Sucessfully Solve T280i Hang problem! Hi i am solve my hang problem SE T280i! please take a look my log----- COM3 [VCP0] selected module v1.29 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: flash write "smart write" active Skip: Firmware Skip: Flex Skip: Language Pack Write: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 203125 Set baud done Check hardware... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20081214-162902.80E.bin Read data done Check data... Check data done Writing... Area: FFS/File system flash: 89890400040089:89890400000000 Write: FFS/File system Writing done Finished, time used: 884 sec Remove/Install battery now ! umadineshdas |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
thanxxxxxxxxxxxxxxxxxxxx very much |
I AM SOLVE MY PROBLEM WITH THAT FILE--- T280i_repair_ffs_03.80E. PLEASE TRY THIS FILE WHEN YOU GET THE SAME PROBLEMS? AND INFINITY IS THE BEST FOR THIS TIME TO REPAIR SE-T280i. umadineshdas |
OM10 [VCP0] selected module v1.30 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: flash write "smart write" active Skip: Firmware Skip: Flex Skip: Language Pack Write: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot fail error: operation failed Finished, time used: 11 sec Remove/Install battery now ! what is the problem i have tryed with hold power button |
problem solved by restarting pc thanx infinity |
Thanks for test report ! It will be useful for many users for sure. |
t280i hang at "sonyEricsson" problem solved by eeprom repair file ...;) COM8 [VCP0] selected module v1.37 Device: Sony-Ericsson-T280i "advanced chip detection" active Action: flash write "smart write" active skip: Firmware skip: Flex/Customization skip: Language Pack skip: FFS/File system skip: Images skip: Melody write: Eeprom T280i_repair_ffs_03.80E.bin Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection ... Check connection done Set baud ... 812500 Set baud done Check hardware ... flash: 89890400040089:89890400000000 flash: Intel ST [def 0080x040000] 32Mb Check hardware done Read data ... reading Sony-Ericsson-T280i_eeprom_calibration-1... file saved: E:\InfinityBox\HModule\Sony-Ericsson-T280i_eeprom_calibration-1_20091216-074211.80E.bin Read data done Check data ... Check data done Write ... Area: Eeprom flash: 89890400040089:89890400000000 Write: Eeprom Write done Finished, time used: 335 sec Remove/Install battery now ! |
Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work Br Faisal_Computer |
plz share t280i flash file and eprom file thanx |
You can download it from Infinity-Box support area |
Thank you very much for test report ! |
