX4 procedure started...
Step 1...
Step 2...
Step 3...
SX4 Auth - Ok
Done!
Uploading RF/Battery tune to phone...
Using : RM-243.pm
Field 1
Record 0 write - Ok
Record 1 write - Ok
Record 2 write - Ok
Record 4 write - Ok
Record 5 write - Ok
Record 6 write - Ok
Record 8 write - Ok
Record 13 write - Ok
Record 15 write - Ok
Record 16 write - Ok
Record 18 write - Ok
Record 20 write - Ok
Record 22 write - Ok
Record 23 write - Ok
Record 24 write - Ok
Record 25 write - Ok
Record 26 write - Ok
Record 27 write - Ok
Record 28 write - Ok
Record 29 write - Ok
Record 31 write - Ok
Record 33 write - Ok
Record 34 write - Ok
Record 40 write - Ok
Record 41 write - Ok
Record 42 write - Ok
Record 43 write - Ok
Record 44 write - Ok
Record 46 write - Ok
Field 309
Record 0 write - Ok
Record 1 write - Ok
Record 2 write - Ok
Record 4 write - Ok
Record 5 write - Ok
Record 7 write - Ok
Record 8 write - Ok
Record 17 write - Ok
Check ST_SECURITY now...
Security status : ST_SECURITY => OK
Done!
Elapsed: 00:00:01
Checking StartUp data ...
SDD Key status : SD Data is Ok
SimLock status : Can't get status (Looks like OK)
PA_SimLock Version :
PA_SL2 phone detected
Done!
Phone disconected!
Phone found!
read info... - Ok
Repair SL procedure started...
Check phone mode...
Phone in RfInactive mode
Test mode set
Writing SimLock Data... Ok!
Writing SimLock Key... Ok!
Done!
Unlock procedure started...
Checking locks...
Blocks : 7
LOCK STATUS :
BLK : 1
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
PA_SL2 phone detected...
Using F-bus count...
Sending code 802040042922135 Level : 7 to SimLock Server...
Simlock Server Answer: Phone already unlocked!
Unlock Done!
Old 06-01-2011, 16:19   #12372 (permalink)
Member: 572216
Sonork: 100.1612300
Thanks Meter: 3,737
Phone found!
read info... - Ok
CNT : rm443__09.10.image_mb_ae_matt_black
Check files done...
-> SWversion check skipped : Custom mode selected
SL3 Simlock read ... ok
WMDRM read ... ok
WMDRM_PD Data saved...
RPL saved : D:\SAEEDULLAH KHAN\Infinity\BB5 Easy Service Tool\BEST_v1.22\Backup\Cert\358256037033996_SIM.rp l
RAP_BOOT: 0803000302010000
RAP_PUBLIC: 1350020C868F6350651B95951AA34436A7876C74
CMT_ROOTKEY: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP_PAPUBKEY: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2
Checking CNT sector PN<>FL
PN CNT sector : 128 kb
ConvertImage: Processing rm443__09.10.image_mb_ae_matt_black
ConvertImage: Page Size is 128K, no need convert
Loader len: 427648, CHK: D62E
ADL -> Sending loader...
Update Server code succesfully sent to phone!
TIME : Boot time : 00:00:10
Waiting for response: 29
Waiting for response: 28
Waiting for response: 27
Waiting for response: 26
Erase : Processing rm443__09.10.image_mb_ae_matt_black
Erasing area 0x02620000 - 0x029BFFFF, NOR, CMT
Result: 0000
Erasing area 0x029C0000 - 0x03FBFFFF, NOR, CMT
Result: 0000
TIME : Erase time : 00:04:28
Write : Processing rm443__09.10.image_mb_ae_matt_black
Total 880 [880/0/0] blocks to write, writing...
TIME : Write time : 00:00:51
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:05:20
Reboot phone now...
Connected phone - Nokia 6303 classic
Software Info: V 09.10 25-08-09 RM-443 (c) Nokia
IMEI: 358256037033996
PPM version : V 09.10 25-08-09 RM-443 (c) Nokia MB
Product code: 0568726
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 34 certs
Data exist, skip certificate repair...
Done!
Elapsed: 00:08:21
Phone found!
read info... - Ok
Old 06-01-2011, 16:19   #12373 (permalink)
shabir97's Avatar
Member: 1277468
Sonork: 100.1603661
Thanks Meter: 701
nokia c1-01 flash done
Selected FlashSettings : FullFlash
MCU : rm607__03.35.mcusw
PPM : rm607__03.35.ppm_m_c
CNT : rm607__03.35.image_m_c_0595609
Check files done...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
DBG : F00A1FB300020303010100FF
CPUID : XGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.37_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
File : rm607__03.35.mcusw
Image : rm607__03.35.mcusw_ebl_psi.fls
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00040000
Erasing, wait ...
Erase done, time : 00:00:01
Write , Start : 0x40040000 , Len : 0x00040000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40080000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40080000 , Len : 0x00020000
Flashing , wait ...
Processing Region 4/5
Erase , Start : 0x400A0000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:05
Write , Start : 0x400A0000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 5/5
Erase , Start : 0x40400000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:02:11
Write , Start : 0x40400000 , Len : 0x01780000
Flashing , wait ...
Region flash done, time : 00:00:34
File : rm607__03.35.ppm_m_c
Image : package_m_c.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Erase , Start : 0x41C00000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:17
Write , Start : 0x41C00000 , Len : 0x00319A48
Flashing , wait ...
Region flash done, time : 00:00:03
File : rm607__03.35.image_m_c_0595609
Image : package_m_c_0595609.image.fls
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42200000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:03:50
Write , Start : 0x42200000 , Len : 0x00B40000
Flashing , wait ...
Region flash done, time : 00:00:16
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:07
No write data, skip
Flashing done!
Total flash time : 00:07:32
Reboot phone now...
Connected phone -   C1-01
Software Info:     V 03.35 02-12-10 RM-607 (c) Nokia
IMEI:  356984041383063
PPM version :   V 03.35 02-12-10 RM-607 (c) Nokia             M_C
Product code:  0596699
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 39 certs
Set phone to Normal mode...
Done!
Elapsed: 00:08:39
br;>
shabir97
The Following 2 Users Say Thank You to shabir97 For This Useful Post:
Old 06-01-2011, 16:36   #12374 (permalink)
sameera's Avatar
Member: 189673
Sonork: 100.1592062
Thanks Meter: 351
registered to: wc2sime
Phone found!
read info... - Ok
Connected phone - Nokia N73
Software ver : V 05wk47v60.1 20-03-08 RM-133 (c) Nokia.
IMEI : 358634010662868
Ape Ver : V 4.0812.4.2.1 21-03-2008 RM-133
APE Var : V 4.0812.4.2.1-01 21-03-2008 RM-133
APE ADSP: 256
DSP Ver : scarfe_mc.05wk46v50p2
APE Test:
PPM :
CNT :
Product SN : SDH897854
Product code : 0551906
Base Prd.code: 0547471
Module code : 0202855
Long Prod.SN :
HWID : 6020
Retu : 15
Tahvo : 22
Batery: 3811 mV
Camera:
CMT BT:
APE BT:
APE HW: 1
LCDVer:
RF ic :
IMEI spNet : 3A 85 36 04 01 66 82 06
IMEI svNet : 33 85 36 04 01 66 82 76 F5
Blocks : 7
LOCK STATUS :
BLK : 1
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS : All Open
User Code : 78742
Done!
Format File System...
Check phone mode...
Seting Local mode... wait...
Local mode set
Scanning FS parametres...
Checking Data...
Detected : 2 drive(s)...
Start formating....
Using Series 60 format algorithm...
Formating drive : C now...
Step1 : OK
Step2 : OK
End format...
Formating drive : D now...
Step1 : OK
Step2 : OK
End format...
Done!
Check phone mode...
Phone in Local mode
Test mode set
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Set OK!
Elapsed: 00:00:25
Set phone in Normal mode...
Restarting...
Done!
Old 06-01-2011, 16:37   #12375 (permalink)
sameera's Avatar
Member: 189673
Sonork: 100.1592062
Thanks Meter: 351
PPM : rm217__07.30.ppm_c
CNT : rm217__07.30.image_c_tr_128
Check files done...
RAP_PUB: 2B90011328F07A5688626CCF22B0B9119A7F5745
ADL : Check data
ADL : Data accepted
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
Result: 0000
TIME : Erase time : 00:01:00
TIME : Write time : 00:01:18
MCU Write done
Erase : Processing rm217__07.30.ppm_c
Result: 0000
TIME : Erase time : 00:00:18
Write : Processing rm217__07.30.ppm_c
Total 289 [289/0/0] blocks to write, writing...
TIME : Write time : 00:00:24
PPM Write done
Erase : Processing rm217__07.30.image_c_tr_128
Result: 0000
TIME : Erase time : 00:00:45
Resetting phone...
ConvertImage: Processing rm217__07.30.image_c_tr_128
Loader len: 248320, CHK: 36E3
Reset connection...
ADL : Check data
ADL : Data accepted
Write : Processing rm217__07.30.image_c_tr_128
Total 224 [224/0/0] blocks to write, writing...
TIME : Write time : 00:00:18
CNT Write done
ADL : End flashing
Flashing done!
Total flash time : 00:04:06
Reboot phone now...
SwUpgradeSet...OK!
Total - 0 certs
Writen 21 certs!
Done!
Elapsed: 00:04:53
The Following User Says Thank You to sameera For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.80683 seconds with 10 queries
