12-06-2008, 10:42 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: TUNISIA-KEBILI Age: 44
Member: 108627 Status: Offline Thanks Meter: 307 | Successfully Unlocked ZTE-125 Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20081206-103826.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20081206-103830.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20081206-103834.B1E.bin reading additional data... done backup critical area Done Check memory... Check memory Done Write... reset... done Write Done Finished, Remove/Install battery now ! Time used: 69 sec |
The Following User Says Thank You to limem2003 For This Useful Post: |
12-06-2008, 15:11 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @limem2003 Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
Always infinity the best of the best Successfully unlocked ZTE 231 | limem2003 | Infinity-Box | 3 | 01-06-2009 18:17 |
Successfully Unlock ZTE 227 With infinity | FayGsmDz | Infinity-Box | 3 | 11-08-2008 08:44 |
unlock zte 125 | freshwhite | Infinity-Box | 2 | 10-02-2008 14:55 |
Successfully Unlock Vodafone 125................ | SOHAIL BASHARAT | Infinity-Box | 8 | 08-23-2008 09:27 |
