Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2005 Location: Bulgaria Age: 33
Member: 182669 Status: Offline Thanks Meter: 87 | Sucess unlock Vodafone 225 ,vodafone 227,vodafone 228 COM10 [VCP0] selected module v1.60 Device: Vodafone-225 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:22A0 Connecting Done Check hardware ... sw version: VDF-P108A2B06-Bg-BG02 g3dBV2.0 May 31 2007 15 33 04 04.12.00 18. Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\InfinityBox\Pana01\Vodafone-225_eeprom-static_20090104-115858.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\InfinityBox\Pana01\Vodafone-225_eeprom-security_20090104-115859.B1E.bin reading eeprom-complete... file saved: D:\InfinityBox\Pana01\Vodafone-225_eeprom-complete_20090104-115900.B1E.bin reading additional data... file saved: D:\InfinityBox\Pana01\Vodafone-225_lock-area_20090104-115903.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 22 sec Remove/Install battery now ! COM10 [VCP0] selected module v1.60 Device: Vodafone-227 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: VDF-P108B1B03-FrRoBgElHu-BG05 g3xAV3.0 May 27 2008 15 40 46 04.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\InfinityBox\Pana01\Vodafone-227_eeprom-static_20090104-120045.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\InfinityBox\Pana01\Vodafone-227_eeprom-security_20090104-120045.B1E.bin reading eeprom-complete... file saved: D:\InfinityBox\Pana01\Vodafone-227_eeprom-complete_20090104-120047.B1E.bin reading additional data... file saved: D:\InfinityBox\Pana01\Vodafone-227_lock-area_20090104-120049.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 20 sec Remove/Install battery now ! COM10 [VCP0] selected module v1.60 Device: Vodafone-228 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: VDF-P108C1B03-FrRoBgElHu-BG05 g3yBV2.0 04.12.00 18.26.11 08.02.0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\InfinityBox\Pana01\Vodafone-228_eeprom-static_20090104-120136.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\InfinityBox\Pana01\Vodafone-228_eeprom-security_20090104-120137.B1E.bin reading eeprom-complete... file saved: D:\InfinityBox\Pana01\Vodafone-228_eeprom-complete_20090104-120138.B1E.bin reading additional data... file saved: D:\InfinityBox\Pana01\Vodafone-228_lock-area_20090104-120141.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 21 sec Remove/Install battery now ! in 63sec 3 phones Done ;]]]] |
The Following User Says Thank You to lopotok For This Useful Post: |
![]() | #2 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks Meter: 34,298 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
![]() | #3 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2006
Member: 299902 Status: Offline Thanks Meter: 20 | for sure with infinity you have it unlocked COM4 [VCP1] selected module v1.60 Device: Vodafone-227 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00EC:257E Connecting Done Check hardware ... sw version: VDF-P108B1B03-FrRoBgElHu-BG05 g3xAV3.0 May 27 2008 15 40 46 04.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-227_eeprom-static_20090215-134929.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-227_eeprom-security_20090215-134930.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-227_eeprom-complete_20090215-134937.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-227_lock-area_20090215-134950.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 50 sec Remove/Install battery now ! |
The Following User Says Thank You to cell2cell For This Useful Post: |
![]() | #4 (permalink) |
Member: 182669 Status: Offline Thanks Meter: 87 | And another One voda 226 COM10 [VCP3] selected module v1.62 Device: Vodafone-226 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 5 Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 046 EBI_IS_090108_1046 EBI_IS Thhmm Dddmmmyyyy 0123456789ABCDEF Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: D:\InfinityBox\Pana01\Vodafone-226_eeprom-static_20090216-101543.B1E.bin loading data... data loaded reading eeprom-security... file saved: D:\InfinityBox\Pana01\Vodafone-226_eeprom-security_20090216-101544.B1E.bin reading eeprom-complete... file saved: D:\InfinityBox\Pana01\Vodafone-226_eeprom-complete_20090216-101545.B1E.bin reading additional data... file saved: D:\InfinityBox\Pana01\Vodafone-226_lock-area_20090216-101550.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 30 sec Remove/Install battery now ! |
![]() | #5 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2006
Member: 231052 Status: Offline Thanks Meter: 17 | can some people help me, i have vodafone 227, unlocked to vodafone, try tu unlock with infinity COM6 [VCP0] selected Device: ZTE-227, Vodafone-227 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00EC:257E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sta_20090223-143414.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sec_20090223-143417.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-complete_20090223-143425.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 44 sec but with sim card , it SIM LOCKED!! PLS help! |
![]() | #6 (permalink) |
Member: 231052 Status: Offline Thanks Meter: 17 | can some people help me, i have vodafone 227, unlocked to vodafone, try tu unlock with infinity COM6 [VCP0] selected Device: ZTE-227, Vodafone-227 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 00EC:257E Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sta_20090223-143414.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-sec_20090223-143417.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-227, Vodafone-227_eeprom-complete_20090223-143425.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 44 sec but with sim card , it SIM LOCKED!! PLS help! sorry, pls delete my last post! sorry for dubling |
![]() | #14 (permalink) |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2009
Member: 1043909 Status: Offline Thanks Meter: 51,760 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box - News - 29-02-2012 - Doro-PhoneEasy-610, UCall-M108 models supported 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell. It's just an example for Alcatel, if you have another model you must select your model ! ![]() RJ45 connector pinout: ![]() Here is an information how to build your own cable: FAQ: Frequently Asked Questions, cables/pinouts |
Unlock & Flash Vodafone my150x, my220x, my220v, 125, 225, 226, 227, 228 | gsm junction | Infineon C16X M51 & ARM7 M52 BASED | 31 | 01-24-2012 06:32 |
12/03/2008 Huawei T201, Vodafone 227, Vodafone 228 Unlock/Flashing !!! | .:hack3r2k:. | FuriousGold | 74 | 01-16-2009 00:39 |
blocked vodafone 227 and 228! | .:bono:. | FuriousGold | 0 | 08-07-2008 04:08 |
20 May 2008: ZTE-227, Vodafone-227, Philips-192, J-Max-JM5700, G-Tide-W110, user code | InfinitySupport | Infinity-Box | 27 | 05-23-2008 23:02 |
unlock problem vodafone 227 & 228 | fastgsm | FuriousGold | 4 | 04-05-2008 09:42 |
