Old 10-18-2008, 08:05   #1 (permalink)
Ian
Member: 52
Thanks Meter: 13
Unlock Toplux CG260
Dear All,
I have one which has the lock code and I try to use infinity pin finder, it detect the pin by indenpendent CPU and when I try to use other chinese to unlock it ca't be detected.
Please help and give more advice,
Thank you very much.
Best Regards
Ian
Old 10-18-2008, 22:12   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What is CPU chip name and what is pinout ?
Old 10-21-2008, 07:10   #3 (permalink)
Ian
Member: 52
Thanks Meter: 13
Dear Sir,
The CPU name is Skyworks and come with serial number: CX80503-25 E399149-1 ARM and the the pin out is RX=11 TX=12.
After I find the pin out, I don't know which program need to select, so I simply select Chinese miracale and select unknown cPU and wait it mention , press power on, once I press power on, phone started and can't be detect to unlock.
Please advice me accordingly.
Best Regards
Ian
Old 10-21-2008, 08:47   #4 (permalink)
Member: 130995
Hello,
try to read flash from this phone like Newgen-C620.
Let\'s see results.
What is this connector type ? How many pins ?
Old 10-21-2008, 09:57   #5 (permalink)
Ian
Member: 52
Thanks Meter: 13
Dear Sir,
I still got no luck to read flash. The phone will power on once I press the power button and it can't be detected.
The pin out conector is L24A cable.
Is there any other model that I can try??
Please help....
Thank you very much..
Old 10-21-2008, 15:48   #6 (permalink)
Member: 130995
Hello,
You can try to read phone with other models from the same software module.
All these models is for similar CPU chip type.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-22-2008, 05:42   #7 (permalink)
Ian
Member: 52
Thanks Meter: 13
Originally Posted by InfinitySupport View Post
Hello,
Dear Sir,
You are right, It successful detected by Hyundai model.
Best Regards
Ian
Old 10-22-2008, 06:34   #8 (permalink)
Ian
Member: 52
Thanks Meter: 13
Dear Sir,
After successfull read flash, When I press user code, it mention phone must be in testmode, I try power on or power of also cannot, it stated phone not found. I try to reset setting still got phone locked and don't know the dfault code.
Please advice me please...
Thank you very much
Old 10-22-2008, 15:11   #9 (permalink)
Member: 130995
C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ NewGen_Fly_test-mode.txt
What model exactly you have selected for flash reading ?
Pls sent flash file backup and operation log to [email protected]
Old 10-23-2008, 02:54   #10 (permalink)
Ian
Member: 52
Thanks Meter: 13
Dear Sir,
I am using Hyundai H350 model and from the document it stated press power on and if I press power on for more than 2 secound, the phone power up and if press one secound, it still stated no phone connected.
Please advice me please... for the flash file already send
Best Regards
Ian
Old 10-23-2008, 13:29   #11 (permalink)
Member: 130995
Hello,
For test mode operations you need to change cable.
Did you made required cable modifications according to manual ?
Please Help, just need few flashing/unlocking answers - P520 lomna Samsung Flashers, Software, Firmware. 3 02-03-2009 23:42
toplux! AG280, Have keypad password! minhtrimobile Various 2 12-17-2008 14:47
unlocking LG-cg225 cellrepairus NSPRO 0 04-30-2008 22:37
Rare Toplux Cg260 For Sale Devils Advecut Sell ur Old and Used Stuff 7 03-06-2004 13:42
Toplux CG260, new, barred in Sweden, unlocked. Firecell Sell ur Old and Used Stuff 7 12-16-2003 01:07
Page generated in 0.18765 seconds with 10 queries
