10-03-2017, 12:48 | #139 (permalink) |
Freak Poster Join Date: Sep 2009 Location: ghana
Member: 1115532 Status: Offline Sonork: none Thanks Meter: 6 | if i click on support & download area it open this - Click to menu "Support & Downloads" and once again to "Support & Downloads" - Click to link with Support Area that you want to access NOTE: Different Support Area links will be available depends on your active Services Infinity-Box Shell is not required any more for Support Area login ! How to access Support Area: 1. Login to your IOS Account |
10-03-2017, 12:54 | #140 (permalink) | |
result ? | |
10-24-2017, 11:36 | #143 (permalink) |
Junior Member Join Date: Feb 2017 Location: aveiro portugal
Member: 2684593 Status: Offline Thanks Meter: 0 | Infinity best code Hi need help nokia 225 Unlock procedure started... Using F-bus count... Sending code 051050060249442 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! tried code manually code error Thanks! |
12-20-2017, 07:16 | #150 (permalink) |
Insane Poster Join Date: Sep 2012 Location: india Age: 36
Member: 1807959 Status: Offline Thanks Meter: 17 | Card found : 8CAD13A1 , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Identify [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 425 [MSM8917] ID_BLOCK_S : E81BC01B ID_BLOCK_I : 000560E1 ID_BLOCK_L : 04D3F81B8609C68410D890629EBD3142 ID_BLOCK_L : F4B933C63EC4F3543D8A4E1FA85C512B Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
