03-27-2009, 14:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: .::AZAD KASHMIR::.
Member: 681574 Status: Offline Sonork: 100.1614243 Thanks Meter: 138 | successfuly unlock vodafone 226 thanks infinity team COM8 [VCP0] selected module v1.64 Device: Sagem-my226 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 EBI_IH_290607_1456 EBI_IH 290607_1456 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-static_20090327-171020.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-security_20090327-171021.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_eeprom-complete_20090327-171026.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my226_lock-area_20090327-171052.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 79 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to ikram tabassum1 For This Useful Post: |
03-27-2009, 22:16 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
06-27-2009, 16:00 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
successfuly unlock vodafone 236 | LABOSSEF | FuriousGold | 0 | 12-16-2009 11:01 |
Successfuly unlock vodafone v810 | SOHAIL BASHARAT | FuriousGold | 8 | 12-03-2008 10:10 |
need help for unlock vodafone 226 | hanen | Infinity-Box | 3 | 02-12-2008 15:18 |
can SMTi unlock Vodafone 226 soon? | ktele | SMTi | 1 | 12-21-2007 10:15 |
CID 52/53 Unlock VERY CHEAP ! Motorola by IMEI (fast) Sagem w8 Unlock, Vodafone 226 | allGSMUnlock | Main Sales Section | 0 | 11-02-2007 17:59 |
