02-16-2009, 14:27 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006 Age: 38
Member: 283204 Status: Offline Sonork: 100.1577140 Thanks Meter: 1,098 | succsessfully unlock lg kg110 with infinity box COM25 [VCP1] selected module v1.36 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 354701011864118 current otp imei: 354701011864118 file saved: C:\Program Files\InfinityBox\LGA\eeprom_354701011864118_LG-KG110_20090216-185555.B1E.bin ........ version: 404-XXV10g91KG110P40FL Check flash Done Check space ... current eeprom imei: 354701011864118 ................. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 50 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to Harkishan singh For This Useful Post: |
02-18-2009, 20:00 | #3 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
succsessfully unlock motorola w370 with infinity box | Harkishan singh | Infinity-Box | 5 | 08-11-2010 19:44 |
succsessfully unlocked nec n343i with infinity box | Harkishan singh | Infinity-Box | 4 | 10-27-2009 21:55 |
succsessfully unlocked motorola w377 with infinity box | Harkishan singh | Infinity-Box | 5 | 11-11-2008 08:12 |
succsessfully unlocked lg kp202 wiyh infinity box | Harkishan singh | Infinity-Box | 3 | 09-24-2008 09:28 |
succsessfully unlocked lg kp130 in infinity box | Harkishan singh | Infinity-Box | 6 | 08-21-2008 19:36 |
