10-22-2008, 08:52 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: MX-KEY is the BEST NOKIA TOOL
Member: 46042 Status: Offline Sonork: 100.1575650 Thanks Meter: 93 | need help with phone code COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "user code" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:5D03:0005 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.S210BGR.25.S M.BTM_GEMINI_HSD_V001.C18.GB_0001.BIN ver. sw2: HSD_V001.C18.GB, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ...................... detect standard fat location pass #1... ............................................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.S210BGR.25.S M.BTM_GEMINI_HSD_V001.C18.GB_0001.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[RATECH25_GEMINI_PCB01_GPRS_MT6225_S00.S210BGR.25.S M.BTM_GEMINI_HSD_V001.C18.GB_0001.BIN]_20081022-094343.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... Special operation Done Write... flash: EC257E25082501:18E59F00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 351 sec Remove/Install battery now ! |
10-22-2008, 11:24 | #5 (permalink) |
No Life Poster Join Date: Jan 2007 Location: PANGANDARAN BEACH Age: 44
Member: 427685 Status: Offline Thanks Meter: 103 | COM10 selected module v2.64 Action: read codes unlock method: read codes Model: Autodetect 6228, 6229, 6230 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot disabled chip: 0031:0000:9801 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6228,E02 Date: 2004.07.02 Version: 1.0 Version: 073245_411_V1350 Version: TIANYU28_06A_HW detecting structure #2... 0 done 42 byte(s) read imei: 35355401530841 connection Ok detecting structure #1... 0 done 148 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 110582 Finished, time used: 31 sec Remove/Install battery now !,Action: read codes,unlock method: read codes,please try bro Last edited by PRIMACELL; 10-22-2008 at 11:29. |
The Following User Says Thank You to PRIMACELL For This Useful Post: |
Need help remove phone code from htc touch [ANSWERED & SOLVED] | keeran | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 7 | 01-29-2010 02:37 |
i need help with radio code plz help | roadrunner007 | CAR Electronics | 1 | 04-09-2009 10:07 |
k300 help with phone code | alison0101 | Sony Ericsson | 1 | 08-15-2005 20:22 |
Need help with VB code for keymaker in Armadillo | Surej | GSM Programming & Reverse Engineering | 4 | 02-25-2003 06:01 |
help with phone code for T190 | cris | Motorola ODM | 1 | 11-26-2002 11:08 |
