12-15-2016, 05:54 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: sharjah, united arab emirates Age: 31
Member: 2149733 Status: Offline Thanks Meter: 83 | Support this phone team 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0318A1B4 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 5BF3348E742F0047 ID_BLOCK_L : C060A78CDC7C318B Use CM2 Internal Loader Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Identify [ v1.04 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0318A1B4 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 5BF3348E742F0047 ID_BLOCK_L : C060A78CDC7C318B Use CM2 Internal Loader Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! pls support this phone micromax a092 h/w ver:-LELM003 S/W VER:-MICROMAX A092V13140422 |
