Successfully worked on J100 with Infinity?Share Us Anyone successfully used infinity for J100? i guess lots of guys having the same problem and need a good help from someone who had successful operation on J100 and having enough info about cable and other settings. |
hi if you used the correct cable pinout you will see the result |
hi u can use cruiser cable . It works perfect, i have tested it myself |
I have tested with cruiser cable also, wit 6 pieces. Works OK. |
Tested 15 units with Vygis/Infinity box cable. |
Hi, all ok unlocked some Phones. Br |
yes u can use cruiser cable . It works perfect, i have tested 5 nos |
i've successfully unlocke J100 with Infinity using Cruiser Cable. but i forgott to save the log. Take Care ENJOY |
Works perfect with cruiser cable, Se-tool box cable. |
You mean no modification is needed? Cause here in tghis forum there's a special pinout for J100 cable. |
is there any pinout for j100 cable for infinity, cause when you see at the site, it only show "same like k750 cable". br, s1emens |
TOP 1....12 9: Gnd 10: phone Rx 11: phone Tx |
please use universal cable k750 it work perfect tested it work 10000% |
I made cable,it works just fine... one tip-when sw says press and hold power button,dont hold it,just press shortly |
now here is the log i unlock successfully another J100 Thnxxx to Infinity. COM10 selected Action: Unlock Device: SE J100 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW ver: R1E004 HW ver: SEMC_NC2 LP ver: CXC1250396_lp_EU2_R1E004 Flex ver: FFN_NC2_01_FILE Check Flash-1 Done Check Flash-2... In progress... file saved: Backup_eeprom-1__2006-11-25_12-43-51.80E.bin Check Flash-2 Done Write... Write Done Finished Remove/Install battery now ! Time used: 18 sec Take Care ENJOY |
