Old 11-23-2006, 18:23   #1 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 210
Successfully worked on J100 with Infinity?Share Us
Anyone successfully used infinity for J100?
i guess lots of guys having the same problem and need a good help from someone who had successful operation on J100 and having enough info about cable and other settings.
Old 11-23-2006, 19:16   #2 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
hi
if you used the correct cable pinout you will see the result
Old 11-23-2006, 19:20   #3 (permalink)
Member: 90092
hi u can use cruiser cable . It works perfect, i have tested it myself
Old 11-23-2006, 21:18   #4 (permalink)
huzsolt's Avatar
Member: 75392
Sonork: 100.81199
Thanks Meter: 135
I have tested with cruiser cable also, wit 6 pieces. Works OK.
Old 11-23-2006, 21:28   #5 (permalink)
Member: 4434
Thanks Meter: 20
Tested 15 units with Vygis/Infinity box cable.
Old 11-23-2006, 22:06   #6 (permalink)
maybe's Avatar
Member: 56215
Thanks Meter: 67
Hi,
all ok unlocked some Phones.
Old 11-24-2006, 07:24   #7 (permalink)
CHAPRAN's Avatar
Member: 31906
Thanks Meter: 101
yes u can use cruiser cable . It works perfect, i have tested 5 nos
Old 11-24-2006, 07:36   #8 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
i've successfully unlocke J100 with Infinity using Cruiser Cable. but i forgott to save the log.
Take Care
ENJOY
Old 11-24-2006, 12:56   #9 (permalink)
tersace's Avatar
Member: 44483
Thanks Meter: 4
Works perfect with cruiser cable, Se-tool box cable.
Old 11-24-2006, 15:17   #10 (permalink)
meisam's Avatar
Member: 115172
Thanks Meter: 210
You mean no modification is needed? Cause here in tghis forum there's a special pinout for J100 cable.
Old 11-24-2006, 18:39   #11 (permalink)
s1emens's Avatar
Member: 40602
Thanks Meter: 116
is there any pinout for j100 cable for infinity, cause when you see at the site, it only show "same like k750 cable".
br,
s1emens
Old 11-24-2006, 18:49   #12 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,401
TOP
1....12
9: Gnd
10: phone Rx
11: phone Tx
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-24-2006, 20:36   #13 (permalink)
wiliam's Avatar
Member: 241831
Thanks Meter: 18
please use universal cable k750 it work perfect tested it work 10000%
Old 11-24-2006, 20:51   #14 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 70
I made cable,it works just fine...
one tip-when sw says press and hold power button,dont hold it,just press shortly
Old 11-25-2006, 11:04   #15 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
now here is the log i unlock successfully another J100
Thnxxx to Infinity.
COM10 selected
Action: Unlock
Device: SE J100
Checking data, wait...
Connect...
Press and HOLD Power button...
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
SW ver: R1E004
HW ver: SEMC_NC2
LP ver: CXC1250396_lp_EU2_R1E004
Flex ver: FFN_NC2_01_FILE
Check Flash-1 Done
Check Flash-2...
In progress...
file saved: Backup_eeprom-1__2006-11-25_12-43-51.80E.bin
Check Flash-2 Done
Write...
Write Done
Finished
Remove/Install battery now !
Time used: 18 sec
Take Care
ENJOY
***Success Unlocking Alcatel V670 With Infinity *** MED9 Infinity-Box 11 11-16-2009 22:12
Successfully unlock Alcatel-S319X with Infinity Masud-GSM Infinity-Box 4 02-08-2009 05:34
Successfully Unlock ZTE 227 With infinity FayGsmDz Infinity-Box 3 11-08-2008 08:44
successful unlock sagem 220x with infinity asco777 Infinity-Box 0 05-02-2008 10:50
((( why i can't connect J100 with infinity ))) Faisal_Computer Infinity-Box 10 04-30-2007 11:04
Page generated in 0.38977 seconds with 9 queries
