01-09-2010, 11:18 | #1 (permalink) |
Junior Member Join Date: Apr 2006
Member: 258803 Status: Offline Thanks Meter: 8 | successfully unlocked t156 ufone set by infinity.. just sp unlock in service menu COM4 [VCP0] selected module v1.60 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-static_20100109-151207.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-security_20100109-151208.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_eeprom-complete_20100109-151215.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T156_lock-area_20100109-151234.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 66 sec Remove/Install battery now ! now all sims are working...... |
The Following 3 Users Say Thank You to majid ali kar For This Useful Post: |
01-09-2010, 19:45 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
Help G1157 Unlocking New Ufone set | Danish Shafiq | FuriousGold | 32 | 03-07-2010 10:17 |
..::Post Successfully Unlocked T156 new security BY INFINITY BOX::.. | RIZWANJAT | Infinity-Box | 13 | 12-10-2009 15:17 |
how i unlock new ufone set huawie t-156 i need ur help | ar_memon2 | Infinity-Box | 4 | 09-23-2009 08:38 |
SuccessFully Unlock T156 | MOBIL CLINIC | FuriousGold | 1 | 08-13-2009 16:51 |
sansui v929 successfully unlock user lock code by infinity | amit_varietymob | Infinity-Box | 2 | 07-09-2008 12:10 |
