10-20-2008, 22:34 | #1 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 818352 Status: Offline Thanks Meter: 266 | Sucessfully Flashed LG KE770 Device: LG KE770 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20081021-144627.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta2_20081021-144634.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35030526000000100_20081021-144637.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35030526000000100_20081021-144642.B1E.bin reading [eeprom-dyn_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-dyn_35030526000000100_20081021-144758.B1E.bin backup critical area Done Check memory... Check memory Done Write... reset... done Writing: Firmware Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 11439 sec Note - Take More than 2hrs to flash so Full Charge ur Battery Before operation Regards,Trigger |
The Following User Says Thank You to unlock trigger For This Useful Post: |
10-21-2008, 08:43 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
>>> Successfully flash Lg Ke770 <<< | Faisal_Computer | Infinity-Box | 20 | 08-17-2014 13:26 |
Sucessfully Flashed LG KE970 IN 2HRS 30 MIN | unlock trigger | Infinity-Box | 5 | 10-22-2008 13:55 |
""""""""""suceccfully flashed lg ke770 just in 59 minuts"""""""""""""" | makkah mobile | Infinity-Box | 15 | 09-20-2008 17:56 |
Need file for flash lg ke770 | amir2202 | HWK | 4 | 04-10-2008 15:43 |
LG KE770 flashing with HWK | rudeaex | HWK | 1 | 03-26-2008 11:35 |
