09-19-2008, 15:52 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | """"""""""suceccfully flashed lg ke770 just in 59 minuts"""""""""""""" Device: LG-KE770 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sta_20080919-164502.B1E.bin reading [eeprom-sta2]... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sta2_20080919-164504.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sec_35030526000000100_20080919-164507.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: D:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-complete_35030526000000100_20080919-164510.B1E.bin backup critical area Done Check memory... Check memory Done Write... Writing: Firmware Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 3591 sec hi infinity team plz close this time 230400 460800 921600 was not working |
The Following User Says Thank You to makkah mobile For This Useful Post: |
09-19-2008, 16:42 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You was unable to work at high speed due to you have used wrong cable. I suggest you to use Infinity-Box Unibox for flashing to be able use high-speed instead of your current cable. |
09-19-2008, 21:02 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You must use unibox (with or without PinFinder, it's not important, PinFinder can be used as an universal cable too). But I talk not about PinFinder or wrong pinout ! I talk about cable (or box) that you have used ! DO NOT use COM port cable ! Use high-speed unibox ! According to your log (COM1 [Serial0] selected) I can see that you have used not unibox but you have used other cable ! Do you understand now your mistake ? |
09-19-2008, 21:18 | #7 (permalink) | |
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | Quote:
and one more Q now can i unlock N95 8GB phone with INFINITY-BOX + UNIBOX + BB5BOX COZ UNIBOX IS POWERFULL ! TOPIC CLOSED ! | |
09-19-2008, 22:16 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Man... I have tried to explain you your mistake with big patience but your unprofessional reply is really not good. If you do not know difference what is COM port cable and what is Infinity-Box high-speed unibox it's a big hole in your knowledges. You must learn more about cables and hardware to avoid this kind of discussion next time. Hope you will read this thread from begin, check your cable and finally you will understand big problems with your current knowledge level. Answer to your Q (probaly it's your IQ without I, so called negative IQ): you need to use standard Infinity-Box package that already has "high-speed unibox" for high-speed operations. For now I hope you did not continut to post in current thread (at least before you will get more knowledges) to avoid more strange actions from your side without any reason. Hope you already understand your mistake and you will never talk this way in current forum again. |
09-19-2008, 22:28 | #9 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
Code: Set Baud... 115200 Set Baud Done Connecting... Maybe its easier to say: USB to COM cable, not port from the main computer. @InfinitySupport: its ok, you're so cool . relax, he have too high self confidence sometimes "ultra mega super duper easy way not working for some body" | |
09-20-2008, 07:55 | #10 (permalink) | |
in last two messages i was kidding seriesly i know very well what is com and what is usb and what is unibox i m using 15 boxes this time for flashing and unlocking infinity-box is very special for me and this is best box in last two years that i have say many time in last posts hope u will close this thread ............................. TC | |
09-20-2008, 08:21 | #11 (permalink) | |
No Life Poster Join Date: May 2006 Location: U wont beleive Age: 43
Member: 275631 Status: Offline Thanks Meter: 408 | Quote:
by a supporter can b great help to other ( accept the thread starter)... BR .:KHALIFA:. | |
09-20-2008, 09:52 | #13 (permalink) |
No Life Poster Join Date: Sep 2005 Location: -=HORIZON=-MobiSoft Rahwali GR Age: 38
Member: 181213 Status: Offline Sonork: 100.1586186 Thanks Meter: 201 | i m new to the software world. i want to ask if RJ45 & Unibox cable same? and how to check the cable (damaged or good working) without mobile and with meter. i m asking because i have tested two cables KG800 (with kg800 & kp100) and c2500 (with KG195) and found the pinout good but not connecting with phone. please help B.R MSAShami |
09-20-2008, 11:27 | #14 (permalink) | |
(1)first tell me ur infinity box COM1 is ok and have u installed drivers and which models u have attattched with infinity-box (2)how many phones u have try to attatch with kg800 cable 1.........18 12: phone Rx (RJ45 pin-2) 13: phone Tx (RJ45 pin-3) 18: Gnd any only one have u succecfully attatched if not then ur cable is not good and check with meter ur connectivity is OK RJ45 pin-2 to pin number 12 of cable jack and RJ45 pin-3 to pin number 13 of cable jack and same as pin number 18 for GND its about kg800 cable | |
09-20-2008, 12:24 | #15 (permalink) | |
1. run Infinity-Box Shell 2. go to "Documentation" page 3. you will see Unibox/RJ45 output pinout. Many boxes has the same pinout like Infinity-Box and RJ45 cables from many boxes can be used with Infinity-Box, but some other boxes has other pinout and you must check that your RJ45 cables is compatible with Infinity-Box pinout (pins 2, 3, 7 or 8 is used). | |
>>> Successfully flash Lg Ke770 <<< | Faisal_Computer | Infinity-Box | 20 | 08-17-2014 13:26 |
LG KE770 droped in water | Slavixs | LG Hardware Repair | 3 | 01-15-2010 14:03 |
Sucessfully Flashed LG KE770 | unlock trigger | Infinity-Box | 2 | 10-21-2008 09:13 |
Flash LG KP115a corrupt in support | elcapitel | PolarBox 3 | 1 | 10-08-2008 00:51 |
Need file for flash lg ke770 | amir2202 | HWK | 4 | 04-10-2008 15:43 |
