12-08-2008, 13:08 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: India (Gujarat) Age: 36
Member: 223135 Status: Offline Sonork: 100.1592685 Thanks Meter: 177 | Succsecfully Format ZTC V66 module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:EB41:67BC high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: RATECH26_06A_PCB01_GPRS_MT6226_S01.S800KLB.26B.TS. BTM_06A_PRD_V040.C14.C_0004.BIN ver. sw 2: PRD_V040.C14.C, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:2BEA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[RATECH26_06A_PCB01_GPRS_MT6226_S01.S800KLB.26B.TS. BTM_06A_PRD_V040.C14.C_0004.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[RATECH26_06A_PCB01_GPRS_MT6226_S01.S800KLB.26B.TS. BTM_06A_PRD_V040.C14.C_0004.BIN]_20081208-173733.B0E.bin flash: 98004900000002:2BEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98004900000002:2BEA0000000000 Finalization Done Finished, time used: 199 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to uttam For This Useful Post: |
12-08-2008, 13:21 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
scan and format ztc c3000 | N_YOUNGBY | VE-KING | 4 | 08-06-2008 07:01 |
Ztc N82-1 Successfully Formatted With Infinity | amit_varietymob | Infinity-Box | 5 | 07-22-2008 08:06 |
ztc k700 no format | omkarvitekar | Infinity-Box | 6 | 07-15-2008 21:19 |
ZTC N82 can't format | bachirDraria | Infinity-Box | 21 | 07-15-2008 20:40 |
not format ztc 168 by spidermam | muhned | SpiderMan | 8 | 12-30-2007 19:38 |
