12-31-2008, 13:23 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Edmonton AB
Member: 340564 Status: Offline Sonork: 1591034 Thanks Meter: 529 | successfully unlocking J132 module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20081231-172037.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 86 sec Remove/Install battery now ! thanks you infinity |
The Following 2 Users Say Thank You to kasrawiz For This Useful Post: |
12-31-2008, 16:24 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
01-05-2009, 11:34 | #5 (permalink) |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | COM1 [Serial0] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090105-233340.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 75 sec Remove/Install battery now ! |
The Following User Says Thank You to GSM-DOCTOR For This Useful Post: |
01-07-2009, 12:34 | #6 (permalink) |
Freak Poster Join Date: Sep 2007 Age: 37
Member: 585634 Status: Offline Thanks Meter: 45 | COM5 [VCP1] selected module v1.30 Device: Sony-Ericsson-J132 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 2088C0FFFFFFFF:2088C000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb Check hardware done Read data ... reading Sony-Ericsson-J132_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-J132_eeprom_calibration-1_20090107-171408.80E.bin Read data done Check data ... Check data done Write ... ..... flash: 2088C0FFFFFFFF:2088C000000000 Write: simlock Write done Finished, time used: 65 sec Remove/Install battery now ! |
The Following User Says Thank You to vjohn456 For This Useful Post: |
01-07-2009, 22:58 | #7 (permalink) |
Junior Member Join Date: Oct 2007
Member: 606016 Status: Offline Thanks Meter: 0 | v0.915016/UNI CARD SERIAL: 00047122 Loaded 51 flash descriptors llbug: port 4 open error: "Le fichier spécifié est introuvable" FAILED TO SETUP PHONE Elapsed: 0 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... supported phone was not detected FAILED TO SETUP PHONE PROCEDURE WAS STOPPED BY USER Elapsed: 3 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... ROMBoot not answering ! failed FAILED TO SETUP PHONE Elapsed: 25 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... ROMBoot not answering ! failed Can't load ID loader ! Elapsed: 15 secs. Open COM port OK FAILED TO SETUP PHONE PROCEDURE WAS STOPPED BY USER Elapsed: 82 secs. PLEASE ATTACH TURNED OFF PHONE NOW IF PROCESS NOT STARTING,UNPLUG/PLUG CABLE/BATTERY FEW TIMES... bootROM version: 0502 Locosto HS detected, booting... ROMBoot not answering ! failed FAILED TO SETUP PHONE Elapsed: 19 secs. |
J132 successeful unlocked........ | foufou34 | SETool2 | 48 | 12-17-2013 16:36 |
SE j132 Successfully Unlocked | zeerik | Infinity-Box | 23 | 10-13-2010 08:21 |
successfully unlock j132 | MOBIL CLINIC | Smart-Clip | 2 | 04-15-2009 19:41 |
<<< Successfully Unlock SONY J132 vth INFINITY >>> | roopesh_500 | Infinity-Box | 8 | 12-26-2008 14:31 |
Successfully Unlocked Sony-Ericsson-J132 | limem2003 | Infinity-Box | 6 | 12-08-2008 11:45 |
