-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Support Area access procedure improved (http://forum.gsmhosting.com/vbb/f296/support-area-access-procedure-improved-2196220/)
YellowBoss 02-21-2017 23:30
- Login to Infinity Online Service (IOS)
- Click to menu "Support & Downloads" and once again to "Support & Downloads"
- Click to link with Support Area that you want to access
NOTE: Different Support Area links will be available depends on your active Services
Infinity-Box Shell is not required any more for Support Area login !
How to access Support Area:
1. Login to your IOS Account
http://www.infinity-box.com/support/...reaViaIOS1.jpg
2. Click to "Support & Downloads" and select Support Area that you want to access
http://www.infinity-box.com/support/...reaViaIOS2.jpg
Nasir Mobiles 02-22-2017 05:25
will not required or will not work anymore ?
shell is easy way to enter in support area so please do not terminate if you are going to do so.
hard to remember multiple logins. :mad:
YellowBoss 02-22-2017 07:44
Shell works for now.
Actually new method is more easy, because you need to know only one password - password for IOS.
With this password you can login to IOS and after that - you can access Suport Area with one click even without dongle.
InfinityHelp 02-22-2017 08:12
Instruction moved to first post
princesaddam 02-22-2017 09:23
After login iam Getting account is not active iam having Support
Activation 1: Infinity-Box/Dongle; ; Firmware Version: 0135; Registered: 2015-06-05; Expired: 2018-10-21; Support: Active
Still this error
https://s23.postimg.org/gkjv9g03v/2017_02_22_13_49.jpg
Nasir Mobiles 02-22-2017 09:36
its working... :)
http://oi67.tinypic.com/vfh0f7.jpg
Shubhanshu~ 02-22-2017 10:25
It will be better if there is one button in software to click to go to support area.
YellowBoss 02-22-2017 14:16
Still this error
Please close browser, login to support again and try to login to Server #1
What is the result ?
princesaddam 02-22-2017 14:19
same error i try to do it with Shell also but same
YellowBoss 02-22-2017 14:19
Originally Posted by Nasir Mobiles (Post 12356504)
Can you login to BEST support area well from IOS ?
YellowBoss 02-22-2017 14:20
Do you mean you have the same problem with Shell also ?
princesaddam 02-22-2017 14:22
Yes sir same prblm with shell also
Nasir Mobiles 02-22-2017 14:32
yes both links for support working fine.
Faheem Anjum 02-22-2017 14:35
Will be more good if have Support Access button in Every infinity modules
so it will more friendly and easy !
YellowBoss 02-22-2017 14:43
Probably this idea is good for the first look but we do not want to make more and more the same buttons in all exe. Just imagine what should we do if we need update support area. Update then many different exe files with new method, with new server address etc. ?
Sorry, but it will be no such button in all exe.
Page generated in 3.35191 seconds with 5 queries
