12-04-2009, 11:51 | #1426 (permalink) |
Freak Poster Join Date: Apr 2008 Age: 40
Member: 752606 Status: Offline Sonork: 100.1587361 Thanks Meter: 110 | lg b2050 unlock with infinity box module v1.39 Device: LG-B2050 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: enhanced Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 2088C5FFFFFFFF:2088C500000000 flash: 2088C5FFFFFFFF:2088C500000000 flash: ST M30L0R7000B0, M36L0R7040B0 B 16Mb id: 00005272 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 356558006780164 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356558006780164_LG-B2050_20091204-154943.B1E.bin .. version: -j9GB2050 Check flash Done Check space ... current eeprom imei: 356558006780164 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 22 sec Remove/Install battery now ! |
The Following User Says Thank You to adreesas For This Useful Post: |
12-04-2009, 13:21 | #1427 (permalink) |
No Life Poster Join Date: Jul 2004 Location: EL JEM/Tunisia Age: 56
Member: 71213 Status: Offline Thanks Meter: 120 | SFR 232 Unlock 100% Hi....... Unlock succefful by INFINITY.... INFINITY TEAM is SERIUS For All update........ 1000 thinks INFINITY TEAM ------------------ COM4 [VCP0] selected module v2.98 Device: SFR-232 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7503:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.FES-FR-SFR-P103F2V1_0_2B01.BIN ver. sw 2: FES-FR-SFR-P103F2V1.0.2B01, 00000000 code offset: 00000000 ffs offset/size: 00A00000/00600000 ffs/eeprom address assigned: 00A00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: SFR-232_ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.FES-FR-SFR-P103F2V1_0_2B01__ffs... file saved: C:\Program Files\InfinityBox\MModule\SFR-232_ZTENJ25_07A_PMJ_PCB01_GPRS_MT6225_S00.FES-FR-SFR-P103F2V1_0_2B01__ffs_20091204-130808.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................... required data found flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: area 1 (pass 1) ............................................ area 1 patch applied Ok Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 Write: eeprom Write Done ====> Finalization ... Finalization Done Finished, time used: 880 sec Remove/Install battery now ! |
The Following User Says Thank You to dvb_gsm For This Useful Post: |
12-04-2009, 16:48 | #1428 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 642071 Status: Offline Thanks Meter: 54 | Coral 655 phone code Infinity pin-finder Cable: L10c MModule v2.96 COM7 [VCP0] selected module v2.96 Action: read codes unlock method: read codes Model: Coral-655 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:7D03:0002 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: C2016HW_2.7_EU_DIGICEL Version: C2016_EU 44 byte(s) read imei: 35742902024790 connection Ok 157 byte(s) read 166 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1122 Finished, time used: 9 sec Remove/Install battery now ! |
The Following User Says Thank You to Dwight07 For This Useful Post: |
12-05-2009, 07:59 | #1430 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | zte a136 unlock done COM10 [VCP0] selected module v1.68 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091205-115440.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091205-115441.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091205-115448.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091205-115500.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 50 sec Remove/Install battery now ! old models working fine but we need new models unlock please infinty team |
The Following User Says Thank You to nadim electro For This Useful Post: |
12-05-2009, 19:32 | #1431 (permalink) |
Freak Poster Join Date: Mar 2004 Location: China SZ Age: 50
Member: 58924 Status: Offline Sonork: 1583810 Thanks Meter: 57 | OT103 unlock OK see log COM10 [VCP0] selected module v2.98 Device: Alcatel-103X, 103A Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:5318:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:2BEA0000000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is present rom info detection finished TCL-ID detection... TCL-ID detection done rom info protocol ver: 05 ver. sw 1: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN ver. sw 2: MAUI.08A.W08.36.SP1.V28.F1, 00000000 code offset: 00000000 ffs offset/size: 003A0000/00058000 TCL-ID identification version: 175 provider: 103X-2BRGTE1 customization: CM17CA40 customization: XM17CA40 TCL-ID identification done ffs/eeprom address assigned: 003A0000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: enabled product id: JRD_COMMUNICATION_U91X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished security area (sec info, part #2) calculation... identification header detected customization: XM17CA40 customization name adjusted flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #2) security area (sec info, part #2) calculation done security area (sec info, part #1) calculation... max address is too big, should be recalculated: 0827D124->0826AF14 ..................security area (sec info, part #1) detecting size... security area (sec info, part #1) detecting parameters... security area (sec info, part #1) encoding... done flash: 01227E221A2201:2BEA0000000000 flash: 01227E221A2201:2BEA0000000000 Write: security area (sec info, part #1) security area (sec info, part #1) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E221A2201:2BEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E221A2201:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-103X,103A_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_ 08A_W08_36_SP1_V28_F1__system_log__00000000_200912 05-144938.B0X.bin Finished, time used: 115 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following 2 Users Say Thank You to DOCTOR8 For This Useful Post: |
12-06-2009, 13:39 | #1432 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | T156 old security done :) T156 old security unlocked thanks infinty -- waiting for release of new security from a great team here is the screen shot |
The Following User Says Thank You to azeem781986 For This Useful Post: |
12-06-2009, 15:36 | #1433 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | SUNY_ERICSSUN_SUCCESSFULLY_TOUCH_SCREEN_CALIBRITY_ DONE MODEL = V200 CPU TYPE = MT_6226 NEW FLASH_FILE DETECTED by the BOX,,,I'm Sending this file to INFINITY_TEAM to UPLOAD on SUPPORT,, LOGS: ------ COM5 [VCP0] selected module v3.02 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... M108_PCB01_GPRS_MT6226_S01.S600_B_DISC_E_V1_0_1_A_ E__fullflash_20091206-192451.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031254:F229 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: S600.B_DISC_E_V1.0.1.A.E Version: S600_HW 60 byte(s) read imei: 38240901080007 connection Ok 512 byte(s) read 204 byte(s) read reading data #2... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 13 sec Remove/Install battery now ! BR |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
12-06-2009, 19:03 | #1435 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Congratulation infinity team unlock ufone in pk successful unlock on infinity box. logs are => module version: v.1.72 under test exe => operation (3) started: COM5 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081034106180 ==> get_sw_version sw ver: P1.2PU01V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 19 sec Power Off/On phone now ! very very very very thanks infinity team |
The Following 2 Users Say Thank You to drjaved_akhter For This Useful Post: |
12-06-2009, 20:06 | #1436 (permalink) |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 48
Member: 185608 Status: Offline Thanks Meter: 592 | Only Infinity can unlock this NEW of NEW SECU! NEW OF NEW SECURITY HUAWEI SUCCESSFULLY UNLOCKED BY INFINITY. Use Pana01 V1.72 Here is log: => module version: v. => operation (3) started: COM4 ==> get_dll_version dll version: 38.0i ==> set_com_port ==> set_baud_rate ==> set_v24_mode ==> set_baud_rate ==> check_comm_link ==> get_ms_id imei: 353081033154603 ==> get_sw_version sw ver: P1.2BF02V01.01 ==> get_sec_version sec ver: 00.31Et(4242) ==> get_eep_version eep version: 000C ==> get_eep_revision eep revision: 0000 ==> reading... access result: 00 access level: 03 ==> set required mode... ==> reboot... ==> reading... lock result: 00 lock status: 020A ==> unlock... verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 verification result: F0600100561200FF00040105020503050405000000000000 ==> restore original mode... last error: No errors => operation finished ==> close_com_port Finished, time used: 20 sec Power Off/On phone now ! 100000000000000 THANK TO INFINITY TEAM! |
The Following User Says Thank You to Nadjombe For This Useful Post: |
12-07-2009, 06:10 | #1437 (permalink) |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM9 [VCP0] selected module v2.75 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0303:000D Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S4_TOSHIBA_ETFIHAP_V030 Version: A760_V3.0_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-3)... 0 1 2 3 done 209 byte(s) read writing data... verification... verification Ok Finished, time used: 9 sec Remove/Install battery now ! |
The Following User Says Thank You to cel_phon For This Useful Post: |
12-07-2009, 06:11 | #1438 (permalink) |
Member: 950201 Status: Offline Thanks Meter: 1,928 | COM9 [VCP0] selected module v2.75 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0303:000D Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: S4_TOSHIBA_ETFIHAP_V030 Version: A760_V3.0_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 159 warning: wrong packet cs warning: wrong packet cs items cleared: 159 of 159 building list... done items remains: 0 Finished, time used: 24 sec Remove/Install battery now ! |
12-07-2009, 10:56 | #1439 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Pakistan..
Member: 301242 Status: Offline Thanks Meter: 201 | COM3 [VCP0] selected module v1.72 Device: Zong-A136 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: PAK-P108A2V1.0.0B01 CMPAK-P108A2B07-En-PK01 g3dBV2.0 Apr 24 2008 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-static_20091207-144845.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-security_20091207-144845.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_eeprom-complete_20091207-144847.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Zong-A136_lock-area_20091207-144849.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 21 sec Remove/Install battery now ! |
The Following User Says Thank You to fawad85 For This Useful Post: |
12-07-2009, 13:12 | #1440 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: some were in my head Age: 42
Member: 922273 Status: Offline Sonork: 100.1583612 Thanks Meter: 119 | Quote:
